- cold start problems
- I have been trying to find some gas mileage info for my coupe...
- Rim Caps
- Aiming headlights
- stinky heater
- ATTN: MIKTIP
- Does anyone have an exploded front parts diagram, specifically the bumper and surround for a '93 90.
- Project completed
- my ignition switch ceased to function today. read on
- quattro system
- Slayer are you thinkin about an S4?
- Bad day for the 90.
- Mike tip had a question about cams
- Wanted: Performance Catalic Convertors (Dealer wants $559)
- V8 swap
- I saw a chip for the 12v on superchips!
- Car is stalling after TAP cone conversion!!! HELP!!!!
- my check engine light has been coming on! help!
- FOR SALE: 1995 90s Quattro 12v V6
- Clear side markers
- A/C Recycle button (lights up, does not work)
- Anyone want to buy a BMW 318i 1990 4-door £2200
- Dual Headlight ideas...
- Good deal?
- headlights bulbs....
- timing belts....when to change?
- 2.8 v6 question
- to brake poll
- Speaking of brakes....
- hey everybody, a question. (long)
- My car sounds like its a diesel!!!
- So I got this idea..................brakes.............good brakes.........
- Vibrations at 40mph and 80mph?
- dash speaks are 4", right?
- oddness...
- sway bar links
- Hey quick poll here...what rotors and pads are all of u guys running?
- E Brake? Where do you adjust it?
- Car failed emissions! Any ideas how to make it pass?
- Stereo Wiring Question: HELP!!!
- Quad round headlights.....wiring
- Bumper on 1988 90
- I'm confused! B3?? B4?? Did i miss something. Somebody explain! All i knew was A4 A6 A8 S4 etc.&TT
- Porsche RTurbo With 50 more hp then the GT2 this car makes me tingle all over!! :o}
- Steering column stalks
- Dual round Headlights. Where to get them?
- Coupe Q V8 Conversion....Yes
- My headlights are cracked
- Coupe quattro for Sale
- 88 audi 90. What buttons do you press so you can enter the code in the radio. (different then 92+)
- control arm bushings
- To make up for my defense of Honda's, check out this site . . .
- MikTip....
- Alen...
- 88 Audi 90 (non-quattro) Stock rims! Do they make them any bigger then 14"?
- MikTip, were you the one that has/had a Coupe GT with the Sport Quattro hood....
- Car Accident
- People only want to race when I'm with my g/f.....
- check this thing out
- In the process of replacing my lifters!!
- Miketip have a question?
- Something to check out...
- Final drive (gear) fluid replacement questions...
- 4000 Front Sway Bar on the rear of the CQ Question.
- Cleaned up the t-belt instructions. Made the page "Mo-betta"! :o)
- My baby got vandalized :(
- I found my new engine. It's a beauty. I fear at only 440kW it's a little underpowered though . . .
- V8 in my 90 quattro
- Axle question?
- Power steering fluid
- Anyone installed subwoofer...
- How hard is it for my '88 90 q to go out of alignment?
- $2100 just to do both frame rails in my 90! What do you guys think I should do? details...
- I am having a slight problem with my coolant temp gauge..
- Audi 90 - fuel pump
- About to replace my lifters....please help!!!
- headlight bulbs for 93-95 90
- Power Seats...
- Hey Slayer!....
- High pitch noise between 2-3000 RPM after cone install?!?!?
- check out this fun site...
- If you relocate the batery
- Can somebody tell me exactly what european headlights are?
- MikeTip how do you like your wires and could you tell and difference?
- 84 urq for sale in nj/ e-mail me for more inf
- Question? sounds stupid but if you were in my position you understand.
- Who want to turn off their "chime" in the dash of their 1993-95 90?
- A "real" supercharger!
- Anyone have custom(mandrel bent by a shop) exhausts?
- ANYONE KNOW A GOOD SOURCE FOR A FRONT BUMPER+ITS FIBERGLASS SURROUND FOR A '93, PREFERABLY RED?
- Vacuum leak in power steering
- 93 90S
- Audi A4 3.0 Quattro VS. Volvo S60 2.4T AWD
- Yet another vicotry! (Thanks to help on the forum)
- Steering/Alignment problems revisited (long)
- Quattro Club of America?
- I woke up this morning and I had a turbo!
- Q: Location of antenna amp and poor reception tip
- wiring diagram
- Pick-up coil
- What plugs and wires should I buy for my 12v and where?
- so I have an idea
- Tranny Fluid Change...
- Need help with wiring on factory gauge cluster
- Hy there, I'm new to this forum and I would apreciate your help...
- intake
- Cracked Headlights
- It was the damn temperature sensor! What is this?
- Radiator
- Clear Corners
- test drove a TT 225 roadster tonight
- rs2 not as hard as you think... reply to email
- I think when I get one of these in my driveway . . .
- front view- how much to fix wild guesses?
- crash pic
- Pic of my 93 quattro
- part of my euro grill
- Euro Grill
- anyone know where I can find the tool used to...
- A little fun in the snow...Not!
- Gauges
- For anyone looking for a good Audi garage.
- Miketip, Are you still selling white guage faces?
- Blower not working?!?!
- Did a little test of the Quattro II system. . .Not impressed.(long)
- sorry to keep at this but...
- FS: JE PISTON for 3B or AAN
- Coolingwaterwarninglight flashing
- Brake Caliper Problem on 90 20V...
- A thought...
- uuuhhh... i am in LOVE with the interior of the new a4 cabrio/coupe!!! any idea
- My AC/Heat doesn't work but my blower motor works just fine(it turns on to cool off the engine)But..
- Audios69 is that really your garage???
- Anyone know how to double check timing?
- Need help...bushings
- To Nice Ride....
- Anyone ever put a thule rack on a CQ??
- Swapping an Audi 80 2.0E dashboard for Audi 80 Quattro dashboard
- www.estrictlyforeign.com
- 12v scott are you going to sell you lltek intake?
- How much does it cost to install cams on a 12V
- A few easy questions...
- Upgrading
- pic of my garage
- Where can I get the adapter to flash read my codes??
- opinions wanted on cold starting advice I've gotten (long):
- MikTip, would you put the Nology wires on again if you had it to do over?
- How I spent Xmas Vacation....
- Doors won't lock!!
- holy sh!t you can buy it! from SGI
- Injectors?
- Get bent...
- installed now o2 sensors.. engine light still coming on
- i hate snow
- Hydraulic pump noise ' 91 CQ
- Donuts on Christmas morning...
- saw Lord of the Rings last night...awsome flick..i also saw a Audi 90 on the hwy.
- well jus talked to my mech. and the tranny will on the ground this afternoon.
- Has anyone here dynoed their car?
- K&N filter transition piece?
- A4 coupe??
- New to board
- Just found this....
- 14" of unplowed snow...what did you think I would do with my quattro and Nokian snow tires?
- Where can i get one of those eyebrows for my 88 audi 90?
- My antilock is off and my switch won't work. Anyway to bypass? BTW my instrument cluster is fried!!!
- LETS get this whole seidl and rs2 bumper thing corrected... (mik read)
- New Sig Test
- Who here has a euro plate? If yes what kind? I'm getting mine Jan. 15!!! Friend visited Romania!
- RS2 Bumper
- And honestly why does everyone ask Miktip vague questions...like other people cant anwser them?
- QuattroMotion
- How old is everyone here just curious....?
- Help- Intermitent temp gauge
- Hey MikTip- any plans to put equal legnth headers in your 90?
- Anybody know the actual curb weight of our cars?
- RS4 Front bumper
- Anybody know where to find an aftermarket blower motor for a 88 Audi 90 5cyl in the Atlanta Vicinity
- Der Neue Audi A4 Cabriolet
- 2.8L 30V
- Miktip when are you going start assembling and marketing exhaust ???
- Anyone know a good tinting place in northern NJ for my 95 90?
- Wheel bearings??
- Car having trouble starting cold. Once it does start i have to rev it up to get some juice flowing!
- chip
- replaced my fan motor, but i accidently popped a vacuum line off...
- where can i get the rear mount on the rear diff?
- A4 coupe
- another photoshop by me..
- MIKTIP...you have 93 audi 90cs???
- 1993 AUDI 90CS web pages?
- COUpe quattro with v8 and have anyone done business with...
- Carborated-4 cylinder-90!
- 4 month old stebro cat back exhaust system for sale. Paid 700, selling for 400.
- ABT's TT
- Monster Coupe!
- Poor Audi........
- Great news!...and now I'm stumped...help!
- ok ok ok...so I can't spell Detroit.
- Detriot autoshow anyone?
- 2bennett strut bar??
- Civic EX vs audi 90cs?
- MikTip, who installed your exhaust (probably should ask how did you install it :o)
- Brake Fluid leak on 90 20V... help?!
- Splash Guards
- Miktip!!! Can you show me how to take off my alternator for a 88 Audi 90? Thanks in Advance!!!
- part # for rear diff mount
- I can't start my audi. HELP. It was Ignition control module. Thanks!
- 1 wheel drive Audi!
- 12 cylinder Audi!
- I'm looking for guy who did conversion of auto tranny to 5-speed
- Hmmmm?
- A4? Cabriolet Audi!
- Blue 90! With Siedl body kit
- bumpers...
- When your bored some thing like this can be good for the audi soul
- performance exhaust....help
- 200+ MPH!
- The trunk lid on my coupe won't stay up on its own. Anyone have this problem and know a fix?
- Im like 95% done my subwoofer/rear deck speaker install...
- 100w headlights again - IqDoU?
- Shocks...
- new sig - this time it's an audi:)
- intermittent headlights and turnsignals on '93 90S
- Duh...! witness the sliding sun visor!
- brake problems, help please
- Need advice: ABS Sensors (MikeTip, can you help?)
- hey 'slayer!! i slayed two bmws on my way to work today! audi's rule!!
- AudiWorld Model Guide Accuracy?
- One Step Closer (20v Turbo Update)
- Hood Conversion
- Need help, my rear suspension is making noise......
- MikTip hope this helps.
- Need help asap
- the tranny is goin to be pulled tommorrow to see whats exactly wrong...ill go from there..
- Hey Mik Tip I would appreciate some advice.
- "Proud" 90 owner!
- engine mount help!
- I am loving this snow... Finally it is snowing in NC
- Starter problem......I think!
- my car walks like a duck....
- Hey Miketip-I want those white guages!!
- OK, a few 90 questions. Need help!!!!
- 10v Block Conversion
- 1990 Coupe Quattro - first $10,000 takes it
- Help with Manual Trans
- stalling out continues...
- there was alot of metal particles on the magnet in the tranny pan. where does that metal come from?
- Anyone looking to sell any 93-95 for cheap? Less that $3k
