PDA
View Full Version : Audi 90 / 80 / Coupe quattro / Cabriolet
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 [196] 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259
  1. Does anyone have before & after pics of the removal of their plastic body trim?
  2. Got the ol' 2212 DTC code tonight (Throttle position sensor)
  3. The new A8...
  4. removing tie rod ends...
  5. holy crap... there are two of these on ebay.de right now... here's your chance.
  6. DTC codes, 4444, 1111, 2132?
  7. I put my stock rims back on the car ... sick of the bent modas
  8. '94 90CS - leaking coolant
  9. Paging Steve Balgach...
  10. How much to fix or replace an AC compressor on a CQ?
  11. my Audi 80
  12. airbag
  13. how do you debadge a car ?
  14. Radio
  15. What is the circled part in the diagram?
  16. HELP 1990 Audi 80
  17. anyone here from columbus ohio?? gonna be there in september
  18. Funny
  19. anyone know what this is?
  20. Sticking caliper ?
  21. 89' 90Q antilock brake question
  22. need help with a wiring thing...
  23. New brakes
  24. problems....fuel pump?
  25. Did any of you heard of putting a compressor in a 20v 1989
  26. I had some steering wheel shake when braking at speeds over 120km/h before the new brakes and now
  27. Got the Wilwoods on --
  28. Snoogins, Is this your old CQ?
  29. Will these tires fit?. . .
  30. It kinda makes me wanna play baseball.
  31. how bad is it to come incontact with R12????????refigerant coolant???
  32. Toronto Mechanic Needed Help Please!!!
  33. Hey 2.7t
  34. how hard is it to remove the front bumper of a 91 90 20v sedan?
  35. Anyone here with Magnaflow exhaust??
  36. 90 quattro sport 0-60 time
  37. Anyone know the coolant fan wiring?
  38. hood question
  39. How do I disconnect the airbag? Is this necessary when I remove the guage cluster?
  40. Is it possible to jumper something to get fans on before engine is warm? ('94 90)
  41. H4 Conversion Pics
  42. When I take the instrument cluster off does the clear plastic on the front
  43. Power windows relay? cost? part #?
  44. will B4 90 rear rotors/pads work on my B3 90 20v's rear brake set-up?
  45. cooling system help please
  46. Hey blakeskate... this should help you out...
  47. Finally passed those emmisions, but just barely!
  48. replacing a tail light
  49. Who is doing development for the 12v engine?
  50. It feels like I just got back about 20 HP today... I had a missing exhaust clamp...
  51. Is there a diagram of relays somewhere telling what they all do?
  52. I need somones help on coolant problems
  53. Help! Climate control, windows, and wipers won't work. I checked
  54. HELP! i lowered the 90 20V, but the rear is about an inch higher than the front!
  55. Reluctantly won this....do not know if I'll use on my ladies 90CS.
  56. 88 90q - Need Headlight Part
  57. Power Steering Fluid
  58. Rear Headrests? Anyone selling?Anyone...Anyone...?
  59. Anyone got a Shift Lever that's not cut off?
  60. Rally event info. Northern Indiana/SW Mich/Chicago
  61. anyone with a red 90q 20v at pep boys on quebec today in highlands ranch?
  62. I was reading some stuff from the detailing forum. was wondering if anyone has experience with some
  63. is the 94 90CS wheel bolt pattern 4x108?
  64. Anyone know what happen to Nick, did his email die again???
  65. Ok, so I have a question regarding the "foglights only" mod
  66. Anybody know how to fix the loose window regulator?
  67. 90 CS alignment
  68. Working on another really cheap 2084 replace tool.....
  69. Control Arm Removal
  70. Question about luxury features
  71. Control Arm Bushings
  72. Removing Tail lights
  73. What do you guys think about this...i am in the market for cheaper car
  74. Drill holes in ISV ???
  75. does anyone have an audi icon???
  76. Uploaded couple new shots incl. sub in trunk if anyone is curious. wilwoods coming tomorrow.
  77. Hehehe... Eat Sh-t NASCAR. Got Quattro?
  78. Is it possible to remove the glass from my fog lights?
  79. Valve seals job quote from a local shop...
  80. Does anybody have windows rattling when they're down or partially down?
  81. Climate Control System
  82. I am confused... The Bentley says
  83. Anybody on the U.S. side relatively close to Kelowna, BC ?
  84. Distributer cap replacement-who designed this thing anyway?
  85. does anyone have or know where i can buy the rear lower bumper piece for a 95 90q?
  86. Does Zimmermann make rear rotor hats for CQ's?
  87. Little inside info for Northern Indiana/SW Mich/Chicago people
  88. Jim Bush : Other G.R. residents - any info on this car?
  89. Where can I download a copy of ETKA 6?
  90. Problem with steering rod end nut to strut...
  91. Short shifter kit installed.
  92. How do I install a burnt ETKA?
  93. new European Car issue: anyone else disappointed with the 1.8T Challenge contenders?
  94. knock sensor torque question
  95. Which bumper is the S2??? I like the Cabbie one better...
  96. 8v - sensor identification
  97. what is VAT?
  98. I'm a little skeptical about my "bent" wheels....
  99. F#*@!!! (kinda long)
  100. here's your chance...
  101. Who wrote MikTip's brake rotors are the same size as factory?
  102. hawk pads - front for 89' audi 90 quattro 20v
  103. Finally got my new cats installed!
  104. Water behind drivers seat?
  105. Radiator replacement question
  106. my new 90cs
  107. coolant filling help please
  108. Red 90 20v q in Muncie, Indiana!
  109. bad clutch master and slave----> broken pressure plate?(longish)
  110. CapitalAudi: Pictures from May 17th and May 31st -/- Reminder for this weekend.
  111. i found my problem, i'm soooo stupid, why did i fail emissions?
  112. The UPS Man brought me some good stuff today.
  113. ok, please help and yes, I have done loooong search here!
  114. Newbee Questions - Just purchased 93 CS Quattro
  115. I'm no longer the sigless wonder.
  116. Video: Typ44 lapping the Nurburgring
  117. blau's got some good deals going...
  118. R12 to R134 conversion
  119. Speaking of AC.....
  120. Very stupid question...Where are the recharge ports on a 20V car?
  121. Has anyone charged their A/C using the high side port?
  122. Installed Weitec Ultra GT - Front is wayyyy too low...
  123. Ok the 6 hour oil change is finally over!
  124. OK, the Wheels are On and the Pics are Up!
  125. B4 hood install question
  126. 20v head question...
  127. anyone here in the GTA own a silver 1989-1990 90 fwd??
  128. So...let's talk about exhaust bay-bee
  129. what's the difference between Engine mounts with and without AC?????
  130. Poor idle when engine is hot
  131. Heater Core 1989 80
  132. Well... I started it...
  133. Can anyone post the Diagram for headlight removal of an 88 80??? Thanks alot!!
  134. Found out the cause of my groaning steering sound
  135. Radiator Crisis
  136. Swap question
  137. "Smoking Deal!" ;O)
  138. Allow me to remind you of this...
  139. I need a part number for a WOT switch for an 88 10v 90
  140. Multi temperature sender new 3 wire vs. old 4 wire plug
  141. Any guesses?
  142. Removed rusted mid-muffler to put in straight pipe
  143. Like anybody is gonna buy anything from Latvia much less a former Soviet Bloc country.
  144. CQ backseat removal (electronic boxes)
  145. HA! I knew you'd come around. nOOOOOOb!
  146. i hate bad mechanics
  147. Uh oh...I ventured into German E-bay territory...
  148. What are the general causes for loose, sloppy steering?
  149. Whatcha think?
  150. How's a 270 cam in a 4-banger?
  151. I got new Gas Cap!
  152. Well, I proved it.. But Yager, you were right.
  153. MikTip, All - Your insightful knowledge please...
  154. failed emissions 3rd attempt
  155. MikTip... You have 2 emails regarded the secret, hush hush Europe operation.
  156. Skolnick, here's another leather interior - decent car, not TOO far away! (From me)
  157. 10v turbo conversion....
  158. Cool 93 90 Dealer Brochure
  159. is this the correct cylinder numbering?
  160. for some reason I could hear the termanator music in my head.. as I cleaned her up :-)
  161. followup on my rebuild for 91CQ/ Where should I start looking for an engine swap?
  162. Finally put my summer wheels on...
  163. rotors
  164. anybody know anything about this car?
  165. Need some hood measurements.
  166. Can anyone recommend a mechanic in the Denver area?
  167. Got my lifters today TOTAL price $115CDN. 3 Days for shiping (NO charge) Quantity 8.
  168. bleeding brakes
  169. This aux gauge cluster should work eh? What d'yall think?
  170. Ok i need a new bumper stock one is all messed up!!!!!
  171. OMGHi2U!
  172. 88 90 Q antenna location
  173. rotor question / opinions: slotteds on front and cross drilled on backs.....
  174. audio help please
  175. diagram request
  176. Where can I get an...
  177. Bumper height questions
  178. Crankcase breather tube...
  179. A/C drainage problem?
  180. Need new piece
  181. Would this front bumper fit a type 89 audi 90
  182. Looks like those guys up in G.R. got desperate. Yellow CQ is on ebay now!
  183. Well, this sucks...
  184. Audi Sport steering wheel....
  185. Front Bumper
  186. Jim Bush or any one local to him, where was that yard that had soem CQ's and other such cars?
  187. Need to repaint my RS2 bumper AGAIN!!
  188. 91 CQ/186K miles. Thinking of rebuilding engine? Not sure how much it will improve power? any exper
  189. QUICK question: What is the offset and width(7?) of the stock 15" 10 spoke wheels for b4?
  190. cabriolet top
  191. Body kits, Bumpers, Skirts
  192. what would be different between RS2 lights with xenon conversion vs. RS2 lights with 8000K HID ?
  193. Finally......
  194. Location of oil pressure sending unit/probe/sensor/whatever...
  195. I seem to be going through oil although there is no leaking
  196. Before and after my new exhaust was installed i was smelling that nice fart smell from my car...
  197. I thought these looked kinda like an Audi 6 spoke wheel design....what do you think?
  198. Another new pic..rear
  199. hmmmm.......
  200. 17" ADR wheels 4x108, what do you think?
  201. Any aftermarket XENONS for 90's?
  202. Tie Rods/Front Bushings
  203. Audi Sport Header is in (Tubular, Equal Length)
  204. Windows
  205. Photos from the Rallycross
  206. High flow cats for 93' 12v part #
  207. Mr Miktip, a coupe post ago you mention flywheel bolt, to hold crank? can you explain????
  208. Coolant temp sender on 1991 2.3 20v (7A)...
  209. Anyone with an S2 front bumper...
  210. Engine skip (sorta long)
  211. S2 rear rotors at your local audi dealer
  212. Supercharger for a 12v V6?
  213. how far should the 3mm T handle reach to adjust the mixtrue
  214. GIRLS!!! (from DE, NJ, PA, etc.).....
  215. Can't get O2 sensor off. Need help!
  216. Aftermarket B4 hoods
  217. An American car mechanics nightmare, more crammed in than a fat lady in a mini....
  218. is the power window lock button and the 'L', 'R' buttons for the power mirrors supposed to light up?
  219. Um... ok.. but why? speechless. the fact that I am posting this.. I am sure....
  220. ALRIGHT! Who's In??????????????
  221. Woooo brakes are done...
  222. headlight cleaning trick
  223. Need new resonator for cat...Any suggestions?
  224. RS2 Bumper & B4 Hood Group Buy
  225. Springs? ;O)
  226. dose any one know a better place to get rs2 from then euro price
  227. brakes
  228. Found the start problem, thanks for your help
  229. A few pics from today's Rockville, MD meet up...
  230. NorCal Audi Club Marin drive rescheduled: June 21, 2003
  231. CV BOOT SWAP
  232. Intermittent power windows/sunroof
  233. Does this make sense? I have to swap to the 7a crankcase pulley.....
  234. need audi 80 body parts
  235. Any CQ's w/ black interior being parted out? Either private or by a yard?
  236. Help Help
  237. Help!!! Both Low beam headlights NOT working ...
  238. Removing the catalyst....
  239. German Audi goodies... should I get them?
  240. WAY off topic but WAYYY funny...
  241. Stuff...README!
  242. why are my window switches blinking!!!!
  243. speaking of lower door moldings...(again). CQ
  244. crank holding tool...
  245. Window Switches
  246. 1989 Audi 90 20v
  247. Bi-tone Ginster Coupe
  248. Just got my Audi
  249. New addition to profile, I can't stop laughing!!!!....
  250. pistons rings
