- VT SportsCar Rally-X
- Hey blkaudicq and everyone else in Ohio that is interested.
- Custom Exhaust options for my '90 CQ (20v)??
- Oil pressure gauge question?
- Here's the skinny on what happened to the Parts Dept.
- Question about o2 sensor splicing with Bosch 13913...
- Miktip..your S4. does it have a trans oil cooler?
- Amsoil!?!? Whats up with this stuff?
- Re: MikTip, can you please advise ....
- Ok for all you guys asking, here's a throttle body I can make that some can afford...
- Hood insulation
- De-greaser?
- Well, it finally happened!
- Philly Area peeps: Fun Run scheduled on 10/12. Mark your calendars!
- who sells inexpensive cams for the 12v?
- Nitrous on a 2.8L?
- Question for thoes w/ aftermarket head units. I know this is not the audio forum but...
- Anyone live close to Force5auto.com that could take some digi pics for me?
- Front door speaker pods ??
- www.audi80.com is now online again, sorry to all frequent visitors for the downtime!
- I'm never using anything lower than Premium ever again
- HELP !! I broke my car :(
- Miktip....what year is your S4?
- My $27.00 mod I did today.. .A4 wiper arms... cleans the car up nicely.
- One of the two lights is out on dash a/c control switches. They have the dash off.......
- Can Anyone Post An Audi 80 With BBS rims on it?? I'm trying to make a decision.. Thanks!
- Hey Oliver Sprenger!
- For those of you who thought of re-painting your car..what color would you choose??
- Oil filter recommendation?
- Miktip....
- Alex...
- pics of my car
- How do you do this?
- Swiss Cheese Airbox!!! hmmmmm...
- Parts Dept dead but VAG Parts is alive.
- Question to the 20V tech meisters.
- headlight replacement
- Special Tool to Remove Spark Plug Wires?????
- For those of you running coilovers: what spring rates are you using?
- Pittsburgh/Cleveland folks...Oktoberfest this weekend at the new Beaver Run race track
- euro rear tailights for a coupe is it possible to find them with the orange signals in rear
- Electrical problem
- New Signature. Thanks for the quote MikTip!
- ok hotshots try to figure this problem out...
- Achtung Mr Sprenger...
- My new boost control, plus goals for my project....
- Reset the ECU by unhooking the positive terminal and tapping it 3 times (on your head...)
- Guys i hate to say this but. . .
- Are Importvision Headlight Conversion Kits any good???
- Update on TDL heads... and question on mudflaps/guards.
- Oliver springer, maybe alex?: need help with some mirror info if possible,
- Starlight is in the shop getting a new evaporater finally. It will cost......
- SGI A4 conversion kit
- 90 sport question
- car alarm woes.
- Something just doesnt seem right about my car...and its a good thing
- What exactly are involved when doing Tune-Up? besides....
- Making my friend's Jetta look more and more like an Audi...
- Brock Rim+H&R+brembo+willwood+coupe= pic inside ;-)
- Audi 90 model 1988 no quatro bumper removal
- After bedding my pads in (50-0 stops) ...
- (newbie question) what is RS4?
- 1st gear short - no power !!!
- 10-spoke stock to swap with 5-spoke stock with tires.
- Plasma HID xenon foglight bulbs from ebay..
- Wow...an S4 on ebay...oh wait, that's a 90, the S4 badge fooled me.
- How did that person put the A4 front end on the coupe?
- X-post from teh Chicago area forum. Re: junkyard coupe
- Body side molding 1991 80 Quattro
- Flunked my emisions test!
- North Carolina meet on Tuesday October 1st in Raleigh!
- FS: 90 manual
- Outside Temp. light blinking??
- Diff fluid....redline or amsoil. Opinions?
- Stupid Q. for Miktip
- my car...
- Finally got some pics of my Coupe 20v...
- Whats the difference inn handling between the front engine awd and mid engine awd?
- I'm a Rookie at Engine Stuff... Can someone help me out??
- What do you think i should do (my 12V fwd vs. 20v CQ)
- Where can i get B3 trim pieces (mid-door and bottom), and how do I attach them
- PBR metal master & ATE power slot, noisy combo?
- My alarm set light blinks red at the rear fog lamp switch..........
- Hokie_90...ques about O2 sensors
- FOGLIGHT PROBLEM
- Mine....allllllll mine!
- PlayersEightball: (or anyone that has TDL heads)...
- vacuum lines ('93-90)- not shown in bentley's
- How many hours of labor would a shop charge to take heads on/off?
- Finally Got around to Posting a Pic...
- just put clear corners on (added pic)
- fun with trouble codes on 95 90
- Recall info for you! ;O)
- A4 3 Spoke Pictures, P/N's
- Can someone confirm IGNITION SWITCH part #
- Has anyone tried these manuals ?
- Cialowicz -- your stuff installed yet? curious about your impressions of the cams
- 1.8T
- AVG, do you have any more shots of the handbrake covers? also is...
- Too bad I already have a car... :-/
- woohoo .. new car
- Will 1985 Audi 4000 rims/tires fit on 1994 90CS.....
- rear differential lock...
- Porsche mirrors...would I need to get an adapter?
- Thoughts anybody?
- Exhaust Question.
- RS2CQR Project Update
- Problem, RS2 headlight, inside assembly is loose!.......
- Sometimes my temp guage goes back and forth from cold to normal operating temp several times .......
- I wondered if anyone has taken out the rear headrests?
- My sunroof is starting to go slow and making a scratchy noise. What causes this?
- Saw a white 90 at Purdue today w/ RS2 bumper, are you around here?
- Spark plug and O2 sensor change help....
- I'm surprised no one has bid on this
- one last question then it is out with the old and in with the new alternator
- one more question for milwaukee people
- hey guys, one question
- Hey guys i need an opinion...
- Does a light blink on the dash-switches when alarm is armed?
- A4 3 Spoke Teaser Pics
- MikTip
- Looking for 5X112-15 space saver spare for audi
- Oct. 6 Calgary Area Audi GTG!
- Air Bag light won't shut OFF? ('93 90CS)
- Temperature indicator problem
- Needed '95 90 or '97 Cabrio Wiring Diagrams (Edit)
- What causes Limp Home Mode? Can a bad alternator or bad voltage regulator do it?
- Jimmy Pribble! I have a question about your RS2 MAF....
- attn: 90quattrocoupe (or other)
- fog lights
- Need a good head for a 90 200TQ.. 5cyl turbo head? anyone have one? please?
- Looking for seat
- 95 90 no spark, HELP!!
- 90 Audi 90
- How are the V6's in some of your cars?
- yo, i spotted a white type89 90q near Olive on route 28 in NY, anyone here?
- Montreal Folks : *MAC meet next Tuesday (Oct. 1st)*
- So do you think he every drives this in the rain? hehe hehe..
- Fixed instrument cluster voltage regulator/stabilizer
- need rear muffler!!
- Anyone here have/had Ground Control? What do I have to weld to where?
- Does a headlight assembly for a 93 fit a 95????
- My new sig...
- brakes squeak, but only when they're hot...
- I replaced my O2 sensors! Car is running so much better.
- Oliver: Can i have some info on that phone in you RS80?
- After replacing my sparkplugs, car felt like it is dragging...What's going on???
- I've been told . . .
- Hey guys! I've made a page to show you how to wire up the RS2 lights.. W/Pics.
- FS: Floor mats
- Go here
- is it okay to put 205s on 6.5in stock 93 b4 rims?
- Hey Audios69, are you back? you didn't fix your website yet. what happened to the tachorings stuff?
- NEW VIDEO of my car!! This is what too much free time adds up to...
- Just looked at 1991 90 20v quattro, need some input, please its important to me
- Any Good Mods for an 88 80 Non-Quattro?? I'm looking for some zip to it
- ACTUNG! 12v tuners!
- Some fun with my dirty car...
- Anyone running Yokohama Avid H4's?
- Question # 2
- Question about the key/remote for my 90
- Cut springs?
- can i have some pics of audi's with rims and without lowered suspension
- going to look at 1991 90 quattro 20v, clutch test?
- haha.. seduced my girlfriend on the top of her hood last night after the college pub..
- question plus bonus picture of the big plan
- HEEEEEEEEEEELLLLLLLLLPPPPPPPPPPP!!!!!!!!!!!!!!!!!
- Check out my old O2's...
- College student, waiter, bartender...
- who's last name is Rodriguez, I think you may have sent the Klez virus...more inside
- Fog light wiring
- What are 10 spoke '93 Audi 90 rims worth? (In good condition)
- ???If you could have any audi right now what would you choose????
- Here are some actual pics of my car, XM radio, sub and head unit.
- STOCK STEREO
- 2003 Audi a4 cab x-post from midwest forum
- Should I buy this turbo 90q(need opinions fast)
- Here's a weird one
- What about the twin turbo wagon?
- Why not to use 5k's or 200's turbo sys for turbocharging v6???(kinda long)
- question for my 1995 audi 90Q
- Info on converting front of audi 90
- Ordering new springs/struts asap...where to get H&R and Bilsteins or Konis from???
- Have to check the moonroof switch on my 90
- Help needed, please . . . .
- Question on connecting a new deck to rear "active" speakers...
- A new part from Kamei....
- Hey guys... Looking for some used stuff...
- Rob K
- What the heck is this?
- Anyone know where I can get some Supertorismo Corsa rims?
- Here's your chance!
- is a 5cly turbo swap into a b4......
- Electrical (light) problems
- This is what it all boils down to...
- I would like to use porsche studs for the coupe.. any info on this? or am I on my own?
- Is Quattro "all wheel drive" or "four wheel drive"?
- 16" or 17" wheels????
- anyone know where you could buy the. . .
- When should i check the oil level.... must the engine be hot? warm? cold?
- IF AUDI'S DIDN'T EXIST, WHAT CAR WOULD YOU BE DRIVING??
- Vermont coupe for sale...
- How much horse power can u get on the 20v turbo with..
- 2nd Calgary Area Audi Get Together! (Oct. 5 weekend)
- stalling
- Pic Wanted
- Brake Pedal Free Play
- Suspension Question
- Has anyone installed the center console gauges into thier B4 90 ?
- Anyone have a working Automatic Trans for 94 90 cs that they want to get rid of?
- acceleration problem.......... helppppppp
- cuatrokoop - Just a thought on oversize rings for 10vt
- need RS2 intercooler and exhaust manifold.....anyone??
- audi 80 buildup
- Salvage/parts yards in Denver?
- good mechanics in Indiana????
- Speaker size confirmation/recommendations ('93 90)
- Besides being an Audi fanatic, what do you do for a living???
- Suspension Parts HELP
- I bought Porsche plugs for the Rs2 mirrors only $11 a piece going to make custom harnesses.....
- Ordered the wheel!
- Major project on the way, need advice...
- What happened to BMWSLYR?
- Audi 90 Coilovers
- d'oh
- Fuel pump buzzing loud
- Does anybody know what is underneath the 1997/1998 cabrio bumper cover?
- Here's a thought....
- Temp Guage 91 Coupe Q occasionally malfunctioning
- WTB: Original Fog Lights for '88 Audi 90
- Finally! ...some pics of new ride....well...only in the sig...
- Selling my 94 90 cs... only $6900 CDN that's approx $4600 US.
- Gear/Differential Lubricant Question inside.
- Mt. Greylock Audi Run wrap-up & pix
- Older A4 style? Not a Honda?
- broken glass on euro spec headlight... anyone know if I have to replace the whole light?
- shift knob
- 7A head wanted
- anyone have wheel spacers?
- Wheels for '88 Audi 90
- Mr. Miktip few questions again: brakes: clearing issue:
- '93 90CS Repair Manuals???
- audi 90 alarm
- Octoberfest Open House and Car Show @ Hartmann Motorsports 10-06-02
- Where is a good place to buy. . .
- stalling
- Rust Proofing - Yea or Nay?
- Dyno Rsults
- WTB: Grey Door Tweeter from '94 90S
