- Oil pressure warning when engine lukewarm
- Help please. Tail gate light nearside
- supercharger side fill?
- Valve stem seals or ...?
- Air suspension woes… or not?
- IE: Audi a6 2.0 diesel Shuts off while driving
- Audi A6 C6 2011 electrical issues J519
- 2006 Audi A6 - Dead MMI - Changing Radio?
- Wheel bearing recommendations?
- Suspension tie rods and PM recommendations
- CZ: Audi A6 4f C6 2.0 tfsi 125kw BPJ
- Another C6 Avant! (and supercharger oil question)
- DE: Tools to replace water pump Audi A6 C6 3.2FSI
- 2007 A6 engine replacement advice
- Audi A6 C6 MMI cutting out
- TPMS+EPC+Stabilization Fault codes
- Anyone ever have their MMI Wheel stop working?
- Motor mounts: electronic vs dumb
- CZ: Audi A6 2.7L diesel - Multitronic CVT - Car will not move
- Good website to buy parts, oem or better quality?
- UK: First Start in 7 years, diesel!
- MAF location?
- A6 / Q7 3.0 SAME??
- Transmission AFT Service Recommendations, A6 C6 Quattro
- 2008 S6 5.2L V10 check engine + ESP lights after valve cleaning service
- headlights
- AU: 2007 Audi A6 C6 2.0T Weird Misfire problem
- Popping from Speakers that goes away
- 2010 A6 3.0 p0019 code
- New Shoes
- Carbon Cleaning w/o removing lower intake? - 2006 3.2 FSI
- 2.7 V6 injectors
- rear brakes are over-heating
- Mirrors folding out on one side
- 2006 A6 Transmission Program LA Area?
- a6 c6 2006 avant brake light switch
- Please help! I'm about to buy a cheap 2008 S6, but it has many problems
- AU: C6 A6 breaking CV shafts
- USA: How do I know what type of headlight I have?
- Has anybody removed a HID conversion kit and returned to halogens?
- 2011 S6 coolant leak
- A6 c6 3.2fsi idle speed
- 2011 Audi A6 3.2 dreaded TPMS, parking brake and traction control errors
- Seeking Assistance with Audi A6 , 3.2, 2005 Door Issue
- NO: Tire recomendation for 19" wheels?
- Ignition Power Source -2008 A6 C6 4F
- ESP FAULT SEE OWNERS MANUAL on startup
- How to remove the jack stands?
- FI: Desperate
- rear windows raise then immediately reverse...
- Dynamic turn signal
- Factory headlight bulbs
- Left rear door won't open from either outside nor inside, where to cut?
- CZ: Brake
- UK: Tcm update, diesel
- New help with a Cam Sensor O-ring
- Sudden sound when driving and something hanging below car
- Weird electrical problems
- UK: diesel Audi problems
- HID Problem, Missing something obvious
- Car Won't Start - Whining Noise
- A6 C6 avant
- Battery Dead - won't jump - clicking sound
- S6 won’t idle, no power, sputtering 5.2L
- AU: 2007 Audi A6 2.0T fuel injectors
- 07 S6 Brake job time
- Alarm Horn Fault
- 2005 A6 Air suspension leaks overnight
- Help me diagnose noise
- A6 C6 Manual Swap thread
- How do I remove / install this rubber window seal?
- 2008 Audi A6 Allroad JDM - Needs front DRL lights
- A6 3.0t Avant: Persistent Oil Leak (Please help ANYONE)
- 2011 Audi aftermarket tail light (6 pin vs 7 pin connector)
- Acceleration Issue
- MMI 2G Not Working (A6 C6)
- Best Resource for repair manuls (paid and free)
- Audi A6 Quattro stereo wiring
- Steering Wheel Compatibility
- Got a killer deal on a 07 A6 4.2, or did I? key stuck, no start, "SAFE" message
- Squealing when turning at low speed
- CT: Looking For Audi Tech/Mechanic
- C6 S6 cold start issues
- C6 S6 oil sensor issues
- Lots of electrical codes...whatever could it mean.
- Transmission Issue, Adding fluid issue
- A6 C6 rear diff confusion
- UK: Gearbox issue! c6 estate
- 08 A6 3.2L with P0087 (fuel rail/System Pressure Too Low)
- Sagging headliner? Here's how to fix it
- How to change your gearshift to C7
- Audi A6 C6 2011front left mid speaker problem
- 2007 - S6 - All The lights came on
- USB Issue Warranty Issue
- Fixing oil leaks - 2008 4.2 A6
- Air Suspension Woes
- Autoheadlights not working
- NZ: Shutter Problem Bi-Xenon Headlight
- Rubber Mats
- 3.2fsi cranking but not start
- 2011 A6 C6.5 AUTO HEADLIGHT ISSUE
- UK: Water in passenger rear footwell
- Misfires after new coils/plugs and now...BRAKE PAD LIGHT?!
- C6 Audi S6 Weight Distribution?
- 2008 A6 4.2 - Help me figure out this coolant leak
- Needle Sweep on 2006 c6 A6 S-line?
- RS: No Hot Air of Fan, 2005 diesel
- Both brake lights and rear signal lights failure
- RS: Rear window heater defogger not working, 2005 diesel
- BG: A6 3.2FSI TIMING CHAIN QUESTION
- Changed battery, now no crank no start. 2005 A6 3.2
- IE: Cd changer problem
- Cluster needles stay on even after locking the car
- 3.0TDI with fuel pump toothed belt that doesn't fit
- Using lithium battery
- A6 4F 2004 Starting Issues
- 2008 s6 mmi issues
- AE: C6 high fuel consumption and excessive smoke from exhaust
- Coolamnt pump leaks. What parts to replace?
- Wheel spacers
- Poly V belt tensioner fail
- Starter problems with my car
- P2006 after thermostat replacement
- MMI sudden issue
- Headlight - bulb upgrade options....LED, etc.....
- Rattling under acceleration between 1500 & 2000 RPM
- C6 Coolant Leak To many options to resolve - were do you start?
- 2007 A6 Quattro...do anything else while doing valve cover gaskets?
- Audi A6 Fap issue and VCDS full error scan and fix after 16 years
- 2006 Audi A6 3.2 - No dash display in center and intermittent MMI - NO START
- Blanking plug on door close to lock
- Help identifying a part on a c6 3.0t
- Help identifying coolant leak
- 06 A6 c6 2.7 Tdi rough start and idle
- replacing rear lower control arms
- Need some tips and advice
- elm327 Hiden meneu ?
- Audi A6 C6 2008 TCM issue
- Audi A6 C6 drivers window fault
- PCV Relocation, now, SC belt is loose!
- Faults - time to part ways with my A6?
- Bluetooth Module & Dying Car
- Inquire about installing start button
- rats
- UK: Car is in safe mode
- Audi a6 c6 4.2 2006 air suspension fault
- A6C6 171q brake fluid leak
- 2008 Audi a6 Level Control system module
- Rear lower control arms
- 06 A6 Bumper bracket replacement ?
- Need help finding cosmetic items
- A6 C6 2.4 V6 Not Starting
- HU: Big Red "BRAKE" warning come and goes
- 07 a6 4.2 fsi
- How to disable mirror fold-in motor?
- A few issues with my 2007 A6 4.2l
- BLACK FRIDAY SALE / CYBER MONDAY ON NOW @ deAutoLED.com – bright error free LEDs
- BLACK FRIDAY SALE,, SuperSprint Italy
- 2007 A6 Avant fault codes
- Altenator exitation voltage
- PT: Audi A6 C6 parking sensors auto activate
- Engine/trans. pulled & back. Help!
- Speedo light faulty
- fuel injector?
- Need Help locating a coolant leak
- Climatronic settings not showing up on mmi screen
- Self Studies Program for Audi Mechanics
- Need Help with color code
- Rear door warning lights wiring
- 2009 A6 can’t seem to figure out what version of MMI
- Front Bumper
- 2007 3.2 Avant timing
- Help Needed: Budget Bluetooth for Audi A6 C6 without AUX/AMI, MMI 2G Low/Basic
- rear brake hose retaining clip
- Audi A6 C6 2007 2.0 tfsi
- Rough idle on V10 2007
- 08 Audi A6 rear main seal
- MMI Issues
- Can find location of the EVAP Purge Solenoid Valve?
- washing fluid leak
- Recommendations on 2018 S6 or newer model??
- Audi A6 Allroad 2008 MMi 2g android contacts won't sync
- 2.4 A6 C6 2007 fuse box - need help
- Seat backs are detached 2011 A6 Avant
- Sub standard wiring
- Upgrade my headlights
- Brake Pedal warning folllowed by 'Brake" in red underneath
- CD changer and AMI install
- 2008 S6 engine wiring diagram
- 2005 Audi A6 telephone cradle wiring
- How to connect to back up light (reverse) for Carpuride Display Unit
- A6 C6 Dead MMI?
- Added 0.5 Liter of drinking water to coolant ... now what?
- C6 Oil Separator
- AFS headlight self-leveling issue
- Hacking speakers
- Replacing drivers door for C6 avant
- Rear Wheels Problem HELP PLEASE
- P0304
- NL: Steering wheel upgrade? New one with control button units
- A6 2010 Performance modes
- C6 3.0 v6 - Radiator support foam strips?
- New S6 V10 Owner
- New RS6 Avant owner (C6)
- G201 error.
- MMI upgrade
- Intake Manifold Tuning Control Solenoid Valve Location?
- C6 wagon are the best
- A6 C6 Voltage drop with higher the rpm.
- Audi A6 3.2 Giving Away Parts Worth $10,000
- Audi A6 3.2 Brake Job Overview
- ECM repair
- A6 C6, car randomly won't start and I'm getting a red flashing oil pressure light.
- ES: Conversion from A6 into S6?
- A6 2008 - low beam LED error after hour of driving
- 2008 A6 4.2 cooling fan staying on continuously after shut off
- 2008 A6 4.2 - Coolant temperature sensor locatio
- 3.0T JHM Pulley Install
- Alarm arm disarm by door lock button.
- Advice on buying S6 Lemon Car?
- J518 repair europe
- Car battery dead,,keys wont enter door and remote key obvioiusly not working
- Wipers no signal - not working
- Squeeking noise steering
- loss of transmission
- C6 3.0TDI Gearbox Query
- UK: A6 c6 2011 parking brake issues !!
- Passenger HID out and frustrated....what am I missing?
- Bumper Cover help l
- A6 4.2 V8 Rough idle and stalling here are my symptoms
- BDW 2.4 crank no start
- 2005 audi a6 3.2 im begging for help i dont know where else to turn.
- Faulty PCV Valve?
- Issue with replacing cooling fans - bottom bolts cannot be unscrewed
- Interesting A/C issue
- Adding another audi to the sable
- 2010 S6 Driver seat not working
- Ambient lighting blinking when doors open after replacing with led strips.
- Mutiple short to grounds problems...4.2 FSI
- UK: ABS/ESP + Parking Brake lights
- Vibration when accelerating
- 2010 S6 V10 BXA Bank1 Exhaust Cam - Tone Ring Clock Position
- Audi A6 timing issue
- A6 3.2 Timing cover leak
- A6 C6 2006 Avant Bank1 0 Compression Bank2 155 Compression
- A6 C8 (2023) - Error identified during coding after installing tpms sensor
- What's the name of this part?
- 2015 A6 Quattro - quick question about a plug I found
