- miktip - what happened to those white gauge faces...
- cone
- Ground Control
- B3 hood conversion (long)
- Anyone have a wiring diagram for a 93+ 90?
- 40mm Valves
- Few 90CS Questions
- Anyone use a Jamex air filter that replaces the bottom half of the airbox?
- Leaking oil...
- Miktip, just a question......
- Audi 80
- Replacement bulb for key?
- 90cs suspension question
- what does everybody think of the Power Chip for the audi 90??
- Hey Miktip, check it out!
- Looking to buy a 90-91 Coupe... Want to know about the hood conversion from a Audi 90
- For Sale: (1) my Audi & (2) never used Zimmermann rotors & Mintex Red Box pads (all 4 corners) PIC..
- Will a V6 from a 90 mate w/tranny in my 88 80q? Manual.
- Intercooler anyone?
- Green!
- Looks like that front spoiler on the Pink Cabrio may not be custom?
- Chip! Chip! Chip!
- New Audi 02 Lineup ....
- at what oil temp should i start to be worried...
- Suggested maintainance on a '89 80 2.0L?
- Can get a coupe with 265k kms for $1500..has been lined up for two years...any thoughts...
- I don't think this was production....
- 1993 90cs AEM intake?
- Switch the synthetic at 80k ?
- 90-91 Coupe... Is there a add on Turbo/Supercharger Kit???
- god damn it....something elso don't add up...i think
- Found an 87 5000 block...
- Pink?
- Silver?
- what is the button mext to the fuel gauge...looks like the one for resseting the trip...
- 1993 Audi 90 CS
- '94 90CS compressor problem (?)
- 94 90cs
- 5 cyl head replacement?
- '93 90s
- Hey guys did you see what happend to Alex van Gerbig's Audi 80?
- Where and how do you get these pictures, miktip?
- Audi meeting......German Style!
- Where they going with my 80?
- control panel lighting question A80
- AUDI 80 , CO emission is too high
- Replacing front wings on a 84 gt coupe
- Xpost from my question about older cars in A4 forum...
- how to remove side mirrors...
- AC leaks on floor
- Loss of power when engine is hot.
- Another Engine Light
- Parts car: Audi 90 20v Quattro
- Engine Oil & Air Filter...
- Power for my 5cyl 10v
- NE Event Update - Audi Cruise Direction
- checking and fillng up the oil..
- Musty smelling A/C - manual type
- '88 audi 90 engine light flickers - but no computer code stored
- A few Audi 90 questions
- Lifters?
- Club VAC NEEDS YOUR HELP!!!
- Clunking and Humming and shaking, Oh my!
- Why do I get about 250 miles from my first 1/2 tank of gas, and only about 150 from the second half?
- are valve guide seals the same thing as valve stem seals?
- waterpump, timing belt question?
- 90CS exhaust
- Audi 5cyl blocks. All the same?
- Audi belts
- Blue Smoke?
- Car Runs Better with Octane Boost. Any Detrimental Effects?
- Housing for right front fog light on 1990 90 quattro20V sedan needed
- Audi Window Decals
- What size are the rear component speakers in a '95 90Q?
- What is that hole in the cat? Where is my vacuum leak? 1990 80
- leaking water by gas pedal...
- Question about replacing my cats and my O2 sensors on my 90CS...
- More AC problems (vent not working), please help...
- HELP! Quick question on rear brakes on CoupeQ
- stop buying new oil.....
- instrument cluster lighting question
- A/C Woes...
- Help!
- Thoughts on new suspension...
- Do 4 stud to 5 stud adapters exist? . . .
- exhaust
- Does anybody know if...
- Gains from a Ported Intake Manifold?
- .....sorry, forgot the link.....
- Up and running again with my new fuel pump.
- Radiator fan question....
- I like this coupe.. =)
- I just saw this over on the classifieds, makes me wonder where i've been the past 104K miles........
- Best place to get touch-up paint?
- any coupe quattro owners/enthusiasts in the winnipeg area?
- all thats involved in the timing belt removal
- What is the factory Offset of the OEM wheels on the 90?
- Update on VAG-Tool Database and AudiWorld Companion
- how do front strut cartridges attach to strut?
- fuel pump
- Fan only works on 2 highest speeds; switch? resistor?
- The ultimate measure of American business(off topic)
- AC problem in the 90 degree Iowa weather!
- another oxy question
- Sound in the engine.
- New Ronal R-38 wheel
- Ethanol VS Premium gasoline
- I-5 fuel mileage
- The first nice picture of my car...
- hey miktip... regarding 12v changing to a 30v.....
- Will A4 muffler fit a 90?
- fuel millage has droped..aproxx price of oxxy sens.
- Help needed from Audi Coupe 89-92 fans, please!
- 011 emblem info. Coming down to the wire.
- The best part of the Mt Washington Hillclimb...
- changing 12v head to a 30v head??????
- kevster - Blaupunkt installation - pics & notes
- Is it difficult to replace the pads/rotors in the rear of a 94' 90CS? by hand.......
- Synthetic Vs Petroleum based oils in my '93 90 s
- Zimmermans
- Gas Smell?!?!
- Did the 90's ever have plastic headlight lenses...
- audimarc, some reading for your pleasure -
- I put in those front speakers on my B4 90...
- The paint is on. The wrecked audi 80 is back. (long)
- Seems "audimarc" has a problem with me..............
- question please
- Climate Control Fan Display
- Heres a story for you all...
- Thanks for all your help Mik, VT-Cat
- Not related to this forum, but is this the HOTTTest...
- A/C RELAY - BURNED
- Decent/affordable auto body shop??
- Funny thing about this forum! One very rarely ever hears back from those whom have asked?
- Surging
- a funny thing happened...
- Susp. Ideas '93 90CS
- Miktip follow up Que.
- Fuel system advice please.
- I just figured out what the little"NT" icon is. No text.
- Audi Coupe -> 90 Question...
- Coilovers installed
- orifice tube changed
- Go to enclosed link to see how many posts you've posted and where... (since tracking started)
- Does anyone know if the rear Wheel alignment is adjustable on a 92 100cs
- I know what I'm doing this weekend :D :D...
- Question(s) regarding Coupe...
- PLEASE HELP ME
- Brake pad screw stripped. Suggestions?
- Will using a heavier weight gear oil benefit a noisy rear diff?
- Maybe starter? Help! '93 90cs FWD
- Survey: Keyless Entry
- Any opinons on the Valentine 1 radar/laser detector? what do u guys have??
- For those interested in the 011 badge.
- One more thing...
- Would a short shifter from a 96 A4 fit the 93-95 90s?
- Anyone going to Mt. Washington Hillclimb this weekend?
- Off topic Radio Question...
- Contrary to popular rumors in Seattle, a new fuel pump is only $176.
- ECUs
- Does the Bentley manual have instructions......
- Does lltek sell anything for the B4 90????
- We are looking to plan an "Unofficial" AW convention - please come over and post your input!
- NorCal SpeedRing help. Trying to book a company event and no one will call us back, any help?
- removal of 90- CQ distributor
- Are any of you guys going to Waterfest? Also there is a parts car in england on ebay for $30for
- Anyone know where lltek is located? what country/state/whatever?
- Two front speaker questions...
- lumber support for electrical seat (driver)
- CRISIS IN CT!
- New Audi Owner
- Survey: What fuel grade do you use?
- Help!? Weird interior lighting issue
- Need Help!
- CQ in Boston area Friday night...anyone here? :)
- miktip,you ever have your engine dyno'd? This may have come up before and apologize if so.
- Keyless entry / factory alarm question...
- 25 Valve Audi Engine! Used in Talladega
- 2.8 30V!
- Das Autobahn!
- Audi Downloads! Video's!
- R8 Poster
- 4 Zylinder 1994 Audi 90 (80)
- German Cabrio-
- phat race against a GTI tonight
- Anyone know how to get hold of Erik Addy?
- cheap insurance?
- After A/C evaporator R/R, seat heaters don't work
- need advice on replacing several wear parts...
- Any difference from 90-91 quattro coupes?
- Anyone have a security camera?...
- Where can I find the Orifice tube?
- Over heating problem on 90S
- Where to find wooden shift knob for '95 90Q?
- Someone put out their cigarette on my white hood!
- Anyone tried these?
- Anyone Know where....
- Emblems undergoing final testing.
- Cabriolet Differences
- Front strut disassembly
- Any good mechanics near Summit County, Colorado?
- Caliper question... (please help me today, I'm placing an order!)
- Freak or Unique?
- Best/Fastest engine for an 80?
- help...help the V8 forum is down and i need help...
- Engine making strange noises
- V6 Cone filter Heat shield. Interesting-No MAF?
- Rattle from from what REALLY sounds like the cam chain...
- German 90!
- Anyone interested in one of these?
- Muffler
- How does one post a picture as a signature I can't seem to figure it out?
- Brake Dust Elimination!!!! HELP!
- Shocking Suprise with headlight replacements...
- need help for a 92 2.8 12valve.. Please have a look at this thread.
- who's coming to our cruise this saturday, 6/16?
- Creaky Steering...
- Power steering leaks
- Who would be interested in a bored out 93-95 90 V6 Throttlebody for $125?
- Need help from 90-91 Coupe Q, or Cabriolet owner(s)!
- Re-installed the cone filter-ahhhh . . . ..
- Just finshed washing the car...now wax questions...
- exhaust cracked.....
- FA on Ebay - 93 90 Black Leather seating - Anyone need?
- 12v V6 No Start (x-post)
- Das Motorad!
- Audi 90CS Black on Black in the Green!
- Wilwoods!
- My car disgraced me
- Colored Guage faces, preliminary photo-
- Anyone know this Audi?
- aurora ignition system
- Just thought I'd throw this out there for another power option.....
- Has anyone installed s/steel braided brake lines?
- Looking for a muffler...
- Does anyone have a ported intake manifold if so what are the gains? ...(more)
- This forum has been assimilated, resistence is futile. ;-)
- front/rear anti-sway bars...
- Clear corners for '95 90Q
- I just might be leaving these pages. My B4's place in the driveway could be taken by a WRX soon.
- Ok here is my car! This is an old pic, I don't have the fog lights anymore..
- Brakes
- Wiring remote starter and door control.
- Speedo and Tach reading........................
- Anyone know of any salvaged 93-95 90's? Me need a few parts!
- radio reception and cracking speakers...
- Antenna shaft replacement
- Colored guage faces for 90's!
- this is my Audi......What do u think?...Opionins please...
- My 90S
