PDA
View Full Version : Audi 90 / 80 / Coupe quattro / Cabriolet
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259
  1. This enough offset to get into the subframe to do the control arm nuts? Or should I go higher?
  2. (Hub question) Does anybody know . . . . . .
  3. Do these wheels remind anybody about anything?
  4. in a perfect world...
  5. Is my 90Q capable of majorly breaking down after this?
  6. PSA: jpcady is the man
  7. a_CQ I sent you an email....
  8. Timing belt job....
  9. Will pay for Hella Right side marker (Clear)
  10. Part 4 of my on-going problem with the propshaft center bearing squealing....
  11. Option code look-up help...
  12. Some vanity plate options....State of IL got back to me with pissing news...
  13. '95 90q Sport - Should I get Bilsteins or BOGE, and who has the best price? And some cars for sale!
  14. Does a 20V have a Steel RF shield on the distributor?
  15. it's official... the rally car hates me.... 2312 temp sensor ghost.
  16. I need a new Hella Right side marker Clear need a source
  17. My CQ has no muffler... just straight pipe from the resonator
  18. Last chance offer on RS4 wheels 17x7.5 et35
  19. WTB: 14" (yes 14") wheels for my 86 5K -- 4 x 108
  20. Just looked at the R8 pics. love it but the silver intake covers remind me of Mercedes
  21. I've got that sinking feeling! Clutch pedal low?
  22. Hmmm....how do i bring a thread back to the top, so it doesnt get lost in the mix.....
  23. replaced ignition switch and have some problems
  24. LOL...this is hilarious! Audi commercial...
  25. Cliffs notes on replacing front subframe bushings on a CQ. Anyone?
  26. I WANT COILOVERS!
  27. Coupe window regulator rebuild
  28. Pro-Mount Review #1
  29. Can the cluster bulbs be bad even though the filament appears intact?
  30. CQ hatch leaks, anybody else? Comments please...
  31. Cheapest source for 7A flywheel?
  32. Heater core housing not moving
  33. Just for a little advice...
  34. Removing Throttle Body
  35. NEW PARTS!!! 4 weeks later!
  36. Ordering a new trans, 1995 90 q 5 speed. Where is the code on the unit?
  37. Took a LOT of math but I've finally done it!! I've nailed an equi-distant strut washer gap...
  38. This is a public apology to Tim & his outfit FAP99....
  39. Comparisons between stock 5cyl and stock 2.8 6cyl.
  40. Nate!!!!! Why you selling you 90?
  41. Can anyone confirm that a dead temp sender on a 1990 CQ will show nothing?
  42. Having a heack of a time finding coolant hose # 855 819 375 F... any ideas?
  43. Having a very hard time getting power steering pump model
  44. Allroad mounts on B3 (coupe-q) rear differential
  45. Anyone know of an good NJ shops?
  46. 01108 - Power Window Closing Relay (J292)
  47. Man I need to clean my car again...
  48. LAST CALL: ACNA 2-day track event @ Willow Springs (Oct 9-10)
  49. Are there any folks here that live in/near/around Boise? I'll be out there from this Thursday...
  50. Auto trans lighting BT....The bulb is ok on the auto trans shifter but ....
  51. Happy Birthday Jacky
  52. Whats the correct procedure for 1994 90S Ignition switch replacement? Seen different proced's
  53. 2 part question...
  54. AANarchy
  55. Does the timing belt get louder as it gets near its life's end?
  56. These will make someone very happy...
  57. 20v with no balls, bad knock sensor?
  58. 90 q c
  59. B4 Clutch problem... what do you guy thing ?
  60. Is rear window from B3 swappable with B4?
  61. Timing belt off without mark! What should I do?
  62. 2006 Central PA SCCA Driver's Challenge - Very faint Audi content
  63. Hello...
  64. Is there any reason why I can't have different springs on the front vs. rear of my vehicle?
  65. fair price to sell 1990 coupe quattro 90k miles?
  66. Did clutch. Hard shifting bleed already
  67. More alloy washer blueprinting
  68. measurement/clearance and strut travel issues you can expect with alloy washers...
  69. anyone got a working ISV that they want to part with?? ....
  70. Schumi WINS!!!!!!! In CHINA
  71. a couple of questions
  72. hey! anyone need any remotes?
  73. ECU Pinout/Bentley request.... B3 90q... Need to know pins for knock sensor
  74. Hey all, back from Greece and brought some pics for all (long)
  75. head gaskets
  76. How to hold cam pulley while removing the center polt?
  77. If anyone needs B3 or B4 parts let me know.
  78. springs / shocks for my 90Q -- looking for sources
  79. 91 CQ Power Seats
  80. yo CV did you send that CD to my adress in Ontario or New Brunswick???
  81. Radio question....
  82. Oh, did I mention they true up and polish out VERY nicely?
  83. got my srutmounts replaced about a year, 10 k (km) a go and they seem loose again ?
  84. do these parts have the right specs for the 3 to 4 wire maf swap??
  85. my car is bleeding black goop
  86. tbelt (what else do i need?)
  87. picture friday
  88. Ok so why thf don't my gauge lights work? cut out the trunk wires already.....
  89. How to pull codes on a 95 90s
  90. some might be interested (not my ebay auction)
  91. alloy cupped washers with strut bezels installed in car...
  92. whould this work on the cq
  93. Ok here's Ryan's discovery and with some other things it'll work as well as if I...
  94. Speedo quit on me today....
  95. Mance, did anyone ever guess correctly what "Side B" of the Pro-Mount tool was?
  96. anyone ever install rear euro lights?
  97. Pic Day
  98. What options are there for raising the suspension on B3 90 Quattro?
  99. Friday is picture day?
  100. I set off the alarm on my CQ. Woo, it works.
  101. How do you bypass immobliser
  102. dad got me an awesome birthday present =)
  103. Might be time to **gasp** sell the CQ... (kinda long)
  104. Heheheh, I just had a lil stoplight-to-stoplight dalliance with a V8 S4...
  105. What are the 2 little plastic tube pieces that come with a head set
  106. o2 sensor replacement update...
  107. Buying 97 Cabrio Any advice?
  108. Is there a procedure for breaking in new brake pads and rotors?
  109. Anyone have a spare pearl under headlight trim for the driver side? Never lost one before....
  110. remote locking and full closure
  111. For a_CQ...a little progress report.
  112. European vs. Stock (american) headlights
  113. Any site that I can buy some clear corners off besides ebay?
  114. Turbos twisting...
  115. Who said stock CQ suspension is no fun???
  116. No start in todays rain....
  117. Heated Seat Switches!
  118. Wheeew... done! Thanks for everyone's help on my prior posts today...
  119. Coolant Temp Sensor (CTS) failure causes engine shutdown
  120. anyone want some reeems?
  121. How to remove distributor parts on '89 10v Audi 90?
  122. Why would anyone want to leave the Solid Strut Mounts for Pro Mounts?
  123. An old video for the new guys!
  124. One of my favorite pix ever. I wish I still had the original hi-res version.
  125. KoupeKrazy likes to build crazy koupes
  126. BakerCoupe likes stabbing car parts...
  127. qpilot likes sniffing car parts...
  128. Pics of the new ride!
  129. Is the hatch supposed to unlock with central locking? I always have to unlock it with the key.
  130. Anyone here still looking for a Gamma OE tape unit?
  131. After systematically following my own "clunk check-list" I've found my clunk and it aint pretty...
  132. BakerCoupe has a lovely kitchen...
  133. Since Skoolie is all about pics today, can anyone guess what happens next?
  134. I need an alternator adjustment bracket (the toothed one). Any 5 cyl. 80/90/CQ bracket will do.
  135. Ooooooo that's cooked!
  136. Hey I have 3 4x108 spare tire donuts I don't need. ANybody need them?
  137. BRAKE light
  138. I'm gonna try to get 2 birds with 1 stone on this...
  139. Anyone at Penn State?
  140. Front end clunking noise check-list
  141. Serpentine Belt replacement interval '95 90quattro 2.8 V6 (and some cars for sale)
  142. Anybody hear or know if they have released a 1/18 scale model of the R10 LeMans car?
  143. Safe airbox mod
  144. Glovebox Light in a cabriolet
  145. Can't get my brake caliper bolts lose. Is there trick or a good tool to get these puppies to spin?
  146. I'm attempting to R&R my front lower control arm bushings on my 93 90 today and...
  147. these are the rims I want, but I can't afford =(
  148. my plan for next spring
  149. Too hot!
  150. Skollie like
  151. Advice on a parts deal gone sour?
  152. My 80 invisible front wheel...
  153. 15x6.5 A4 1.8t alloy wheel...
  154. 14x5.5 UrB3 steel wheels
  155. 16x8 UrS4 forged wheels
  156. Post-trip dental bite impressions...
  157. Installed 034's 3" turbo back exhaust last night. Impressions inside...
  158. Radio Wiring diagram
  159. Shock install update
  160. Hot
  161. Anyone who had a t-stat stuck open, do you recall your coolant and oil temps under normal driving?
  162. Taking strut tower impressions (dental style)..
  163. NEW CQ OWNER!!!
  164. Mance: Any reason i cant use these in the front of my car?
  165. Audi 80 For sale $800 OBO
  166. Spark plugs
  167. Rattling...
  168. my 90's new big sister.... already gettin' me into trouble, heheh
  169. Looking for Front Bumper for 1990 CQ and side moldings.
  170. Thermostat
  171. **Hartford, CT GTG - Tomorrow - 9/27- Forecast is 73 degrees and sunny!
  172. Where to get bilstein sports for my CQ? My CQ is very early
  173. Driveshaft replacement question
  174. People that have taken the "front suspension noise poll" I need you now in this post...
  175. 89 90 FS on craigslist
  176. anyone near Harrisburg, PA?
  177. anyone here going to the Hartford G2G tommorow?
  178. TONIGHT: L.A. GTG @ The Stand in Encino (SFV) - 7:00pm
  179. B4 Quattro spring options...
  180. Front spring/suspension noise Poll:
  181. Going to pick up a new trans...what should I do for a clutch?
  182. Holy crap that was a crazy adventure. So much good as well as lots of bad =( .. now, as like so many
  183. Chipped AAN + 170k B4 90 = 2nd prop/drive shaft joint going bad ...
  184. No spark code 2114 California 20V
  185. Need new RS2 Projection headlamp
  186. I installed my euro center section on the CQ on Saturday
  187. Mance & others who have dealt with the drive shaft center bearing .....
  188. On factory springs, what's the proper orientation of them? Paint marks go at the top...
  189. B3 strut brace sources--STFA but.........
  190. Dammit. I need a suspension for my CQ. This is ridiculous.
  191. urethans bushings for 1990 audi 90
  192. Where to buy the BOGE strut mounts: 8A0 412 355A aside from dealer.
  193. Bolts underneath Alternator
  194. I never knew Audi made these wheels in 4-lug...
  195. Looking for good Machine shop In Oklahoma city
  196. Hard to manualy select 3rd on the auto box..
  197. Can somebody answer this for me? Why does Blaufurnugen charge...
  198. Azeem & CvTech 2 of the most dedicated Audi 90 lovers on this Forum...
  199. G60 brakes from a type 44
  200. Will it be big problem if the cam mark and crankshaft mark are a little bit offset?
  201. anyone own a clairon radio with removal key? I need to do heater core and lost my keys
  202. Something I learned about prop shafts & the center bearing this weekend....
  203. Halo lights?
  204. Damn parts warehouse sent me the wrong rotors!
  205. Anyone have euro b3 headlights they need to get rid of?
  206. Some pics and updates on the car... [edit]
  207. Some pictures of the "project"
  208. When should rad fans turn on? I noticed on both my 93 90 and my 95 Cab that...
  209. FAST HELP PLEASE: NEED ETKA DIAGRAM OF A B4 (5SPD) CLUTCH COMPONENTS FOR R&R
  210. 4000/cgt x-post
  211. Are the cluster bulbs removable from the plastic base that they are in?
  212. 12V X post
  213. engine speed sensor
  214. any suggestions to what i might find?....... cracked head maybe?
  215. how hard is it to het off the transmission fluid pan to change the fluid/filter?
  216. lock ball thingy?
  217. I love the smell of smoking brakes...
  218. Hurray... I've got bad wiring between the ECU and CIS flowplate pot...
  219. Is there any way that a coil pack could cause damage to new plug wires?
  220. Auto indicator on dash of Cab....
  221. ok..looks like my 90 is pretty much dead .. it was not a clogged cat .. lack of fuel i think
  222. Solid Mount-to-Pro-Mount conversion kit and new cupped washers...
  223. yo CV and other Chi-town peps...how did ya make out in that crazy hail list night?
  224. I'm parting out a 93 90S and need to find out where the ECU is???
  225. Alternator Bracket
  226. How much of the trunk wiring gets exposd and cracked?
  227. so did some research because i can't sleep, B3/B4/B5 all share the same rear wheel bearing
  228. Trouble Starting
  229. Would it be possible to create a 80/90/Coupe/Cab FAQ?
  230. have a couple of questions on added keyless entry (yes i did search) more inside
  231. So I want to clean up an prep my engine for the 1st step of my swap project what do I use?
  232. Problems
  233. Need a pr of headlight assemblies '94 90S and more....
  234. New AW STFA Avatar =)
  235. Friday video
  236. Friday pics from ACNA Road America Sept 2006...featuring a minor celebrity...
  237. Speedometer Cable Location in Tranny
  238. Instrument Cluster Bulbs
  239. alternator belt
  240. My Friday pic
  241. I want to post a friday pic
  242. Friday!!!! Stealth 90 Style!!!!!!
  243. Poll: Friday! Not sure which pic to use for sig...
  244. does anyone have a rear jamex brace for a coupe they want to sell ??
  245. Skoolie...
  246. Rear Bumper
  247. i get a 2312 code
  248. REMINDER: upcoming Audi GTG @ The Stand in Encino -- TUE Sept 26th
  249. Lago...
  250. Anyone have a picture of a rear B4 sedan strut brace ?
