- Wanted to send out a big thanks to JimBush
- any one looking to go widebody on their coupe?
- Anyone install VW Mk2 or Mk3 seats into B3 90?
- Tie rod end help.
- Summer Mileage Survey
- Headlight warning buzzer always on when headlights are on.
- How many of you guys will replace the front axles when you get to a certain odometer reading..
- Hey guys found this intresting.
- 90 CQ Intake Manifold & Breather Question (It was a free car)
- CQ Heat Box Modification Feedback
- CQ strut equipped with Mance BBSE, Bilstein UrS4 inserts, Mance Pro Mount and H&R springs...
- Cams, lifters, intake valves, etc. removed so my head can be machined.
- replacing this might suck....
- Anybody know anything more about this car?
- It's 5pm Saturday in Salt Lake...do you know where *YOUR* Audi is?
- Engine 'stumbles' when (non cold) A/C turned on
- Looking For: BLACK MOULDING *pic*
- 20v Intake Manifold
- Help with removing Strut/spring assembly.
- how do I take apart the trunk lock cylinder on my 88 90Q
- How to adjust idle? Where is the screw? Picture attached >>>
- what's the substance used on the ABS sensors... is it white grease? if not, what is it?
- Has anyone found "Pre-cut" window tint for the B3/B4's?
- Anyone know the servotronic relay number in a B3 (88-91) Audi 90? TIA!
- What is the approved way to fix the truck wires eletrical short?
- O2 sensor
- 97 cabriolet transmission ????????????
- MMMMMMM
- hmmm so are B4 and Coupe fenders identical?
- all dash lights on
- How low can you go?
- Aftermarket Fuel Injectors
- Question for red90q
- [Paging Hybrid_Hatch] Wanna go half n half on this car? Bet we could get them down to 200.
- Safety first....
- Its pic Friday, I'm not working today, got nothing better to do. Let the comments begin.
- Put 12V to AC compressor and nadda
- Trying to isolate the shimmy and figure out the A/C as well...long details inside.
- Junker CQ - Contact Info Inside
- AUDI 90 -- Audi's Turnaround Car
- Junker_CQ...cabby for you
- white tank in the trunk?
- On an Audi 90 & an Audi 100...are the window's the same size? Do they have the same dimensions?
- I'd forgotten how good junk yard therapy feels.
- brake symptoms: I'm still trying to isolate my problem
- why you a) do this on a closed track and b) wear a helmet
- Cab lovers
- Floor insulator...
- CQ: Driver's front half-shaft replaced and now I'm hearing noise in the car while driving...
- strut mount question (probably a n00b question) and a couple of other questions.
- part number request / hot start problem fixed!
- Anyone placeing a order form autohausAZ in the near future??
- Fuse ontop of relay is supposed to be there on a 1991 Audi 90 with NG engine?
- [Problem] Anyone have an idea why my interior lights just went out? f--------
- sticky ignition
- Ok....I've STFA, does anyone have a recommendation what to set ignition timing to?
- Are the front bumper shocks adjustable at all? (B3)
- Who runs / owns / takes care of / has anything to do with 20v.org?
- Am I missing anything for a tune up before I retry for emissions?
- Anyone want to claim this? [Cross Post]
- Spring claning!
- FOB gremlins
- Anyone have the part number and/or replacement for this side paneling? >>>
- I took out my carpet earlier to power wash it...and the padding underneath of it is trashed.
- How many quarts of oil does the 2.3L 20v take? Search results inside >>>
- Let's Go Celtics :)
- country road did me no good this weekend... Need you guys to help me!
- new picture from alaska
- exhaust leak on 1995 90
- so it's almost time to change that blasted clutch... (somewhat long)
- oil in coolant maybe
- New to the Forums
- Xenon used in Hi-beams? I'm always playing with my electrical system and now wondering..
- Anyone know Grant Collins from Bellvue/Seattle area??
- Burien, WA - Audi Expo - June 28th - Who's attending?
- gold plated t-stat?
- Picture of a Coupe with lower door moldings removed?? Is there a big gap to rocker panel?
- CQ Dash: Square vent-like grill in the middle
- Needing parts for 1989---90 (non quattro)
- 2 prong aux fan switch?
- looks like this cq is back on the market
- Steering damper removal question
- Anyone try this bad boy? Audi I5 20v Garett GT Turbo Kit - $1,755.00
- Audi @ work
- Shadow of Bob: Question regarding your a/c swap . . .
- What does your call sign mean?
- Has anyone ever converted the climate control unit from one of THESE to one of THESE? [pics inside]
- V6 coolant hoses.....how many total?
- Anyone know where I can find and/or pickup a Euro license plate surround? Like this >>>
- Found some RS2 Headlights on {fee}bay .... a little pricey [not mine]
- carpet removal
- alt confusion (ping skolnick)
- Any parts cars kicking around right now that have a trip computer switch?
- CQ Window problem. (comment/something to look for if you think your regulator is broke)
- question of the 8mm allen drain
- Real Values for Coupes?
- Why are trashed out Cabriolets expensive? This weekend went to see 3...
- SKF part # for 7A pilot bearing is 6002-2RSJ....
- For sh**s and giggles, I called the dealer to ask about b3 a/c condenser.. $538.21
- Ahh the boot looms....
- Quad round headlights?
- picture sunday??
- Which clutch should I get?
- HVAC Foam Elimination from '91 CQ
- Removing the rear seats in a B4
- Coupe window regulator - "worm gear" upgrade?
- my instrument cluster keeps busting fuses. any thoughts? thanx..dave
- I forget, can I change the strut mount without taking the ball joint loose ('93 90CS)??
- I assume that this is the stock fan switch ('93 90CS)?? That mounts in the radiator
- G11 and G12 prices
- Lots of pictures, help needed, details inside >>>> [good read]
- rims rims rims
- Confirmed. The head on my red CQ is warped.
- Had some rear UrS4 hubs machined down for my 5 bolt swap.
- Someone posted a link to a parts website that had an option for USA or Canada, can't find it now
- You could put wider rubber under these fenders!
- Listen...you can almost hear it :-)
- Exhaust Setup
- probably time to sell the 88
- headlights not working in the 93.
- Look at what I just picked up =D 1990 Audi 90 Quattro Sport...aka "The Beginning" >>
- Transmission problem
- How to fix? E-brake issue >>>
- Maybe I'm just paranoid, but I just ordered a locking gas cap due to climbing prices at the pumps..
- Not mine, just throwing it out there. Can look at it if anyone interested.
- New bearing and still having 'hummin'...
- im looking for a euro rear plate tub. some one have an extra?
- Saw a non-pearl white CQ today with B4 hood and RS2 lights in Vancouver, BC.
- Just a little FYI for those looking to buy a cq on Ebay.
- Please Help - 94 90cs q won't start
- So what does everyone think about the new M1
- My Upgraded Brake Master Cylinder came in earlier this week.
- International Shipping Question: S2 bumper
- Check this out.
- Anybody here still do caliper watching? Noticing what cars have gone over to BBK's.
- gotta hate rear noises
- Stalling issue and possibly related VSS (G68) issue
- koopS2 you out there? YGM! About Friday GTG.
- Anyone parting-out ? I want to find a bellypan/underbody tray/skid plate..
- 3-spoke Airbag wheel question
- trunk damper
- hydrogen power cell
- Seems to cut out when rains
- New front pads and rotors installed on the Coupe...almost. :-(
- true love
- ebay vag plug with rosstech software with Vista.
- coolant threads galore.....
- Fresh 1994 90CS in my local junkyard.
- Proper PS flush? I can of Pentosin to clean and 1 can to fill. Correct?
- how do you press in front sway bar link bushings without the proper tool?
- Anyone know where a good Clutch job write up is for a 95 90Q?
- I searched but cant find anything....
- Nice Coupe
- Need ops here guys>1994 AUDI 90 cabby, AUTO ,101k, 26-27 MPG - $4800
- bmw coolant should be the same?
- Getting the pulley off the alternator
- would this work in our cars?
- What we call "Quattro weather" in Florida...
- Pulled the head off my CQ tonight. 4 of 5 cylinders full of coolant. What are my chances of...
- Wheel size
- Does your fuel gauge do this?
- the strange and mysterious?!?@??!@?
- Front Suspension Bushing Replacement, 1993 90CS
- bump on cv joint
- 'km to empty' acting up --> became innacurate/slow to fix itself (days ago).. display off today
- Heater Control Problems
- ProDrive Audi to the white courtesy phone please
- /anger The latches on my back seats totally froze up. I broke off one of the levers, and
- those who did their own TB
- is this serious?
- Fan resistor questions: Where do the wires go? (also A4 resistor?)
- Ready for take off !
- Update with pictures of my front end damage. What am I looking at here, all suggestions appreciated.
- Driving past a Chevy (GM) dealership this weekend and nearly cried when I saw this
- Oil pressure/temp question
- remove power seat w/o power ?
- wow..3 for 1 deal on Audis....
- It's official. Blown headgasket on the red CQ due to popped hose which led to overheating.
- Stalling out in gear but idles great
- blau email?
- Guys who did Xenon upgrades on your RS2 lites...what ballast did you use?
- dealer$hip labor rates are up again
- voltage regulator
- 24 HOUR FATHER'S DAY SPECIAL 18% OFF
- Crawling around under the CQ today, questions for the forum
- anyone have a black hood for a CQ or a B4 conversion for my car?
- Parts link request. Someone posted a list of parts sources links on here and I can't find it....All
- alarm horn?
- Brakes any one?
- so I finally got around to getting the CV joint off....
- Improving AC performance on a '91 CQ
- new a/t fluid
- A few questions on a 1990 Audi Coupe Quattro. Yes, I searched the archives first.........
- TB at partstrain
- has anyone had the leather/cloth on there front 80/90 seats re done by a upholstery shop?
- Hey VAP, what is your reasoning to only put spacers up front on your car?
- Anyone have a b5 s4 or a4 sport rear sway bar on your B4?
- CCK's ready for assembly
- AFC question
- F1 Canada...Friday highlights...
- couple questions
- Why on EARTH would anybody do this to their Audi?!?!?
- temperature gauge reads half
- [Picture Request] Already STFA.....stock 90 20v quattro front end...direct shot...
- Biting the bullet, getting my A/C looked at next week
- Any way to replace the woodgrain panel on the front of the airbag without replacing the airbag?
- Ya'll got to watch this.
- anyone interested in a rare set of MASitaly Presidents? 16" x 7.5"
- Thank's
- Need selector fork
- Is Audi this annal? So I need a carpet for my coupe. I need one badly so I have 2 options.
- Another Coupe for the Stable
- So Pimp :)
- Any problems with using wheelspacers/lugadapters?
- Shifter parts help
- Removing windshield washer squirters. Any ideas? I've searched the archives and found the...
- changing air filter 88 90q,any BTDT to lift and seperate?
- I noticed a relay in my fuse box says manifold preheat location
- Hmmmm looks like I might have to recover the drivers seat. The leather ...
- Need Window Regulator for 1990 Audi 80
- Crooked Switches
- My clutch suddenly won't release...
- How to kill or turn off Airbag light after replacing CQ's steering wheel?
- EGR soleoid Opps
- Test drove a local '89 Audi 90 Quattro >>>
- Evolution.......
- Finally Done!
- I 've never been a fan of tan interior but I can check this CQ out if anyone needs me to...
- Keegan Bartel is a THIEF
- So what I thought was just a broken S2 fog turned into a muchhh bigger can of worms..
- Oil Pressure Switch
- Leaving today for Poland
- What type of bulb do S2 fogs take?
- follow up on axle choice
- Audi Expo 2008 - It's almost here!
- What is important to you when rehabbing a garage. Adequate lites?
- S2 Fog's
- Console removal help needed
- To those parting out. . .
- Audi b4 Lowering
- Are alot of the audi 80 -> audi 90 parts interchangable? Headlights, tail lights, etc?
- Another from ebay.de >>> actually NOT that bad...
- What would be some of the most common problems with a 1989 Audi 90 Quattro?
- Uh oh.....timing belt question
- Something that just happened to pop up on German e-bay & noticed on Motorgeek.
- Question, what kind of springs do these look like?
- Still dealing with my brake dilemma on the CQ.
- audi 80 quattro 2.8 v6 1992 elec.problems,no wipers,indicaters,heater...
- brake pad opinion so far as it seems
- CQ: Those with custom exhaust/mufflers...and kittys...
