- Anyone selling an instrument cluster or odometer parts?
- I'm not sure if you guys have seen this yet but...
- searching for a panel assembly from/with a power window master switch (drivers side)
- 1988 audi 90 fan always running when the ignition is turned to acc or the car is running
- if i pull the head, does the head gasket absolutely HAVE TO be replaced?
- thermoswitch location on 88 audi 90 5 cylinder 2.3
- Miktip - you used the nightshades stuff on your tails - right?
- Bentley for 20V Audis shows the proper way to remove...
- On the ever popular O2 sensors... MikTip?
- Vibration when downshifting?
- Pictures from the 3rd AudiCommunity meet!
- CQ, Steel moon roof - to - Glass sun roof swap, Been done before?
- I remember way back in the posts that there was a (russian?) site with exploded views of...
- What do yo guys think about this short throw?
- A/C compressor
- Draining Coolant
- What's going on here?
- More pix from April 26th Audi meet.
- Got this gauge cluster from an 1990 Audi 90
- 93 Audi 90CS: 14 pics!
- Is there a Standard equivilent to a 4mm wrench?
- DC/MD/VA: Capital Audi Caravan to the UMD Car Show this Saturday.
- anyone in the GTA still looking for a 1990 90q20V?
- R134 a retrofit?
- Pls Help - how to remove ignition for 93 Audi 90
- iskolnick, can you do me a favor?
- Can somebody post some pictures of CQ in these color?
- Hose kits available for the 1990 CQ's?
- How many lbs per square inch does it take to pop....
- Cheapest source for Pestosin?
- Where is the low pressure port to refill A/C freon?
- I need a Cat
- i figured out what my leak is, it must be...
- Back to the alt. belt, and posible culprit
- The dead horse could use another kick...Timing belt related, crank pulley...
- Air Con Leak Inside car
- Prospective Buyer. Help!!!
- Where can I get an AC Hose cheap from the Condensor to the Reciever/Dryer? Shoken is out of them
- april 26th AUDIMEETUP video
- Audi 1993 90s - OIL LIGHT COMES ON when RPM shoot past 2200 - NEED HELP
- New question, where can i get rocker pannels for my car, like the ones here (open)
- pic of my car, looks pretty bad, its an old pic, i fixed all the rust now
- Replaced crank bearings...
- cv boot
- Strange cars kept parking next to me today...
- could someone tell me where the ISV....
- Who's car is this, 2Bennett's?
- new suspension /head swap question
- I tried a G-Tech on my 90. Here's the results...
- Will I be able to...
- Something is wrong here.....(bored at work)
- sprechen zie 20v turbomotor?
- Roll it over...
- AUDI FANS DO NOT COME ON
- Water coming in along windshield
- Let's see who's got the coolest Audi poster?
- Spark Plug Wires on '98 Cabriolet ...
- sounds like tire noise, but could be wheel bearing?
- Passenger side motormount!
- New owner of a 200tq 20v!!!!
- is the engine from an 80 quattri the same as a 5000s
- Morning, anybody knows about just Daves 12v emblems?
- Need help Steering Issue
- looking for clear corners and tail light lenses?
- 1991 Audi coupe for sale-should i get it?
- All of you with 5 lugs...grab it now!!
- Dash switch lights working intermittently
- 111 RSVP'd for SoCal GTG May 17th
- Question for all you with mods.....
- has anyone ever tried to put a 1.8t into a 90?
- Is $50 to much to ask for a completely working instrument cluster.....
- abs off light on why?
- Anyone have any interest in a GP for the OEM 3-spoke Sport Steering wheel in my sig?
- does any one know where i can get a passenger side fog light for a 88 90 quattro
- I think my car got a little jealous of me working on someone elses car.
- Mik, need your help!
- My new RS2 eye's
- Alternator belt and Ac Belt
- Location of blower resistor...? Any picture...?
- What size converter to get???
- Thinking of changing stock Airbox to Cold Air Intake on 88' 90?
- Dilemma...
- Radio Install Question. '90 90 FWD
- I've got 2 bent rims!!!! Yayyyyyyy! (Special Ed voice)
- What engine mods are available for a 1988 80Q?
- As the mornings get warmer and warmer up here in NE, my exhaust smell worse the warmer...
- New Audi Magazine...
- 1991 80q - radiator plastic repair?
- Cone filter....Cuzzzzz
- After $3200 i got it
- Iskolnick, someone bit your style!
- Help...pls...!!!
- mo mo wheel...why?
- here's your chance:))...Catco cats...dirt cheap!
- What a nice day for gravel and tarmac twisties...
- Squeaky Back Window in Coupe Quattro
- COupe quat smoked tail's and chin spoiler?
- Removed tint now what how to attack the glue??
- Where can I get the MAF->airbox gasket?
- Q=for miktip
- Any ideas on what is the best place to get RS2 bumper and as compleat as Nicks???
- does anyone have the Ross-Tech.com software? how is it? user friendly? anyone selling theres?
- evilaudi who makes the front bumper you have? and where did you get it?
- How many liters of oil do I put in the rear differential in a 90 1989 20vQ
- please help - How to remove coolant pipe???
- Poll: How many email messages would MikTip get per day if he posted his email address?
- where does everyone temp gauge usually settle: at the middle? or slightly over?
- !!!!!!!!! MikTip !!!!!!
- Installing some front 4" speakers in the dash...
- Two alt. belts and only 120 kms showing on the odometer....
- '91 CQ (NG 10v na CIS-EIII) having problems pulling engine codes. This is a euro RHD car:
- OT in Real Life...
- Anyone in Vancity or CAN have a good line on clear corners???
- i jus noticed how much i need a paint job tonite...
- how long it takes to replace transmision on 89' 90 5cyl non-quattro? auto->man swap possible?
- Clarion db235 or Blaupunkt Tampa Bay HU????
- Both screens on my climate control don't ligt up any suggestions?
- I have been running...
- Check out my new rims :)
- Continuing with Mods to Coupe Quattro..... ;) I do have a question though..
- MikTip, what's you thinking on this?
- coupe timing belt question
- Parts for rear drum conversion
- I found a little sumthin sumthin to replace the 90...
- Starter problems?
- Help needed! Intermittent stalling
- Mmmmmm... West German Quality
- Why does ETKA hurt my eyes so much?
- 93 AUDI 90 CS: replaced vacum lines...now dealer says replace EGR valve. Anyone have this problem?
- Driver got rear ended?
- AC Evaporator P/N
- Buying a 20v 200tq......
- what else beside the timing belt
- odometer
- Merchant's can balance a tire better than any other place!
- Rice wannabe!
- 9490s01913, how much is the bumper repair gonna cost u?
- Install me, please...
- '91 CQ - NG engine. Clutch required. What else should I be replacing while I'm in there?
- Am I the only one here that doesn't have clear corners?
- Anybody know how many CQ's are still around in the country?
- Erebuni Body Kit
- How to enter lockout code on radio?
- x post steel to alloy replacement
- Shout out your ride, what u got?
- Would spasers on my rear wheels radus over-steering (audi coupe ,150hp, fwd)?
- Anyone have a spare instrument cluster around??
- Coolant level dropping....
- Well i should have my car running tomorrow.....
- A/C Hose needed (metal one under battery). Question on likelihood of bad compressor as sys open 3yr
- BMW guy, might convert to Audi Cabriolet, Questions
- My christmas present update...
- Vogtland Springs, FYI ;O)
- Stalling 1990 80Q
- Somebody in Kelowna driving a pearl '93 90 with for sale sign $17,000 ?
- 88 90q fuel pump question
- Noisy When Wet?
- Any good shop for parts in Amsterdam?
- OH NO!
- pic of irish 20v
- 1 new tire
- 93-94 Audi 90 question...(answers for any and all much appreciated)
- Are these 16" or 17" rims? Couldn't tell...
- Iskolnick, just found something on ebay that I thought you might want for you S4..
- Is the diff switch from 100Q/UrS4 same as 90Q?
- anyone have diagram of 20V distributor cap( with wires going to proper positions on cap)?? TIA
- That mullet post inspired me... mmmmmmmmmm..... a real RS2 (BWW)
- performance 88 90
- Why is this car so awesome? It needs a mullet alarm though..
- Somebody asked about door locks some time ago. I just stumbled across this. Hope it helps.
- help! installing new valve cover gasket on 80q
- Need a solution- to... *(little long)
- can someone help me? (ot)
- Need help - blowing #17 fuse on my CQ
- Where to buy a rear diff switch for a 95, 90 QS?
- audi 90 temp sensor
- Tranny Fluid
- My christmas in April...
- How many of you guys have put in a left side foot rest in your rides?
- Well cars back with schrick 260 cams..
- Want to do a tune-up on '98 Cabriolet
- CQ lower door trim......I know, its been beaten to death...but questions remain...
- my new project any advice
- audi 90 5 speed 1988 limp hose
- Wheel bolt change?
- Gifts from heaven (AKA Clairparts) :)
- Help guys.. no spark after schrick cam install
- 1988 audi 90 temp sensor wire diagram help!!!!!!!!!
- audi 90 1988 5 banger will not start pleasde help
- Just bought a 1994 90 CS needs struts/upper mounts HELP!
- What a sexy bish!
- I love this engine bay...
- Clearing Climate Control Codes...
- Just pulled my codes...
- What bumper is this? (May be a stupid question)
- 20v motor, with v6 radiator...
- Will VW dealer have rubber muffler hangers?
- Would this rims fit!???
- Engine is pulled....
- Quick Bilstein suspension question...
- LOL! WTF is this?
- Hey! Xel is trying to scam me! ;)
- Coilovers
- Go to this or BakerCoupe will cry...
- present from fedex...
- All you with RS2 lights, bumper, fogs, indicators, Can you post pictures?
- Cross-drilled Rotors & Pads: is this as cheap as they come???
- How do the mirrors come of on B3 Models???
- Buying 90 CQ apox. 206,000, well taken care of, IMO (A tad Long)
- Do you have everything for your Audi, I think not......
- New Parts Classifieds for 20valve folk
- Going to look at a 1990 80 today... anything to watch out for?
- Xmas in April!!!
- correct me if im wrong...
- Steering groan...suspect damper?...
- Lower me, please...
- 20v rotor arm replacement (I've 'search'ed already)
- AUDI 90 Fan Switch Help?
- Climate Control - Outside Temp Acting Up
- Reverse lights on working - where to check first?
- tire width issues
- Horn contact lube?
- To anyone who bought an S2 or an aftermarket bumper....
- Picture of my European 90
- The Unfair Advantage on espn..................
- Any body see this......
- Cheap!
- Audi Swap
- Question for those with Bilstein/ H&R setup...
- Speed question... Type 89 vs. B4
- Finally Passed the Emissions Test
- WANTED: B4 Audi 90 in GTA. Anyone selling?
- What a mess
- Who's the moderator for this forum? Can you email me?
- I searched and couldn't find it so... what bulbs go in the foglights on the 93 Audi 90S?
- Anyone here?
- suspension and aftermarket parts for 93' 90 s...
- Bearing clearances
- I have seen pictures of a silver CQ with an RS2 conersion
- CQ windshield replacement?
- to those running bilsteins on their CQ's...
- group buy on S2 front bumpers anyone?
- Need engineering help - how to calculate EGT given displacement, RPM, and F/A ratio ?
- Haha, here's your chance!!
- How to find Engine Code?
- windshield washer squirter problem
- Vaccum hose question...
- hallo, Any one here with t.s.r's "Brands Hatch" engine?
- Can't find the right tool!!!
- Does anybody know if 2.8 12V's in Europe had different ecu than we do here?
