- Volume/Dial Knobs
- Looking for a car for my brother
- Audi A4 B6 Driveline Slop when HOT
- all 4 brake pads and rotors
- Symphony II HU bargains
- Question about Audi A4's
- possible feedback on audi 2004 6 speed
- Codes P0421 and P0431
- 1999 Audi A6 2.8 avant
- Where to buy a turbo replacement??
- Wheel look: black wheels on blue S5?
- Opinion on coil packs needed...
- Trunk will not release
- Strange Thing!!!
- First time Audi buyer
- DIY: Easy Cracked Radio Reciever Fix
- fm radio antenna
- stealership
- Heater Hose
- P0011 plus idle and acceleration problem
- 2003 audi a4 hood
- 02 1.8 cyl 2 misfire?
- Major transmission failure - need advice
- Car bucks and jerks when accelerating
- Alternitive Transmissions for 2002 1.8T A4?
- Clicking when almost completely stopped?
- What are these...
- Pressure plate only replacement?
- Installed k04 Kit last year...meh.
- :: ECS Tuning :: Free Shipping On B6 A4/S4 Control Arm Kits!
- Stock AMB 1.8T with 1st gear power loss and surging?
- High flow cat on 3.0
- Quick AC question
- looking for some advice on suspention
- 2004 A4 cabrio quattro 6 cyl : oil transmission stick
- New Bilsteins shorter than OEM?
- 2004 Crystal Blue 1.8t or Silver 3.0
- Please Help! My B6 Has Gone Bad.
- Audio issues
- :: ECS Tuning :: 40% Off 19" STP-3 Wheel Sets!
- Towing
- 2004 A4 Drivers seatbelt return trouble
- key won't open door
- Very strange oil consumption issue - 02 3.0 6M
- :: ECS Tuning :: 3M Di-Noc Vinyl Wrap!!
- planning my first project
- Axle Seal Question
- Horrible radio reception
- Show Pride In Your Ride and WIN $100 !!!
- Switching from 3.0 6M Sedan to 3.0 5A Avant
- Can't turn off hazard lights A4 - Pls Help
- Unexplained RPM Spikes/Power Lag
- Help with axles
- Help Need instruction on removing top dash panel
- Replaced all the coils but my car is still shuddering
- Just can't get my front passenger door to work
- Waterfest 17 Special at Detailer's Domain - 20% off!
- Fair price to have all control arms replaced...
- ignition coils
- Which Relays on my A4 1.8T?
- Clock / Calendar is resetting.....
- Fan Control Module/Relay
- DIY replace A/C compressor and dryer?
- Need to replace coil on cylinder 3
- Hard Starts STILL? Replaced camshaft position sensor/timing belt + ETC
- Gave up on silverstar ultras and trying something new on A4 headlights/foglights
- steering noise
- ROUGH IDLING
- A4 3.2 FSI Rough Idle
- Lost power while driving
- A/C Fan
- A4 ENGINE FAULT CODE P1504 AIR INTAKE SYSTEM LEAKE DETECTED IN MANIFOLD
- 2002 a4 1.8t quartto
- Stressed out.. Need Help
- Waterfest pricing from AWE Tuning has arrived, now through July 18th.
- My First Ever, Audi A4 1.8T Quattro
- CVT Problems
- Cost Efficient B6 Mods
- 2002 A4 lower front control arm inner bushing install?
- July 4th Specials at Detailer's Domain
- Vag com issue 01206
- Few questions Re: 2.0 A4
- Car STILL will not start. Please help. (g28 Problem)
- evaporator drain clogged?
- N112 Valve Trouble
- '04 a4 Bose symphony Radio intermittent reception
- :: ECS Tuning :: Schwaben Custom Fit Floor Mats FREE Shipping!!
- APR Summer Sales Event, Now Happening at APTuning!!!!
- DrivTech | Vogtland Suspension Sale
- All auto electrical technicians HELP! Strange door problem
- need some help with a fuel pump
- '03 a4 1.8t Coil Packs
- Ultrasport Steering Wheel Badging Question
- Bank 2 Misfire
- best spark plugs for my b6 1.8 a4 Quattro
- center brake light replacement
- Wipers stop in up position
- tail light assembly
- PureMS.com New Website Launch Special
- A/C has a wierd smell comming out of the vents.
- rear sway
- reverse light
- 1.8 Fuel Filter
- New owner - coolant leak :(
- Ross-Tech Login
- Fuel Pump Question?
- timing belt job
- Do these symptoms match my CEL codes?
- a/c
- bank 1 sensor 1 o2 sensor
- Audi dilemma
- left headlight dipped
- Passenger's Front Wheel Noise
- out bulb message
- Trunk problems
- Looking for a set of OEM HID headlights for a B6 A4 2002
- Wheel fitment please help
- Thinking about buying a supercharged 2005 b6
- Father's Day Special at Detailer's Domain
- One more A/C question. Is it compressor time?
- Help With Codes PLZ
- Power to Lighter
- Smoke coming from left side under the engine, is it due to a leak? Check the PICS
- Shock question
- Tracing Slow Oil Leak - Pictures
- Intense vibration while accelerating (2002 A4 3.0 Quattro Automatic)
- Clutch/Flywheel
- strange humming noise!! urgent help!
- '03 A4 1.8TQ - steering rack Koyo vs ZF - interchangeable?
- Engine Code Help
- help esp light going on and off
- part number question and VAGCOM question
- Headlamp housings adjustable for fit?
- 2002 1.8 consuming coolant. What to do?
- Exhaust Advice
- Serial Number - Track Age - Water Pump
- price suggestions for private sale.
- Why am I receiving codes P0491 and P0492
- 2003 A4 HELP with wiper fuse location HELP
- Oil Leak
- Need help with diagnosis
- upgrading to B8 S4 front brakes
- Tiptronic shifting problem
- Anybody got a XENON Driver Side Headlight Assmbly
- Please help diagnose my a/c (air conditioning) problem
- Ultrasport and Bilstein
- audi A4 a/c
- esp proplem
- Leaving car undriven for 6 months or more
- Deck Install using Pioneer ADT-VA133 kit
- A/C Only blows cool out of One vent !
- Electrical ISsues
- :: ECS Tuning :: 70% Off B6 A4 Red/Clear Tail Light Sets!!!
- Quick HID Headlight Questions
- NEED HELP--- Lack of Power/Turbo Issues?
- Won't Start After Spark Plug Change
- audi a4 jerks when moving off from stop
- Where to buy a extended warranty? Carchex, Warrantydirect, or etc...?
- Memorial Day Special at Detailer's Domain
- name/part# for piece of air intake
- Problem: Radio works, No Sound (Bose)
- B6 A4 - NOISE FROM REAR DIF
- Billy Boat Exhaust Group Buy!
- Fault code: P0030 HO2 Bank 1 Sen 1 Heater Circuit, Exaplain please...
- Repair shop in Northern Virigina
- Mineral Hydro Fluid??
- Low Oil Pressure, Coolant, Engine Malfunction warning lights r on, SCARY PLEASE HELP
- Driver door power failure, such a pain when its gets hot and windows dont open
- Timing Belt Changed? Looking for clues.
- Thinking of buying a 2002 A4. Advice?
- B6 Daytime Running Light Mod
- 4 questions
- Shaking on car
- Looking for a audi mechanic/specialist in NYC area? Please contact me
- HID's in stock non-hid housing or spend the money on a OEM hid set?
- Fog Light HID Kits - $60 Shipped w/ Warranty
- Part Number needed! Any hel appreciated.
- vibration while idling and driving
- Headlight issue ?
- Transmission Error Code Please Help!
- No low end power
- Thinking of buying a higher mileage A4 Avant
- Wiring harness part number?
- Timing belt/camshaft/ecu issue? Confused wife??!!
- Blew a cv boot...
- 2002 A4 Propshaft vibration Bearing replacement??
- New 2005 6-spd 1.8T A4Q-Normal shut down sound?
- PICTURES - Plastic Piece Breaking WHAT IS IT?
- High pitch wining noise
- Suspension Tools
- ENGINE OIL LIGHT
- I meant air leak
- Boost Leak I think? Need ur suggestions
- Crankshaft Position Sensor
- What to look for when purchasing a b6 a4
- Strange door problem? please help
- check engine light on
- iso smic
- APTuning Garage Sale - Low Miles Engines, Trans, Seats and Misc parts!!!
- strange fuel problem
- power windows strange problem
- installed test pipe now lots of white smoke
- CVT Transmission life?
- fuel pump/filter noise??
- Audi 2004 a4 Cruise Control Module located
- Widest Tires for 2002 A6 3.0 Quattro
- Need RH door blade
- When to Change Transmission Mounts?
- Primary O2 sensor - 3.0L
- Has anyone seen this light before?
- New to Audi's. Few questions? (interior/seats)
- Broken Diaphram in 3.0 Intake Manifold
- 1.8t Transmission?
- Throaty Sound when Cold Starting...
- odd colour paint match problem HELP
- Fuel Injection system not responding
- having a humming noise comming from a fuel filter I think.
- Dead stereo
- Driver Side Headlight Question. Help!
- 1.8T Engine
- Boost dropped 10 psi, boost leak?
- Changed O2 Sensor Twice, Still Throwing Codes
- Rear Wiper Motor
- Rust preforation
- ESP light on
- Newbie in need of some help please!!!
- any good audi mechanics around Philly
- Water intrusion on drivers side (long)
- Fault Codes: Need Help
- Magnaflow 14851 race series mufflers on 3.0?
- Engine Cranking but not starting
- Tyre poke - how much?
- no more "beep" when doors lock/alarm
- Hello! Looking to buy '02 Audi A4 1.8T Q
- Body Molding Question
- bilstein sport + h&r combo: do i need rubber spring seat on perch for front springs?
- Another broken window regulator
- 02 Audi A4 3.0L Not starting HELP!!!!!
- X-Post : Magnaflow Catback kit group pricing is set.....details and pricing here
- Suspension Update
- EPC - Car Dead - Boost Won't Hold...?
- Taking to Dealer for 75k Service - What to Expect?
- Acceleration problem - LED tail lights
- radio and sunroof Q
- 02 Audi A4 3.0L fuel pump replacement
- help with a new used car purchase
- CVT? throttle cuts out
- Fuel gauge not working!!
- Finally did a k04 install by myself..."whew"
