View Full Version : Performance and Tuning
- v-tune...
- Anyone know the CC rating on the stock 2.8 30v injectors?
- is the compressor housing alumn??
- Looking yo upgrade my intake manifold. Need Help!!
- Anyone know how much fuel the IAT can add or subtract?
- X-Post from B5: regarding K04 chip
- does the B6 1.8T have the 3bar FPR or the 4bar FPR stock? thx
- Who all swapped the 2.8 Transmission into the 1.8T
- Shift point ?
- Any one running the Autronic SMC Kit?
- Valve Cover question for you DBW guys...
- Is anyone running a
- x-post, thread on engine internals on TT forum. interesting stuff.
- Cat cams price...
- boost controller... which ones have no boost spike?
- xpost: need help diagnosing engine problem
- Turbo Question on the 1.8t engine
- where can i buy decent gasket for gt turbos?
- anybody know where to get O2 sensor simulator for our car??
- Is Mance still selling upgraded control arms ?
- Does the heater circuit of an 02 sensor turn off at some point?
- New motor and drivetrain for Rallye
- who did DBW to Non DBW conversion?
- Funky noise
- How much did everyone pay for their aftermarket cams for the 20v? TIA
- looking for Seattle-area shops for mods
- GHL custom exhaust
- X-post.. upgrade brake kit for my A6 2.7T... i want to upgrade my stock brakes
- NE1 know where I can get just front G-stop SS brake lines for a B5 A4/S4?
- Can anyone tell me the 3 hottest parts on the Market for Audi's?
- Blizzak LM-22 215/55/16 XPost....thoughts?
- Turbo question:
- Water Injection Question
- gt25r update3...
- blow off valve or cold air intake?
- Cat aftermarket cams for B5 1.8t A4
- x-posted from the s4 forum: brake bias calculator
- Anyone recommend a chip dealer in Portland OR? For a 03 Allroad 2.7T. Thanks
- Anybody have a link for a Dual weber Carb
- Audi and TDI experts....
- Anyone have the stock gear ratios for a 97 5 speed
- Bung-hole for my TP. hehehe
- Tunin gup my new A4
- Darkside?...
- Dam Control Arms,What are your thoughts on fitting Zircks?
- EO5
- T-28 question: Is there suppose to be a gasket between the exhaust manifold and the turbo?
- ko4 kits
- Sparco help needed
- Best Turbo Poll
- Dyno Graphs/Results
- Sleeving blocks... not audis
- anyone want my SRD's?
- gt25r update2..
- Quattro IV vs Subaru AWD
- Drive train Stabilizer..Who has it?worth it?Easy to install?
- anyone ever use a program like this..
- Stumble a 3k rpms (vag-com plots inside)
- Results from Dyno run at xotic motorsports
- Aftermarket cams for 1.8t, has anyone tried them?
- CUSTOM TURBO SYSTEM
- will a front wheel drive chip work on my quattro
- will a GT35 bolt on to an APR maifold?
- Eventually going for a turbo upgrade. If I decide to change to forged pistons/rods, how difficult...
- recommended reading from a friend of mine...
- Is anyone familiar with Renner Motorsports and their work?
- Not exactly audi related but
- What exactly is involved during an "engine rebuild?"
- x -post: 00 Stage 3 car leaking exhaust into cabin, rough idle, and seems like some sort of timing
- any input on the most reliable and cheapest ko4 kit?.......2000 S4
- What would cause the shaft of a K04 to break right where ....
- anyone know any audi/vw tuners that are also competent mechanics in the LA area?
- This thing looks like it could be interesting
- APR Stage 4 Piston Failure.
- OK...here's another STG3 (APR/PES) question..NOT about performance (finally!!)
- Opinions on Ceramic coatings for turbo's ?
- What ever happened to Avalon's oil coolers?
- GFB stealthfx BOV spring tension problem
- some update on the gt25r project...
- X-Post, Socal Dyno Day GTG at AMS!
- MC/MC2 vs 7A (turbo vs no turbo)
- What blocks log injector duty cycle?
- APR stage 3 and PES T-28 butt dyno questions...
- how do you figure out volumetric efficiency?
- What is the internal diameter of the "soft" portion of the fuel delivery line,.......
- Paging xr4tic...
- Tiptronic Tranny info
- Blown K03 on a 97 a4 auto. Would it be worth the extra money
- REpost for daycrew: 99.5 1.8T n-dbw: 7psi max & 21vac??
- Planning the DP back part of exhaust, need a little help with parts needed..
- A little more on Eurospec.
- she lives... yes!
- exhaust tech question?
- Where should i get parts for custom DP? eg. 3-bolt flange, piping?
- What's the skinny on the APR Stage 3 + kit? How much power?
- 2.0L kits and blocks
- Other than injector CC rating...what other things are there to watch out for?
- 1.8 in desperate need of more. what chip should I do?
- turbo timer problem for 2003 a4 1.8t
- i have a k26 turbo and need to Know what can be upgraded
- CT/NY Audi Group Get Together & Dyno Day Update - Dyno Scorecard & Car Wash
- J32 software for 2000 w/ k04/fmic?
- my boost controller
- Custom Garrett Software - Part Two - The Dyno Results
- Could this be fit to a 225 TT?
- This has been done to death but I need honest opinions before pulling the trigger.--->
- Several engine mods NOT bolt on need advice
- any good mechanic shops in ny
- Does anybody know the max temp a CF hood can take?
- if i relocated DV to throttle body, will i run into problems??
- VAG-com M-blocks...? Different information in different blocks on differnt 1.8T's?
- Writeup on the 1.9L Custom Turbo'd A4
- ok, while i am waiting for more parts to come.. how do you do catalytic converters?? anyone?
- CT/NY Audi Group Get Together & Dyno Day Update#5 - This Saturday 1/24...
- Intercooler experts and opinions Dual vs. FMIC
- So I'm at work and I see some familiar MAF's sitting on one of the other engineers desks...
- Pics of 1st Eurospec skru-up
- Pics of Eurospecs latest Fikup
- Strange "pop" @ 3k RPM, only when at WOT, only in the upper gears (4th +5th).
- Paging xr4tic...
- I need to post pics of 2 blown motors from Euro Spec kits, does anyone have a place I can put,
- Does anyone know the part number for the stock flywheel on a 2000 A4 Quattro ATW?
- x-post from the S4 forum. Not getting a lot of feedback. TIA
- any tig welders here? know how to stop this....
- RC Engineering injectors? Consensus...
- Injector Color Code? 2.8
- chip
- People with REVO...
- SS 304 or 316 corner tubes
- Anyone know how to reset the readiness codes with the VAG-COM?
- anyone want to let me know if this is safe or not?
- for those that done turbo upgrade, or hv larger fuel injectors...etc. how is your gas mileage?
- New Intake manifold project under way..
- What should the max. MAF readings (in units of g/s) be on a PES T-28 kit (n-dbw)?
- anyone know if i can get a automatic tranny that holds more power than my stock on my 03 A4...
- xr4tic, re:injectors
- (X-post) Anyone ever have a bent clutch fork?
- Lucas are you here?
- Does anyone have contact info for Schrick North America? Thanks.
- Is there a good 'ol way (analog - without computers) of doing an alignment?
- HELP needed Error:17938 - Camshshaft Timing Adjustment: Short to Ground
- Any one know of a High Volume Oil Pump for 1.8T engine?
- Stealth Mission: WORX A4 gets Custom Garrett Software - BAM! Explosive Power!
- anybody following these products' release? looks promising
- I just installed a test pipe and I have some questions about avoiding a constant CEL
- scrounged this up on a thread on vortex..fueling comments?
- Heavy duty carbon remover??
- CT/NY Audi Group Winter Get Together & Dyno Day - UPDATES #4
- X-post: Anyone try the Bosch green top injectors (42#@3BAR) with the PES T-28 Kit (ndbw)?
- need performance tips and hints please
- Rumor has it, that one of our own A6's, has finally recorded a 12.9 1/4 mile!!!!
- STFA - need part number - From the B5 Forum
- attn Audi2ptzero: Did you DBW come with EV12 type injectors?
- What's the fastest anyone has had a 710N go bad?
- Why isnt there something like Hondata for our ecus? Are our ecus not fully cracked yet?
- Whats the equasion to convert units of cc's -> lb/hr?
- frothy oil...
- Whats The Biggest Turbo That Will Fit The APR Stage 3 ManaFold?
- Anyone know where to buy Motul 600 on a sat. in the OC? Please?
- what should 02 voltage #'s be at idle? should they sway or stay put?TIA
- Do I need larger injectors?
- High flow cats
- repost-Major Engine Failure -HELP-
- ATP Turbo install probs
- neone know how to adjust sound on the lltek hybrid bov for B6 1.8t?
- fast and the furious
- is the any difference(air flow wise) between cheap cone filter and a brand name cone filter?
- What to look for when looking at used Stg 3 1.8T??
- Audi TT Heads differences (180 vs 225Hp) ??
- Just lowered my car ('02 A4) Do I need to get an alignment. If so, can I getaway with driving...
- Similar to Jamez post below, look what GIAC announced today.
- To xr4tic and you other guys wishing for a way to tune your motronic...
- POLL....Motors blown with PES kit...
- X-post - How do I run this type of Boost Line, adapters?, It is for the Blitz DC series...
- so does the 1.8T quattro 6 speed tranny that is available now
- Fantastic new Chrysler Four Twelve Sport car!
- ***HELP*** I have a little problem with my turbo (long explanation within) x-post
- Some pictures of the internals of my blown motor...
- DBW guys check out this new tuner car
- Does anyone make an adjustable cam gear for the 10v 5cyl?...
- CT/NY Audi Group Winter Meet & Dyno Day - UPDATES #3
- Feeler Post: Is there any interest in setups that go WAY BEYOND Stage 3.....m.....
- 4000q 4.11/1ring&pinion in A4 5speed?
- Anybody know if a switch like this is available on the market...
- is it possible to install a apr chip on your own
- Contact details for Juan Mendoza
- What would it take to convert B6s returnless to return fuel system?
- Does normal injector math doesnt apply to an engine with returnless fuel system ?
- attn giac chip owners
- Paging Brent V...
- 1.8T engine differences ??
- Are the back of the K03 and K04 turbos the same?
- QTEC Down Pipe, freeexhaust by the push of a button... (more)
- HELP SSP TipMod into my Automatic A4
- weird noise coming from the engine
- Electronic Stabilization Program - activate?
- Is vibration in the clutch pedal only attributed to a bad throw out bearing? What can I do to fix...
- custom exhaust
- vw obd2 to laptop capabilities,and mods w/out chip
- HELP needed with cat removal
- Are those cd's they offer on eBay the real deal...
- Large injector recommendations?
- Thinking about trying to do a brembo bbk group by anyone interested?
- Performance suspensions for 4kq's?
- What do you guys think about the ECS Stage2 ver2 brake upgrade?
- oil plug to oil pan is completely stripped...
- Options for upgrades -- '97A6Q
- Automotive schools?
- splicing into the electrical connection from the N75...
- A4 2.6L
- Paging xr4tic...
- installed K04 a few days ago need some info...
- Who has the best deal on 50lb injectors or should i say, best 50lb injector for the price?
- exhaust poll and help
- S4 or A6 2.7T
- Looking to buy a K04 for a TT as mine blew up HELP suggestions
- Anyone know of any good suspension shops in Long Island?
- New Low Blow
- CT/NY Audi Group Winter Meet & Dyno Day - UPDATES....
- Someone help!!! Crank shaft and cams moved turing TB job!
- What's the '02 A4 1.8T Oxygen Sensor voltage? Most cars it's 1.0V but someone said '02's are 5.0.
- VAG-COM data of my A4, comments?
- looking for suggestions for 18"x9" wheels for my 96/97A4 1.8t
- new b6 s4 upgrades?
- CT/NY Audi Group Winter Meet & Dyno Day - Jan 24th - Wethersfield, CT
- Exhaust questions, Also can anyone tell me about Borla or Dynomax mufflers
- 98 2.8 fwd center exhaust
- ?'s regarding a normal 2.7 bi-turbo vs. KTR's single turbo setup...
- Engine trouble, loud clacking, no cell lights though, help...
- What are healthy g/s #s for a MAF?
- S4 BSFC question - are RS4 injectors limited?
- Worx visits the Dyno - GIAC Power!
- X-Post from B5 A4 forum, you guys seem to know more over here (drivetrain problems inside).
- Will OBD I throw codes with no cat?
- b5 2.8 to 2.7tt swap info?
- Next Audi Project: some questions regarding custom turbo setup with B6 1.8 or 3.0...
- More engine mounts questions.....XR4TIC, is your email address updated (returned to me)
- I had a little time today so I worked on my Monster
- N75 replacements?
- 20V flow numbers....
- What words come to mind? Busy? Ghetto?
- Anybody chipped an A4 with CVT?
- Is it normal to see lower boost when using a race gas program v. 91+ program?
- Bellowing smoke out the exhaust, no boost no power HELP!
- Also, looking for specs for valve springs......
- STFA'd, no luck. Anyone with info/email to someone with info, regarding A/FC connections.....
- X-Post from B5 forum in regards to brake pads
- APR Stage III Gone Bad.... Help!
- opinions on an Unorthodox Racing pulley for a 1.8T??
- Update: Ex. leaks found, running, but need to fix those
