- Coolant for 1995 Audi 80 (2.6 V6)
- 96 Cabriolet - Looking for Fog Lamps (Running Lights)
- Plugged CLS pump back in, now alarm won't turn off
- Using a new key remote for an Audi 90
- Splash pan: B3 1988-1992 80 / 90
- Driver's seat is loose
- 1994 Cab, Windows and Top not working
- V6 with manual transmission?
- B4 A/C recharge---yes you can!!
- weird slipping in drivetrain
- 054 133 551A Fuel Injectors
- 1991 Audi 90 Quattro 20V Idle/Power Loss
- Serpentine belt broke new belt now no start
- drivers door lock 1995/90
- my 93 has 147,000 miles on her
- will an mk3 jetta bumper fit an audi 90?
- Help front springs problem
- '96 Cabrio - Time for a new engine - sources?
- 1989 Audo 90 Quattro B3
- convertible control module
- Oil Pan
- 90 quattro gearing
- 94 Cabriolet - Starter
- 94 Cabriolet convertible top troubleshoot
- I also need a used right hand Passenger heated mirror / electric complete assembl?
- Curious Idle/stalling problem with 20v Coupe Quattro
- Ignition switch finally gave, luck i had 2 guys push the car while I poped the clutch
- 1994 Cabriolet
- 95 90Q
- HELP HELP HELP BRAKES
- Brake Light circuit short - blows fuse immediately - 1998 Cabriolet
- 12v 95 quattro
- 1990 90 Quattro window controls
- Audi ABK Intake
- 1997 audi cabriolet
- 95 audi 90 2.8 auto trans issue
- Forged front control arm upgrade
- NIB 90 20V Ate rotors for sale $90 shipped
- '93 90 Quattro Suspension
- carlisle
- 1995 90 exhaust question
- Pump for Cabriolet top
- 1989 audi coupe 2.2 e
- Tips for removing motor mount
- Low Heat on a 90-Coupe? Heater Core? Suggestions?
- ok. sorry guys. i posted this before. i am parting a '93 90cs non-quattro...
- instrument voltage regulator
- Cam seals leaking
- 1991 Audi 90 Quattro 20V Issues
- 92 A80q starter trouble
- 1991 Audi 90 2.3E fuel leak
- 1985 Coupe Belt moldings needed
- Audi Cabriolet Antenna.
- a/c low side fill ?
- 1995 Audi 90 Quattro Sport
- Oil in coolant but not coolant in oil on '88 Audi 80 4 cyl. auto. Suggestions?
- Valve Stem Oil Seals
- 1995 Audi 90 Q Fuel Cluster Guage always empty
- Cold start problem- 1989 Audi 90 Q
- Non-airbag 3 spoke sport wheel
- Anyone know of a good mount for iphone/ipod
- Propshaft rebuild
- Carbon fiber parts
- vacuum lines
- Remove ignition in '97 Cabrio
- 1995 90 wont crank
- Differences between 1989 and 1991 audi 90 quattro
- Head gasket question
- I Need Transmission Advice
- catback exhaust
- 1995Q Jacquard Satin Sport Interior-value?
- Where can i get one?
- a/c drains
- Fwd B4 rear suspension onto a B3
- bag with all relays
- brand new front ball joints R/L
- Anyone near the Portland area, check this out!
- 95 cabriolet- charging issue
- Does 1990 Coupe Fan Usually turn on where you can hear it after turning the car off?
- oil leak
- hard start, rough idle
- Audi 80/90 parts - ECU, window regulators, fuel distributor, etc
- Free: 88-92 Front Door Panels
- changing fuel filter
- what is up with fuse 13 ?
- Coilovers 94 audi 90cs
- need help with strut bushing or a pic
- 1995 Audi 90 Quattro Hesitation when warmed up, need advice
- Stock 195/60 or larger 195/65 for my B3 90?
- 1974 Audi 80 vs Porsche GT3 at Nurburgring
- cabriolet roof problem
- Knock Sensor Codes?
- Routing power wire from engine bay to cabin? 20v Coupe Quattro
- Can 90 Coupe without airbag be retrofitted with one after the fact?
- Donor fuel injectors
- Wheel bearing info
- New Member, New Car, Any Veterans want to chime in?
- Slow oil leak, from metal return line?
- Good price for Yakima bars?
- Looking at 90 Coupe with rust underneath?
- Fuel Tank over-pressured?
- Vacuum pump interchangeability
- Audi 90 Roof Rack?
- Saw a 90 at the auction this week (stopping in to say hi)...
- 90 Coupe Quattro Build Date 9/89 with airbags. Does that mean it has the 2nd sway bar
- Vacuum Pump testing
- Need Audi 90CS Parts Ecru Interior
- 1990 Audi 90 20v Quattro - MAF
- 93 audi 90 dash lights out, parking lights out, glove box lights out
- Bushings
- Starting Failure after replacing burned Fused box 97 Audi Cab
- [F62] Temp Sensor vs. [F76] Thermal Switch vs. [F54] Fan Control
- 90 overheating slightly
- PARTING: 94 audi cabriolet
- My baby
- Any leads on a 91 CQ for sale?
- Well, my 95 90QS is getting ready for 14" of Snow :)
- Speed Sensor
- Looking for a new front bumper?S2got wrecked
- 1995 Coupe Quattro 2.8E Gearbox
- First start after 5 years
- Where to find 80/90 exterior trim replacements?
- Fuel pump issues... i think
- Cabriolet does not crank
- Best struts for my '90 90q?
- 1995 Audi 90 Q Hood latch cable either broke or came undone at the latch??
- Plasma gages NIB $250 shipped
- No rust B4 front struts
- (FS) AUDI Bumper Moulding Trim Set
- 90 CQ idle stumble
- 1995 90 Quattro, Parts for sale.
- FS B3 and Coupe no rust subframe
- Lug bolts with NB stamped on the head
- cat light flashes and then stays on
- WTB: Climatronic heater box, EGR Temp Sensor, ABS Sensor
- ISV; who needs 'em?
- Won't start when engine runs: wipers, turn signals, heater, cooling-fan...
- Knock Sensor #2 '90 A7
- Coil Pack Resistance
- Does this motor have compression? Hard to tell...
- pictures
- 88 90 quattro..remove key and still giving power to accessories..help!
- 95' 90 Quattro Rear view mirror came off?
- 2 new front balljoint for 90 csq for sale up to offers
- TWO 1990 Audi Coupe Quattro's - E-Bay Auction with NO RESERVE
- 20v Intake mods: Is it worth it?
- 1990 90 (B3 A7) Fuel pressure regulator very hard to find...
- Need your opinions Cabriolet owners
- 88 model 90 FWD 5cylinder NG engine
- New ecm, still have check engine light
- 1990 audi 90 Q 20V fuel smell inside car
- Looking for TPS/90q Hitachi
- 1990 CQ won't start - help me troubleshoot
- Floor mats wanted for 90 Coupe Quattro
- help ! audi 90 2,8 - cam seals
- Power seat problems
- 1996 cabriolet replacement
- [Help] CEB Tranny (auto) shift pattern/hard shifting
- 93' 90 CS headlights
- Changing front struts on B4 cabrio
- Audi 90 and Audi A4 rear upper control arms
- Ok fellows, I have a strange(very strange) problem today when I open my Trunk!!
- Audi 90 Electrical problems!
- anyone got a front DS "bowden cable" ?? (cable from inner handle to lock)
- Front Brake Caliper type? 95 90QS
- 1994 Audi 90 - Heater Fan Not Working
- Hubturn? need info about my factory B4 Antenna?
- cant find a windshield!
- Exhaust Manifold Studs, Cat side
- 1995 90 Quatro parting out or for sale
- 95 Cab imploding
- roof problem ?????
- 1971 Audi 100 (112) Newbie ride
- CQ rear strut insert R&R question
- Sold The CQ have some Unobtanium Left
- Buying a 1991 20V 90Q, what should I look for?
- Source for OEM parts
- 95 Code Locations
- 95 Cabriolet Gas fumes problem
- 90 CQ Idle seems very low when starting?
- Which to replace: Cabrio Top or Just Window?
- last chance rear tailights off 90 2,8 v6 Q CS 94
- 91 cq US
- Help Manual Transmission Leak 1995 Audi 90 Q
- Need alternator for '88 80 quattro
- New CQ Radiator Fan not made in China
- cant communicate with interface vag now? reveresed the black connector
- Trying to diagnose a '93 Audi 90 Quattro; clutch, or transfer case, or something else
- B4 washer tank in a CQ
- new here guys and i wanted to show you my ride
- Q's about my new 1995 90Q - trunk switch?
- '96 2.8L Cabrio - Sluggish, Misfiring - Coil Replacement
- added 3 quarts of oil at 1,224 milesafter first oil change ?
- 80 b4 2.0 manual trans
- New CQ owner, a few questions
- 2.8 12 v Engine question
- Let us see your Audi.
- '91 CQ Radiator Fan Connector/Wiring
- 1997 Cabriolet
- Fuel Pump Relay
- Well guys I think my 93 90cs is kaputt
- 1993 90 CS
- Bilstein absorbers question on a B4 Cabrio
- '95 90q Upper Oil Gasket and Subframe questions
- Another quick question regarding the ignition switch on my 95 90qs since I owned it.
- Well, I finally hooked up my VAG Software to my 95 Qs After it triggered cel light.
- Selling my 1993 90 quattro
- 2.8 v6 coupe quattro
- Central Locking working pressure
- I need help with a Part Number that Hubturn mention?
- Whats the Best Online Oem Audi parts dealer for prices?
- Audi 90 20V
- Alignment Specifications for '95 90Q Sport
- Whats it called?
- Radio keeps cutting out. Plz help
- CQ radiator fan
- Rear brakes doing most of the braking...
- How can I tell if my alternator needs to be replaced?
- audi 90 died
- 94-98 Cabriolet Power Top Motor
- Lago Blue.... I need info on the spring "isolators" you made
- Audi Cabriolet idle question
- Happy and Safe Thanksgiving from one B4 to Another B4
- :: ECS Tuning :: 7th Annual Sale And Holiday Giveway!!!
- 1994 cabriolet central locking
- 2007 A4 Convertible Roof problem, part 2
- need trunk lights for 1988 audi 90
- Audi Cabrio..check engine light..what do i do?
- Audi CQ 20v distributor rotor removal
- 1988 audi 90 Q clutch opinion.
- audi 90 won't start
- Mystery: engine dying 1991 90 I5
- 2.3 cabrio cambelt change
- 1990 CQ Rear Speaker/Factory Amp Wiring Troubles
- Remote locks
- Clutch "sticking"
- 20v Heater Valve
- 20v Heater Valve
- anyone need parts from a '93 90?
- Audi 80 B4 1.9 TDI 1993 engine&body parts
- Quattro exhaust on non-quattro
- Engine management system failure lamp on
- Selling Radio and Speakers
- Oil leak from passenger side valve cover- cam seal?
- Bumper (with fogs) for 94 Q?
- audi value
- RPMs jumping up and down
- 92 A80 quattro A/C and alternator belts broke
- Fuel leaking under pressure... HELP!
