- Rich condition...
- Need Help -- Rough starts in cold weather
- up grade radio??
- Woot, ER FMIC score...
- Key Blade
- Allow me to Introduce...
- Radio Busted
- REPOST....TT 5cyl pics released!
- Question about calipers: My local junk yard has audi calipers that look
- Anyone no where I can source a RNS-E "non-Bose" wiring adaptor?
- UPDATE: Ceramic coating, engine removal and ITG air filter system...
- Which TIP to get?
- A couple of questions on my car that is acting up
- Anyone else think that the new VW CC is just badass?
- Forge 007 or 710n
- audi snowboard racks or thule???
- Say it aint so....a TT 5cyl turbo????
- Steel wool + CPs = restored performance?
- A4 1.8t Engine mods - Newbie
- Steering suddenly loose/inaccurate
- How can you tell for sure if you're losing engine coolant because of a bad head gasket?
- I know it's been asked before, but what's the story with replacing batteries in our cars?
- Lets see if these babies have any effect
- Looking for a good mechanic in the Santa Clarita Valley, California.... Tired of Keyes AUDI!!!
- 'Useless info we should all know' post......does your fob not work as good as it used to?
- Losing coolant after flange fix
- new to this stuff.. what can be more reliable in the long run for my usp, coilover setup or a
- Plastic Cover
- questions about 3.0l's
- Wheel color question
- 1.8 or 3.0?
- General info for those with 1.8Ts...
- stuttering on startup
- Hartmann Wheels gallery just finished with a huge update
- good news! my mpg improved from 18.5 to 21.5 after i installed my miltek HFC and new O2 sensors!
- POLL - what's in your CD changer? i'll start -- common, lamb of good, muse, MMW, my bloody valentine
- GDawg recently posted about changing the transmission fluid, but...
- ongoing CEL, cat related
- Link to changing motor oil
- All you 3.0 guys... exhaust & intake info here.
- 20% off Storewide for 7 days! Starts today!
- Coolant bleeder Screew - New metal part
- Tire Recommendations
- Part number please for purple clip in driver's door frame wiring harness on A pillar?
- no start updates, car is fixed, problem was
- FOB 8Z0 837 231 F acceptable as a replacement for 8Z0 837 231 B ??
- The new A4 allroad doesn't look bad. Maybe it's just a glorified Avant to some
- Cylinder X Misfire Issues
- Dropped auto leveling headlight. Busted two support screws. creative ideas?
- Special offer on Stoptech Big Brake Kits for selected Audi vehicles....
- bad, bad news for my car
- Can an O2 sensor go bad without throwing a code?
- spark plug replacement on A4, 1.8T, 2002
- my friend has a 2003 A4 3.0 that needs a battery replaced, he was quoted $280, does this sound right
- Does anyone know where the crank sensor is on the 3.0 ?
- GDawg...or anyone else with a Platnium interior..
- Vag-Com USB Cable from Ebay
- 2004.5 audi a4 for sale
- Changed the transmission fluid yesterday and she shifts like buttah again!
- UPDATE: Well the engine removal process as started but first take a look at the ceramic coating...
- ratlle inside car...seems to be on pass side around dash area!!!
- YASBR (yet another Sprint Booster review)
- What's a good price for an ER front mount intercooler?
- i have a set (5) s4 avus 18inch with pirelli p6 with 5k miles for trade for 17inch a4 wheels
- Help! Wipers stop in middle of travel!!
- Resync keyless entry after replacing battery
- Jury-rig crank case vent tube replacement (2004+)
- Clutch issue???
- Revo Technik & BGB Motorsports Spring Cleaning at Roebling Road.
- Any local or chain stores sell Motul 5.1?
- Paging Jet Jockey
- Found this bolt in my driveway today, any thoughts as to where it came from?
- I got problems!!! Please help!!!
- Battle with license plate lights...
- Yikes! Checking oil today, and dipstick crumbles and falls into engine.
- I need help from an Audi tech... This is my situation: My car is an 04 A4
- Thanks Audi world - engine speed sensor fix
- PhatNoise connected, now having a few issues, phatnoise guru's please help.
- I pulled some codes on my car today with a scan tool to try and....
- A4 3.0 coilpack replacements noob question
- Hit/Skip?
- Fuel filter connectors
- So i want to paint the HP2's...what does everyone think of a gun metal color?
- wierd electrical problem
- Can't turn radio off -- help!
- Doors Autolock not working
- Service Display
- 3.0 V6 Temperature Sensor location
- What is a good price for B7 brakes?
- My car went into limp mode tonight. Couldnt rev over 1k rpm's....
- Wheel squeak help
- Free tickets to KONI Challenge race at Homestead
- Power Steering rack replaced 03 A4 3.0
- Hey MikTip
- wind noise in 2002 A4 3.0 w/ sport package
- Honestly - there is too much info available on an RNS-E retrofit! (help needed)
- Subframe clunking when going over bumps
- Stock clutch okay on GIAC FXK03 - what do u guys think?
- Better gas mileage with K04?!
- Anyone replaced their aftermarket snub due to age/mileage (not cracked)?
- xenon bulb lifespan? do they dim over time?
- Need battery expert advice, calling diagnosticator1!
- 1.8 T used water pump & timing belt-free
- So what do matte carbon fiber S4 doorblades look like?
- Stern Adjustable control arms all back in stock!
- bah, no start update, tried new crank sensor/impulse sender, still no good
- Been laying low on this, Just scored some B5 S4 brakes.
- Do ALL US RNS-E units have the "AM/FM" button as opposed to "Radio," or did that change with newer
- headliner removal diy?
- Wheels: how do i figure out ...
- Should I use Motul RBF 600 or 5.1?
- Does anybody have Teddybgame's email or contact info?
- Can I change the settings on my CC to go down to 60F like the B7?
- Suspension question...
- 245/40R17 on 17x8 35 offset fitment?
- PPC ECU upgrade
- 255mm vs. 245mm rear rotor
- Ahhh...... I love 60F+ temps, all the creaks, squeeks, croaks and groans are gone!
- is it hard to change the inlet pipe? I just bought the APR one and also the throttle body hose
- anyone have a pic showing where the crank sensor is located on a 1.8t?
- Can I install Bose speakers easily i.e plug and play into stock components?
- Update 2: Sprint Booster + K04 + Lemmiwinks
- '05 A4 1.8T Avant TCU Problem!!
- how to run indepent fogs on 2003 audi a4?
- Paging QuattroFan02...so the value for Ch. 12 did write successfully.
- Clutch vacuum vent valve switch aka clutch pedal switch
- Why is there motor oil dripping from here...
- Anyone know the part number (revision) of the recalled fuel pumps of 2003 models?
- Thanks Mike and Greg at DTH. Finally got today my Special/Custom DTH FX 600...
- UPDATE: And now for the aluminium intercooler piping...
- anyone needing to get rid of a APR throttle body hose in red???
- Checked out the turbo and DV, looks to be fine.
- Couldn't stand the lag without the Sprint Booster. I gave in and re-connected it.
- driver door bose speaker cackle sound during talk
- 2003 1.8T 6.5 years old, finally bitten by the coilpack devil
- Need opinion about timing belt..
- Anyone here gone from B5 to B6 1.8T?
- snub nose mount - vibration issues?
- What would you do if you're dead set on a Black Stoptech kit but the only ones on sale were red?
- Been driving without the Sprint Booster for 2 days now...my thoughts inside.
- Maya STMs tire size HELP!!!
- Audi Symphony headunit problem
- Remote Key
- Need help on next mod -
- Update request on whoever bought the aero wipers on amazon
- So I hear this very faint whining noise as boost builds...
- Hood Insulation Pad Rotting
- 2003 A4 Avant 3.0 Quattro Purchase Question
- 2003 audi a4 front right axle replacement HELP!
- Rear end creeks
- Key Broke
- replacing o2 sensor, autozone carries a bosch for $153...
- Help. Need your opinion. Would you take this deal on a New 2008 Toyota Highlander?
- bad pizza?
- Checks before purchase?
- how do I check for proper fuel pump operation? i took the cover off and it makes
- PS Fluid
- What to do with my K03 turbo?
- 05 1.8T A4 or 06 2.0T A3??? please share your wisdom, opinions...
- Dash touch-up needed
- Gas cap issue?
- Changing the Timin Belt on an A4 2004 1.8t (60.003 Miles) stock
- Any DIY for CVT oil change?
- I've joined the K04 club!
- Has anyones headlight washer cap just fallen off?
- croaking and humming sound
- 2002 A4 1.8 won't start
- What Oil type is the best for..??
- took out the amber lens on h/lights but cant find anything on the archives on all chrome bulbs that.
- Uh Oh...I gotta clunk!
- I need some Audi keys
- Update to all you 3.0L guys with a rattle under engine load during accel.......
- UPDATE: Check out the masterpiece! Thanks Markku for the excellent work...
- Ecodes specials....
- anyone know someone in south jersey that can do a timing belt?
- How far can I go with a 1.8t tiptronic?
- MikTip...
- KONI Sale!
- You on here? white with LED tail lamps and LED strips up front, yesterday 6pm Jackie Robinson Pkwy
- My a4 is sick... several codes, need help
- Optima almost twice the price of a cheapie battery. Why not buy 2 cheapies instead of one optima?
- Car doesn't recognize that right rear door is open....broken sensor
- Well, tonight's the night...taking one last drive to meet the buyer of the A4 to finalize the sale..
- 2003 A4 avant power sterring
- radio problem
- Battery question
- Program codes for a B6 avant? such as window roll up/down with remote...
- FOB no longer works after being on the washer and dryer. Can I buy a used FOB and reprogram?
- I just want to praise the folks from G2 USA (Caliper Paints)
- Where is the best place to get an Optima Red Top battery with shipping to Wcoast?
- FYI....B6 3.0 Supersprint sound clip
- Genesis 380 w/ APR Stage 1+ will these injectors work properly?
- I just got a valentine one . When it first chirps for K/Ka band...about how far away do you think..
- FYI...in case anyone is interested...vagparts.com is no more :-(
- Lost my gas cap - where can I get a new one?
- Oil Sludge / low oil pressure
- It's time for some new tires - what summer only tires are people recommending for their B6?
- Windshield washer not working.....
- Anyone know the stock watt and kelvin of the b6 a4 halogen headlight?
- B6 A4 ECU PINOUT
- headlight adjustment - '05 oem xenons - which adjustment screw does what?
- Best exhaust?
- Dr. Brian...more pics
- Who has the best prices on stock rotors and pads?
- 1.8t tuning
- New Cat!
- DIPPED headlight out
- coilpack question
- Tire question and opinions wanted. Currently Pirelli P6 235 45 R17...
- Thinkin about a B6 Avant>
- need some assistance on chnging battery-cant search forum
- Need ideas on removing a broken screw...
- I think my headlight fluid is low...m....
- false reading -burn out LH turn signal, rear brake light.
- Yet another N249 mod question
- Red flags? Odd things about the car I'm considering purchasing...
- Once again. Switches peeling. Yes, I've searched and its still
- CVT Tranny - Oil Change
- 2.0t in a B6 ??
- APR Stage 1+
- new maf did not solve no start issue, all 4 plugs do fire 1-3-4-2, fuel is spraying
- will a faulty cam position sensor cause the car to not start sometimes?
- Three years later, get my first No Front Plate Ticket.
- What would be a decent price for this '04 B6 1.8tqm avant?
- Any of you guys taking part in the GPNY karting event on 3/1?
- Another Power Steering question... please I need desperate help!!!!!
- Labor time to replace an E-Brake wire? (e-brake is sticking)
- Here we go again! However this time it is a smaller post... :-)
- Voltage regulator or alternator?
- Simple Road Course Setup Recommendations
- B6 w/1.8t or B7 w/2.0t ??
- Spotted, Artic White Ultra Sport, dropped, in Colorado,KS plate, AW plate frame...
- b5 s4 front brake swap
- What goes into an A.W.E. Tuning exhaust?
- Aero rear wiper
- is it easy to change out your turbo???
- Anyone know is these eBay center caps will fit 19" RS6 replicas?
- What is this hose?
- Can anyone provide some part numbers for the plastic covers from
- UPDATE: I think you'll like this one too! Wastegate installation and a little surprise...
- Audi A4 3.0 Timing Belt Change Question?
- Final Stage of my CF Dual Projector headlights
- Platnium S4 Recaro's on eBay if anyone's interested
- need to go to a good home b7 s4 mint white leather on white alacantara front and rear seats heated
- GIAC Stage 1+ w/ USRT Genesis 380 injectors
- B6 A4 reliability - better info - please sign up
- Changing Battery-Anyone know of something to plug into lighter to save settings?
- Very slow coolant leak question:
- Its a Quattro kinda day!!
- Weird smell, only on cold, snowy days, in reverse?
