PDA
View Full Version : Audi 90 / 80 / Coupe quattro / Cabriolet
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259
  1. Battery Drain Possible window/sunroof??
  2. random question
  3. Crankcase Breather Hose?
  4. for the coupe guys/ girls, a question
  5. CV Joints?
  6. CQ tie rod end removal
  7. White exhaust once engine warms up.
  8. CQ "knock sensor?
  9. connector for coolant level sensor
  10. Lower Left Control Arm
  11. MFTS: Where to buy a new one?
  12. 96 cabriolet radiator replacement
  13. Cruise control started acting funny
  14. Tires
  15. Distributor Rotor
  16. Starting problems. . .
  17. Checking in
  18. Starter cable solutions...
  19. ??? fuel pump relay
  20. CQ front wheel bearing - circlip confusion
  21. Not starting in cold.
  22. Flywheel resurface question 1.5"pins
  23. Window and rear defroster electrical bugs
  24. Coupe Rear Hatch Cover - How much would that be in good condition?
  25. Cabriolet-sensor issues?
  26. Audi Special Tools on ebay...
  27. Where is #1 Cylinder NG
  28. Timing belt change - Where to buy the special tools?
  29. shift shaft seal revisited!
  30. Bought used car, new problems
  31. Trunk harness is like a bad virus!
  32. 90 v8 Quattro
  33. Help Please/CQ has very poor low end torque/Wont climb a very steep hill
  34. Coolant bleeding
  35. Timing belt - What they don't tell you
  36. Odometer Problem NOT broken gear
  37. Fog lights and rear fog light
  38. Audi 90 engine swap [20v vs 2.7TT vs 4.2 V8]
  39. 1990 90 20V - Good deal?
  40. Cluster voltage reg question
  41. 2.6 v6 cabriolet gauge pod bulbs
  42. Dash light help?
  43. 12v 2.8l Coolant flush. Need opinions
  44. Reverse/ plate light
  45. Electrical Issue with cluster ... 95q
  46. 91 CQ seems very slow off the line! I have owned this car for 7 years
  47. 1993 Audi 90 torgue specs
  48. Cab/90 Heater
  49. I have searched and searched, but no luck
  50. 12 disc cd changer
  51. Which radiator Mounts to buy?
  52. Clutch not disengaging but pedal returns fine
  53. G11 or G12 for b4 90??
  54. Wow.... What a PITA 95q
  55. Odometer/Tripometer ??
  56. Cleaning the ISV Valve?
  57. Replacing Rear Caliper Mount Bolts
  58. Can someone confirm this issue? ( Eletrical )
  59. need a center cap
  60. need help with my Audi
  61. 1990 Audi 90 Fuelinjector Pulse Width/Cycle Duty?
  62. 90 20V needed for magazine feature
  63. Sunroof Problem
  64. Starter problems.
  65. after market intake
  66. 93 audi 90 cs FWD
  67. Problem: Losing power while driving
  68. 1993 90s throttle cable..
  69. audi 90 quattro running rough
  70. Where are A/C Pan Drains in 95 90 V6
  71. Central Locking Has Gone Crazy
  72. My First Audi Need Advise from the Wise.
  73. New and a couple questions
  74. havin fun in my CQ 20vt
  75. 1993 90 Quattro V6: Oil Pan Pullage!!
  76. Audi 90-CS mystery vaccum line
  77. Start problem (LONG TERM ISSUE) on CQ Turns over but slow to fire!
  78. Looking for bumper
  79. Fuel Pump Hum
  80. Beater--91 coupe quattro
  81. Swapping seats from cabriolet to coupe?
  82. My B4 90s Stopped locking all doors with key. weird?
  83. 12v out of time.
  84. Man another problems crops up...(Anti Lock) question
  85. 1995 2.6 cab...service costs
  86. 12 valve no start
  87. V6 12v idle issue
  88. 1995 90Q Door Glass Replacement ??
  89. Torque specs for 90???
  90. Brakes, Brakes, Brakes...
  91. Question about power steering fluid.
  92. cabrio fuel filter
  93. After Run Relay '95 Cab
  94. 93 90s engine swap
  95. Multi-Function Temperature Sensor
  96. good news and bad news...
  97. 90 Seats
  98. Update!
  99. Dome Light Not Working. Ideas?
  100. Hi, New Owner(1989 Audi 90 Q) Having a Strange Problem
  101. 90Q Rear Shocks
  102. 1991 7A For Sale
  103. Parts, vin and engine code.
  104. anyone know if theres a place to buy pre-made headlight relays?
  105. Thoughts on favorite winter tires? Anybody?
  106. body kits
  107. Anybody need an AC compressor
  108. 93 90s Cooling fans
  109. Sunroof switch inquiry amoung other questions
  110. Well does it really take 12hrs. + for the Admins to approve my DIY??? Really????
  111. LED Gauge Cluster Swap
  112. DIY manual tranny fluid change write up for Audi 90 12v V6 (93'-95')
  113. Resistance values for MFTS & CTS
  114. leaking gas out of "actuator"?
  115. Hello new Audi owner here (1995 90 CSq)
  116. audi CQ 1990 20V no start
  117. Cabriolet Instrumentation Swap
  118. 1992 Audi 80 convertible inner door armrest
  119. Update
  120. ACC belt diagram please?
  121. Totaled
  122. B4 90 Headlights-QuantiTEC??
  123. Early gen motor to Late gen tranny?
  124. help me with my trans!!!!
  125. 98 Cab Rubber door trim question
  126. name this part!
  127. my cure for the "discontinued, without replacement, p/s line"
  128. it might be time to part 92 80Q
  129. Distributor to cylinder wiring order for 4 cylinder 80
  130. Parting out 7A
  131. AUDI 80 COUPE SUSPENSION NIGHTMARE
  132. Wallet hurt!
  133. Dutter S2
  134. EGR valve removal
  135. Climate Control Unit - Removing & Installing - need info -
  136. Brake pad Sets - need suggestions
  137. 1989 B3 Audi 90Q
  138. Accomplishments on the 90Q for the day...
  139. B4 90 Lowering Help!!!
  140. Cabriolet 3rd Tail Light Needed - and a Question
  141. Springs, shocks, struts for 1988 90Q. Where can I find them?
  142. 4x108 Wheels - Centerbore?
  143. Anyone have anything "sporty" for a 95 90Q suspsension their getting rid of?
  144. CQ/Cabriolet doors
  145. Ouch
  146. Engine out of '91 200 20V Turbo Quattro into '90 Coupe Quattro
  147. Polyurethane engine mounts
  148. Need some noob questions answered
  149. high beams
  150. Motor mounts 88, 90 weekend project
  151. Whats the "sports type" suspension?
  152. Everything you know about Audi 90 suspension and lowering, please put in here.
  153. WTB - Pro Mounts for B4 chassis
  154. Looking for 7A Engine
  155. Noctious Exhaust Smoke
  156. Searching for catylitic converters for 1994 90 s
  157. Holy Sh@t, what a mess....
  158. Cold air intake installation questions
  159. 1988 Audi 90 quattro Distributor pickup coil
  160. Help with Turbo conversion.
  161. Water Pump failed after 36,000 miles!
  162. Body kit for CQ?
  163. Help with Engine Mount Installation 1995 Audi 90 Manual
  164. Exhaust from hell!!!
  165. audi 80 parts compatibility
  166. Power Loss/Flat spot. Need Help
  167. FS: 4 Audi 80 wheels
  168. Are ABA Clamps compatible with silicone hoses?
  169. need distributor info for an 88 80 with 2.0
  170. B3 Delco Fan Speed Control
  171. B3 Delco Fan Speed Control
  172. Anti lock off
  173. 95 90Q and A4Q rear upper control arms interchangable?
  174. Last of the ole' cq parts!!
  175. Advice on CQ
  176. Radiator broken.. need recomendations..
  177. 94 audi 90cs whole or parts
  178. Front End Fische
  179. power steering whine/hum
  180. Speedo not working
  181. car died then won't start
  182. EGR valve gasket
  183. Seafoam-ing a CQ
  184. Found some Cq Parts laying Around What do you need??
  185. Oil cooler leak and oil pressure switches leaking
  186. Darn flashing oil light. Why?
  187. hey wats up
  188. cluster swap...A4 into 90 CS???
  189. I'm looking at buying my first Audi...
  190. Coolant Flush
  191. 1997 Audi Cabrio access to fuel tank
  192. good alternative to vibrant 1134??
  193. Silicone fittings for intake
  194. 90 20v loses power after hard acceleration
  195. Strut Mount Assembly Question
  196. Looking to buy a 1990 90 Coupe
  197. Drivers Seat Rebuild
  198. How Many Valves?
  199. Coolant?
  200. Cabrio top
  201. How Much To Do Front Struts?
  202. More 1995 90 quattro questions
  203. Installing an aftermarket head unit into a '94 90s??? Eff.
  204. '94 90csqS A/C control unit swap (analog->digital) = Possible?
  205. A/C Recharging
  206. FRONT END KLUNKING "PLEASE HELP"
  207. New Member and New Owner! 1991 90 Quattro 20v
  208. local tristate gtg - October 10th, 2009
  209. Oil pressure in a 95 2.6 v6 cabriolet auto
  210. exhaust clamps
  211. Ignition Switch
  212. Clicking Axle
  213. Can I do a front strut job without special tools??
  214. New 98 Cabriolet Owner w/Questions
  215. 90 Cabriolet cd changer bracket
  216. proper offset for 17x7 wheels?
  217. New oil pump and timing belt--now it won't start!
  218. 1995 90 quattro oil pressure switch wire?
  219. Door harness disconnection issues
  220. engine still not running right... any ideas?
  221. Super Clean 1990 Audi Coupe Quattro CQ
  222. Speedo and stereo not working on 95 v6 cabriolet
  223. 94 90cs quattro swap?
  224. Audi 80/Cabriolet bumper question
  225. WTB: 7A or early 3B Cam Gear Pulley
  226. Anyone use the Climate Control OBD listed on 12v.org?
  227. Spark Plug Preferences
  228. 1996 cabriolet spres needed !!
  229. 7A Cam Gear Interchangability
  230. why is finding a cv/axle/boot kit so hard?
  231. Fault with getting stereo to work on 80 cabriolet 2.6
  232. thrmostat
  233. Where to buy a hall sensor for a 7a 20v..
  234. No Spark
  235. Cleaning Engine Bay
  236. OK to use 205/65/15 tires on 1995 90 FWD?
  237. Parting out '94 90 cabriolet
  238. Question
  239. Couple Spare Cq parts.
  240. Oil Pump questions
  241. Automatic Tranny Fluid
  242. New member with you guessed it, An electrical issue!
  243. 95 90Q with a AAN engine
  244. Electrical Problems 1996 Cabriolet
  245. starting problem and accelerating issue with Audi 90
  246. 1996 Cabriolet Key
  247. Best jack stand placement on B4 chassis
  248. Rubber Seal on Throttle Body
  249. Real Thing. Turbo
  250. Any word of advice on replacing lower oil pan gasket!
