PDA
View Full Version : Audi 90 / 80 / Coupe quattro / Cabriolet
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 [127] 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259
  1. Repost, Blast from the past.
  2. brembo big brake question
  3. Beautiful Audi Coupe Quattro for Sale
  4. Strut mounts, right?
  5. Heater core is DONE!!!!!!! :)
  6. Anyone know the part # for a 7A, 4 wire water temp sender.
  7. need a jump from me? better open the hatch....
  8. So I finally saw the new A6 on the road today.
  9. Anyone with a B4 90 bentley manual, wiring diagram request
  10. I went out fun running today in the 90.
  11. would it be safe if i got a 17x8 rim with a et of 20mm...and got a 20mm et b/c ive got to have 40mm?
  12. how much do you think i could get for.....
  13. 96' 90q
  14. What I have to park by everyday at work...
  15. Leater headrests split? FYI
  16. A ghost in the machine...
  17. Bought a CD manual from Ebay can someone tell me if it's the right one I need?
  18. where can i get a remus muffler?
  19. let the games being
  20. Anyone have a used radiator fan?
  21. want the best huge filter?
  22. Where to get a decent exhaust tip?
  23. Hey Audi ¹²valve, awake?
  24. a quick question...
  25. OK, I found the car I want!
  26. B4 quattro rear suspension overhaul parts list
  27. 2Bennett Coil Program????
  28. So whats the actual redline of a 90
  29. Aspirations...
  30. Anyone looking for a second set of wheels?
  31. Strange thing with my suspension....
  32. big sur rules
  33. MOON?
  34. Ok, so how do you post more than one picture???
  35. finally changed the rubber hose near the left side of my battery...wow...
  36. Front End Brake Noise??
  37. stock downpipe purchace
  38. Anyone with ETKA wanna post pictures of the powersteering pump for my coupe?
  39. link.
  40. Fuba Stank
  41. Anyone have the new Eurotuner from this month?...Great coupe 90 pic....
  42. Reconnecting the Parking Brake . . . . .
  43. Will an engine from a 1992 Audi 100 fit in a 1993 audi 90?
  44. Need help with removing old sunroof... getting painted!
  45. Are there seat (front and back ) removal instructions in my Bentley?? I can not find them.
  46. gear grinding when cold
  47. light bulbs
  48. I need a 1993 90 Drivers Headlight and a Bentleys
  49. something weird happened today...
  50. Body Kits...
  51. my car keeps locking by itself
  52. Anyone have a spare CAT-DP gasket?
  53. 1 more question about the engine swap...
  54. how much can i get a set of stock used 1990 fog lights for?
  55. It is Friday...right???
  56. Heater Core is Out.
  57. Coolant On Ground?$# Help or Advice
  58. a quick question...
  59. Battery choices, what is a great battery for audi's?
  60. Woooooooooo!
  61. Anyone ever taken the dash out of a 90 with passenger side airbag?
  62. MikTip. Please, I need your help.
  63. my friday contribution: finally got a front bumper, needs to be painted still
  64. Does anyone have a pic of a CQ with RS4 reps
  65. Cheapest source for OEM transmission mounts?
  66. found some water wetter
  67. where can i pick up some vacuum hose?
  68. got my o2 out, is this normal?
  69. I'm getting a squeak every time im on the road and i press on the gas
  70. I'm going to look at an '89 E30 M3 today or tomorrow....
  71. POW
  72. If only everyone watched this first...
  73. 20v oilpan anybody?
  74. Forgot that I took these pictures.....
  75. wOOO hooo@@ sold my old tires for $30!!!
  76. So I had a break between classes today, got out to make a call and ....bad heart=don't read
  77. I need consultation from someone who knows the 7A motor inside and out
  78. Early 90 CQ has sunroof switch but no domelight. Is it wired for one if I buy the sq. assembly from
  79. Is anyone in the cabinet no longer post on here?
  80. chck engine light
  81. Anyone on here good with fiberglass?
  82. Silverstar fogs?
  83. Question about starter compatibility
  84. '89 90(10v) Question: Losing power after running for a while?
  85. UrS4, can u either post or email me the pics you have for step-by-step inlet VS install...
  86. Anyone know how to remove some old tint ?
  87. Muilty funktioning temp sensor F76.. What does it do..
  88. Dash is coming out easy on drivers side, not on passenger??????
  89. whats the max offset the coupe can have?
  90. wtf?
  91. 1994 Audi 90CS Q ClockSpring Exploded???????
  92. Could I fit this on a 93 90
  93. 2 tasks completed by 90q20v newjack!
  94. Starting help
  95. hardcore!
  96. if i swap in the odometer from a b4...
  97. Interesting read while sitting at the airport in Cincy.
  98. One addition to the Q and A paper in the white face gauges.
  99. So yes, repeater is a free man now.
  100. After trying to get my exhaust fiasco straightened out...
  101. A Rolex for the Audi sway bars
  102. Ok Question Time
  103. Building an Exhaust for a 90csq
  104. G60 Conversion on 89 90q
  105. So will front calipers for B4 be good for a swap into B3 90 20V
  106. Well, just ordered 811 907 423 "Bushing for connecting rod" and washer fluid resolvor
  107. a pristine example of a CQ
  108. Anyone know the Bosch part # for the 3 prong plugs for an 88 80 4cyl?
  109. Anyone know of a good source online to buy bulbs.
  110. How do I remover the instrument cluster in order to change a bulb ?
  111. Umm...where's MikTip...did I miss something?
  112. CqATL, here is your car, and some background information if you do not already know . . .
  113. Audi Remote
  114. Am I entering the.... REPAIR ZONE?
  115. teh hotness!
  116. Odometer gear and white gauge faces.
  117. Spotted a black Coupe on DC beltway (Amer. Legion Br. South). Looked like....
  118. Anyone have 7A connecting rod specs??
  119. automotive proposition
  120. diff cover?
  121. parts wanted!
  122. foglight trick...
  123. Rear calipers totally shot...[more] anyone selling ? :)
  124. Stongard anyone?
  125. Anyone looking for a CQ, New England, VT especially!
  126. I'm just so dissapointed that my Audi is a lemon.... :o(
  127. Any idea why my fuel gauge needle goes up and down? mostly down of course
  128. Lookie what I bought!!!
  129. Is there a huge difference in light output between stock and euro e-code headlights for a 90(b4)
  130. explain this
  131. Any thoughts/opinions? (besides that I suck at the photoshop)
  132. Ok, i know this is few days late, but here is some pic of my new CQ...and some questions... BWW
  133. bilstein sports.......
  134. Rare?
  135. Oil Question...
  136. ordering front shocks.....
  137. 1991 90 Quattro 20v price update and the problem that caused the damage.
  138. It seems as though after 3 years of owning the wrong car, Xel finally got an M3.
  139. can one swap the two front rubber brake (b4) lines with stainless steel
  140. Another Coupe for sale
  141. w00t!!
  142. ok i give up...
  143. Looking For a Gear Indicator in the Cluster
  144. Attn:Brdman-just paid for white gauges-I need 160 mph set
  145. Anyone know where to get the 8mm 12 point bit for taking off the half shaft?
  146. Reminder: Kent Falls, CT gtg/bbq...Saturday, Oct. 9th.
  147. more ugly seats
  148. more questions on MC-2 swap...
  149. Ignition Switch... on ebay. looks identical to the one I just put in. who needed one?
  150. CQuuL ! I need your street address!!
  151. Trade: 512Mb PC2100 computer RAM for 93-95 Audi 90 Bentley manual. Fair?
  152. So.. I've always used Audi OEM wheels on my cars... but I'm looking at something from ADR for my 90.
  153. a quick fix.
  154. So i went over a bump, then my interior lighting went out.
  155. Suspension Overhaul Photos
  156. Did my outer CV boots for under $20.
  157. So in Texas.....
  158. me want............
  159. poll: AAN or 2.7tt
  160. Engine Swap...
  161. anyone have a good source for factory repair manuals, non-Audi.....
  162. If I increase my injector size to 195cc RC fuel injectors, will I need to do something with my FPR?
  163. Thanks for the entertainment...
  164. clear corners arrived! havent really looked at em, but how hard is it to replace em?
  165. Why is my rear wheel scalding to the touch and smell like burning?
  166. How much is my car worth?
  167. Front sway bar links, plastic?
  168. doin rims in the next week or so... any ideas for the coupe?
  169. 2.8 30v engine swap in a 93' 90q, how hard is it?
  170. I can't find a part#, did search, russian etka, shockan, part connection....
  171. anyone has Bentley repair manual on CD?
  172. does anyone here have an MC turbo 90Q?
  173. Is it easy to replace the heater controls ????
  174. breather tubes were filled with some rust colored gunk and greenish white ****
  175. Shalaka!?
  176. 1991 audi 90 20v sedan quattro
  177. Muffler system suggestions?
  178. Parts going in the trash if no-one wants them...
  179. poll: how many people love their cars?
  180. How would these rims look?
  181. Fan problem: follow up
  182. sporatic speedo prob.
  183. Ok the dealership sucks thats all there is to it...
  184. i was about to post something about my cv boot trouble but....
  185. Anyone along the I-95 corridor....
  186. Who knows where to get those non-blind spot mirrors
  187. hey guys, i'm looking for 1 speedline 2308 wheel (i think it's 17x8) for a friend's 90...
  188. free CQ hood
  189. 17x7.5 (et 42) wheels going to fit on a 93 90? Or is that too wide, too far inside.
  190. Any Real Gains from Removing the Cat on a 7A???
  191. I should have 3 complete front/rear 90Q fully adjustable sway bar link kits available by Mon/Tues...
  192. Free CarFax Report?
  193. Has anyone ever had a problem from importvision?...
  194. success!! thx for the Ignition Switch tipoff. replaced it this morn & all is back 2 normal =D
  195. how hard is it to change manual climate control bulbs?
  196. Power windows worked sometimes now they dont at all
  197. half my dash lights are out what should I check?
  198. 1988 80Q these cars can't be this slow can they???
  199. DAMMMMMMMNNNNNNN!!!! Prepare for take off.
  200. New B7 on AW homepage looks like a Hyundai.
  201. what do our fuel injectors flow? Also what would be a nice upgraded flow for new fuel injectors.
  202. NEVER add up all the costs of a project! it hurts!
  203. Any easy way to check check engine codes on 88 80 w/o electronic reader? Hoping it is 80s GM easy.
  204. 1995 AUDI CABRIOLET TIMING BELT
  205. looking for leather interior for my 1995 Audi 90
  206. All you guys with big brakes think your soooo cool, well u know what? eat this....
  207. Need mechanical engine answers
  208. Got two things today: new oil filler cap, power steering fluid.
  209. Is it common to cut off your shifter then glue the shift boot to the remaining rod?
  210. Infrared Key-
  211. All XXTuning Dyno Day Graphs (& pics) are now posted for you to compare to your hearts content..
  212. Compression v. Leakdown
  213. anyone running TSW hockenheim R's on their coupe?
  214. Washed and waxed both my cars last week, just thought I'd share a few pics of my Audi fleet ;-)
  215. Did any of the cabs in US have electric seats ?
  216. Lowering a 1988 90 quattro
  217. Exhaust time...
  218. Tons of parts left......
  219. thought you guys would like this.. 20vt in it..
  220. Alex VG- I'm waiting for MONDAY BLING pictures from the dyno this weekend?! where u at!?
  221. Headlight electrical hight adjustment added!!!
  222. B3 & CQ folks with the antilock switch. When pushed does the button stay depressed (like the fog
  223. Looking for carbon fiber hood and rs2 lights...
  224. I noticed that the 95 B4's cluster lights glow nice and red...
  225. he needed quattro...or to not be such a dumbass, either one.
  226. Seems like a great deal...
  227. Crazy Autocheck system! Help plz
  228. MikTip: Your expertise is needed on the B5 forum.
  229. Say hello to New 90 CQ owner... (hint: ME!) .. Thanks to WA (user, not the state) for everything!
  230. Thanks SQuuL...ya jinx'd my odometer!! :P
  231. Oxygen sensor part number please
  232. WAY off topic but....GO DOWNLOAD THE FULL SPECTRUM WARRIOR DEMO!!!...its dopeness!!!
  233. brake noise
  234. Anyone from here snag these...?
  235. Clean Audi Trifecta
  236. I might have found the reason why I'm losing power steering fluid...
  237. 1994 Audi 90Q - No Sparks !!!!
  238. A good video for Sunday afternoon...
  239. aw poo... im mad.
  240. My CQ's climate controls dont work any more, any help would be appreciated.
  241. Any news GermanMissle about the windshield?
  242. Can someone please post pics of safe places to put jack stands where they won't intefere
  243. Any Quick easy way to test my washer pumps??
  244. Anybody know if all the Coupes in Europe came with Board computer??
  245. MY 90 RUNS!!!!! Im fixin it
  246. to anyone who'se ever had a stuck starter (for whatever reason... IGN switch or other)
  247. help! how do the cams go??? i forgot
  248. Where can I get some power steering fluid?
  249. anyone know if a under engine cover from a B3 will fit on a B4??
  250. what doesn't work: Wipers, ClimateControl, Turnsigs, Windows, Sunroof, Headlamps, Fogs, Defrost
