- lost AM reception
- hissing noise passenger firewall coolant leak
- radio change
- Audi A8L 2009
- Coolant leak, I can see it...
- instrument table
- 2003 Audi A4 1.8t Quattro
- Trunk not unlocking with remote?
- 03 a4 1.8t quattro - head gasket?
- A4 B6 cab..
- 2004 Audi a4 3.0 mysterious misfire
- Audi A4 2005 1.8L T Loses power to wheel momentarily
- Low groan after maintenance
- Right Brake and Reverse Light
- Cooling fans
- Front grille rings size ?
- Slack Timing belt - Do I need a new head?
- wobble
- Audi A6tdi quattro fuel gauge not working
- 2002 S4 1.8t looking for help.
- How to remove A4 B6 cab front plastic part of roof?
- 2007 A4 interior lights won't work
- 2002 Audi A4 rough idle at start up
- Need professional advice/tips for my new B6 1.8TQ project!
- Location of oil sensor fuse?
- HELP! Steps for AC flush/oil level
- 2004 A4 quattro 1.8t 6 speed(sedan) Clutch wont engage! SOS
- 2003 A4 Quattro AC Problem
- 2004 Audi A4 Exhaust
- 2007 Audi A4 2.0L Turbo Ticking Noise ... normal?
- AUDI A3 CABRIOLET 2009
- B6 avant stage 2
- Led low beam bulbs?? 02 avant
- audi a4 computer and cable corrosion
- Help! Turbo & misfire codes!
- Good gas?
- Wont Run
- whirring noise when driving 1.8t quattro B6 cab
- Cabriolet roof latch rattle help?
- Xenon or Halogen headlights?
- AC compressor install
- CELL light came on today going home
- Electric Windows in a 2003 A4 Cabriolet
- Fuel vapor line replacement - Need insight!
- Please help! Strong hissing in undercarriage
- '06 A4 CCM Replacement
- B6 A4 Cooling System Leak....HELP!!🙏
- after adaptation and activation DIS showing wrong values
- Audi A4 1.8T Catalyst Help.
- New Audi Owner. 02 A4 1.8t issues.
- Audi A4 Transmission Trouble, Please HELP!
- rear break lights on all the time
- Rallycross A4 Build
- Air bag light
- Water ingress in ECU area Audi A4 renders it completely dead!
- Please Help! Has Spark, Has Fuel, No codes, No start!
- 2006 Audi A4
- 5 speed tranny problems IN NEED OF HELP
- 2007 Audi A4 Quattro?
- Diesel sound like when gear engaged
- What/where is the PCV?
- fuel sender left side Audi A4 3.2 quattro
- Overheating
- slack in intake adjuster when pulley is torqued
- Air in Power Steering, what hoses to check?
- A4 B6 1.8T IDLE PROBLEM VAG SCAN
- 2002 Audi A4 sputters at low RPM's
- 2002 Audi A4 stereo wiring problem
- Secondary Air Injection System for 2003 audi TT quattro
- Oil sensor and usage?
- Audi a4 Bex turbo noise sounds like exhaust
- Audi A4 B6 Motor Engine Lubricant
- Quattro 5 spd transmission rear bottom plug missing
- fuel guage fault
- A3 3.2 2004 model
- DIY guides to flushing power steering a4 b6 1.8t?
- A4 1.8T quattro improvements
- ABS and Traction Control lights
- 19" v708's on dropped (b6)?
- New To My(sister): 2003 A4 Avant
- Simple exhaust tip mod using Audi Q7
- Throttle Actuator Error
- Managed to lock myself out of A4 05 reg.
- ABS Sensors
- A4 1.6 spark plugs needs changing every 2 weeks
- A4 b6 back up camera help
- 17833 - EVAP Purge Valve (N80) P1425 - 002 - Short to Ground - MIL ON
- How to know if your heater flaps are closing fully?
- Location of hood sensor
- Audi 1997 Cabriolet
- 2007 audi a4 2.0t ( P0706 code) - PRDS flashing? need help-
- Classissifieds
- Where can I find a labeled picture of the fuse block
- SAI pump
- What option would you choose for stereo?
- 2005 A4 MODS QUESTIONS
- How to open the trunk from inside the car?
- Need help from Audi experts on the car heater coolant please?
- 2005 s4 6spd stick shift
- 1.8 vs 2.0
- Radiator support
- audi a6 2005 wont start
- 2004 A4 1.8T TRANSMISSION WONT COME OUT OF 4TH GEAR, HELP!
- Wiper Arm Question?
- Audi A4 Cab - Hazards on faster than normal, alarm sounds when doors open
- Coolant hoses needed
- How do you check for a bad oil cooler?
- A4 Grove Box Problems
- PARTS NEEDED TO CLONE THE (B6) S4
- Power Steering Issue/P0741 Looking for some help!
- S4 parts on an A4?
- heated mirrors retro fitting?
- ABS ESP Electronics Module Needs Replacing - Advice?
- ABS ESP Module Needs Replacing - Advice?
- 1.8T far too slow.
- Audi a4 b6 Cold start problem
- Control Arm assembly diagram
- A4 2004 1.8T Quattro (B6): Which Alternator?
- fuel gauge issues
- Best rear diffuser for Audi B6 A4?
- Aperture panel
- Oil usage needing to top up.
- A4 SAI pump wiring diagram
- Curious re relay in dash
- Service Manual
- Is it best practice to replace flywheel w clutch?
- Please help.
- A4 USP Vibrations under heavy Acceleration, 3-4k RPM
- A Different Kind of Heater Problem
- Non-plastic coolant flange
- Wiring Harness issues
- Coolant issue brown sludge
- Help with bushing identification.
- Front bumper
- New to Audi need some good advice please.
- 2005 AUDI A4 1.8T Headlight Malfunction
- 02' A4 3.0 V6 Timing Belt
- A few questions, new to A4 B6
- ***Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - January 1st - 7th, 2017***
- Please help! recurring issue.
- B6 1.8t turbo blanket options
- 2004 A4 Avanti 3.0L Cranks but no start
- Wiring diagram for Camshaft Timing Adjustment
- 2003 A4 1.8t Timing belt broke
- Immobilizer issue? Or something else? Pls Help
- ABS Module issue"
- Help! Engine won't turn, car thinks it's standard
- smoking coil pack
- Starts jugging and jumping at about 1600rpm then esp lights comes on
- Back drivers side brake red hot but others aren't,,
- A4 headlights halogen or xenon?
- 2003 AUDI A4-1.8T OVERHEATING NEED TO FIX ASAP PLEASE HELP
- A/C blows hot air
- 2004 A4 Avant 1.8T Wagon - Privacy Cargo Cover - Standard or Optional?
- !AUDI ONLINE PARTS WINTER RAFFLE!
- Audi A4 2004 (B6) Cold Start problem..
- WHAT DO YOU WANT TO SEE FROM A PARTS DEALER?
- HEAD LIGHT PACKAGE QUESTION
- B6 start up issue
- Could my scan tool miss a code that vag-com could find?
- What Sealant for Valve Cover Gasket?
- What does this brittle cable go to?
- Looking for cylinder head
- A/C issue
- 2004 A4 head gasket?
- Who made the OEM B6 A4 rims?
- Dashlights, wipers, signals, fogs not working due to leak
- Reduce Warm up time, Increase smooth idling.
- looking for a mechanic in Bay Area
- WTB: Catalitic Con. For a 2004 1.8T
- Is genuineaudiparts.com still around?
- g71 g31 and several other codes
- EPC Light
- :: GruvenParts.com Custom Billet Accessories for VW/Audi !
- Diesel Sound, Rough Idle In Park Only, Hissing Sound, Clunk
- P0393 - Camshaft Position Sensor 'B' Circuit High Bank 2
- Starts Strong. Dies Fast
- Exhaust puffing smoke when cold starting. Video link attached.
- 02 audi a4 stalled while going 80 mph
- Audi A4- Issue starting/ accelerating/stalling
- Blinker lights up but doesn't blink
- Automatic shift cable adjustment after tcm repair
- 2004 Audi A4 leaking oil
- xenon headlights
- A4 electric problems
- :: ECS Tuning :: Not Too Stiff.. Not Too Soft.. Just Right...
- Chasing gremlins in my 2003 A4 1.8T
- 2004 AUDI A4 1.8T SEDAN CRANKS BUT WONT START.
- A4 3.0 P0011 Camshaft Position - Timing Over Advanced
- Car died while driving. Won't start
- Tire upgrade
- :: ECS Tuning :: Precise. Effortless. Shifts.
- Original Window Sticker ?
- Taillight | Headlight | SideMarkers removal and condensation fix DIY
- SportShifters.com - SportShifter now available for your B6 manual!
- Shift cable adjustment after tcm repair.
- Powerloss Audi 1.8TQ
- :: ECS Tuning :: A Tune Tailored for your Audi!
- Help please
- IMMO pin from dump file???
- !NEW AUDIWORLD EXCLUSIVE PROMO!
- 3.0 V6 A4 Cab - Broke down side of the road
- Having to change front axle again
- What is this?
- intermittent signals,wipers and heater
- 2003 A4 3.0 ECON on no a/c or heat
- Clicking electrical noise from inside, HELP!!!
- 2004 A4 1.8
- Can someone do me a favor? Need measurement on Cam Lockdown tool
- :: ECS Tuning :: A Different Kind of Performance Piece..
- Audi A3 8P Paddle Shift Steering Wheel to A4 B6
- Sofware and interface choices???
- What are the viscosity specs for stock Audi transmission fluid?
- Buying a 2004 Audi A4
- Dash Board LED Display problem A4 2012
- Signal problem - right turn signal turns on left instead
- CCU Repair
- 2002 A4 3.0 cam and misfire error codes
- 2003 a4 3.0 camshaft position codes
- On-board computer problem
- :: ECS Tuning :: Timing Belt Kits + FREE Schwaben LED Pen Light! | B6 A4 1.8T
- Audi a4 v6 1999 leaking coolant fluid through drainage
- Help diagnosing smoke
- Front bumper
- :: ECS Tuning :: The One-Two Punch! ECS GEOMET® Rotors & Exact-Fit SS Brake Lines
- 2003 a4 starting problem 1.8t
- AC Compressor don't get power
- :: ECS Tuning :: Protect Your Pan! | ECS Stree Sheilds - $40 Off!
- 2003 a4 1.8t engine whine
- :: ECS Tuning :: Now Available! | HRE Wheel Collection
- Is this turbo about done?
- Transmission/Drivetrain noises
- A/C Woes: Compressor, Fan, or Other?
- :: ECS Tuning :: Keep Your Cool This Summer | B6 A4 1.8T Thermostat Kits
- P0299 code and loss of power issue
- Tinting
- audi a4 01 door not unlocking
- :: ECS Tuning :: Demand H&R | Sport Spring Kits For Your B6 A4
- P0171 Audi Newb
- BIRTHDAY SALE!
- Just bought my first Audi
- :: ECS Tuning :: NEW!! ECS Turbo Inlet Hose | B6 A4 1.8T
- Audi A4 wierd noice *video*
- :: ECS Tuning :: ECS FSI Coil Pack Conversion Kits | B6 A4 1.8T
- :: ECS Tuning :: NEW!! Stahlbus Oil Drain Valve Set | B6 A4 1.8T
- 03 A4 3.0 quattro v6 no brakes
- :: ECS Tuning :: aFe Power Summer Intake Rebate | B6 A4 1.8T
- Tons of issues
- Another B6 forum?
