Log In
View Full Version : Audi 90 / 80 / Coupe quattro / Cabriolet
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259
  1. RS80 - alive and kickin'
  2. 1991 Audi 90 - Speedo stopped working
  3. What are common CQ problems?
  4. Vacuums...
  5. New to me Audi, smallish issues
  6. How to remove dash panel above pedals?
  7. New to Audi
  8. i just need a little wheel help
  9. audi 80 2.3 quattro crankcase breather cleaning
  10. 1990 CQ keeps popping out of 4th gear
  11. Roof opening problem
  12. NEED- donut seal for exhaust for 91 CQ
  13. Selling my Audi Cabriolet 1995: $3100 OBO
  14. Front Suspension Sound
  15. strange sound when taking off.
  16. Anyone with buying experience from BM Town?
  17. Mounting auxiliary lights on B3 80/90 models?
  18. RS2 seats for Audi 90?
  19. Broken headlight......
  20. Looking to buy a 90 with Quattro
  21. Any sources for new trunk gas struts?
  22. What's your shift pattern? Is my clutch okay?
  23. How do you replace your cruise control switch?
  24. what headlights fit audi 80?
  25. Isv hose replacement Early 7A (hitachi isv)
  26. two sets of custom 4 x108 wheels 17s and 18s $350/set
  27. 1994 cabriolet roof problem
  28. Anybody have a lower grille for my 1990?
  29. Is it ok to only replace 1 defective fuel injector on a CQ versus all 5? Is used ok?
  30. Oil coming out the oil filler cap?
  31. 94 model cabriolet
  32. Hello Everyone New guy with a few questions
  33. Looking for e-spec front bumper
  34. Touch up paint for my 90q
  35. please help me find were this plug goes
  36. I'm looking for outer tail lights-audi 80 b3
  37. 89 Quattro - Temp light., lifters
  38. Time flies...
  39. Audi 90 possible overheating problem?
  40. Need Help Identifying
  41. Been away a looong time - thinking of getting another Cab
  42. Looking For a Set of Aftermarket Wheels for My 97 Cabriolet
  43. 1988 Audi 90 Quattro fuel problem
  44. replacing speakers
  45. 1990 audi 90 quattro full interior for sale
  46. Cabriolet complete top replacement and hydraulics too!
  47. Anyone have black leather front seat parts for sale?
  48. Front wheel noise when turning at speed
  49. 12V V6 Cam Position Hall Sender Replacement DIY
  50. Injector retrofit, Hesitation and exhaust smells
  51. Oil pressure guage pegged high much of the time - correct?
  52. First family drive in the 20V - fun!
  53. Idle Problem with my 1990 / 80 2wd 8V Automatic
  54. Radiator replacement/repair options? Early '90 90q20v
  55. replaced injectors and pressure regulator, now '90 90 7a is idling funny
  56. Other Audi models share brake parts with my 1990 90 model?
  57. AllRoad turbos in 90: Questions
  58. My climate control is the best!
  59. looking for coilover on my Audi Coupe Quattro 2.3 20V
  60. What is instrument knob nearest fuel gage?
  61. Wiper issue - any tips for a newbie?
  62. 1990 CQ red/black partout
  63. Speedometer.
  64. B4 bulb socket needed!!
  65. Selling my 5 speed Cab
  66. Parts on the way :D
  67. odd behavior 12v 90q
  68. Anyone lookling for some Cabriolet Parts?
  69. Complete V8 drop out.
  70. My Audi dies at high MPH
  71. 93' 90 auto fwd to manual fwd swap questions
  72. Bolt on exhaust kit for my '90 Audi 90 Quattro 20V
  73. 7A Fuel pressure regulator...
  74. 1990 Quattro 90 brake bleeding weirdness
  75. Suggestions for bushing kit for 1990 90 suspension?
  76. Coolant flow pattern in 20V 1990?
  77. Small milestone - and first top down day of 2013
  78. 90 Quattro digital climate ctrl - only 2 fan speeds?
  79. Where should nipple on PCV hose/pipe go?
  80. Need help with 1990 Audi 80 quattro
  81. Seat Cover Suggestions...
  82. 10v low rpm misfire
  83. Try Again - Catalytic Size ?
  84. Whole top or just back window?
  85. Picture of B3 80/90 with Depo clear blinkers or smoked?
  86. My 1994 90 cs. Stance state of mind
  87. 95 Audi 90 Body kit? any help?
  88. Advice for what to take off a parts car before tossing it?
  89. B3 90 20v exhaust questions
  90. Giving back - a cheap battery to replace pricey MT-91
  91. Anyone have a left front blinker for an 88-91 80/90?
  92. Please read. I need help
  93. new with audi..
  94. Unbiased opinions please?
  95. 90 cluster vs cabriolet cluster
  96. Looking at a 1997 Cabriolet and have a few questions
  97. Smorgasbord of small things on 1991 Q20V I need help with.
  98. 1994 90 Quattro CS for sale
  99. speed/rpm/temp/fuel sensors. location and signals?
  100. Radiator fan not working - suggestions?
  101. superior audi
  102. 1995 2.0 cab, revs
  103. Cruise control fix - plastic collar on actuator rod?
  104. WANTED 2bennett CCK WANTED!!! Used++
  105. b4 taillense
  106. G60 brake swap, 4 to 4 lug needed?
  107. Audi model 80 and 90 have identical headlights?
  108. Help with ignition timing on 1990 20V?
  109. Custom Deck Wiring Harness
  110. wheel studs
  111. PS Rack Seal. Forum Newbe
  112. camshaft postion sensor
  113. Story and mechanical freshening of a 1990 20V sedan.
  114. 1994 90 cs might be next car. help
  115. obd1 or obd2
  116. 1990 Quattro 90 rear diff capacity wrong?
  117. Looking for headlights for my 1990Q
  118. Audi RS2 headlights or aftermarket projector halo??
  119. 20v (7A) intake / exhaust questions...
  120. '90 90 quattro 20v rear struts DIY?
  121. Questions specific to the early 20V Quattro 90.
  122. Wooden trim replace/swap
  123. B3, B4, coupe stuff for sale.
  124. Sweet Quattro glowing shift knob!
  125. Tail light mod
  126. Longshot for a B5 shifter
  127. Euro headlights
  128. Anyone care to trade?
  129. New Member - Key Question
  130. 1994 cs quattro stall while driving and wont start
  131. powersteering pump b4
  132. any B&G suspension complaints?
  133. 1994-98 parts needed for my cabriolet
  134. New here
  135. short to ground near front of engine (B3 7A)?
  136. Plasti Dip rims
  137. Just pondering...other fwd engine options?
  138. charging circuit diagnostics
  139. B4 Rear Child Lock LOCKED
  140. B4 Euro trunk
  141. B4 RS2 headlamps
  142. Please ID these alloys
  143. 90 quattro 20v: Sell it or keep it?
  144. 1990 90 quattro rear struts
  145. Parting out 1994 Audi 90 cs sport
  146. PS Pump Wanted and PS Pumps For Sale
  147. Power Steering Pump Interchangeability
  148. Aux Gauge Question
  149. B4 white gauges
  150. Audi 80/90CS tail lights inner
  151. Antilock light
  152. Audi 90 problems.
  153. Emssion Testing Fail
  154. 1995 audi 90 heater core R&R
  155. Ball joint nut and pinch bolt size.
  156. head lights dim
  157. Banjo Bolt and Starter Problems
  158. Anyone need a blower motor resistor?
  159. performance parts
  160. 2 CQs in SF Bay (Colma) area - Need gone NOW!
  161. Erratic Idle? Idle Screw Hole?
  162. Search
  163. 96 cabriolet tcm location
  164. 1990 90 Quattro 4 Sale !Craigslist Link!
  165. parting out 93 model 90 non quattro
  166. WTB: Fresh air fan resistor
  167. Parting out 12V V6 AFC Engine
  168. 1990audi quattro coupe 4 lug to 5 lug?
  169. 1990 Audi quattro Coupe 5 lug
  170. 1990 90 Quattro 4 Sale
  171. What is this noise?
  172. Banjo Bolt Misfit
  173. Merry Christmas!
  174. screw it I'm selling it ! 94 cab $600
  175. Pics of my '93 CS Quattro
  176. Rear diff mod???
  177. Chirping sound coming from rear
  178. looking at building a 500HP coupe 90, questions.
  179. 1996 Audi Cab -- misfire/running rich and lean/can't drive?
  180. '93 90 cs quattro lowering springs
  181. '93 Audi 90 CS Quattro Speedo/Odometer Issues
  182. Identify the Bolt Size?
  183. Unnecessary, but cool conversion.
  184. 90 Quattro b4q struts
  185. New member, thought I'd say hi!
  186. O2 sensor removal
  187. fuel distributer
  188. 96 Cabriolet 54K Miles Tempreture question
  189. Have shop manuals if anyone needs any help with anything
  190. Driveshaft romoval help
  191. Just acquired 96 cabriolet 54K miles
  192. A lot of work to be done, any advice?
  193. NEED HELP with a 1995 cab convt
  194. Parting out a 1993 Audi 90S
  195. Hot air at center vents but cool at side vents..why?
  196. Cabriolet Manual Conversion
  197. Parting out 94 cabrio
  198. '91 Audi 90 Quattro 20V Update
  199. 95 90Q
  200. Audi 80 engine RPM/acceleration oscillation problem
  201. 1995 90 Quattro sport (forsale)
  202. replacement plugs
  203. need to identify a part as well!
  204. Exhaust Leak
  205. I need help identifying a part!
  206. Audi Cabriolet Window Control Module
  207. 80 transmission
  208. What weight oil are you guys running?
  209. Speakers stopped working
  210. Axle bolt torque
  211. Bumper Cover
  212. Replacing Clutch Slave Cylinder - '94 90 Quattro
  213. Heater Blower assembly...
  214. Anyone know the torque of the high (red) oil pressure switch? Can't find it anywhere
  215. no idle switch?
  216. Heater Cores on 94-95 90's...
  217. Domio Effect...
  218. New Member Audi 95 2.6e Cabriolet few questions
  219. another winter tire thread, or to all of you northerners with snow
  220. 1994 90CS Quattro for sale/parting out
  221. Audi 90 Intermittent Heater
  222. Cold Air Intake 94 Audi 90 Quattro
  223. Audi B3 20v Euro plates?
  224. 1990 Coupe Quattro in Green Bay
  225. 90q fog lights
  226. 95 90 Q 2.8 running rich?
  227. Audi 90 Fan belt slipping on AC
  228. 95 audi 90 ABS off light on. Help!
  229. 94 audi 90 front bumper
  230. 94 audi 90 exhaust
  231. Audi 90q/Coupe 3b rear diff seals question
  232. "New" Audi 80 rough at idle
  233. injection issue?
  234. Crankshaft removal tool
  235. valve cover bolts... are they anything special? I just broke one .
  236. Radiator Issue
  237. New here and confused already
  238. No brake lights, but brake switch OK
  239. FS: AAH Cylinder Heads
  240. New member with a few questions
  241. It's sadly head gasket time - any advice?
  242. here's some of the parts i have for sale off the b4 90 2.8
  243. WTB '91 Audi 90 20v Rear Diff
  244. 90 CQ engine/transmission/parts
  245. Rear Driver Side Window Alignment
  246. DIY 94 cabriolet auto trans rebuild
  247. Questions installing OEM Audi 3 gauges
  248. Audi Quattro 90 disappearing coolant
  249. audi 90 cluster odometer stoped working
  250. turbo query
