- Floor Mats(carpet) source?
- Just bought and 1988 Audi 90
- 94 Audi 90 CS Quattro (Sensor Question)
- Anyone need a set of 034 7A injectors?
- Audi 90 - No start troubleshooting
- 1996 Cabriolet help
- A4 B5 instrument cluster to 80 B4
- Audi 90 - No start sometimes
- master and slave cylinder going bad?
- ignition on the way out? PLEASE HELP!
- 1990 90 rough idle
- A90 1995 , turn signals are now hazards?
- battery drain positive connector identification
- Oregon audi 90 parts needed
- 1995 Audi 90 quattro sport suspension options
- Audi 90 Quattro 1990 2.3 170hp Exhaust.
- any aftermarket suspension?
- speedo issue
- Windows/Sunroof don't work in heat
- trans oil/speedo question
- First Audi 88 90 Quattro!
- 1993 Audi 80 B4
- 1996 Cab need front licence plate frame
- 1995 90 Steering lock assembly
- Central Lock Pump Buzzing
- Power Window Control Module
- 95 A90 Quattro suspension help
- Coupe TDI swap
- Audi 80 1.8S 1989: High idle and it throttles up at intervals.
- Is Faulty Cruise Control a Can of Worms
- New project car! 1988 Audi 90
- How do I remove front valance? 1994 90
- Exhaust spacer
- Crushed. FedEx truck rams my 1997 Cabriolet and ignobly ends its proud life.
- cabriolet hydraulic valves
- NEED: 90 quattro radiator
- Audi 80 monojet ignition problem need advice
- New owner: Audi 1994 Cabrio
- Coupe Q Coolant Level Indicator
- Coupe Q Tach Not Working
- New owner, '93 90 quattro few questions.
- now - is my ignition switch bad?
- No Spark, no 5v pulsed signal going to POS (ICM)
- CEL codes.... dont know how to clear/fix them
- Opening the 1994 Cabriolet Top Manually
- headlight and key buzzer dinger reminder thing
- New member, saying hi and asking for help...
- '90 90 quattro stalling/low power
- where to get tail light replacement 1990 90?
- 1993 Audi 90 FWD at the PAP in Atlanta East
- New owner of a Audi Cabriolet :)
- 91 CQ Airbag light stays on for several minutes?
- '96 Cab window adjustment
- Free to good home - Drivers side fender, 1996 Cabriolet, Green.
- Starting issues ...
- 94 Cab Rear Main Seal
- Clueless as to part and all that stuff...
- Need Help! 1994 Cabriolet body parts
- Coupe performance in snow versus newer A4?
- Transmission kit- indentification
- Low coolant. How bad is that?
- 88' no start
- Are auto & manual engines swappable?
- 1990 80 won't run after timing belt
- Just got a 94 cabriolet
- Potential New Owner - Any Advice?
- '90 90 quattro 20v issues
- 1994 Audi Cabriolet Convertible Problems
- 1991 Audi Coupe Quattro Instrument Panel Gauges are Dead
- Win or Support project for 2 doors Audi 1982!
- Parting out audi 90 1990 quattro 20v tornado red
- 95 audi 90 quattro center console
- IR key replacement audi 90
- audi 90 aah transmission problem
- Cabriolet ABS speed sensor in 1995 90 Quattro?
- New audi 90 cs sport owner in Utah
- 95 audi 90 gear oil
- Audi 90 quattro coupe no power to the distributor
- Allow me to introduce myself... -City$lik
- Put the key in and nothing
- Springs and Ride Height on B3 90
- Audi 90 quattro
- Audi Cabriolet at the PAP in Norcross Georgia
- Need new Headlights?
- Little bit of snow, lots of fun.
- Free NIB upper and lower oil pan gaskets and grungy fog lights
- how to connect Depo headlamp ass'ys to existing 1990/90 bulbs & wiring?
- 1990 90 10v - does the %$#@! rotor come off?? and other DIY notes...
- Parting out: 1990 audi 90 20v (7A)
- Valeo Clutch Kit?
- first audi, need info
- Electical Issues '94 80 Cab
- IOS: 12v engine
- Fuel pump voltage question
- Audi B3 80/90 Underbelly Pan Cover (sound deadener)
- 95 audi 90 parts/customizing
- Having problems with B4 dash removal
- Audi80 engine sound/tappet noise--> need opinions
- 96 cabrio auto trans identification
- Cabrio still overheats. Help please.
- Ross in Santa Rosa California (Where to Buy Factory Manual?)
- help heads not getting oil
- Carbiolet Lowering Kit
- Rear brake calipers and stuff FS
- 20v Not getting spark on all cylinders
- Failed Emission Test
- Climate control head unit removal
- Eng Block question 12v Cab
- ISO a driverside fender for my cq
- 1996 Cabrio: how to find engine type
- hey, any of you guys from Sacramento visited the Rocklin Pick-n-Pull?
- 90 Audi cq corner lights
- Climate Control Gremlin
- Looking for a Part #
- '95 90 Quattro rear left caliper replacement bolts?
- Head Gasket
- Heater control "valve" issue
- 90 CQ progress with a problem
- Shift lock solenoid clicking the automatic shifter Audi 90/Cabriolet
- NEED HELP IDENTIFYING PART NUM :))))
- Getting an old CQ back on the road
- WTB: Audi 90 B4 FWD parts
- Help! 94 Audi Cabriolet possible Timing belt issue
- would inside door handles from a '97 cabriolet fit on a '91 coupe?
- Delta radio aux options
- MODED 12V up for grabs
- Blink code 2121 question
- 15x7 speedline sl 423audi coupe.
- B3 Robert Bentley repair manual
- Brand new OE 097 transmission now $899
- iso aah oil pump
- 93 Audi fuel pump issues
- DEBRIS in your OIL ? ? ?
- 1994 cabriolet engine and convertible top issues
- S2 or rs2 front bumper for audi 90 20vt swap
- Audio 90 parts
- Steering Wheel Options
- Timing belt idler roller torque
- audi 90 quattro timing belt selection
- 95' 2.8 awd 90 150k smoking out of oil fill cap
- New to me 1995 90 Quattro exhaust help, how many cats?
- Hmm...eBay offerings...
- Looking for a windshield 90 coupe
- Rear Cabriolet window from France $155
- Just picked up a '94 Cabriolet with 73k miles
- Anyone help? Overheating issue.
- AC v belt installation??on what pulley?
- Need help!
- My Cabriolets - passion to own
- 96 Cabrio using some oil
- Someone please sell me on the prospect of owning an Audi 80 Cabrio
- Brake issue, need advice! Audi 80 B3
- Audi 90 Electrical Nightmares
- Audi 90 2.3 NG, KE3-jetronic issues
- 30.1MPG on my 225,000 90 Quattro 20V!
- CQ Project Blog
- Acceptable coolant and oil temperature range gauges on 5 cylinder cars?
- Audi coupe 1982 with lots of life in her
- Stopping By
- 96' Cabrio Repair Help
- Somoene buy these before I have to crush them!
- Is the brake system from a B4 the same as a B5?
- Front end intermittent grinding
- audi a80 no response from roof cover
- 7a Harmonic Balancer Bolts PN
- 93 90 2.8L blue smoke
- engine tick
- sway bar options for 1994-97 Cab
- Starter Bolt torque
- 1989 90Quattro 5 Speed For Sale
- Audi 80 2.0E 8V engine specs request
- Cabriolet Starter
- :: ECS Tuning :: Audi 80/90/100/200 5 Cylinder Ignition Wire Sets!
- Power Steering Problem 1995 V6 80
- 1990 Coupe Quattro Transmission Problems
- '93 90 2.8L expansion tank hose
- 91 Coupe for sale
- audi 90s 1994 issues
- B4 Starting Problems
- B4 stuff for sale
- B4 90 1.8t
- How about another 90 thread v. Rally
- Power Mods for the 90 2.8
- Anyone pull off the rubber door molding?
- 1994 Cab Radio
- AUDI coupe - Tuning
- what color are the...
- Ready, fire, AIM!
- New Member
- Need to sell a UR S6 Avant or a CQ? Torn between the 2?
- Starting an engine for the first time in 5 years
- All the magic smoke escaped!
- 1990 80 quattro
- Favorite/Preferred Replacement Part Manufacturers
- MOT Failure - need help
- 95' 90 Quattro rear wheel bearings
- flush (and clean) cooling system??
- vicious starter
- Aircon intermittent
- so I bought the '93 90 cs quattro that I traded for '00 a6 4.2l
- lowering b3 80q
- Vr6 engine swap
- White Foam under Oil Cap
- 90 20v
- WTB: 1991 Coupe Quattro Bentley Service Manual
- '90 90 quattro 20v (7A) stalling issue: Help please!
- Early 7A ('90 90 20v) Hall Sensor: Replacement?
- Wheel offset help needed on cabriolet.
- Big MAF question for pre-March '90 CQ
- Help ID this Vacuum Part
- replica rs2 OR 993 fog lights
- odometer help
- problems with AAH/AKH 12v V6 - Stage 1+
- Sport Suspension - Truth or Myth?
- 88 NG 90q driveablilty/timing 2 issues
- Back from lurking, need sum stuff...
- FWD snow performance
- Audi Convertible Tank
- Front Brakes - '95 Cab
- '91 Coupe Quattro Headliner Frame
- Valve cover gasket replacement 90Q (early 7A)- torque specs?
- can someone provide me with MAF transfer of ANY maf??
- Snow Pics!
- Picked up a Donor Car this weekend.
- 250k
- 1995 90 front Bumper
- camshaft "pulley" location??
- When was the last time you saw 5 90s all together?
- B4 cabriolet 2.6 won't start
- My New 90 is officially on the road
- Audi 90 CS Quattro No Start
- 1990 20V 90 fuel pump - Real Time alternatives?
- install crank trigger??
- Driver door panel removel
- how it works/how to read the Oil presure sender
- happy new years
- 1990 CQ shift linkage
- Anyone with a spare wheel?
- CQ fuse #4 short
- Installing dashboard in my 90, need help.
- Heater box refurbish...
- Transmission question
- fuel sending unit broken??
- got a set of 4x108 porsche wheels from a 914 that also fit 90s
- 1995 90 quattro stuck after engine install
- 1991 80 Quattro Electrical Disaster.
- Just i little show off... JHM solid throw shifter...
- 80' lights open when trunk is open. reverse lights dont work either..
- '93 90 quattro 2.8L quirks
- Headlights and cruise out.
