- How many of you own your audi outright?
- *** Paging 1/4 scale*** please see message below...
- People with early model JJ TIP, how did you contect the stock BPV hose to the TIP?
- Instrument Cluster Failure - A Call To Arms!!! Please Read!!!
- What does evryone think about the spoliers you can buy on ebay
- K04 question
- how to fix my remote?
- How much price flexibility is there on B6's out there right now?
- When we get a "car running too lean/rich" DTC which sensor determines that???
- which pads to replace green stuff
- CVT failed on wife's 03 cab! (long)
- Recode Remote Key with Vag>
- Install and mount my Ipod Nano
- quick 710N dv question
- Can you see your camshaft through the oil filler opening? (1.8T)
- where do you guys ground an aftermarket amp in the trunk?
- Vag codes - Update on B6 Avant prob:
- OK, headlight washer question
- Pull: How many have seen any sign of rust (any where) on their B6 ? What MY ?
- APR Now Provides Financing!!!
- One JHM short shifter left in stock...
- My Axxis Ultimates are driving me nuts with dust. Carbotech Bobcat pads ordered.
- Are all SS brake lines the same? Is one better then the other?
- How do you reset the fob controls (lock/unlock/trunk) after pulling the battery?
- Nav Q's for a B6 shopper
- who still hasnt done the breather hose recall and still has no tears or problems with that hose?
- i love my B6.
- Well, $187.56 later, I got the replacement interior parts from Clair! Anyone know how to replace?
- Front CATs showing fault code
- Driver side low beam "dipped". Conclusive alternatives?
- Ordered up my rear wheel bearings - $145/ea at Clair. Got a shop press lined up too...
- I need to replace my front brake pads/rotors. Can I just get b7 pads and rotors...
- Birthday coming up soon, here is my gift suggestion for the girlfriend... what do you guys think?
- anybody know what technical term and part # for this?
- is it possible to make a beige car look good? or is exterior mods a lost cause on beige
- buying 1.8t, need opinions
- people with aftermarket wheels what offset do you have?
- do B6 come with a clutch fan or dual electric ?
- New Shoes mounted and car washed - Pics for your enjoyment
- Kenwood DNX7100 - navigation system install
- Frozen Rotors!
- Does anyone know if ross-tech software is compatible with mac?
- Paging TeddyBGame - sharkfin help
- When upgrading to B5S4 calipers, do I really need to change the rotors?
- Europrice Leftovers Sale, it's on the shelf, it's dusty, it's priced to go...
- oil question
- Anyone going to the track day at Mid Ohio for May 28? ....
- How much is reasonable for changing front and rear differential fluid?
- How different are Sport (1BE) alignment specs from Standard (1BA) specs? (BWW)
- Ah, Crap! looks like a rear wheel bearing is toast - Tech articles will help, but...
- Followup to window screeching thread
- Central Door Locking Problem
- eibach or vogtland with koni fsd best for rough city driving
- Already STFA but found nothing...
- Poll for 3.0 owners: How much did your last oil change performed by a dealer or Indy cost?
- When the tranny is not bolted to the block the crank on the block spins freely even when the tranny
- Can you believe this? How much would you pay for the General Lee?
- new audi owner with stock wheels and rims
- Driveline thunk when coming off a stop (triptronic) maybe trans mount?
- Possibilities for front end clunking?
- Whats the story with the bushings for the RS4 rear sway bar?
- B5 or B6?
- Hi All- I have a B5 S4 and am looking at picking up a B6 Avant 6 speed as another car...
- Does anyone have a good source to buy special VAG tools???
- What is the prefered year B6 to buy and why??
- Did I get the right plugs? BKR6E-11 (Vpower)
- Forced off the road this morning to work...
- A.W.E. Tuning "Partner Spotlight" - BHR, Inc.
- I found some more goodies in my closet....RS 4 dead pedal....Bluetooth...Audi Sport Polos....
- Can anyone tell me where I can find a Thermal R&D down pipe for a 1.8T? Thanks
- Damn new B6 won't run right (long story)
- to add a 4ch amp I would need hi-low converters for the front channels
- who makes the best underbody neons for the a4?
- What are the best bulbs to use for blue neon headlight conversion? And can they replace the fog"s?
- Question on torque converter
- the doctor
- Damn shop wouldn't pass the A4 for state inspection because he said the front inner brake pads were
- i think i am going to pick up a set of wheels from one of my friends...
- Good link to bookmark!
- Front directional bulb change
- Add for A4/S4 Audi all weather mats and lic plate frame in the classifieds.
- Driveline noises... Haldex issue?
- do you think i should get the a4 ecodes or the s4 ones?
- PSA: The "Tgr_Clw goes Big Turbo" fund is now open...
- New Audi Owner
- cam tensioner seal leak-->rear coolant flange
- Need help deciding if I should chip my car knowing that in 2 yrs I'm going to upgrade to a K04
- iPod install..all credit to the board...
- coolant flange part numbers + where to get
- Avant tailgate brake light update
- sidewall slash?
- 02 1.8T Oil Dipstick part# ?
- Clutch problems, any advice/input is appreciated!!
- B6 Noob question...
- Besides a new rear sway bar, what other suspension mods can I do while keeping the OE sport
- paging: Bronze
- Feeling good! New oil & filter, air filter, fuel filter, and rotated tires. All fairly simple!
- Give me a brake! ....
- Going to the Dark Side... Well, Partially
- I have a boost leak - where do I start looking?
- Independent Garages
- reset service warning...
- So looking for a B6, how come some have matching lowers and some have the greyish black ones??
- how much for navigation on 03 a4
- my new rims
- Do you guys have AWM engines in the 1.8t's?
- 03 3.0 Stock Exhaust?
- CEL P0431.. Warm up catalyst, warranty and repair advice needed
- 2009 Audi A4 Pics here....
- Suspension Gurus - What is missing from this picture?
- whats is the ground clearance of eibach springs? need to know if my 5.5" jack can fit under
- How do you turn OFF your service reminder ?
- Is hissing noise normal with 3.0???????????????????????
- audi approved oil
- Anyone with pics/info on B8 A4?
- If you ever wondered what your instrument cluster looks like on the inside...
- I may have fixed my random engine miss problem-but i had to reduce the plug gap a lot (more)
- Got a knocking/clicking sound coming from driver's rear; simple rock, or bigger problem?
- coolant leak questions
- I learned somehting new about the alarm system from my service advisor...
- New Bay Area Performance Shop
- Opinions needed...paint doorblades or keep them black?
- shifter still moves a little bit between acceleration and engine braking with snub mount
- need help deciding what sway bar to upgrade too. S4 or RS4?
- What kind of gains with hyperflow induction on 3.0Q 6sp?.........
- replaced all the pentosin in the PS reservoir with M1 ATF
- Cant seem to find intake for '02 3.0Q 6sp...
- Transmission mount help? See picture inside
- PSA - Rant - Don't Use Celebrity Motorsport
- metal hitting sound while starting engine .......
- Need some help with these crush washers for K04 install
- Need Front Licence Plate Bracket
- Anybody interested in bike holders...
- Paging Tgr_Clw, YGM.
- Keep off Lease or get new?
- I know I've done this before... but... I need a Glovebox, black, unbroken.
- BMW, LEXUS, INFINITI 6cyl have 300hp+, wassup with AUDI!?!?!
- this is cool, refrigerated glove box
- LOL I wonder if anyone followed this writeup
- HELP! top governed speed 2002 A4 3.0Q?
- How many "breakaway" clips are on the back of the door panel (driver's)?
- Well, it didn't take long! The car sold today....sale pending cash transfer..
- Got my car back from the dealer. Am I missing something?
- So, B6S4 Brakes In. Jesus, perfect upgrade. Same, progressive feel just a lot more bite. Not jarring
- My $3000 test of 3rd party extended warranty service.
- Carbonio question
- Just got the car back from the stealers for my CP. They changed #2 to the R version....SO
- I heard back from Clairparts (Barry); WOW! Assessments/reactions appreciated (see below for thread)
- RS4 Police Car
- Is a hissing noise normal normal when coasting on the 3.0?
- Gapping Bosch F5DPOR Sparkplugs
- sounds ridiculous, but.. wipers barley wiping
- STFA, but didn't find much. This morning, after I started the car
- a reminder of the weekly Philly area MRSCC meets 4/29
- Anyone interested in a brand new APR Stealth exhaust....
- 02 A4 Avant--Springs and shocks or 18" rims and tires first?
- Opinions on Clairparts? I'm waiting on a response (other questions inside)....
- PSA: Tramlining is one ugly and annoying bish. I don't like her. Any tips to minimize it?
- tuning
- Damn, my 3rd coil pack failure last night...
- Wheels for A4 8E B6
- 02' A4 1.8t $12,995. . . but it has 90k miles. Pass or not?
- YAY, replaced remaining 5 coil packs with Hitachi's, no more !$@^ failures!
- where is a good price for xenon headlamps?
- I haven't peeked in the PS reservoir yet but after reading on PS pump failures
- Ok, has anyone bought an oil/fluid extracter and probe that fits our cars?
- Quick detail of the B6 w/ new detailing toy.
- Does anyone else find the cupholder in the center console very annoying? Removable?
- Replace Ash Tray to Non Smoker Tray
- wheel help.
- Pic request and Assistance with Koni FSD
- vacuum check valve and vacuum hoses questions - need some part numbers
- Now Playing: Reel Big Fish / Zolof The Rock & Roll Destroyer - "Ask"
- While going to put my wheel locks on...factory lug bolt tool doesn't fit in RS4 wheels!
- X-post: great alternative to Clair Parts and World Impex for all your OE part needs...
- my experience with ecode..
- Any of you people purchase parts from rockauto.com??
- no reason why my post should have been erased. that is unfair. if a certain tuner
- Interior Paint chipping
- Need some help from you 1.8T guys......
- HITACHI "E" COIL PACK - screw size?
- Suggestions on how to take off those plastic lug bolt caps?
- Sidewall cracked? Manufacturing defect?
- WTF happened here?
- Blackout part II!
- Sad Realization: Chip, Injectors, Exhaust... still slower than a V6 Camry.
- So, B6S4 Brakes going in, w00t. Replacing rear rotors and pads. Down to the metal.
- FMIC v. DSMIC. Discuss.
- How much longer before FMIC vs DMIC threads arise?
- I need more power! What are all my options?
- Question on a B5 for Miktip...
- how much can sell my car for? 2002 a4 3.0 56k mile. Is 15k a fair price?
- Any particular reason why a coolant flange needs to be replaced?? (m)
- Car hicupping at a stop. RPM's drop about 100, then jump back up real quick, shaking the car.
- is it possible to tap into stock wiring/amp to upgrade the rear sub?
- Question about towing...
- My A4 hit 70,000 miles tonight on the way home from work. <<<sigh>>>
- I am going to replace my 16'' OEM wheels with 18'' ones
- follow up on the rear brake pad issue
- Recirculate LED "on" all the time
- Honda Civic boost gauge pod, and, oh yeah, Stage III+ bliss
- DOH!!!! flashing CEL after 7 days of ownership **edit-Pic posted++
- best car cover for B6 sedan? TIA
- Replica Oettinger Front Bumper
- No luck searching: the famous thread about the guy eating at a buffet
- rear brake pad question
- So pissed right now
- 20" too heavy?
- fuel leak 1996 A4 2.8
- B6 Exhaust Buzzing
- Hitachi E coil update....
- So I've finally put on my summer setup...
- $1099 for 80k mile service, you got to be kidding me.
- HVAC control question.
- Hey...whazzup guys...long time no talk...
- 2004 A4 Wipers
- B5 S4 seats in B6 A4?
- moly/lithium or just lithium grease for doors and sunroof?
- Here are a few wallpapers
- drove my audi for the last time for three long months
- Need your opinions and advice on an A4 buying issue
- Finally got a picture of my new Avant..
- Re: Does anyone have any have any new or slightly used bumpers 4 sale. USP, Rieger or Caracter...
- My second mod of many more to come...
- I need more power so I've decided to turn in my A4.
- Dumb question, but hw many boxes of the Hawk HPS pads do I need to replace all pads, front and back?
- just wanna confirm, there's no wear sensor on the rear pads, right?
- A4 B6 3.0 Need better suspension than stock...Any Ideas please!
- Can anyone confirm part # for wheel bolt for my 02 A4. I found 4A0 601 139. Thanks!
- random 1.8t low rpm (usually sub 2000k) engine miss - any ideas? more inside...
- 3.0 Oil Change - M1 0W-40 or M1 5W-40? Toronto = Cold winters, hot summers.
- Anyone in Illinois want to help a brother out w/ a APR home programmer?
- New pics
- Is this guy on AW???
- Interesting....
- Say, if a person had Euro mirrors on their 2004 B6 A4 Avant Q...>>>
- ECS Kamei Lower Sport Grille Kit Questions
- Just a Heads Up!
- Does anyone have the torque pattern/specs for the headbolts?
- suspension settling and thoughts on why one fender sitts higher?
- Navigation Plus question...
- WORK WITS wheels for sale - New - 18 x 8.5 et32
- Question, I have Been using mobil 1 5w-30 should I swich to 0w-40 or 5w-40 ?????
- So I got busted after only 14 days!!!
- Aftermath of first Penske Audi GTG/BBQ
- Car Care Products
- Hitachi coils..how are they holding up for people..
- Good idea to change the fuel filter around 40k, right? ('03 1.8t)
- Don't want to spend the money on a full exhaust... What would like, new mufflers sound like?
- PWing : Some shots in route to St Helens
