- Free 90CQ hood
- If you're gonna be a dog, why be a chihuahua...
- Niiice
- New here
- For those with a remote interest....
- A quickie video of the AAN/A4 Pikes Peak car...
- AC BT, question...central vents are non-functionable and the control head...
- FWD Front wheel bearing tool
- Suspension Creaks Solved..finally
- B4 interior trim question-
- Pop open CQ windows...
- girlfriend is lookin for a audi cabrio...preferably a quattro and under 6 thousand...
- Finally I towed the CQ home and started pulling the 20v...
- anyone here going to the W.E.M.F.
- DING....here you go...TIRE last phase...props to audi12valve
- Audi 90 manual tranny in a 90's cabriolet?
- Is there some special way to bleed and change rear pads on a 1990 20v 90?.....
- Anybody ever replaced Center driveshaft bearing on the CQ as per 20v.org instructions?? More inside
- Anyone got hi-res of this pic?....BIGGER
- NEEDED- Diagram of Rear Diff/Suspension ASAP
- For my CQ's 145k mile Bday, it got some new kicks...
- Looking for pictures of black B7 RS4 test mule with blacked out tail lights
- are 993 Porsche Mirrors the same as RS2???
- r12 - r134 conversion
- Anyone here planning on attending the ALMS race at Lime Rock Park July 4th weekend?
- Has anyone installed a remote start on their car here?
- Thinking about putting this on the CQ. Ops?
- caliper guide pin boot part number for G60's - Scargo?
- Ronal wheel SALE, 17" R38, etc.
- Question? Coupe fenders = B3 sedan fenders, I searched
- Materials used to polish the wheel on the left
- Front upper strut mount replacement...
- All i really wanted to say was....
- Did somebody just run away??
- Window regulator replacement pulleys
- Road America is cranking up! This weekend is the June Sprints, next month...
- Ok got a 20v sedan again :)
- pictures from a local get together, i was the only older audi
- Got back from Indy this afternoon(long)...
- x-post , when i get bored crazy things start to happen to my car :o)
- Any of you have the stock stereo you want to sell?
- ok, well.... Its really bad news (finally) for my '94 90 Q
- Instument panel lights not working . . .
- An over-shadowed and hollow success on Pikes Peak today....
- What would cause a pulsing alternator warning lamp? B4 93 90q.
- 96 Cab Transmission Swap
- do "high performance" wires make a difference...
- Tuesday Picture day
- Can i remove the valve covers without messing with the camshaft?
- and yet another pic...
- found an old pic of the coupe
- Disc Brake Piston Tool
- running really ****ty...
- Guys running lowered cars, think you should have a skidplate on your ride?...
- 94 90s window and sunroof relay
- Somebody needs to get off the crack
- Looking at a 91 coupe quattro...any specific problem areas?
- oh and I can't remeber how to get the colum switches off
- before I call the strip houses, was wondering if anyone had a computer column switch/wiper connector
- 90 exhaust?
- 6/26/05 - Krispy Kreme GTG in Newington, CT
- Thinking of getting the old lady an A3
- Rally guys (owdlvr, Squidix9, etc...).... I need to converse with you about skidplates
- need some help
- If I had the money!!
- What are the Brake hardlines on our cars made from? Regular steel?
- I need a borbet wheel center cap. Anybody have a spare?
- Audi tranny to a small block....Where??
- New Sound System for '88 Audi 80 Quattro
- Subaru bumper 90% done, good enough for now.
- Does anyone have a nice pass side center taillight for B3 90 (big red) for sale?
- 5th Annual Audi Expo - Schedule:
- xpost: many pics of gm's ghetto coupe getting a good workout...
- Is having rims with different offset in front and rear bad for quattro system? Same tire size though
- power top issue
- Starter trouble...fixed
- 1994 90s 4 door
- So i got the tires switched for free..
- Is the ECU between the 1990CQ and 1991CQ interchangeable?
- Bad P-shop modded S2 idea from UK. Urrrp. Where's that trash bucket?!
- Need shock help
- Anybody tried using V6 12V B4 airbox on a 7A Coupe?
- Got new exhaust today
- timming belt advice
- 80 Performance
- Does anyone know if the rear brake...
- Different 3 wire coolant sensor replaces a 4 wire?
- Code pulling question - only asking after search
- besides bigger brake kits, is there any other option for better braking
- 1994 audi 90s
- I keep havin bizzare brake issues
- If a tire is mounted backwards (tread is going in other dire4ction)...would
- Clutch weight
- Cleaning my EGR....Suggestions...
- Questions on replacing upper bleeder screw coolant pipe.
- A/C compressor FS on EBay
- is it unheard of to have manuel seats that are heated? im talking about aftermarket seats, recaro?
- hard starting if the fuel pressure regulator is worn out?
- crazy thought
- Does the headliner piece for sunroof has a separate item#?
- Anyone have any experience with the cheep E-bay ETKA's?
- Formula 1 at the brickyard
- 20V knock sensors
- WHOS GOING TO THE BURIEN WA MEET ?? only those going reply
- Thanks for the info the other day with regards to the 7A build up...
- well got the temp sensor for my b4 v6... but...
- Kamei Honey comb vs Kamei Sport grill
- what do you think about these
- Doors
- RS4ktq - you RSVP'd for Burien on our meet site, will you be joining our cruise or meeting us there?
- Can anybody tell me where these parts go when I change the suspension...
- tomarrow is install new head day!!!
- Scargo......
- AUDI WINS LeMANS!!!!!!!!!!!!!
- now this is a funky colored cab!
- Anyone know where I can get Borbet Type E 16 Inch?? Or any Borbets for that matter? Thanks!
- Bypassing the heater core
- fuel supply line(to bottom of filter)
- Well it took me long enough but they are on & operational......
- What tire pressure would be considered "normal" for a yokohama avs 100 tire at
- so far in lemans on speed audi is 1-2-3! not too shabby
- MIL-H-5606 Aircraft Hydraulic Fluid as substitute for Pentosin?
- Where is the coolant temp sensor located?
- Audi 90 quattro wheel bearings...
- It's like christmas all over again, this should keep me busy for a while...
- Looks like I found a Coupe
- Paging ScarGo!
- nu-cq, YGM at e-mail listed here
- Another miletsone
- car has been idling very rough and hard starts for a while now
- when a prank gose wrong
- What do ya think of this?
- RS2 me!! RS2 me!!!
- friday pic post/projects
- finally rounded up the batteries to the remote
- And for your viewing pleasure, the Supercharged S4 that couldn't.
- REMINDER: GTG IN WALNUT CREEK,CA TOMORROW 4 PM, BROADWAY PLAZA
- Friday pic of my seats
- anyone herd of starla exhaust. I think they are swedish
- Friday Pic day, my favorite Cab wish I could have one
- Joe (NoNonsense)...you da man!!!
- What goes where? Fan wiring schematic to Resistor Pack/Plate
- happy birthday to my car
- so the girl in the pearl 90 wants to buy my cats for me
- Me and bubuski in Toronto
- absolutcq20v The new sig is awesome.
- Can anyone tell me which one i need??
- better than stock
- Listen to this crazy crap...
- Hit or skip? Friday bling, bling!!
- My center muffler rattles when I whack it..
- Scalding Sensation......
- ugh... why do i always get stuck with the honda kids...
- NE1 knows costs to change knock sensor 2?
- Oil Leak. Help.....
- Don't forget to register: 2-day ACNA driving school @ Streets of Willow - July 8 & 9th
- So long, and thanks for all the fish...
- My speedometer is going crazy
- Anybodu has a spare V6 airbox from B4 90 they would get rid of?
- New System Installed
- cars temp is going wonky
- Gas Meter
- I need to get my low beams to stay on with my high beams.
- 12v Overheating Problem - Stuck and Need Help
- My long to do list
- Audi 100q Auto $1800 135000 miles.. Hit or Skip
- took a look at my shifter, thats odd.....
- It appears that Auto-Cross has a different meaning here in Aust >>>
- Auto-Xing my 90 20vq for the first time this weekend, any suggestions?
- 9 days 'til Audi Expo! - Have we heard from you ?
- buying small items local.....any luck?
- damn hot start problem
- Heres' your chance guys, dont miss out on this one!!!!!
- Best place to buy clear corners
- 1990 90 needs help
- Can you only get mineral PS fluid from the dealer? They want $23/ltr
- any known instances where shift linkage can break?
- OT CF question for you CF junkies
- Anybody have any extra parts?
- So the wheels were balanced and handle awesome at 90+,
- injectors with grey connectors?
- How to open hood with broken release cable
- OK I have had it, the Coupe is going on Monday
- Damn wiper switch has gone bad
- 88 90q for sale - - Boston
- Today is my last day of High School, tomorrow I graduate...
- opinions on motor set ups....
- Anybody has that memo from Audi saying 12V's will use a bit oil - normally...MikTip? Others?
- Good place to buy a CV joint/boot/greese/clips/?shaft? online or in the GTA?
- anybody ever bought from etires.com?
- first attempt at a sig with real pictures. thoughts?
- Are Brocks balanced from the factory? or would they need balancing once mounted.
- what does it mean when i rev and then it drop below idle rite after and stalls
- Repeater,..
- Looking to do a Big brake upgrade Porsche vs. 2B kit....
- Autocross tyres for a 90q20V (205/50/15) - X-Post
- AKTE please on EVAP canister purge valve....
- driver side rear door replacement
- to those that have or had a 4 banger
- The car is broken
- Repeater this one's for you
- A fabricators top ten site....
- S2/RS2 bumper-cover
- to anybody thinking of upgrading their shifter
- Mance Preloading Strut Brace Group Purchase Update...
- Requesting backup
- Here's the "noise insulator" urethane perch shims for coilovers...
- heres the engine code thanks for checking for me scargo02
- The BOOM Box!
- Got a 7pc set of FlexHead Gear wrenches for $40 at local fleamarket....
- SOMMERFAST 2005 German Car weekend in Stowe, VT June 24-26
- Please Help Identify Engine
- Weight difference between a 996 caliper & a G60 caliper?
- Replaced rotors and pads, and now i get a rubbing noise,
- Tim! Q.P. calling Mr.Reepeetair! did u ever solve the squeely A8 rotor + 993tt caliper problem?
- nor cal people,update on the meet on the 18th in walnut creek
- $146.26 for 5 cylinder condenser?!!?!?
- This is just hilarious....
- trunk lid rear left light. any1 have 1 for sale?
- How does a chikaan turn into a cathouse?
- well it sounds like my driveshaft bearing is goin...
- best way to remove a o2 sensor
- Dual bulb B4 headlights????
- Changed front brake pads on CQ... do I need to reuse that metal bracket that was screwed on?
- Is the eBay Car Parts Wholesale B4 hood any good?
- (Edit) WTB: RS4 reps 4x108. Email me if you wanna get rid of one set
- damn. missed this one
- Wheels for sale??
- Is Brdman* still selling the white guage faces and accessories?
- Are these cabbie wheels? What size? Porsche Red calipers in there.
- Problem with the heater
- Cheap Junk?
- shokan wasnts 245 for a USED b4 spoiler
- Does anyone have a pic of TSW Imola's on their car that they could post?? Thanks!!
- Big up to Xel, qPilot and KoupeKrazy for setting some fast lap times and for some great racing!!!
- is there anyway to tell exactly what year-model car an engine came out of ?
- 1990 QC 1.8T for Sale
- Where is A/C condensor
- Their first day together. :)
- Anyone have a source for a b4 spoiler?
- So i go into a local parts store and I inquire about corss drilled rotors, and the sales man replies
- Now i'm pissed!!!! I'm showing a buddy my rally lights this morning...
- Does a 7A has a coolant drain plug on the block?
- Campbell/Nelson or Shokan for rear diff...I have a choice, anybody have experience with either/both?
- Any idea why shokan would ask for my VIN# before I can order parts?
- 2 questions about brake lines and their couplings....
- Solid mount upper seal replacements for stock Audi dust caps are now available...
- hay you sedan guys...search this...
- My new Coupe...
- Thanks for the help
