PDA
View Full Version : Audi 90 / 80 / Coupe quattro / Cabriolet
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259
  1. wholesale online getting a bit slim
  2. EBC opinions
  3. Where can I find the harness to go from my B3 headlight setup to the RS2 ellipsoid set up?
  4. Anyone looking for the upgraded brake master cylinder this seems to be a good deal. (UPDATED)
  5. B4 strut bar plates in CQ rear?
  6. How do I test 12V to the AC compressor on a '91 CQ? Thanks.
  7. what exhaust to go with?!?!
  8. any San Diego residents out here? dinner/GTG thursday evening...
  9. Aybody have a 80/90 automatic parts car?
  10. How much do you think I should ask for...
  11. fun little front-end rework project
  12. Can anybody confirm PN# 437 927 809 as metal sleeve thats holds...
  13. Cleaning out a huge garage to get your tools and car in is a bitch!
  14. Come check out JFR's
  15. 1991 90Q sedan running crappy after 1/2 of running
  16. '91 CQ Dead AC
  17. Another Audi joins the family - bought the Coupe Quattro
  18. Does an 17mm offset wrench really work for the Control arm bushings???
  19. The Audi at my wedding...
  20. Did some work on the red CQ today...
  21. CQ fuel pump relay location
  22. Mance I've got a fan questions for u? (I searched allready)
  23. tips on fixing door side pockets
  24. 1990 cq power loss
  25. Shift linkage replacement
  26. VW Steering damper let down;-(....
  27. Performance/Body Suggestions for Coupe Quattro?
  28. Aero Wings
  29. 89' 90 starting issue
  30. My cheapest upgrade...
  31. Spotted Red CQ in MT Veron Hosp
  32. 90CS will not start relay clicking constantly
  33. Stebro exhaust size
  34. Resonating exhaust... how do I get over this??
  35. Pic request - Underside of B4 hood that shows the placement of the seals
  36. If I were going to build an RS2 -replica- sedan, which platform is more appropriate B3 or B4?
  37. Anyone ever, or know of, measurements for the front sub frame?....
  38. I can not wait!!!
  39. FYI - Recently sold my mint B3 88 90Q for $2,400...the right buyer will come...
  40. Relay not needed on High Beam for RS2's running Xenons....
  41. Thoughts, advice, suggestions? 1988 Audi 90 Quattro considering to buy >>>
  42. Daul exhaust in a CQ
  43. Is there a cheaper source for the water temp sender for CQ?
  44. Maintenance Saturday! Any advantage to going with a bigger oil filter?
  45. Anyone have Castle strut nut tool? If so may i please borrow it for a week..
  46. clutch questions
  47. Help: Upper Spring Seats Needed ASAP
  48. Should the transmission mounts on the sub frame be level?...i would think so...
  49. replacing cv boots vs getting axle rebuilt. preferences?
  50. Engine and Clutch Replacement Tips?
  51. Cracked rear subframe.
  52. any1 know someone selling OEM wheels for a CQ?
  53. Whats the best way to clean an expansion tank?
  54. Just picked up a coupe that had the 20v motor in it, but is blown. Can I put a 12v V6 in it?
  55. X-Post. Clutch slave cylinder success
  56. HELP!!!! Driver window stuck down and it's supposed to rain tonight!!!!!
  57. what kind of fog lights are these??
  58. so I just went to my local stealership... and it has really earned the "steal" in its name
  59. My weekend...
  60. 95 90s problem
  61. Anybody seen this yet? Scamola or real?
  62. Is it possible to bend or strip the steering rack, or the strut is bent??...
  63. CQ on the block here in Illinois near northern Chicago...
  64. When doing the B4 hood conversion on a CQ?
  65. a little OE bumper alteration
  66. Can someone please post/scan Bently instructions for setting ignition timing ..
  67. need help with 1990 audi 90q 20v!!!
  68. Matching Headunit w bluetooth, onboard memory
  69. Is true dual exhaust possible on a B4? I STFA...couldnt find a definite answer.
  70. Getting ready to put the 90Q back on the road and park the CGT for a bit...Questions...
  71. Audi Club? In Barrie Ontario Canada
  72. i love having pre owners who car about there car.
  73. Coil overs, What rates are people running?
  74. Went to go bleed my brakes this weekend ... i've got a weak stream
  75. Anyone has Princess Di's Cabriolet pic?
  76. Anyone replaced their steering dampener before?
  77. oooops
  78. I ordered springs and bilstiens for my VAP CCK...
  79. paging Brdman* did you get my latest email?
  80. WANTED!!! (1995 90Q 2.8L ECM)
  81. Audi 90 for sale in my neighborhood!!!
  82. Boss is making me relocate to the L.A. area from Alaska. Anyone live there?...
  83. Installing TT Head Unit into coupe...
  84. ...now I'm really baffled...
  85. coupe continued
  86. Is access to the bleed screw for clutch master cylinder from under the car
  87. Free audi 90 quattro (b4) car parts this weekend in Fort Collins, CO..
  88. MY REVERSE LIGHTS ARE NOT WORKING??!!
  89. This is how I roll. Weight saving mod on my red CQ.
  90. removing CA bushings. Need another suggestion
  91. Drives and Shifts
  92. A little info for anybody looking for one. Wheel hanger bolt....
  93. Who's moved their fuel filter to a more accessable place on their CQ?
  94. Is this some kind of custom job roll bar attachment?
  95. Hey Hey, calling all AW'ers in the Denver, CO area.
  96. I guess I need to find some B4 control arms and fenders for my bumper install
  97. Tell me about the clutch master cylinder.,
  98. Have a safe Memorial Day holiday and let's be safe out there....don't want this to happen.
  99. 1993 90cs will not start relay 208?
  100. Out of curiosity...what are the most common mods for the Audi 90 Quattro Sport?
  101. anyone bought replacement parts from this company!?
  102. b4 quattro engine swap....
  103. Local 94 Cab for sale, advice requested
  104. Quick Headliner wiring question.
  105. Is the rad cooling fan always supposed to run when you have
  106. Pic request
  107. Pulstar Sparkplugs? Anybody ever hear of them?
  108. Anybody have the new 034 Shift Mod in their car? What do you think?
  109. True or false test for the class...................
  110. New carpet?
  111. x-post pic from awot. who's CQ in this pic?
  112. Crazy Germans
  113. Thoughts, advice, suggestions? 1990 Audi 90 Quattro considering to buy >>>
  114. just me or is this funky?
  115. Where did you buy your Eibach for your CQ?
  116. Hmmm it seems the passenger side grab handle for CQ's has now become NLA...
  117. alt issue, 2 versions?
  118. Ive got a bunch of stuff all boxed up that some people might be interested in...
  119. what are somethings toworryabout when removing the cat converters?
  120. I recently purchased a 91 90Q20V sedan and having a little issue
  121. whats the going rate for a B4 90
  122. still no start and no spark
  123. Looking to pickup an Audi 90, going to park my C5 A6, need a car to ONLY have liability on it...
  124. Transmission question
  125. B4 platform (90Q)
  126. Beware of User Typ44...(Long)
  127. where can i get carbon hood for my b4?
  128. In need of an inner door handle
  129. Removing Tie Rod.
  130. Does this sound like an ignition switch issue?
  131. I've seen this mentioned before. Green "goop" on oil cap and in intake manifold.
  132. EGR valve pipe flarenut removal & reinstallation
  133. Door buzzer? After putting dash back in, no more. Is it a relay buzzer? ...
  134. Suspension squeeks, front end
  135. fender mounts for S2/RS2 bumper installation
  136. A Ginster Yellow Cabbie?
  137. My battery keeps dying overnight?
  138. does anyone have any write up or info on monting an rs2 look alike front bumper?
  139. ride height issues
  140. Fuel Leak???
  141. Sunday pic. (cell phone pic)
  142. I miss the 20v...
  143. coupe drama-long
  144. Steering wheel off center - anyone know why? More inside...
  145. 89-90 CQ PS pump? My mech tried to put a 90 90 20V pump into my CQ and it did not fit? Could my
  146. whoopie!
  147. 1st in class and 1st overall...out of 45 cars. I'm so proud of my little Q!
  148. would it be realistical to try to change my clutch in my driveway at home?
  149. Looking for a used set of 12v v6 coilpacks, anyone?
  150. High Hydrocarbons at idle
  151. hrm... cheap cab that could be an easy project
  152. weird question: i installed my momo steering wheel today and had a strange thing occur
  153. any1 know where i can get sway bar link bushings for an 88 90Q
  154. guys with the 034 20v injector kit... longterm impressions? Fuel economy? Emissions? Power?
  155. Anybody have a good B4 hood grill? Somebody hit my CQ in a parking lot.
  156. Sup Guys, my CQ is for sale...
  157. VAP...YGM ..word attatchment
  158. Car's ready; cooler loaded; slight hangover...time to fling the 80Q rally car around this weekend!!
  159. Want to replace end links...
  160. I have heat! Just in time for summer, eh? 1 question
  161. Stock >> stock 4 spoke steering wheel swap 1991 CQ airbag wheel
  162. Stock ride height measurement?
  163. lookin for a cheap TPS. anyone know if one off a 1990 cq would fit my 1990 90 2.3l 5cyl fwd? thanks
  164. update on cooling issue
  165. Aaaaaah, the Ring in the Autumn and an S2 to fling about!
  166. CPS plug readings?
  167. Wanted to throw up yesterday...
  168. Ignition Switch and Window Switches on 1995 90S
  169. Remember! Carlisle is this weekend.
  170. B3 15 inch tire recommendations?
  171. Shaved Handles on a coupe...does anyone have pics?...
  172. windows on assenger side wont open.94 b4 90cs
  173. front stabilizer bar for an 88 90Q
  174. CQ running hot...
  175. Anyone know if power seats from a '90 coupe swap into an '85 Coupe w/ Power seats
  176. need help adjusting passenger side window on a coupe
  177. Looking for delrin sway bar and sway bar link bushings.
  178. Power steering pump.. loud whirring sound.. going bad?
  179. need help with 1990 audi 90q 20v front rotors!!
  180. drop???
  181. i need an igntion wiring diagram for the ignition system for my 95 90Q 2.8
  182. Modded S2 rear bumper....Hmmm, not to my taste, but who am I too say.
  183. Anyone know a source for custom hub welding / drilling? (5 lug conversion info...)
  184. Cam postition sensor?
  185. Throttle response, or lack of
  186. "heater box" clips from AW Tech walk through - questions
  187. 97 cab with key stuck...
  188. One question before I ask my question.,
  189. Wish I was in the market for some RS2 Style Rims...
  190. Short or bad relay? Started the car and climate / blinkers / CEL panel all dead..
  191. Anyone need an early 7A ECU for the 034 chip swap?
  192. help!!!!!!!!!!!!!!!!!
  193. So it begins...The post fire rebuild in the CQ
  194. IGNITION HELP
  195. Ok, I give up. Who's got the pic of the "Dome Light Fix"? Or a link to the writeup?
  196. Stuck drivers rear Upright bushing Bolt.
  197. Initial 034 12v chipsets, details inside:
  198. How do i know if i have bad thermostat or bad fan switch on 90 V6
  199. <flame suit on> Has anyone put a B5 tiptronic behind a 20v in a 90?
  200. Footwell lites..think I'd like to do this mod. Don't know whether to just have them come on...
  201. stuck thermostat?
  202. So I never ened up buying that 90q 20v...
  203. Who here are baby boomers and/or empty nesters?
  204. I wonder how old this pic is?
  205. would fan switch with 75/84 C work on 1995 90?
  206. S2 bumper for sale on ebay.co.uk,
  207. Trying to verify a part# but KATE doesn't show a reference and the search comes up nil..
  208. Anyone know the part number for these?
  209. Did 90s ever come to North Am with no gauge cluster, manual HVAC and no HL washers?
  210. 88 Audi 90 Quattro For Sale - Philadelphia Area
  211. Who's adjusted the door glass in their CQ's? My passenger side window...
  212. New Domestic In-line five with Euro tweaks to watch for...
  213. Anyone got a B4 retractable antenna assembly (complete) for me?
  214. I know its been a while...So who here is in the Seattle area?
  215. B3 suspension, can't get slotted nut out (and other questions)
  216. where is coolant drain on block of 1995 90 FWD auto ?
  217. 20 V Cams
  218. just picked up a momo steering wheel, however, i cannot find the hub for my exact model and year
  219. WRECKING YARDS.. seattle
  220. S2 Body Part Help
  221. evry so often when I accellerate hard, I hear a rapid metallic "clicking" sound......
  222. I just finished her
  223. New to 20v, two temp sensors, what to both of them do?
  224. Squeeking problem
  225. Anybody have a spare Crank position sensor for sale?
  226. has anyone here installed a carbon fiber trim kit? i see them on ebay.de. they say money cant buy
  227. The 5th annual Audis at Carlisle gathering is next weekend!!
  228. if anyone is looking for a 4.2 project motor check out my post on the 4.2 forum
  229. 15" or 16" 4x108 Steel wheels (supplier?)
  230. And Murderdyne continues to scam! Ex-employee has a myspace site to bitch!
  231. Wheel Bearings. (for those that did the "cost-efficient" 5-lug swap)
  232. Fuel Lines
  233. A warning to CQ owners for a possible rust problem on the galvanized bodies of these cars....
  234. Koni Improved
  235. this car is mocking me. Please, someone purchase this car
  236. Looking at a 90Q 20v.. should I buy? (long..)
  237. cabrio
  238. is Nathan White still around here!? i ordered 2W bulbs with red covers from his site and
  239. do i need special tool 3247 to drain coolant or just pull out lower hose on radiator?This is 1995 90
  240. I know this isthe wrong place but...
  241. The Champagne "One Lap" B5/S4 is now (Update) 3rd in class after missing one entire track event....
  242. parts available 4 1989 90 qc
  243. Maybe the best high-performance, lifetime warranty "non-coilover" suspension anywhere...
  244. WWAW8090D?
  245. Pollen filter assembly...
  246. Found this "old school" ABT decal kit, woohoo!
  247. new 90 quatrro coupe owner
  248. BMW classifieds?
  249. crank with no start
  250. 2.3 20 valve injectors
