- Looking for a windshield 90 coupe
- Rear Cabriolet window from France $155
- Just picked up a '94 Cabriolet with 73k miles
- Anyone help? Overheating issue.
- AC v belt installation??on what pulley?
- Need help!
- My Cabriolets - passion to own
- 96 Cabrio using some oil
- Someone please sell me on the prospect of owning an Audi 80 Cabrio
- Brake issue, need advice! Audi 80 B3
- Audi 90 Electrical Nightmares
- Audi 90 2.3 NG, KE3-jetronic issues
- 30.1MPG on my 225,000 90 Quattro 20V!
- CQ Project Blog
- Acceptable coolant and oil temperature range gauges on 5 cylinder cars?
- Audi coupe 1982 with lots of life in her
- Stopping By
- 96' Cabrio Repair Help
- Somoene buy these before I have to crush them!
- Is the brake system from a B4 the same as a B5?
- Front end intermittent grinding
- audi a80 no response from roof cover
- 7a Harmonic Balancer Bolts PN
- 93 90 2.8L blue smoke
- engine tick
- sway bar options for 1994-97 Cab
- Starter Bolt torque
- 1989 90Quattro 5 Speed For Sale
- Audi 80 2.0E 8V engine specs request
- Cabriolet Starter
- :: ECS Tuning :: Audi 80/90/100/200 5 Cylinder Ignition Wire Sets!
- Power Steering Problem 1995 V6 80
- 1990 Coupe Quattro Transmission Problems
- '93 90 2.8L expansion tank hose
- 91 Coupe for sale
- audi 90s 1994 issues
- B4 Starting Problems
- B4 stuff for sale
- B4 90 1.8t
- How about another 90 thread v. Rally
- Power Mods for the 90 2.8
- Anyone pull off the rubber door molding?
- 1994 Cab Radio
- AUDI coupe - Tuning
- what color are the...
- Ready, fire, AIM!
- New Member
- Need to sell a UR S6 Avant or a CQ? Torn between the 2?
- Starting an engine for the first time in 5 years
- All the magic smoke escaped!
- 1990 80 quattro
- Favorite/Preferred Replacement Part Manufacturers
- MOT Failure - need help
- 95' 90 Quattro rear wheel bearings
- flush (and clean) cooling system??
- vicious starter
- Aircon intermittent
- so I bought the '93 90 cs quattro that I traded for '00 a6 4.2l
- lowering b3 80q
- Vr6 engine swap
- White Foam under Oil Cap
- 90 20v
- WTB: 1991 Coupe Quattro Bentley Service Manual
- '90 90 quattro 20v (7A) stalling issue: Help please!
- Early 7A ('90 90 20v) Hall Sensor: Replacement?
- Wheel offset help needed on cabriolet.
- Big MAF question for pre-March '90 CQ
- Help ID this Vacuum Part
- replica rs2 OR 993 fog lights
- odometer help
- problems with AAH/AKH 12v V6 - Stage 1+
- Sport Suspension - Truth or Myth?
- 88 NG 90q driveablilty/timing 2 issues
- Back from lurking, need sum stuff...
- FWD snow performance
- Audi Convertible Tank
- Front Brakes - '95 Cab
- '91 Coupe Quattro Headliner Frame
- Valve cover gasket replacement 90Q (early 7A)- torque specs?
- can someone provide me with MAF transfer of ANY maf??
- Snow Pics!
- Picked up a Donor Car this weekend.
- 250k
- 1995 90 front Bumper
- camshaft "pulley" location??
- When was the last time you saw 5 90s all together?
- B4 cabriolet 2.6 won't start
- My New 90 is officially on the road
- Audi 90 CS Quattro No Start
- 1990 20V 90 fuel pump - Real Time alternatives?
- install crank trigger??
- Driver door panel removel
- how it works/how to read the Oil presure sender
- happy new years
- 1990 CQ shift linkage
- Anyone with a spare wheel?
- CQ fuse #4 short
- Installing dashboard in my 90, need help.
- Heater box refurbish...
- Transmission question
- fuel sending unit broken??
- got a set of 4x108 porsche wheels from a 914 that also fit 90s
- 1995 90 quattro stuck after engine install
- 1991 80 Quattro Electrical Disaster.
- Just i little show off... JHM solid throw shifter...
- 80' lights open when trunk is open. reverse lights dont work either..
- '93 90 quattro 2.8L quirks
- Headlights and cruise out.
- wtb: 1990 1991 Audi 90 I5 20V quattro 1992 1993 S4
- Spark Plug Wire to Distributor Map
- Strut Noise and Top Nut Height
- Sway bar upgrades
- Upper strut mounts - sneak a new one in?
- 95 90 - Headlight Upgrade Options
- Audi 90 CS Starting Issue
- URGENT help required please
- B3 1990 80/90 dash bulbs - how many?
- Recommended CV boot kits/source?
- Review of DEPO Euro headlights on B3
- Audi 90 Fuel dumping out of exhaust downpipe
- "Clunk" noise during upshifting
- 1990 CQ 20VT GT3071R 6Spd 01E TDI VEMS
- Fuse panel pic or image
- Making sure I found the right hood upgrade
- 88 a90 quattro $700
- need oil pan bottom dimensions, 1990 90 10v, for pan heater sizing
- Cab guys, I need some info
- ◦1 DIN radio for our cars - which one?
- parts car central maine
- Window Regulator Rubber Isolators for 1990-1991 Coupe quattro and other models
- Help! 91 Coupe Quattro Front Rotor
- Short shifter
- Pax side rear cam seal
- Cabriolet Luggage compartment light switch
- Any interest in a set of B4 Sedan Euro Bumpers?
- new audi owner, 1990 90 so a ton of those newcomer questions...esp. headlights!
- in need of some parts for my audi 90
- WANTED!!!! B4 COILOVERS
- 1993 audi 90 quattro engine dies
- 1994 audi 90 quattro cs sport having trouble
- over heater
- Audi (80) cabriolet resistor plate connections
- Heater core HELL
- Audio system install on 1990 90
- Need help w/ ECU removal: '90 90 20v (2 plug)
- 95 Cab Heater Core
- 1990 coupe quattro running poorly
- **Don Nguyen | Vinyl roof wrapping, tail light tinting, black out chrome trim install
- Stock Radio Needed
- Umm, dumb question. How do i open my gas door?
- 93 audi 90 quattro, no wipers, parking lights, windows, blower
- real time help - 1990 model 90 radio connection diagram?
- wiring inside the engine bay.. Help!
- b4 80s avant v6 x gamma cc + pioneer cd changer
- Good website for parts?
- Picked up a 95 Audi 90 quattro sport
- Instrument Cluster Removal Question
- Anyone have a Quattro logo for 1990 80/90?
- All wheel drive cab
- 1990 coupe question
- Cooler weather (50s), idle too high
- 1996 cabriolet AC problem...relay?
- lower control arm
- audi 80 lights
- Problem with 80's brake light.
- 1988-1991 Audi 80/90 foglight??
- Intermittent Starting Issues (please help)
- lower control arm bolts torque specifications
- jbrentd's Project Coupe Quattro
- upper oil pan gasket
- :: ECS Tuning :: Genuine Audi 80/90/100/200 5 Cyl. Ignition Wire Sets - 84% Off!!
- Vac leak on 2.8 128kw?
- Looking for this trim
- looking for a passenger side valve cover
- Sunroof motor interchange question.
- LBS or torque for head bolts?
- No start
- a-arm bolts.. still no answer.. PLZZ HELP o.o
- '90 CQ Frt Suspension Bushings
- A-arm Bolts...? HELP
- replaced starter and after one night i have no electrical.
- Some 20v quattro questions
- Early 7A 90 quattro project list; input and suggestions?
- Griot's leather restorer on my 1990 worked.
- 1995 Audi Cabriolet : trunk wont open
- Replacement seats?
- Replacemnet seats?
- Bad sunroof motor or is it the cables?
- Missing vacuum line; heater control valve
- FS cq door cards, ECU, window regulator
- Help me plaese
- Temp Gauge intermittent
- Rear speaker replacement.
- Window relay help
- MK1 TT front seats into b4 coupe
- 1995 Audi 90 alternator and brake light
- 1991 Audi 90 woes
- Power steering pressure hose
- Any intrest in a set of B4 sandblasted strut housings for a BBSE conversion?
- Trouble starting '93 90 CS
- Changed a rear ball joint 1990 90
- Audi cabrio 1998 ADR Engine
- Electrical Issue - no power at coil
- EGR valve.. any cheap ones? hahaha
- questions about a 1995 audi 90 with 260000 miles on it.
- 93 cs quattro parts needed!
- TDI 90 Engine Swap
- 1990 Audi 90 stereo wiring help?
- help with early model 90 coupe Quattro parts
- Manual trans swap
- B3 5cyl timing advance?
- front wheel shake
- WTB B4 hitch Brand= Curt, Mfr Part#: 11161
- AC compressor, climate control head unit and relay questions.
- B4 Quattro gearbox needed
- I need a fuel line
- 98 Cabriolet for sale (Boston)
- Some pix's for you guys
- Camber and caster plates
- Suspension Mods
- Don't loan your lawnmower!
- 10v turbo swap
- '84 Coupe Body Repair
- What is everyone's MPG?
- oil pump/sensor
- FS 1990 CQ silver/back
- Help me with my bumper?
- hazzard switch replacment for an aftermarket one?
- 88 audi 90 should start, but won't
- Torn - What to do
- 1995 Manual temp control not working
- Audi 80 and Audi 80 quattro
- BRAND NEW front ball joint 90Q 2,8l 1994 also relays
- I too am selling some cabriolet parts
- Fuel Sending unit
- Rear Silencer for 94 Cab
- 93 90 cs won't start
- Dash board blanks for 93-98 Cab
- Anyone try these coilovers yet?
- 1990 20V Quattro rear fog/ABS question
- 90 q.My clutch feels normal but won't engage
- Running rich
- Has any one changed the rear window on a Cab
- Stolen in Boulder CO last night.
- firing order
- If you never changed your ignition switch
- 90 20 Valve power steering hose replacement how to.
- "Whirring" noise coming from the front
- looking for a Drivers side fender for a 1994-98 Cab i
- 1990 Coupe Quattro HELP!!!!
