- Cluster, nozzles, antenna needed - 98 Cabriolet
- New (to me) coupe... now what?
- Coolant guage lines??
- Ronal 7x15 with 45 offset on a CQ?
- Car Photography
- 20v runs like poop... help!!!!
- will a 1.8t bolt to the 20v and 12v trans?
- Anybody have a parts car? I need a driver's door latch.
- Car Wont Start! Need Help
- wood trim/repair?
- still newbe
- HELP with 034 A-arm bushings....
- radiator fan
- FS: 1988 90 Quattro Southern California
- What are the "telephone cord mod" and the "egr mod?"
- Engine coolant temperature sensor
- New look
- cover that conceals the rag top
- couple quick questions
- Will the B4 bumper fit on the CQ....
- Cold Natured
- 90 90 20v has big problems HELP PLEASE!!
- Just got a 90 90 20V - pics inside
- 1993 90S Radiator/Blinker/Wiper Fuse keeps blowing
- Having some problems with my 96 Cabriolet
- Seafoam or decarbon technique from my own experence
- City Mileage vs. Highway Mileage
- Anyone bought the clear B4 turn sigs off Ebay?
- air mass meter
- RWD instead of AWD?
- Changing power steering fluid. How to drain?
- alternato replacement does not require removal of bumper!!!
- Looking for a wiring diagram for a 1990 CQ
- RS80 still alive!
- Audi 90 rear upper control arm bushings replaceable?
- Engine hydrolocking after fuel dist. rebuild
- I found a AUX GUAGE set at the local yard today.
- Listed my Cabriolet for sale but can't edit details?
- AC didn't start up on first hot day this year.
- turn signal issues in a B4 90
- springs for my cabriolet??
- Mystery check engine light on 90q
- s2 sedans
- FREE 12V V6
- Two questions regarding...
- expansion tank sensor disconnect???
- Backlight on switches (defroster, heated seat, ABS off) Is it repairable?
- Where can I find steering wheel like that? (pic inside)
- MC-1 80q Tech help needed!!!!!!!!!
- steering wheel upgrade 90q for 01's4
- Euro plate portion (rear) wanted
- 928 Porsche rear calipers???
- Body kits???
- audi 90
- OK... One last job (I hope)... before summer
- Part numper please? [black leather shift boot]
- Shifter Slop
- Looking for some euro lights
- Cabriolet shimering upon acceleration....
- Wheel Bearings
- Passenger side visor removal [How on earth..?]
- Fluid reservoir for '97 cabby convertible motor
- I need the panel behind the passenger headlight ....
- An Interesting Cabriolet Transmission Issue (that actually might not be...)
- Anyone got a used Fuel Distributor for sale?
- 1995 90 Quattro Subframe compatability
- For the High Flow Airbox mod....
- Reasonable setup?
- Spark Plugs
- oil drip fixed
- 90 CQ speedline wheels question.
- Right turns, "Card in the Spokes" noise...
- 1997 Cabriolet front bearings
- 1990 coupe window relay (Driver's side)
- Propshaft U-joint
- Need a pic of relay 1993 Audi 90
- Huge Coolant Leak! (B4 90 quattro)
- Audi 90 gas tank vs audi cabriolet???
- few thingsd on my 90q v6
- New to the AudiWorld forum - '98 Cabriolet
- Need OEM black floor mats for a '98 Cabriolet
- Need Right Outer Tail Light for a '98 Cabriolet
- Headrest Compatability
- Who has replaced their fuel lines under the car?
- Beachin' B4
- '98 Cabriolet Power Antenna mast replacement
- Anyone with a pass. side Hella fog 4 sale?
- I need new door glass ...
- Cel light/front windshield or windscreen whichever ya preffer call it
- Turn Signals Stopped Working
- Quirky Problem
- 1994 quattro rear struts
- Current source for all metal radiator?
- Do B3 rear lights fit B4 ???
- 1998 Cabriolet Remote Issues
- The 90q hits Florida...
- cq spring rates
- Rieger RS2 Bumper on B4 Audi 90
- cabriolet bumper 1998-2000 fog lights
- Does anyone in Ontario have a set of rims for sale? (B4 quattro)
- Hub Conversion Opinions
- Dang it !! I snapped a bolt...
- Need some help! Engine shut down ...
- oem brake kit front and rear
- 4x4.25" Wheels on a CQ
- 1994 90cs not starting [one clarification]
- "OK" screen on cluster
- Intro - Test Driving America in a 90q
- selling oem brake kit
- 1994 audi cabriolet convertible (top won't let down)
- Let there be light?
- Ignition Switch?
- Brake question
- 98 audi cab won't start
- anyone near Ottawa got a Vag so I can reset my airbag light?
- valley pan gasket
- Cleaned up the Winter Beater!
- thinking about buying an Audi 90 (1995) any input is appreciated
- Slow sunroof =[
- oil useage?
- would 90 suspension fity on ...
- AC line routing diagram
- Selling everything to pay for Divorce...Coupe related!!
- I've performed a search, but I'm still beffudled...
- Anyone have any water leaking in, B4 models?
- speedo problem
- Audi Coolant issue?
- Replacing 2 tires?
- Wiring Question!
- Anyone interested in a full set of VAP coilovers, springs, shocks, pro-mounts?
- Poor Runnings!
- ac pag 46
- Orifice Tube???
- Where can I find...
- Just spent some money on my baby!
- A/C not blowing cold
- headlight washer plumbing
- Is 91 octane necessary ?
- 034 Motorsports jack their prices up?
- Anybody parting a 93-95 90 with manual transmission?
- Removing Seat Heater Switches
- HELP! Timing OK???
- 87 COUPE GT - quattro conversion
- I have two 034 motor mounts for a '91 CQ for sale.
- thermostat replacement for my 95 cabriolet
- Lacking Power
- Gauging Value of Beautiful low mile 90 Coupe Quattro?
- 1990 CQ not starting. Need help.
- Canadian Audi Owners Stay Away From Autopartsway.ca
- Error code P0401 EGR flow insuf
- K&N 33-2029 air filter for my 12v
- My New (OLD) Quattro
- cause of oil useage? as comp. to honda, ford, toyota?
- lift points?
- passed smog.. found sourse of cool exhaust sound
- vw mk2 rear coilovers on fwd 80?
- CQ Radiator Fan Inline Fuse Kit
- Can't remember where I saw it.. Fog Light Mod
- My 90q 3B project
- Need a Cabriolet wind deflector now...
- Differential pressure regulator?
- 1990 90 20vQ Question
- 14" BBS mags
- 94 cabby top issues
- 15 AMP fuse keeps blowing (related to a 12V portable car heater)
- that suspension upgrade
- Does anyone have one of these switches?
- V6 ISV on UK ebay
- Noise
- 1995 audi 90 vacuum line diagram
- 5-hole mag integration?
- Help me out, please
- Brake Pad Springs
- have 93 audi 90s for parts MUST GO
- Broken aluminum engine mount arm on CQ - common? replacement?
- wheel studs
- Oil Type/How much?
- ehhh this ones embarassing
- Alternator Rebuild
- Is it worth it
- Who here is in the UK..?
- Car not starting 1990 CQ
- heater blower just seized!
- need help
- B4 front turn signals/parking lights not working.
- Just hit 250 000KM
- 20v Engine Number Location
- Is it a bad idea to put a spacer in the trans mounts?
- 17x8-35mm Offset-Fit?
- no heat
- 90 CQ has no low end power and stalls after 10 hours of mechanics looking for problem
- NG snub mount question
- Injectors-2.8L V6? 034?
- I'm Back! - Again
- Wanted: Black Oval Audi Badge
- 93 cs quattro help
- Blower Motor
- Hub Bolt Torque Specs?
- Anyone repalced their original aerial?
- '95 90Q coolant leak
- Dead headlight and high beam stalks
- In need of a cable + other small parts [anyone has any sitting around?]
- Tightening A-arm bolts??
- Cigarette lighter sometimes working
- 1990 Quattro Sedan Brakes
- Very strange throttle/accel problem
- WTB: RS2 / 80 Avant Interior Door Sills
- new guy needs direction
- old 5000 block, work for my 90quattro
- O1A problems? - clunking from front floor board area
- 1997 Cabrio Codes
- CQ windshield leak
- AUDI 80 Horn, Heat problems
- Suspension upgrade [need advice]
- rear fog ligh
- HELP! 90 CQ still wont start hot and has very low power! Mystery?
- coupe quarrto 20v ecu?
- "95 90Q Cruise control module location
- well looks like it's time to lose some cash
- Will a 20v crank sensor work in a 12v?
- turn signal connector pinout?
- Fuel Enrichment Relay Kit??
- help with my audi
- Weisbaden Radio Face Plate?
- What are the unique pitfalls of owning a b4 cabriolet?
- Does anyone know where I can buy an rs2 bumper for my '93 90cs?
- Central locking and anti-theft alarm reset
- Should I replace ignition switch?
- Cabrio Power Top
- Help with my 1997 Audi Cabriolet
- '93 Audi 90S Q - front lower ball joint replacement
- NEED HELP!!!
- rear tie rod
- CV Replacement
- What is a fair asking price for 95 90Q?
- High Oil Pressure
- Caliper Bolts
- CV Boot Replacement
- i know talked to death,, fuel injectors
- Torque Specs?
- WTB: MOMO steering wheel adaptor for a B4
- Seeking 80q or 90q or coupe quattro, any year
- MPG Readout issues. Vac leak?
- Vacuum Hose?
- 90q (B4) vs A4q (B5)
- PCV Hose 1988 Non Quattro 90
- 1990 Audi 80 running problems
