PDA
View Full Version : Audi 90 / 80 / Coupe quattro / Cabriolet
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259
  1. 95' 90 Quattro Rear view mirror came off?
  2. 2 new front balljoint for 90 csq for sale up to offers
  3. TWO 1990 Audi Coupe Quattro's - E-Bay Auction with NO RESERVE
  4. 20v Intake mods: Is it worth it?
  5. 1990 90 (B3 A7) Fuel pressure regulator very hard to find...
  6. 1990 90 (B3 A7) Fuel pressure regulator very hard to find...
  7. Need your opinions Cabriolet owners
  8. 88 model 90 FWD 5cylinder NG engine
  9. New ecm, still have check engine light
  10. 1990 audi 90 Q 20V fuel smell inside car
  11. Looking for TPS/90q Hitachi
  12. 1990 CQ won't start - help me troubleshoot
  13. Floor mats wanted for 90 Coupe Quattro
  14. help ! audi 90 2,8 - cam seals
  15. Power seat problems
  16. 1996 cabriolet replacement
  17. [Help] CEB Tranny (auto) shift pattern/hard shifting
  18. 93' 90 CS headlights
  19. Changing front struts on B4 cabrio
  20. Audi 90 and Audi A4 rear upper control arms
  21. Ok fellows, I have a strange(very strange) problem today when I open my Trunk!!
  22. Audi 90 Electrical problems!
  23. anyone got a front DS "bowden cable" ?? (cable from inner handle to lock)
  24. Front Brake Caliper type? 95 90QS
  25. 1994 Audi 90 - Heater Fan Not Working
  26. Hubturn? need info about my factory B4 Antenna?
  27. cant find a windshield!
  28. Exhaust Manifold Studs, Cat side
  29. 1995 90 Quatro parting out or for sale
  30. 95 Cab imploding
  31. roof problem ?????
  32. 1971 Audi 100 (112) Newbie ride
  33. CQ rear strut insert R&R question
  34. Sold The CQ have some Unobtanium Left
  35. Buying a 1991 20V 90Q, what should I look for?
  36. Source for OEM parts
  37. 95 Code Locations
  38. 95 Cabriolet Gas fumes problem
  39. 90 CQ Idle seems very low when starting?
  40. Which to replace: Cabrio Top or Just Window?
  41. last chance rear tailights off 90 2,8 v6 Q CS 94
  42. 91 cq US
  43. Help Manual Transmission Leak 1995 Audi 90 Q
  44. Need alternator for '88 80 quattro
  45. New CQ Radiator Fan not made in China
  46. cant communicate with interface vag now? reveresed the black connector
  47. Trying to diagnose a '93 Audi 90 Quattro; clutch, or transfer case, or something else
  48. B4 washer tank in a CQ
  49. new here guys and i wanted to show you my ride
  50. Q's about my new 1995 90Q - trunk switch?
  51. '96 2.8L Cabrio - Sluggish, Misfiring - Coil Replacement
  52. added 3 quarts of oil at 1,224 milesafter first oil change ?
  53. 80 b4 2.0 manual trans
  54. New CQ owner, a few questions
  55. 2.8 12 v Engine question
  56. Let us see your Audi.
  57. '91 CQ Radiator Fan Connector/Wiring
  58. 1997 Cabriolet
  59. Fuel Pump Relay
  60. Well guys I think my 93 90cs is kaputt
  61. 1993 90 CS
  62. Bilstein absorbers question on a B4 Cabrio
  63. '95 90q Upper Oil Gasket and Subframe questions
  64. Another quick question regarding the ignition switch on my 95 90qs since I owned it.
  65. Well, I finally hooked up my VAG Software to my 95 Qs After it triggered cel light.
  66. Selling my 1993 90 quattro
  67. 2.8 v6 coupe quattro
  68. Central Locking working pressure
  69. I need help with a Part Number that Hubturn mention?
  70. Whats the Best Online Oem Audi parts dealer for prices?
  71. Audi 90 20V
  72. Alignment Specifications for '95 90Q Sport
  73. Whats it called?
  74. Radio keeps cutting out. Plz help
  75. CQ radiator fan
  76. Rear brakes doing most of the braking...
  77. How can I tell if my alternator needs to be replaced?
  78. audi 90 died
  79. 94-98 Cabriolet Power Top Motor
  80. Lago Blue.... I need info on the spring "isolators" you made
  81. Audi Cabriolet idle question
  82. Happy and Safe Thanksgiving from one B4 to Another B4
  83. :: ECS Tuning :: 7th Annual Sale And Holiday Giveway!!!
  84. 1994 cabriolet central locking
  85. 2007 A4 Convertible Roof problem, part 2
  86. need trunk lights for 1988 audi 90
  87. Audi Cabrio..check engine light..what do i do?
  88. Audi CQ 20v distributor rotor removal
  89. 1988 audi 90 Q clutch opinion.
  90. audi 90 won't start
  91. Mystery: engine dying 1991 90 I5
  92. 2.3 cabrio cambelt change
  93. 1990 CQ Rear Speaker/Factory Amp Wiring Troubles
  94. Remote locks
  95. Clutch "sticking"
  96. 20v Heater Valve
  97. 20v Heater Valve
  98. anyone need parts from a '93 90?
  99. Audi 80 B4 1.9 TDI 1993 engine&body parts
  100. Quattro exhaust on non-quattro
  101. Engine management system failure lamp on
  102. Selling Radio and Speakers
  103. Oil leak from passenger side valve cover- cam seal?
  104. Bumper (with fogs) for 94 Q?
  105. audi value
  106. RPMs jumping up and down
  107. 92 A80 quattro A/C and alternator belts broke
  108. Fuel leaking under pressure... HELP!
  109. Oil Pressure warning light in dash..what sensor?
  110. pulling the climate control panel
  111. Wheels for 1990 COUPE QUATTRO-HELP
  112. 1995 90 V6 AT/FWD dies after warm-up????????
  113. Another water pump gone bad!!!!!!
  114. Will standard 80 coil springs fit my cabrio!?
  115. Hardtop fitting
  116. Bleeding brakes on V6 90 sedan...
  117. Heat and ventilation questions
  118. B4 95 90 sedan w/AT....Reverse Lights on all the time..
  119. 1993 90CS Q ventilation problem
  120. Rear Diff Seal Removal Help
  121. After changing the Brake fluid on my 95 90 sedan with AT...
  122. Audi Cabriolet
  123. Help! I need instructions on removing radiator
  124. Need some Climatronic bypass help!
  125. Power Window Failure? 95' 90S
  126. FS: rear hella taillights!
  127. Ok I'm getting confusing info on the Automatic Transmissions of 90's.
  128. How do I pull my ECU?
  129. Any body got a bumper?
  130. I just spent around 600.00 in parts B4 , gaskets?
  131. Brake BT: Best way to drain Brake fluid from Reservoir?
  132. 1988 audi 90 water pump help.
  133. Audi 80 Cabriolet - very poorly
  134. How old was your B4 when purchased ??
  135. 2.8L gasket sets best price?
  136. FS: 1990 Audi Coupe Quattro 20V
  137. Vacuum leaks!! Need part numbers.
  138. Aftermarket Seat Brackets
  139. Reverse Lights on all the time...WHY??
  140. Dumb Electrical Issues Which Should Be Easy to Fix But Somehow Aren't (Fogs/Blinkers)
  141. 95 90QS Engine just about out!!!
  142. Picture friday?
  143. guess the bad electrical component
  144. Cabriolet Window Question
  145. Newbie with a 93 90 Quattro
  146. 1991 Audi 90 quattro 20V Electrical Problem
  147. Audi Coupe Quattro with s2 body and b3 swap for sale in marketplace.
  148. 1993 Audi 90s
  149. Removing Starter from 1995 90 V6 sedan....
  150. 90Q wont start
  151. 88 90 q Tie Rods
  152. 94 CQ 12v Valley pan bolts loose, gasket looks good.
  153. Radiator AUDI 80 A/C 1.6
  154. Did the 1995 90 sedans come with "Starter Relays"..
  155. Cq fuel mileage check
  156. Help on a 90
  157. How to pull fault codes?
  158. Audi 90s Computer
  159. Please Please someone help!
  160. Proof that Audis were wired by drunk squirrels
  161. '89 90Q car going to dump new parts
  162. The mother of B4 Audi electrical problems...
  163. Conv top operation
  164. Correct temperature gauge/sensor reading
  165. B4 rear glass?
  166. Anyone know of a parts yard with a Cabriolet?
  167. Proper temp for fans to turn on
  168. Audi Cabriolet - Remove Rear Side Window "Component Carrier"
  169. Car only starts in gear?
  170. Manually retract power hood 1999 cabrio!?!?
  171. 1995 Quattro Sport 90 AFC driver side Motor mount?
  172. No spark - No codes
  173. 1990 audi 80 fuel pump relay ????
  174. Fuel Injector Installation
  175. Question during the timing belt change.
  176. help needed...for window motors
  177. 1990 audi 80 non-quattro
  178. Transmission!! 95 quattro 90
  179. Audi Bose deck speakers+Amp in 1995 90?
  180. Weird VSS/check engine light issue
  181. My convertible top works on n off any ideas whats the issue or how to repair?
  182. Starter Question...
  183. Whats it all worth??
  184. Learning by failure - Stud threads
  185. no spark audi 80
  186. WTB: B4 Audi 90, 10-spoke wheels-need set
  187. Cruise control module for 1993 Audi 90 Quattro?
  188. FS: Engine Parts - 1995 AFC 12v V6
  189. B4 OEM Wheel offset: 10-spoke vs. Sport wheel
  190. What to do about bottom door moldings?
  191. Interior Constant 12V Source
  192. 1995 90 stereo wiring diagram
  193. Need a FRONT subframe for '95 Quattro
  194. back spaceing?
  195. 90 Audi Coupe Window
  196. Starting point for learning to work on it myself
  197. F/S:New Becker Mexico Retro 7948 Navigator & Pioneer AVIC-Z110BT!
  198. What are these connections under the dash?
  199. ignition wires
  200. Where do I go...
  201. 95 90 Sport sound system questions! bypass?
  202. Knock sensors
  203. Heads - basic stuff
  204. Misc. parts Audi 90
  205. Unobtainable Coupe/S2 parts for sale
  206. Adjusting windows and seals on Cabriolet
  207. 1994 Audi 90 LCD Clock and Transmission Display
  208. WTB B4 90 Left outer tail light assembly
  209. Head removal questions
  210. Dumb interior question
  211. Coupe Quattro Repair Manual
  212. 1994 audi cabriolet AC HELP!
  213. bunch of misc. for sale for engine and other
  214. Brake proportioner valve
  215. Front end vibration...again
  216. WTB: Dash center and vents for 93 90cs q
  217. Vac line routing after EGR delete
  218. Need diagnosis help
  219. Potential new 90 Quattro Owner.
  220. Aux gauges into 1993 90 that didn't have them
  221. Courious......
  222. Need help with rear brake calipers.
  223. Need help with rear brake calipers.
  224. Anyone doing a BBSE conversion and needs a set of these bad boys?
  225. Windshield trim - is this a problem?
  226. audi 80 ABT 8v engine HELP PLEASE!!!!!
  227. New member from Illinois Audi 90
  228. 95 audi 90
  229. Hydraulic Valve Lifters, Checking
  230. Bad Fuse box
  231. B3 door trim panel removal?
  232. Oil leak that's not valve covers?
  233. 1995 90 QS
  234. Head Bolts
  235. 1994 90 CS - Two Different Keys
  236. 1995 90QS Info/Mods/Support
  237. 97 cabriolet running rough
  238. Diagnose airbag light on '90 80Q?
  239. 1990 Audi 90 Cold Start Valve issue
  240. Maually Lowering Cabriolet Top
  241. CQ won't move
  242. Trans Fluid and Coolant Gauge
  243. Boge turbo gas for '90 80Q rear?
  244. TRUNK LOCK VACUUM SOLENOID
  245. How do you remove the rear "door panel" in a cabriolet?
  246. Door lock mechanism shot
  247. Rear bumper reinforcement woes
  248. fuel injector insulator '89 90 quattro
  249. 1990 Audi CQ Running Rich
  250. 1989 2.2e coupe intermitant running
