PDA
View Full Version : Audi 90 / 80 / Coupe quattro / Cabriolet
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 [122] 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259
  1. I never realized how soft my suspension was until...
  2. more race vids...
  3. Gear selector shaft linkage conversion to aircraft certified universal joint...
  4. Anyone try this lighting mod on a b3/4/cq yet?
  5. Just a reminder to drive safely out there....
  6. slammed pics from last weekend - forgot I put these in my picposter
  7. How many of you used Magnecor wires? happy?
  8. so my buddy took this picture...
  9. Is it possible to swap the round turn signal stalks for the square ones?
  10. Bleeding 1 of 4 calipers? your thoughts
  11. Got new tires... finally
  12. The new European Car is Audi-tastic. Look for the back page article about a 90q "beater"
  13. Bored and just wanted to ask...
  14. Accusump is temporarily mounted....
  15. nicee!!!!
  16. I'm back....
  17. What I did on my birthday
  18. RS2 headlight wiring question...
  19. :'(...
  20. anyone interested in a tubular header for a 5cyl?
  21. Has anyone put the repeater white faces on B4 aux???
  22. rear brakes on 94 cabby. Bottom bolt has locked up and not letting caliper to move
  23. lookingfora gearbox
  24. I am happy... my converter arrived today from ecatalyticconverter.com/
  25. So here we go agin......
  26. Ok why the heck was my gauge post deleted???!?!?!?!
  27. weird question..but I believe there are no stupid questions...
  28. heater motor problems
  29. 88 90 tails
  30. Good news.What color coolant do you guys use? I've seen green and pink on here.
  31. more race vids...
  32. damn power seat stopped working.
  33. AUDI 90 V6 RIMS SEARCH
  34. Idle problem when heat is on??
  35. not really audi but derrick bell rules
  36. Vag Code - My daughters 95 Audi 90 check engine light comes on
  37. still slow heat
  38. Headlight problem.....still!
  39. Who is getting this today?
  40. big maybe right now but......
  41. European B3 H4 headlamps plus white blinkers for sale!!!
  42. ok... so heres how my night went..
  43. Which sensor does the temperature gauge get it's reading from?
  44. aww crap.... time for new exhaust
  45. For those asking how I can pump, filter, recirculate & cool my manual transmission oil...
  46. rally anyone??? hehe
  47. Coolant temperature gauge quaestion 1990 CQ.....
  48. CrazyCab.. FWD rear anti swaybars.
  49. Hey everyone I'm back!
  50. 95 Cabrio
  51. Knock sensors plastic casing cracked and breaking in pieces. Should i replace them or not
  52. Blah. I take that back. Temp Gauge shows nothing. Fans DO NOT turn ON. Nearly overheated but got
  53. Ignition switch replacement 1994 90s
  54. car wont start. stuck at friends house. help. isv issues...
  55. Getting a 20v 90 friday! Have a question...
  56. Blown Heater Core
  57. Just curious, how many of you guys drive with your engine covers off?
  58. doors lock automatically once you change gears from park to drive?
  59. Okay one last problem. Temperature gauge isn't showing anything but I know the car has warmed up
  60. Some direct fit cat info ...
  61. keyless entry
  62. Oh man--My car is idling normal & the brakes are working again.
  63. The Duke lives again!!
  64. What a fricken joke. I took my car for a slow test drive around the block and my brakes barely
  65. Car idles a bit better but the rpms still bounce and dies from a cold start. White stuff &
  66. Someone please rent me the tools for replacing the valve stem seals. It's not worth to....
  67. quattro meets frog
  68. Best place to find a set of CQ speedlines?
  69. Just signed a contract on my first house purchase...
  70. Follow up question on a FWD rear sway bar
  71. manual to powered sunroof
  72. x-post
  73. They need to figure out a new scam! MOFOS!
  74. TaylorAutomotive has failed me for the last time...
  75. Head alignment pin broken. Sould I replace it or leave it? If yes, how do i take broken piece out?
  76. If I wanted to pick up a new PS pulley, what would be a good place?
  77. Super "secret" deal for the Valeo Ultimate series wiper blades
  78. Someting isn't right here....
  79. audi 5000 turbo motor?
  80. East Side Posse
  81. Audi80
  82. More free stuff... Has to go or it get's trashed...
  83. Teh hotness
  84. First snowfall with my 90q
  85. S2 speedo cluster diagram !
  86. so anyone try doing 4 wire to 3 swap for coupe(20v) yet?
  87. Having trouble pulling the ISV off. I have all 3 bolts off but there seems to be some obstruction by
  88. Questions from a previous Type 85 CGT owner. Also: suggest required reading for new B3 ownership?
  89. Pics for ScarGo02...
  90. pic post - yes... you can fit an automatic tranny in the trunk!
  91. Handling troubles/steering damper question
  92. Why do rotors get warped?
  93. stock "stamped" Audi pulley's are never quite true or concentric...
  94. Looking for 15" 4x108 rims... needed for winter tires... email....
  95. It's about time for White Face Gauges again.
  96. Cheap 94 90 Q in Colorado...somebody should take it
  97. B3 Bentleys for under $40? Where?!
  98. Guys with HID kits - question
  99. MikTip ..............
  100. How to change turbo's on an S4! :o(
  101. Wanted: Power antenna for a '97 Cabriolet
  102. My 90 will be gone in 2 weeks:((
  103. whats are my options for busted antenna on a 90S?
  104. Found a cracked hose between the ISV and underneath a green Y-shaped cable
  105. someone looking for ginster coupe? candidate!! url:
  106. Xpost... S2 at Rally NY
  107. Okay, anyone have any tips for getting at the little 10mm bolts to the ISV?
  108. Do relays click when they go bad? (longish)
  109. will a stock shift knob from a 2001 A4 2.8 fit on my B4?
  110. *UPDATE* After pricing Audi base bars, and board rack. It would be cheaper to just get a aftermarket
  111. One of my engine cover screws on the 12v won't come up so I can't take the engine cover off.
  112. Didnt really have the money for new tires - but now i NEED at least one.
  113. This is gross
  114. Sunday Bling - A Lesser Bling
  115. jjtjejhe
  116. DEEP SH*T!!! I open up the engine to replace head gaskets and cylinder #1 is not at TDC......
  117. What is this wire for?
  118. Video: 415whp 20V turbo - Javad's beast - have you seen it?
  119. Where is the TAB on the 7A?
  120. audi 80
  121. Slow night...
  122. 95 Audi Cabriolet
  123. Car not a happy idler. When I turn the car on, a few seconds later it just idles out and the engine
  124. Guys, would anyone around (Norht Jersey) let me use his tools to replace the valve stem seals? I ...
  125. Radio code?
  126. Opinion please, either a Thuel/Yakima roof rack or cutting down a Avant rack to fit. On a 95 90?
  127. What options do I have for an Audi 90 95 rear bumper
  128. FREE! audi 90 rear bumper cover, 4 black door panels and 2 tan audi 200 front seat!
  129. new desktop for joo! where's the cq??
  130. x post: blink codes, how to get em?
  131. got weird rusty bearing sounds coming out of my engine
  132. Need some Parts...(radiator, Pulley)...
  133. is it possible to put a 10vturbo head on 90 quatt. block...
  134. Maybe the best 12V spark plug boot removal tool ever!
  135. An altogether rare photo...
  136. Questions about polyurethane control arm bushing design.
  137. Picture day...*fixed*
  138. newb coupe question
  139. How to get brights to stay on?
  140. More cq questions... help
  141. Any of you see this?
  142. So..Regarding the drivers side Cat recall......
  143. From where can I download EtKa?
  144. could someone get me the codes of the mud guards for the B3 audi 80?
  145. Never been in an accident? It has a '96 A4 (euro) trunk lid ...
  146. Wow... cheap!
  147. Problem after installing gauges-I forgot where needles originally positioned
  148. Help! Camshaft rotated about 30 degrees CW when I was trying to loosen the sprocket. ......
  149. When its cold out, my car jerks forward when i start it up. Any ideas why?
  150. I think I don't have oil pressure anymore...... :-(
  151. One thing went right for me this week! I got my new vac canister and installed it...
  152. I stripped a G60 caliper carrier bolt (17mm)...
  153. Friday is picture day...
  154. b4 turbo conversion -- mounts
  155. MTM 1+ ECU on it's way soon. :-)
  156. how many 1990 cq's were sold in the US?
  157. real steering wheel bad wobble 45-60 mph...any thoughts
  158. S2 conversion in a wagon...
  159. Somebody with a B3 Bentley... can you hook a brother up?
  160. clear lens
  161. 5X112 16X7.5 ET40 wheels won't fit over brake upgrade, you want them?
  162. Paint color by model?
  163. I bet if you looked at a car done by "pimp my ride" up closely...
  164. Anyone tried GE NightHawk headlight bulbs yet?
  165. axle swap - grease inner?
  166. ignition switch problems
  167. compatibility between Cq and 90??
  168. So, after getting my address wrong (their mistake), Taylor is shipping out the part MONDAY, but ...
  169. Fan is constantly running! Whats wrong?
  170. i know this is an odd request...
  171. Motor Options HELP!(more)
  172. Does the TAP short ram intake have that distinctive SRI sound too it?
  173. Drove my 90 to the studio.
  174. Did anyone changed their seat? A4 seat in B3?
  175. Just curious, how much damage would it cause if I drove my car for a short distance
  176. Halloween pic...
  177. Early Friday bling from my trip to Italy...
  178. I need TB tools.
  179. Where would be a good place to buy a steering pump from? It's for a 1990 Coupe.
  180. Does anyone have info on the '01 Passat GLS?
  181. WTF?
  182. Front sway bar links
  183. So the person that was supposed to correct my shipping info left for the day...
  184. Anyone know of a cheaper alternitive...
  185. So near..and yet so far
  186. question here about what i should do,
  187. More complaints about taylor automotive...
  188. '91 CQ: Help with intermittent coolant sensor going off...
  189. Brake Lines what a PITA!! Advice?
  190. water pump 93 90
  191. I ordered clear corner from Importvision.com a few days ago...
  192. Any of you Cabby guys want to "Pimp Your Ride"?
  193. I found a glass etching guy who will do my new RS2 mirror glass with the following message:
  194. For those wanting to know the weight difference between stock and lightweight alternator pulleys...
  195. How much to have these shipped from Germany? Any help please :)
  196. Now that's funny
  197. Very little heat
  198. engine swap
  199. 18x8,5" with a 15mm offset
  200. another 6sp for you Mance. blatantly states it has the wide 1st gear.. the price will seperate mice
  201. B4 parts car cheap... i'm keen but it's WAAAY too far (Wisconsin) away fo me. car is pretty
  202. Anybody ever deal with www.expressautoparts.com?
  203. A few things I have if anyone is in need..
  204. What do you guys know about this!! I May Want One!!
  205. Hmm.. :)
  206. 2 Minor questions. Wierd defogger switch and only one rear fog light?
  207. Calling ScarGO02
  208. Anyone ever swapped a 4cyl for 5cyl engine in B3?
  209. Finally got my bushings from snolvr8....
  210. Anyone ever successfully remove the clear 'glass' from the instrument cluster housing?
  211. WTB: 1991 Silver Coupe Quatt
  212. I need to sorce a S2 rear bumper for my car.
  213. Mmmmmmmmmmmmm
  214. a jeep out accelerates a TT and 3 series?
  215. More oil-related boxes of new parts opened today while the Haltech is being worked on....
  216. Mmmmmmmmmmmmmm
  217. They sent the wrong god damn part.... passenger side cat instead of driver's side.
  218. Fake RS4 bumpah. [EDIT]
  219. F/S Rear Bilstein Sports for 80/90Q
  220. bling
  221. Cambelt change on 2.8 v6 is it easy ?
  222. 1991 Audi 90 quattro 20V pearl white for sale on EBAY started 10/31
  223. What tools do you guys use to replace the valve stem oil seals......
  224. Miktip, ditch the NEU S4 search and pick this up. (BWW)
  225. VR6 Swap
  226. repost? red on red..
  227. Buddy in Cols. bought another CQ off ebay.
  228. Check this out...
  229. Anyone selling 20 valve 88+ 90q?
  230. preseason opening day
  231. Is it possible to drop the oil pan on an 8v without dropping the subframe?
  232. Part# for red caps for cluster bulbs?
  233. Anyone running 20mm offset on the B4, with lowering springs? If so what size tire are you running?
  234. Silicone hose that fits the dual butterfly throttle body?
  235. best place to get a blower motor?
  236. When replacing a timing belt on 1990 CQ, what items are generally replaced...
  237. Looking for parts.
  238. will A4 floor mats fit in the CQ?
  239. MikTip! '93 90CS V6 - I got the T-belt kit from Blau and they sent me a MEYLE. Am i screwed or fine.
  240. Holy cr....p, my heater core outlet broke off....
  241. '93 90CS V6 Crank bolt - 24mm/12point - go figure
  242. can anyone find the coupe?
  243. Election - I like to count.....
  244. Like a complete dumbass I broke my vacuum ball. Anyone have an idea of where I can get another and
  245. CQ clutch questions
  246. Looking at 2 Audi's this weekend! ;O)
  247. Here's the next phase that starts tomorrow. I dont know much about it so I wont....
  248. L0rd of da rings
  249. anyone have a cheaper fuel pump for me????
  250. Anybody having problems with cheapwheels.com?
