View Full Version : Performance and Tuning
- Save on Fuel (and get more power) - How to Properly Blend with Ethanol
- Racechip
- Downpipe Audi A5 2019 45 TFSI OPF
- Anyone Familiar With This Brake Upgrade Kit for S3 8Y / MK8 Platforms? Brake Technik
- JB4 no Speed Gauge reading???
- PCV crank ventilation DIY for s5 3.0 tfsi
- Intake Questions
- RS Q8 performance APR?
- audi s4 transmission issues
- VPS Resonator Delete Kit Clamps
- The Innova 5310 OBD2 Scanner helps you easily find the problem & fix the problem.
- Anyone used Redstar Down pipes?
- 4wd dyno for RSQ8
- RS4 b9 Stage 3 bad result in dyno
- TFSIe 55 & 60 engine versions
- $50 Off the Innova 5420!
- Innova 5610 Hands-On Review: A Pro-Level Diagnostic Tool That Punches Above Its Weigh
- Power Up Your Diagnostics with the Innova 5420!
- Knuckleheaded teen driver - is it possible to detune an engine?
- We’re working on our next generation car scanner and would love your feedback!
- Coolerworx Megathread
- The 5410 Combination OBD2/OBD1 Scanner
- FREE Borescope with purchase of the Innova 5610
- Advice and pointers on brands and parts
- 3.5 Inch Diagnostic Tablet
- VCDS vs Carista
- Diagnostic Scanner for 96 and newer Audis. Free updates & free repair app!
- Innova 5610 Giveaway – Enter to Win Our Best-Selling Scanner!
- So, you want to increase power???
- Looking for Audi Mechanic
- 2017 a6 2.0tdi avant
- Exhaust
- B9.5 45 TFSI A4 intake
- Spprts cat downpipe for RHD
- Innova 3360 Thermal Camera - Infrared Camera with Heat Vision
- Wireless Scanner: Engine, Trans, ABS, SRS, TPMS, Battery Initialization, & more!
- PPI in North Jersey/NYC
- check engine light help needed
- just have to say it!
- How would I go about tuning a 2019 Audi a6 with the 2.0 engine? Is it possible?
- New to Audi, just looking for advice.
- correct spark plug gap for NGK Laser Platinum ??
- lpfp questions
- Bosch Coils + Bosch Plugs - best together??
- replace Oxygen Sensors how long to replace?
- HFC Install
- Performance
- Wagner Tuning Intercooler Upgrade RS5 B9
- B9 s4 sport diff programming
- Chip tune b9 a5 sportback?
- APR Stage1 Tune on 2016 Q3 - REVIW
- Unlocking ECU and TCU
- No spark power to coils
- Using OBD 11 to adjust ACC sensors
- SQ7/SQ8 tunes - convince me, please.
- Audi a4 Quattro
- B9 SQ5 ECU/TCU
- Generic tuning PC/ laptop question
- OBD11 vs Carly
- Best Tunes For 2018 Audi A4 Quattro Prestige With TSFI Engine?
- SQ5 tdi air intake
- AUDI Q7 TDI
- 2015 Audi S8 Vibration 1-3k Rpm
- Audi A4 B9 ECU and Gearbox
- 2022 SQ5 HPFP Torque Specs?
- C7.5 A6 2.0
- Able to use remote starter switch on 2010 A6 supercharged 3.0??
- 2021 A5 Tune Help
- 2016 Q5 TDI - reduced MPG
- No IE tune for my 2024 SQ5
- What is your car buying and ownership strategy?
- Sport Exhaust tips question
- Considering a modified 2018 TTrs
- Audi RS4 B8 conversion to manual gearbox of Audi S4
- Community help before it's too late
- Engine parts compatibility.
- 2018 a4 Quattro….. Anyone tune one of these? Any concerns or problems?
- Audi Q7 207mm lower pulley
- Lack of product knowledge and customer service. ECS TUNING
- getting ECU back to standard help
- Dpf egr deltw car won’t start
- Loud Noise When Accelerating
- 97 CABRIO 1.8L trans swap cv axels
- 07-15 Cabin Air Filter Install
- Looking for 5cylinder turbo
- Chipping a Q5?
- Your Favorite OBDEleven Modification?
- 2003 Audi RS6 Dyno (stock vs with 034 Tune)
- Traqmate Help
- Vehicle Chip Tune - Tracker
- Verstarkt Performance (VPS) RS5 Supercharger Install
- Miami VCDS DPF regen help.
- Audi RSQ8 Exhaust Upgrade - Custom Vs Miltek
- Diesel vs DieselPro
- Pull the Max. with JB4
- 100k Service - 09 Q5
- BE: Tune Audi S5 B8.5
- Diffuser for a4 with integrated tips?
- OBDEleven Nightmares
- A6/C8 Cold Air Upgrade
- ODIS with 6154a for key programming
- 2017 Q7 Prestige 3.0T. Hypatheticaly speaking, tell me how your dream tune would go
- Blower motor replacement
- I found this attached to OBD
- Audi 80 B2 1.8T swap
- Chiptuning remap detection dealers vag
- Audi a5 tail light teardown
- 2.7t higher hp what clutch are you guys running?
- A4 35TFSI s tr MHEV 2022 150HP tunning
- A3 40TFSI SLine upgrade
- How much to lower Audi TT mk3?
- Whining/Air sucking noise on acceleration
- Are stage 2 DSG auto shifts supposed to be smooth or jerky?
- Audi A1 Sportback 2018
- Tuning- Vast Performance? Reviews?
- B9 SQ5 Unitronic Stage 1+
- Any Tuners In NYC Area?
- Best standalone brand for Audi VW?
- RS5 2.9 how much HP max
- stage 3 TCU with stage 1 ECU tune
- UK: Audi Q3 high oil consumption?
- Removing auto upshift in manual mode-4M Q7
- Disappointed with VF ENGINEERING
- OEM vs aftermarket crackle tune
- Q5 3.0sc stage 1: 70-130hp extra. Should I?
- RS mode intermittent - RS5 2020 model
- 2001 a4 disconnect alarm system? apparently impossible
- 2008 Audi tt 3.2 Stock Rear Sway bar
- Any TCU tuners in New England area?
- Spark plugs?
- Project Car Transmission Help Transverse V8
- Downpipe & Xpipe
- New Project Car Reveal + Upcoming TT vs G35 Race
- Can I pair an APR ECU tune with a ZF8 TCU tune (stage 1)
- Audi S3 Stage 1 tune
- Emission Inspection DENIED
- srm high flow short intake inlet that fits S7/ RS7 4.0t
- Anyone done D5 S8 engine upgrades?
- NOVA Mod Friendly Dealers
- IE Intake and Turbo Inlet - Require Remap?
- performance mods
- AUDI A3 1.8 and Audi a1 1.2 remap
- Exhaust Flap Issue
- Exhaust manifold
- The real ideal #tfsi #PCV setup for the #audi #ea888
- Audi S4 Muffler Delete Kit using AWE Touring to Track?
- Chrome trim on grill colour code help
- Seeking Recommendations on NY Tristate Area APR Tune Installers
- left foot braking
- Audi s3
- Does the "CTS TURBO Intake" fit TDI engines?
- United Motorsports Haldex Tune @ 4SeasonTuning
- MK2 Audi TT 3.2l CTS Turbo Intake Install
- MK2 Audi TT 3.2l 034motorsports ECU & TCU/DSG Stage 2 Tune
- Tune Up
- 14 Q5 tdi chip and performance
- 1994 S4 OVER FUELING
- Audi A3 - Map
- Aftermarket Exhaust for 2022 S3
- Stage 1 future reliability?
- Audi TT mk3 stage 1 apr ecu/tcu review
- Unitronic DL382 TCU tune review
- Quattro diff in mk 2
- Audi A8 (D5) hesitates when accelerating.
- Where to Start?
- Groaning sound on deceleration
- Racechip setting
- Looking for a Austin / San Antonio Texas area shop
- MY 2013 AUDI S5 FEELS THE SAME AS BEFORE I GOT MY ECU STAGE 1+ TUNING FROM UNITRONICS
- Racechip vs APR & the rest?
- B8.5 A4 vs B9 acceleration
- Audi Q8 Grill Installation Los Angeles
- A4 2017 gearbox differences
- How to upgrade Audi 2010 A4 ECU
- 2004 s4 turbo upgrade
- Forged Engine Rebuild 2.0 TFSI Quattro - UK
- First Mods Tune vs Pulleys
- Confused
- Looking for simple advice re: JB4/maps/fuel mix B9 S5
- TTS power gains
- CARB to start checking ECU tunes?
- HOW TO MAKE COILOVER MORE COMFORTABLE: TIPS FOR DAILY DRIVING
- 2009 Q7 EVAP Canister Purge Valve
- throttle response and turbo lag
- How to increase top speed of A8 4.0T to Euro spec of 155mph?
- HOW TO MAKE SURE COILOVER IN YOUR CAR CAN LAST THE WHOLE LIFETIME?
- Superchargers or Turbochargers? About Their Advantages and Disadvantages
- When Is It Proper Time to Replace My Vehicle’s Spring?
- APR Plus installed
- Audi A5 3.0 TDI - 218 hp or 245 hp
- Stage 1 Audi A5 2.0 TFSI or 3.0 TDI
- APR PLUS vs APR Stage 1
- Looking for best place in USA for Tune and Mechanics
- Upgraded Throttle body install on A8L 4.0T
- 4 Symptoms That Your Connecting Rod Needs To Be Replaced
- 2007 a6 c6 3.2l quattro upgrades
- Egr delete with only tune?
- V8 turbo
- race chip install RS Q8
- TDI - cat delete, leave dpf in place; dumb or doable?
- 2016 SQ5 with APR stage 1
- JH5IT Turbo CHRA 079145704E
- K04-064 ball bearing turbo?
- My 2010 TTS has a custom downpipe... but which one?
- AEM vs. Snow Performance vs. Devils Own?
- 2018 Q5 2.0T Tuning Options
- Lag and Smoke
- Lag and Smoke
- Q5 e-tron battery performance
- Is it a bad idea to do the following performance upgrades?
- Apr dealer charging $220 to install tune
- 2004 A6 Will Software Update Solve My Probs?
- Wisdom in software flash:GIAC, 034, APR, EPL, IE, OTHERS? 2014 Q5 3.0t
- new NGK HS spark plug series?
- Spring Tune Up 2021
- Rough Idle
- 3.2 VR6 turbocharging
- A4 B8 Rich condition
- Tuning S5
- FI: Custom exhaust for Bitdi?
- Dynamic turn signal!
- Can anyone identify this?
- A3 intermittent whine on deceleration
- Whistle and potential power loss with new intercooler
- turbo. stage 2 vs stage 3?
- High revs - loosing boost
- Any experience with FSTuningea in Orlando?
- Audi A6 c7 2014 2.0 performance ideas and exhaust ideas
- 3.0 vs 2.0 midpipes
- LT: Audi A4 103kw to ???
- C7 cats on C6 3.0 Quattro
- Starting to tune my 2013 A4
- Audi A7 - New Magniflow Exhaust - Sounds Terrible! Suggestions?
- UK: Custom cat back rasp under load
- ES: IE vs performance chips vs APR vs REVO
- Seeking advice S3 2019 gear reliability
- Audi TT mk3 best stage 1 or 2 mods...
- Turbos not spooling
- HELP 4.0T FAILING PCV
- Chip tuning my S4
- ECU coding
- Timing issue with '13 Q7
- GT2052V possible to remake boost controll to manual?
- IE Stage 1 93 octane WOT issues
- What car are these lowering coil springs for?
- A4 Chip selection?
- Engine swapping 1992 Audi 80
- Racingline Cold Air Intake Review. Best CAI ?
