- Car turning over, but won't start
- radiator fan running constantly in cold weather..!
- Fender flares.
- Bowden Cable Source
- my latest purchase/headache
- Cleaned my injectors
- a question of value?
- 93 Audi 90 wont start??
- Anybody want to sell "The Audi Quattro Book by Dave Pollard"????
- SoCal Pick and Pull Yards with Audis?
- 1996 Cabriolet
- new door mouldings for Audi 80
- New 1990 CQ owner!
- driver window regulator
- 034 transmission mounts came in
- Oh happy day, fixed exhaust = return of the torque!
- FS: 1994 90cs quattro sport + parts
- HELP PLEASE.!!!
- I'm Obsessed!
- Car shut off mid drive
- Need Help: Low Fuel Pump Voltage???
- parting out: '93 90 fwd auto
- Car Was idling with old fuel filter
- keys
- 92 80 quattro fuel filter
- First drive, problems, questions , impressions
- Abs sensors
- Fuel Filter
- Been a long time
- Bentley Manual
- Help What Did She Do???
- fuel level sender repair
- 1995 90 wont idle first couple mintues
- Remote Start CQ20V 1990
- Thermostat troubles - with a twist!
- audi 90 idle issue.
- Fix Cabbie or just sell as is?
- 01E 6sp in a B4 qustions?
- Wiring Diagram - Anyone have one to share?
- 95 audi 90qs - No start
- Was 80q barely runs. Now weird results from FI computer output tests
- Center Brake Light On and Parts Cars Available
- 1995, 90 quattro
- finally! steering wheel install...
- Oil Filter, which?
- Valve tip height?
- Compression Tester
- 88 80q 2.3 i5 NG barely runs. Help!?
- Hey socalclimber
- Audi 90 V6 heater blower motor not working
- DIY - replacing B4 clutch master cylinder
- Selling my 95 90q + 94 90 parts car. $1250. Timing Belt broken
- Bored and need ideas!
- 1990-91 Audi Coupe Quattro
- Transmission not going in to gear?
- Tranny removal procedure?
- Gunk in the breather hose
- HELP!!!
- Digital HVAC controls on '91 CQ?
- Gamma volume problems...
- Replacing Rear Window?
- MAF sensor differences - '93 vs '95?
- FYI: Gamma radio code for your Audi for free...
- clutch problems x-post
- 1990 - Audi 90 Instrument Cluster
- Need parts for '88 80 Quattro
- B5 to B4 column switches adaptation questions
- Thermostat question
- Happy Holidays guys!
- Replacing rear calipers. Bleeding ?
- Message to socalclimber
- stick is moving
- Heat/cooling issue 90CQ
- Can a stock alternator handle 4 driving lights?
- cleaned my intake/gas consumption experiment
- Fuel distributor issues, such fun
- ITS FINALY SNOWING!!!
- audi newbie
- fuel distributor question
- fuel distributor '90 80 series
- 90 CQ rear tailight wiring assembly needed?
- cold start issue- 1990 80 series 2.0
- Wipe it off...
- seats
- coolant/water ratio
- please help with lock cylinder
- Driver Door wont close
- 93 90 Quattro - 4 to 5 lug conversion?
- WTB: 1993 Audi 90 Quattro AAH V6 parts
- Busted gray connector hanging on driver's side
- Good vacuum line diagram or where to find in Bentley DVD?
- Quieting manual gearbox whine...
- solenoid change-over valve clicking
- 91 CQ antenna
- Picture Friday: Looking at weight distribution....
- cabby for sale in northeast
- Audi Quattro Concept is Amazing! Light Weight High Performance...
- help for Audi 80 fan
- Is there anybody out there...?
- Euro headlights
- 97 Cabriolet Climate Control Head
- Timing belt, thermostat and waterpump replacement - does anyone have the tools?
- who needs a truck when you have an audi 90?
- Which spark plugs for my AAH?
- climate control problem, no heat
- '95 90 Quattro - Wiring connector colors - HELP
- '89 90 quattro warning light/symbol?
- MAF sensor cleaning
- Wanted to post one more time before I send her to the scrap yard
- Brake pad question
- Can someone ID these lines?
- coupe drivetrain
- Audi Coupe 1993 Trip Computer Switches and cable rebuilt
- Anyone has a link for the VAG Catalog?
- 1990 audi qauttro coupe
- 95 90 quattro will not start
- fly by wire problems ??
- 1993 Audi 90 Transmission problem
- crankshaft position sensor
- rear end tie rods???
- Option code 1BB questions...
- rims question for a 90Q
- Rough Idle Solved!
- crankshaft pulley bolt
- hard suspention
- Collections of AUDI pdf(s)
- strange new rattle
- Coolant expansion tank
- Automatic transmission shifting problems
- Good resource in SoCal (Los Angeles) for rebuilding or custom fuel/hydro hose fab?
- 93 B4 to 97 A4 steering wheel swap questions???
- audi 80 quattro 2.8 v6 K reg VALUE PLEASE
- Parts request: b4 trunk stops.. decklid and quarter panel
- rear differential swap?
- are seats interchangeable between a B2 and B3?
- Trying Something New - '91 Coupe Quattro
- 91 CQ odometer
- audi cabby for sale in northeast usa
- Cabriolet Speedometer Problem
- AAH vs AFC engine code
- got stuck trying to change front control arm bushings
- Hey guys, I need auto-to-manual transmission conversion donor advice...
- stering rack
- Rear caliper piston dust cover ripped. Can it be replaced?
- need owners manual audi 80
- Headlight upgrade question 90CQ
- 80 Power Steering Hose Preasure side solution?
- weird window electric window issue
- 97 Cabriolet Antenna Mast
- Temp Gauge
- looking at a cabby
- coupe hyd steringing/ brak fluid unit
- Coupe Window Regulator
- 93 90 CS CRUISE CONTROL
- audi 90 quattro fuel air mixture ratio
- my audi is 89Q or just 80 b4?
- is fk highsport coilovers good for us
- Need new key help!!!
- good donner car ?
- exhaust white smoke stronger after 2 coolant drains
- Engine Coolant Temperature Sensor...G62 question?
- coupe quattro heater core
- Clutch Master & Slave Questions...
- anybody need dash switches?
- ECU & mapping... '98 Cab (AFC) vs. '96 A4 (AFC)
- quattro coupe
- Ventilation Question
- 98 Cabriolet Headlights
- Help Me! '93 90q Died While Driving!
- GPS in CQ
- Possible Solution for Lousy Stock Headlights
- Trunk Hinge Vacuum Tube Set-up
- axles and struts
- Coolant Leak - head gasket
- 4X108 Wheel Spacer Question
- location of control box for 96 cabriolet cruise control system
- Bleeder screw on heater hose, 10V & coolant change
- Coupe Is Rockin After O2 and Fuel Filter
- LED's = Ballin' = Loudgoldwing
- WTB: Yakima SST Y1 roof rack clips
- let's play "guess the leak"
- Colored coded vacuum hoses
- Really dumb Euro Bumper question
- v6 12v flywheel from 034, any interest?
- 1995 Audi 90 wont Start
- Parting out my sled, '95 90, lots o mods
- What to swap over from a4 to b4 90Q??
- Damper/pulley question
- power steering hoses??
- Audi 90 Quattro suspension
- retro audi 80 sport
- Codes on the Audi 90
- Idle Control Valve
- Temprature and fuel gauge inaccurate
- Coolant/Heater core issues
- Audi 1995 90 at Local junk yard.
- MAF Cleaning
- 17 inch rims for your 90 or quattro
- powered sport seat swap
- well, **** is starting to hit the fan again... clutch starting to slip
- Installing Aux lights. Need help with wiring.
- B3 bumper covers on a B4
- strut caps and tie rod locknuts
- crazy Ruski, how about some pics of those Q-Tech headlights?
- Diferntial Lockout
- any ideas where to buy inexpensive
- saggy driver side rear corner???
- COOLANT LEAK PROBLEM
- Taking apart 80 front seat
- '93 90CSq HID-time
- Chip Tuning, 7A 20v Big MAF Anyone Done This?
- Gearbox shake
- Selling wrong timing belt kit
- Seat Warmer Switch light replacement
- wiring diagram Audi B4 ABK engine
- Driveshaft problem..need advice
- Fuse question
- source for pinion shaft seal on 96 cabriolet
- Audi 90 vs. Audi A4
- what's this squealing noise? (video)
- Rear Window issues
- code 16555 & 16558
- 2.3 10v in 90 Q rough idle trough out RPM's
- a question? motor 20 valve 5 cly
- Hydraulic line between clutch master and slave leak
- Suggested oil grade for cold winter
- Mileometer has stopped & windscreen washer has sprung a leak!
- b3 into b4 hood?
- looking for replacement radaitor
- That's it my coupe is really starting to fall apart
- Who has removed the rad from a b4 with A/C?
- Exhaust Mods... (yeah, I know. But this is different... :) )
- can anyone run a VIN/CarFax for me?
- Audi Porsche 5 cylinder 20valve turbo
- Notes on the loss of a heater-core includes new addition to on-board spares kit....
- strut moves when tire tugged left/right
- VAG-COM
- starting problem
- Authentic euro lights - Anyone want to buy?
- Starter swap help on 1988 80
- Engine speciafications help
- 1998 Cabriolet Dashboard "P-R-N-D-3-2-1" Indicator
- 1997 Cabriolet Tming Belt Replacement Gone Bad
- Germanmissle to Rootmachine to MEEEEEE
- Radiator fans constantly running
- 90 CQ Still having no start issues when warm
- Sudden engin knock?
- SPRINGS Collapsed
