- Ugh, 18+ year-old...water-logged carpet and padding is nasty schtuff...
- good place to get "hella h4 h1" lights?? gotta have em.. thanx..
- bleeding brake fluid,flushing coolant
- instrument cluster for this car
- Ode to our Honda buddies...
- VAP you have mail.
- New to Audi's, Need HELP!!!
- Power Steering Leak from Washer on top of pump
- What's the paint code & name of this color?
- Help/Ideas needed - possible clutch issue
- mount saver question sachs boge
- Messing with the laser @ work today
- Might be a simple question, How do i remove these window regulator wires?
- H&R springs on CQ. Coil stack?
- VP update
- fair price for ronal R38's with rubber? (edited)
- Found a CQ for sale in San Diego
- Ughhh
- 255/40's on 7.5 wides? Think it'll be ok?
- H&R vs. Weitec
- New job Monday morning, my b3 is all set and ready to take me 60km/day, 5 days/week
- quick question, will 01 Audi S8 front Brembo calipers work on a 95 90Q?? would i need
- 93 90s central locking system
- Taking a look at the cup on my strut towers...
- anyone know the pat # for the european one-piece headlamps for the b4?
- Aux Gauges Dim, 4 volts at each globe?
- Rear brake problem (edited)
- WTB Lock air pump
- How hard is it to remove a b3 front bumper?
- Anyone live in Kent? Maybe you can persuade him to ship it?
- Has the market dropped out on CQs?
- Update on rough idle issue
- was it you?
- Another use for coupe quattro tail lights.
- Morettes are for sale in the UK if anybodies interested.
- Replacement rubber trim under the front of the hood? (Or alternative?) B3...
- Need CQ window motor.
- cluster light problem
- After a 4 year hiatus from the event the Hoppen/MTM/Champagne B5/S4 is back at One Lap of America...
- What song makes you want to put your foot down on the GO pedal when you hear it?
- Bolt size for stamped CA ..
- which guage clusters will fit in my 1990 audi 80
- 80 idles rough and dies... Help!
- Audi Expo - June 28th
- still pulling codes! now p0303 misfire and p0174 too lean
- What Radio unit is this?
- Well that didn't last long.
- Ladies and Gentlemen, Riverside Audi's Online Parts Website, AudiPartsDepot.com is now live!
- I'm going to be frank, where do I shave?
- RS2 steering wheel hub
- Junker CQ
- Anyone have any of these laying around?
- Woot! New windows regulator finally got delivered to my parents house, now i just need to find...
- Looking for a black B4 Hood or grill/bumper for my 90 CQ? Also RS bumper? Where should I look?
- Where or how can I get RS 4 Wheel look alikes for my CQ? Can they convert them over to fit? Does any
- ignition coil??
- So I went to replace the fuel filter...
- For those who have upgraded their B4 to a 200TQ Master cyl...
- front end knock...
- V8q engine swap into 90cs Auto 2WD
- Scammer Jaredd Tilford on Audifans
- Removing ignition lock assembly - where to drill??
- Suspension
- New member. PLEASE HELP ME!
- steering wheel
- Does anyone have the link to the Canadian guy who made the lightened harmonic balancers???
- quick question
- Hi , everyone I usually post on UrS4 forum but well I was sent here from there and wanted to ask ...
- C5'ver asking for your assistance...pls. (POWER WINDOWS)
- "The All new A6 Dolphin, now equipped with Sonar" :)
- FS: 1990 Audi 90Q 20v
- 90q20v wiper switch part number question
- there's no reason to use 2 oil pan gaskets on a 7A unless you have the windage tray..right?
- If I had the money I would buy it
- No work today = pictures
- Looking at a 1990 Audi Quattro Coupe
- Which is faster...our CQ's or a 1976 Porsche 912?
- car is back together...
- ebay brake rotors
- I like the way this Cabrio shifts
- be glad we drive "cheap cars" meaning inexpensive...
- finally finished the 5-lug swap on my coupe
- T-belt - is this the tensioner (idler pulley) I need?
- replaced ignition switch today and the car started right up..
- Power Loss in my 90 quattro
- Japanese imported Audi 90 20V for sale in Calgary.
- Vacuum Unit For Defrost-Correct Part Number?
- 4 week timing belt job
- Interesting discussion on UK S2 Forum about RS2 sedans....
- Keep or dump Cabrio
- while looking at rear shocks (koni bilstein etc) i noticed that they dont specify whether or not
- Whoa, anyone seen one of these steering wheels before? Reminds me of the newer B7 option wheel.
- 1-2-3 push!
- new addition to the family!!!
- First time painting!
- Replacing valve springs -- anyone have an OHV spring compressor I can borrow?
- overheating
- Exhaust question: What specifically causes that "rasp" or "buzzy" exhaust tone?
- %&*#ing RUST!!!
- CQ FS in PNW (Portland)
- Here's some snake oil...
- Audi LRU, any luck?
- anyone running a 215/45 on a coupe 17x8? pictures?
- Looking for pic of white speedlines....
- Cq fuel mileage reference check (another reason to like high-test)...
- Just used Evapo-rust...
- High Pressure Coolant leak... odd?
- Starting issues
- I just brought what was left of my parts car to a metal recycler...
- Where can I buy the tool for the weird castle nut on the strut inserts?
- Europrice is back to it's roots...
- WTB struts/springs 1993 90 csq
- Replaced ignition switch...car still won't start. Need advice.
- Photoshop Friday??
- Anyone in the Toronto area interested in a set of factory 16" cabrio 6 spoke sport wheels?
- AC Coil Mounting Stub broke :(
- No grill is the way to rolll
- Coooooooooooooooooooooouuuuuuuuuuuuppppppeeeeeeeee eessssssss
- quick/stupid question.. where's the resistor pack for the blower motor? (I'm 500km from the CQ)
- question, there is a 2001 A4 2.8 30V with 200,000KM on it at a local..
- 1993 90CS Won't Start
- I usually refrain from commenting about other suppliers
- 1995 90s suspension ideas
- 034EFI Stage 1 7A Chipset now availible, details inside:
- AC relay questions
- Oil leaking assistance please
- I went heads up with a 240sx last night.
- Anyone have a turbo whine come from your alternator?
- hey skolnick, do you think you could squeeze a 2.7tt ina 4k cs?
- Easy to replace faulty sunroof motor mechanism?
- Found the problem with my ignition switch.
- what are the differences between the "sport sedan" and the "sedan" 90Q?? thanx
- Anybody wanna buy this warehouse and parts stock in the Fatherland?
- Somebody wanted to see a pic of the 16" A4 Sport Wheels (Swing) on my CQ
- Anyone know if VAP is healthy enough to ship parts? :p
- 50,000 mile 20v Quattro... what's it worth?
- CrazyCab spotted??? Tuesday in Lincoln on 126 heading to Wayland...
- any more suggestions for a rounded o2 sensor nut? still stuck in there.
- 1991 Coupe in Denver for Sale $900
- A/C doesnt work. Mech said system is blocked.
- Help me decide...
- Black speedlines...
- dealer just quoted me $77 for an ignition switch
- ah the leaky V6
- Check out the Truth in the Blacklist clip...
- It's no rocket ship, but a properly running Cq with 034 injectors is pretty darn fun!
- High RPM hesitation problem '93 90q- HELP!!
- Breakdown of cq's by color, anyone have any info....
- what wheel bolt pattern to the CQ's have?
- Just got back from LA this morning. Some observations......
- Black CQ progress
- Painted BBSE equipped strut with new UrS4 Bilstein sport installed.
- Lifespan of battery
- possibly buying a coupe quattro or a 90 as a second car, need some help.
- anybody parting a 95?
- making some progress on the 90q 20v
- Awww, it was not the sunroof drain after all!!!
- Anyone have the UK ebay seller ID who ships euro bumpers worldwide?
- I5 all aluminum replacement radiator candidate?
- I think my ignition switch just died - need advice and help
- Part Number Help? . . .CabCrazy's picture points it out.
- I made a little progress on the black Cq today. I pulled the dash and center console.
- I've officially got a horseshoe up my...
- Curse You Valve keepers!
- '91 CQ cruise control diaphragm-throttle rod connection clip
- How do you put the serpentine belt on a V6?
- any locksmith amateurs in here?
- WTB central locking pump
- anyone in new england, looking to sell 80 or coupe?
- where to buy rear stock sway bar link for 91 cq?
- i finally sold my a4 last monday and i'm thinking about picking up this UrS6 (cq content inside)
- Wheel options?
- I thought all B3's had power sunroofs
- WTB: All four door panels for '95 90Q. Black/leather/woodgrain
- Wire-wheeled and painted the VAP Big Bore Strut Extended struts today...
- Skoolie and others with a sub in there spare tire well...I need inspiration...
- check this out
- Oil temp Gauge Malfunction
- calipers
- Will a glass sunroof from a 93/94 100 fit a 90 CQ or 95 90Q?
- quattro dash badge
- 91 80q shock/strut recomendation
- 94 90CS 4 door at local pick n save. Any one need window regulators?
- stripped an oxy sensor, now what?
- howdy ya'll. anyone out there have a front bumper for sale (dietrich, rieger, etc)??
- Found a nice (euro) steering wheel for my 91 20V
- check out this: for sale on ebay
- OUCH - filled up the CQ w/ 18.2 gallons of 91 oct, San Diego prices @ $4.10 a gallon...SHEESH
- Saw an A5 on the road today...
- Speedometer calibration possible?
- Dealer parts for our older cars...
- I am so happy. After 2 years my Cq is finally running perfectly. We'll see how long it lasts...
- B4 Quattro - Bilstein rear struts listed here.......
- Finally!!!! The hot start problem (and winter cold start problem) is resolved!!!
- 1995 90 Quattro for sale in AW classified
- New suspension goodies! :o)
- Muffler
- which plugs to use on the 20v motor? Search says 'F6DTC Bosch'
- Passenger Side Wiper Arm for '95 90 Needed
- Gonna be in LA for 5 days. Any good boneyards and such for CQ's there?
- Anyone looking for a coupe
- Looking for Suspension
- Mance... ygm... CCK spec sheet.
- Looking for good condition and reliable 90cs
- wheel lugs
- CIS Starting issues: Massive amounts of fuel dripping from exhaust
- What do you guys think.
- Emissions test results...
- So has anybody successfully converted a Cabby into a quattro. I know of 2...
- Need drivers side window motor for CQ
- BIG WORLD OF TROUBLE
- once 02 sensors are replaced what is procedure for resetting CEL?
- worried about blowing cats bad o2 sensor
- note about spoiler brackets
- Typical wait times for ImportVision?
- B3 90 front left hub carrier. Anyone have a spare?
- anyone in CT, or nearby interested in a '91 90q20v for fairly cheap sometime soon?
- I know this has been posted before, but its so cool I couldnt help myself....
- Anybody interested in a CQ? White and in Chicago. 73k on clock. Not mine.
- WTF is going on here?
- VAP BBSE with UrS4 Bilstein pix. These will go in the red Cq.
- oxy sensor replacement 2.8L v6 12v 1997 cabrio
- just picked up a 1990 90q 20v in vt today for $500!!!!!
- White B4 on a flatbed on the 403 today.. anyone here?
- rust
- ETKA help, can someone check these part numbers?
- got one quick question ?????
- Rough Idle, 1991 90-10valve
- auto quattro?
- burning oil -- what to do?
- Repost, 2.7tt in a B4
- Re post - Miles per gallon
- Where did my drivers seat heater switch harness go!?
- 90 cq
- How can I identify if a tie rod end is bad?
- ok, so ive been reading the archivs on S2 hubs. im not quite sure this is the truth or not, but, do
- Wet driver's side carpet & drain holes
- what causes excessive center tread wear on a tire other than overinflation?
- 91 80q rough running
- computer crashed... lost my ETKA, need help.
- Just have a question about intake manifold materials...
- Do you have to change anything else when converting from B3 to B4 fenders?
- Help with mystery wires in CQ
- I did like I said I would. I dedicated this Friday night to Audi. I removed the seats from the
- PSA all Audi's have turbo's even the non turbo Audi's.
- ok, another sillii question. are there any porsche hubs that will fit a 90Q?
- Looking for a DIY alignment link
- A/C Compressor For 91' 90 Quattro Sedan
- if i wanted to drop my 95 90q, say 1.75 - 2.0 inches. how much of the coils would i need to cut??
- \m/
