- Ice storm fun...
- audi smoking out of air vents
- replaced thermostat and now its leaking
- B4 90 Quattro parts source question
- It's been a while....Saw a pre-'90 90q on 85N of Charlotte NC tonight
- red CQ around the university of akron in ohio?
- Mance YGM!
- Damn, CV boot is torn!
- If it wasn't winter...and snowing like crazy....this would be mine...
- Poor MPG
- Ignigtion/Starter problem?
- Question for Dave..OWDLVR
- hey iProDrive here is the answer to the question you asked me
- Alarm went crazy. ('91 90q20V)
- w0000000000000000000000000t!
- there are many cases where many of us here know other members inside a 4-5 hour drive radius...MAX
- Anyone have any spare Key parts??
- 1995 90Q newbie here...
- RS2 Bumper
- My car might be a right off :-(
- Hey old B3/B4 friends... I'm wondering if you can help me out!
- Temperature Gauge
- Interesting bumper on E-bay. RS2 Bumper that is a trial part???
- 88 90Q trying to pass emissions. Need some advice. (long)
- Anyone have a picture of a Coupe Quattro with the stock spoiler removed?
- handy link for anyone "new" to Audi/VW's
- Bottom trim for CQ
- ABK engine question , help :)
- 1991 90Q 20v when parked with heater on smells like getting exhaust in car
- installing new tierods and control arm bushings in 1991 80 quattro
- rear wheel hub
- I think this should work well
- I just spent 1/2 Hour looking for anything on Rad removal in the Bentley......
- Anyone know the german word for this piece?
- Newly Painted 1993 90cs
- Europrice - Double Sale! Holiday Specials and Currency Exchange Sale Combined...
- B4 90 with Polizei livery? Does this exist? Pics?
- How many hours to replace the fuel pump? - audi90qcs
- Washer fluid tubes keep disconnecting...
- New heater core, radiator and thermostat. Car warms up and cool properly, but terrible heat...
- How many of you would have bought a 90 Quattro Avant if Audi had sold one in the USA?
- where is the tranny fluid fill plug (B4) ?
- Will the B4 strut brace fit in a B3?
- Speedlines before and after + some audio goodness
- Rear diff lock might not be working.
- Cheap repair = Huge improvement
- New weird find...
- B3 80 and 90 windshields the same??
- need a front bumper cover black 1993 90CS
- When ever I need to find wires or stuff under the carpet etc. This is where I look.
- is there a difference in between these part numbers?
- car alarm
- *paging jim bush*
- Miktip made the readers rides section of Eurotuner this month. ;o)
- Transmission Noise
- not mine very clean silver audi 80 on my corner has a for sale sign.
- STFA about harness bar width and found nothing..
- Picked up a new ride yesturday...
- I need a 1991 cq maf in working order, anyone have for sale?
- Should there be a cap or something on the spring under the X-plug on P.S. pump?
- ticking noise
- 1990 90 coupe quattrro 220,000miles replaced fuel regulator wont start
- any directions for thermo-stat replacement. Audi 90 1995 12v FWD
- Car over heats, the car is a 95 Audi 90 FWD (more)
- Air Mass Sensor Wiring
- RS2 headlights
- 1993 Audi 90CS
- Is there any salemarket for parts on this site ?
- I'm convinced that my car doesn't like new spark plugs!!!!! :(
- Driving this home tomorrow for $300
- Stupid ISV almost murdered me this morning (well... my 20v at least)
- Just wanted to share...Snow and ice on roads in Denver last night...
- FINAL REMINDER: EPL's 2nd Annual Dyno Day/GTG - TOMORROW
- I'm bored and this is what you get...
- So....I think a part on my audi is broken....Throttle Potentiometer part needed....
- Brocks
- What price range can I get for my Coupe
- HELP!! Where is a good place to buy conrol arm bushings and other items...
- What is a Pedal worth?
- Transmission mounts... what's the alternate source? Allroad?
- Before and after: <Brake content inside>
- From the '92 British International Motor Show
- *sigh*... time for a new heater core...
- 1989 audi 90 urgently need high pressure power steering hose
- How in the hell do I remove the tail lights from my 90 coupe?
- yet another driveshaft question
- How many of you guys get a false reading that the coolant is low? I put a new coolant bottle...
- Work Sucks!!!
- Backup lights still don't work....
- 1995 Audi 90 Airbag light
- ROTFL
- 4 amp mysterious drain
- Wandering Idle Solved - Part Request
- this is an odd request.
- Already queried Pre95, but will ask generally...
- Pic request: B3 front end on a cabrio?
- Still having a/c issues.. replaced switch, relays. Still staying on.. what else to do?
- Ignition switch symptoms..
- front bumper
- Ryan (SCarGo02)
- Reminder : EPL Dyno Day this Saturday!! (2 spots still available)
- 1991 CQ - Center Support Bearing
- car doesnt crank..think it could be related to my car alarm?
- Oh, boy - did I do a stupid?
- Need urgent help!
- Tachometer randomly stops working. Quick tap on cluster glass springs it back to life. Common?
- My odometer stopped working. Tried searching, but unclear if its a 15 tooth
- Ugh. Just got notification that emissions are due. Any advice on getting 20v through?
- Finally pulled codes for no start...got 2114
- Hub removal
- Vermonters: really nice white 94 or 95 at Rathe's with Jaquard interior
- replacing cruise actuator
- Brake calipers need replaced?
- fuel in oil when car sits for a while.
- help
- Picture of the soda blasted speedline...
- Any one have any quick tips on replacing all of the belts? Bumper removal necessary?
- After market stereo guru question - did you re-power the amplified antenna?
- Switching to manual climate in the Coupe (Few Quick ?'s)
- Electrical Issues on 1996 90 Q
- Chassis Serial number
- Two post spoiler FS!
- Pulley squealing like crazy!!! How do I fix this???
- Crank Lock Tool in Calgary ?
- bamboo cq in CT...anyone's?
- Sad GM....sad
- Quattro, winter and snow tires.....
- Newby question on Cam Position Sensor
- Gas in Oil
- Managed to find a bubble flare tool and some metric fittings...
- Rear Caliper Rebuild
- Little help please
- found a 2bennett strut tower brace in the back of my garage. anyone interested?
- Cheeeaaaapppppp cabrio for you topless drivers...
- Removing Diff lock switch from console....
- radiator wiring
- Free 4000 stuff
- Interesting trade proposition
- Diff switch and anti-lock switch
- Stainless braided lines...
- Suggestions on california smog OK catalytic converters? 7A 20v...
- rear defog switch
- new ign switch in and no start this morning...
- Did some trim repair over the weekend...details inside...
- '96 Cabbie on the Cheap!
- Rear brake line question...
- Coolant circulation questions....1990 Coupe Quattro 20V engine..yes I STFA but I'm still puzzled....
- Had the Speedlines soda blasted
- For Sale: 1990 90 Quattro 20 Valve $500 obo
- Over heard at a P*P Boys between counterman and a guy who owned a Benz...
- Installed the block heater this weekend...
- Brought home another Audi this past weekend.
- Had some work done by a audi tech and was curious about parts pricing
- Rough idle issues.....
- Hey, *here's* an idea...
- Switzerland
- I've been searching for tech articles on b3(7A) A/C delete.
- '91 CQ Steering Rack Pentosin Leak Stop
- 20V Manual Trasmission Fluid
- 20v starting issues...
- One more question about Cabrios....I'm looking to buy a cabrio,either...
- Just brought home the 80Q
- Pulled the red plug on the a/c rad, a/c fan speed 1 still coming on at all times. What else?
- A4 transmission mounts (help please) SCarGo02?
- First few inches of snow in Iowa stuck today! The Quattro approves =D
- Correct me if I am wrong...
- Alarm imobilizer
- timing belt tool kit for rent in Burlington VT area?
- Lastly...
- Rollin...
- Just got my E-Codes in! 10 days from Germany! WooHoo!!!
- Everyone seems to want RS2 headlights, what about S2 headlights? Aren't they 1 piece as well?
- '95 90 for sale i Stockton
- Auto tranny Rebuild Kit for a CFS tranny, 1995 model 90 car?
- Need some insight.
- RR Parts numbers
- I'll add to picture day...
- OK. Slow forum Picture Friday.
- HALP! thank gawd I got to my car before it burned to the ground!
- Carfax anyone ?
- Hello, Im Johnny, and I will be sleeping on the couch tonight...
- First -10 to -20 degree fahrenheit temperatures have rolled in for me and cabin air...
- Cam setup in V6
- Driveshaft bolts...
- Anyone interested in an extremely clean '96 Cab?
- won't idle, flucts between 12-1500...crankcase breather?
- Great big thanks to CrazyCab for the switches!
- Winter check list...
- Defrost control flap?
- Source for Shifter Lock Ring ?
- PS Issues, looking for other oppinions...
- Winter oil change reminder...
- 90S needs some oxygen sensor troubleshooting
- Going to drive off a cliff.....Failed emission for the 3rd time
- Girlfriend wrecked the 90, what to do?...
- 2000 audi A4 Quattro overheating problem.. can sum1 tell me any ideas thank you
- Looking for a change,so i thought I get a '94-'98 Cabrio.I don't know if this is the right forum?
- OMFG!
- x-post from PNW forum. just lookin for some advice.
- Cup holders? Need..more..cupholders..
- Changed cap and rotor and now they rub
- Driveshaft...Yep I STFA...
- Going to smog my 20v after work today..... wish me luck :-(
- Adding a block heater... sourcing parts?
- Anybody interested? 90 CQ Black over tan. Have no interest but Midwest guys might be.
- Red Coupe sighting on TV. PBS Nightly Business Report 11/18, minute 50-52. Minnesota
- Does anyone know where i can find aftermarket bodykits for my 1995 Audi 90 Quattro
- 1995 Audi 90 Quattro
- Who wants to sell me a B4 90CS quattro 5sp with a black interior and <150kmiles?
- Getting back in the Audi Game......I wanna play
- Alright, for those of you who went to the BIGGER MAF...B3 90q20v...
- Changing switch bulbs.. 20v.org wasn't too clear..
- WTB: 90 B4 parts
- cruise bladder
- As of this evening, I will be the proud owner (and only the second owner ever) of a beautiful 1988
- This is like 2 mins from me...should this be my new beater? lol
- Can someone run a VIN for me ?
- 1B3 code on a B3 80...
- Decent Cab up on the block.
- Serious V6 problems - Many Questions
- piston ring set
- Need to tuneup 90 20 valve...what type of plugs would you guys recomend?
- fule line
- Does any one know any source for a direct-fit cat...
- does my 92 80q have a brake accumulator like the 5k did?
- For those who have had positive dealings with Audibits2@aol.com...
- Chicago got hit with some snow last night. Not enough for some fun but it put the itch in me
- Cabin filter location?
- REMINDER: EPL's 2nd Annual Dyno Day/GTG - Saturday, Dec. 6th
- what is it with Reno/Tahoe CL?
- I didn't know Phil Collins had an RS2...
- Having trouble removing key from ignition switch
- No start diag 95 90q 12v
- FYI... Very nice looking B3 90 for sale in the Grand Rapids, MI area.
- X-post from A4 board, switchblade remote questions
- The staff at STFA hate me.
- Relocated license plate for Euro bumper.
- what the heck is this?
- Here Kitty Kitty.
- Saw this today..
- 12v.org wrong?
- Put the snows on the Coupe or just sell them?
- help?
- Hey Nate! 235/40 17's backspacing? I have et40, wondering if they'll clear...
- Black 95 Q in binghampton
- Anyone have a front plate holder for a B3 I can has?
- OK, I've got the ET45 CQ Speedlines en route..
- B3 and B4 quattro front subframe
- AC compressor
- Need an alternate spark plug for the WR7DC.. not in stock locally
