- Audi 80 Tdi Bad Idle
- Audi 90 leather interior
- 1995 Audi Cabrio convertible top issues
- Centre silencer part number
- 96 cabrio issues and a first post
- Knock sensor 00524 DTC
- Idle Speed problem
- 1991 audi 90 i5 20V compatible years/model
- wheel bolt pattern
- Distributor issues 90 quattro 20V
- VCDS with "pre-OBDII" (OBD-1) diagnostics?
- Audi 80 compression test
- Need professional advice
- '91 CQ Power Window Switch Always Illuminated
- 96 Audi cab for a rally
- coolant relays confusion ??
- Acidic coolant flush
- 90 Coupe Quattro Headlights
- need advise 1.8 8V cylinder head white residue on valves
- AUDI 90 Engine swap HELP
- 20v transmission swap for 10v transmission?
- Old bumper on, finally...
- Mystery Rear Oil/ Fluid Leak?
- Audi 80 1997 ignition parts
- Audi 90 - Death Wobble
- Audi 80 remove alternator
- Heater Core - Do I have to discharge AC
- 1994 audi cabriolet
- 1994 Audi Cabriolet - worth restoring?
- cooling fan delay relay- id
- code 00532 all I can do is guess atm
- '95 Cab fuel tank
- '95 Cab CFS transmission leak.
- Idle issues-PCV issue? Bad purge solenoid?
- Brake pressure control valve
- '95 Cab lowering springs
- 98 2.8 v6 cab
- '93 90 STRUT MOUNT/BEARING QUESTION
- help with wire identification 1993 audi 90
- How to remove roof trim?
- audi 2.8 v6 1999 cabriolet
- Cabrio-confusion
- 95 audi 90 bumper, or otherwise
- Gauge Cluster Doesn't Work. Might Be Short Circuiting?
- 98 cabriolet window regulator interchangeable
- A/C recharge for 1995 90 Quattro [adapter?]
- Needs advice :)
- Looking for Audi 90 Quattro
- 95 Cabriolet Transmission problems
- Need help: '91 CQ pwer windows update
- Posting my OBD-I codes (get ready)
- 2.2t Head on 2.3 NG. . .(B3 90)
- solving oil pressure light problem
- Audi 5000 parts on Audi 90? B3
- Picture thread?
- New Cabrio owner here so excited for build + some questions
- 2nd rad on my b3 Audi Quattro
- 2 rads on my coupe b3 Quattro 1989?
- '91 CQ power window buttons stay dimly lit even after car locked
- 1994 Audi Cabriolet fuse block
- Need Help and Recommendations - Starting Problem
- 1994 Cabrio map/dome light wiring and top front latch help
- 1990 90 Quattro Alternator Upgrade
- Just got 1990 Coupe Quattro Need beginner help.
- building a fun cabriolet
- Beloved 1990 Audi 90 - Auction: Proceeds go to NPR
- 1988 90 Quattro Knock Sensor Location
- Audi 80 2.6L electrical help wanted
- headlight loom wiring mod from b3 to b4 headlight conversion
- Cabriolet issues
- Cab question #2. Axle seal leaking
- audi 90
- Random Cab question #1
- Which Octane for my 1995 Audi 90?
- Connectors identification audi 80 tdi
- The '95 Cab project. First question of many to follow.
- I rescued a Cabriolet. An introduction.
- 95 90 sport quattro overheating
- audi 90 Quattro Hesitation
- 1991 90 Quattro 2.3 20v Starting problems
- What is a Audi 90 really?
- Seat foldover lever adjustment
- door card panels repair
- Bad cooling fan Connection
- made a strut bar for my audi 80 B3....
- Lost my Speedo and odometer (VSS?) 1995 Audi 90
- here's a question for you guy
- WTB 2.3 20V Head and throttlebody.
- 1997 Cabriolet, 115k miles, Thoughts?
- Need To Replace Brakes Soon. Suggestions Please?
- Cab oil pump leak and whine
- cammed and loving it.
- frustrated to all hell
- 1988 Audi 90 2.3L Problems
- aftermarket wheel?
- Roof cloth sagging advice pls
- Needs body panels? ?
- Audi Coupe Quattro Side Skirt question
- Need some advice again guys :(
- Bypass the brake booster audi 90 cs q?
- Electric fans not running
- 1995 Audi 90 (2.8 V6) oil light.
- 1995 90 wont pass emissions
- Regluing CQ door card vinyl
- 90 Quattro power loss
- Audi 90 Quattro
- Best 1995 Audi 90 2.8V6 Maint Manual????
- 1995 Audi 90 auto trans shifting issue
- 1994 Cabriolet Rear Speakers Dead
- 95 Audi 90 coolant leak
- 1994 Cabriolet Window and Radio Issues
- New Audi 90c owner!
- 1995 Audi Cabriolet Ton of Questions!!!!
- Running rich after removing cats
- crankshaft pulley bolts stuck ideas?
- Audi 80 2.0l 8v torque specs
- 1989 Audi 90
- cambelt change
- Looking for a Passenger side control arm + Performance questions
- NEED ADVICE AGAIN GUYS PLEASE!!!!
- No power to wheels - grinding
- 1991 audi 90 2.3 e automatic
- 1989 fwd 90 suspension
- Problem with 3A engine...
- compatibility questions
- audi 90 wont start
- Evaporator core reliability
- Audi Cabrio Manual Roof Problem, cover won't release automatically
- audi 80 1.6 petrol , oil pressure sender problem?
- Factory volt,oil Pres,oil temp install
- Just drew this Audi 90 Quattro IMSA GTO, thought you guys would like to see it
- Strut and Shock Recommendations / Ideas
- reset auto tranny? and possible sport mode
- UrS4 steering wheel
- Timing Belt Replacement problems
- What gearbox will fit in my audi???
- Cruise relay
- need help asap guys please
- 1993-1995 90 series (B4) Bentley DVD-ROM for sale
- Don't like the quattro in my b3 90q
- Bentley DVD-ROM 1993-1995 90 series (B4) for sale
- AUDI 80 for sale
- Climate control and blower motor staying on
- need advice guys :(((
- Broken odometer gear 90 2.3L A/T
- 1989 80/90 headlight stalk compatibility
- 1989 80q no back-up lights -- suddenly
- duelling temp. sensors
- 90 quattro 20v blend door help!!
- Brand-new just bought a 97 Cabriolet having second
- audi 80 heater problems and radiator does not work
- 1990 Audi 80 - Parts and Thoughts
- 1995 Audi 90Q muffler
- will the s2 steering wheel fit a 95 cabriolet?
- Audi 80 or C4 100/A6 First Car Australia
- Heater core needs replacing, Attention: Greg Kiernan...................
- Audi 80 gl
- Oil pressure light bulb lit over 2000 rpm
- I just bought a 1997 convertible and I need an interior bad
- Got the sister car to my 88 90 quattro
- 1995 Audi 90 advice
- 1995 convertible cruise module
- aah cams
- Audi 90 2.3 ng starter
- wheel fitment on a b3 88 90 quattro
- Doing maintenance
- audi 80 avant 2.6 quattro diff lock control unit
- 2.3 NG turbo project
- B4 Cabrio steering wheel swap
- 1995 90 Q fuel lines? The rear ones?
- 95 Cabriolet Door Latch (Bowden?) Cable
- Information difficulty
- Looking for a Hard Top for Cabrio
- What options for strut mounts without Mance Parts?
- Hey guys,
- 93 Audi 90 Quattro REAR PASSENGER SPINDLE WHEEL BEARING HOUSING
- Audi 80 2.6 avant quattro -94, bushing rear suspension
- For all those wacky electrical problems in a Cabriolet
- Picking springs. . .
- 1993 Audi CS Quattro wheel bearing hub assembly
- You think your Audi is bad, check out this one!
- Parking Light Wiring Gremlin?
- Help/advice on speaker setup idea 93 90 CS Q
- Audi 80 2.6 avant quattro higher in the front
- 94 Cab Roof,windows and trunk
- Sticky thermastat ??
- Any other parts to replace while I'm here?
- Audi 90 CS Quattro trunk lock stuck!!
- Bad traction issues, help please!
- Black Friday/ Cyber Monday deals from Car Parts Discount
- 1996 cabriolet cabin filter??
- Driver side blinker stopped working after small accident
- "Stops" aid A-arm Bushing Function
- Wanted: Peer review of mod
- Brake Pad Carrier needed.
- 12v to 20v swap? Audi 90 Quattro 95
- Speed gear broken at the 251.192 Mil.
- New stabilizer/sway bar end links $3.62 each FYI
- Special promotion for Audi World Forum members
- How to disable my B3's headlight warning?
- I'm new here
- mpi control unit
- First dbag Audi owner encounter
- Forum group buy with Car Parts Discount
- Quick cheap replacement for the 40-201B shock tool.
- the nightmare continues, gas leak. Diagram for fuel system anyone?
- Car runs very cool while driving.
- Audi 90 quattro and Audi 5000 quattro transmissions
- 1994 Audi Cabriolet, cranks but won't start.
- Sad day for me and my 88 90/quattro
- turbo charged motor? 12v AFC anyone?
- advice concerning power wire for amp for a sound sytem
- Cabrio Manual conversion donor alert!
- Thule fit kit '95 90
- Audi 90quattro front grille cover
- Lower oil pan gasket replacement? AFC motor
- Off road parts for Audi 90 quattro
- Audi 100 seats to Audi 80/90
- Recent purchase.
- Oil Cooler removal
- relay #297 What is it for ?
- little help with central locking
- transmission out of wack.
- i guess i'm late to the party
- My trunk is stuck!
- Getting Ready to do the swap, INFO Needed.
- IR key fob find and Oil pressure sensor question
- What's expected summer coolant temperature range everybody is running with AC on?
- radiator coolant fan wiring question, which one goes where? 93 B4q
- 1995, 90 Quattro - low oil pressure light/buzz at 2,100 rpms +
- Coolant temperature sensor 97 audi cabriolet location and replace
- Paging Doug Wells...................
- Cabriolet steering wheel question
- Does anyone have Bolero wheels for a CQ for sale? NT
- My first Audi
- Just picked up a 1995 Audi 90
- 1988 audi 90 2.3 crank seal
- '91 Audi 80 Quattro no crank no start after new water pump
- Audi 90 - Very high oil pressure
- Audi 90 quattro 95 - bleeding clutch?
- Booklet and wiring diagram Audi 80
- 1990 80 quattro no start when warm
- UPgrade AC in 94 Cabrio *Newbie Warning*
- Ur Quattro, should I get it?
- Engine shot:(
- First Audi, true time capsule.
- Special promotion for Audiworld members
- What parts should I squirrel and collect ?
