PDA
View Full Version : Performance and Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. Questions about Literature...
  2. Can someone explain to me how .....
  3. Does an engine's compression have an impact in the total volume of exhaust gas produced?
  4. Air/Fuel tuning questions..........
  5. S3 power loss
  6. TO4B and TO4E info if this helps anyone.
  7. T-28 guys. When do you hit max boost? I'm hitting 1.5bar around 4200-4400rpm does that seem right?.
  8. Need help... Startup and cold idle problems getting worse on t-28 1.8t..
  9. k04 fit on stock manifold??
  10. turbo clipping
  11. ATN: Smokin.........
  12. X-post B6 S4 forum - Looking for a good guide to mods/work
  13. To anyone who has experience clamping the MAP sensor...
  14. Ouch! manifold stud snapped....any tips???
  15. stage 3 install almost done......no software!
  16. 2 Point Zero - Are u tuned yet? Is it running?
  17. Accidentally turned bpv into bov...
  18. MTM Stage 1: will it work in an euro-spec '95 S6? Other options?
  19. Thoughts on aluminum flywheel
  20. APR suregrip pads for Stoptechs, any good?? There is much info in the archives.
  21. Does anyone have any ideas what could be going wrong here?
  22. What is the difference between the B5 S4 and B6 S4 brakes??
  23. X-post: Help with Boost Spikes
  24. Pagid Blue opinions?
  25. that little nipple thing on the caliper used to bleed the brake fluid. what happens if it breaks off
  26. Opinions needed on a BPV - HELP!
  27. how do I wire an electric cooling fan to a toggle switch
  28. S4 vs A8 brake upgrade
  29. Anyone ever get one of these codes? (edited)
  30. I am stupid and need help with Koni sport shocks.
  31. The A4 update,...
  32. PLZ help~ My car died AGAIN, 3rd time now.
  33. Our rods o the 1.8T are 144mm correct?
  34. When selecting rods is it more desireable to have lighter rods, or heavier rods, both are forged
  35. Brief Update
  36. This may have been asked before, but how does back pressure relate to power output on a NA engine?
  37. Question on air intake temperature...
  38. x post: What is the consensus with ATP kits here on the performance forum?
  39. Any race 1.8t's
  40. FMIC or SMIC?
  41. Let's play name that turbo... again
  42. What/why exactly does boost creep occur with a free flowing exhaust?
  43. Just spent an hour reading the post from Liam. Anyone care to explain to me in simplified terms
  44. anybody tuned an rs2?
  45. Who has the yellow A4 "TUNE ME". Fuel pump question inside.
  46. N249.. any takers?
  47. sorry if it a repost, MOTUL oil Audi (TT) any coments?
  48. discussing audi mods with solo ontario organizers
  49. R&A Applied Arts or Autosport Performance (both in NJ)...anyone done any mods there?
  50. Done deal. here is my membership application for your sig, WYSIWYG :)
  51. APR Snub Mount, How long do they Last?
  52. K04 / T28 Hybrid
  53. Reducing compression
  54. APR SIII question....
  55. couple new pics from Mike's car...
  56. Question for guys who turn their own wrench...
  57. For those that have bypassed their N249 valve.. what did you use to cap off the line from the valve?
  58. Some Ko4 questions....
  59. having probs with my pes 7-28 kit.... not sure what it could be
  60. how big can you bore a 5cyl?
  61. Which spark plugs are you T28 guys using? thanks
  62. pic of correct brake line length to use with ECS kits
  63. Att Mike..
  64. APR Stage III overboost problem - please help.
  65. audi 80 v6 2.6
  66. Anyone bypass the N249 so that the DV receives direct vacuum from manifold?
  67. need servis in Chicago area for my audi 200TQ please
  68. John are you AIM?
  69. Mike:
  70. 2.2Coupe conversion to 2.2turbo
  71. How do non-DBW ECUs control boost?
  72. Can anyone tell me where I can find info about stuffing an rs2 trans into an a4
  73. Looking for...
  74. Vag-Com Data Logging Results, Need Some Help. X-Post from A4 Forum.
  75. Anyone know what the ideal A/F ratio is for the 1.8T/2.0T ?
  76. Can someone help me diagnose what's wrong with my car?
  77. mixing diesel and gasoline
  78. Anyone know of a 4 wheel dyno in boston?
  79. 02 A4 Supension prob. question
  80. In reference to fine tuning the 2.0L big turbo'd engines....
  81. Funniest quote i have heard for a long time.
  82. Att Mike, I hear your car is all done?
  83. started the car after T28 install.....really rough idle, no codes. any ideas?
  84. any one have any experience with ECS pulleys?
  85. Anyone know the Pin/Wire color for TPS(throttle Positions Sensor)on 99 1.8t on the ecu. I just need
  86. S4 rear brakes on an A4????
  87. what can you tell me about this spark plug
  88. People with custom exhaust manifolds...
  89. Anti-performance, stock flywheel wanted
  90. Greddy Profec B vs. Greddy Profec B Spec 2?
  91. Dyno results....
  92. This weekend's project....
  93. Upgrading Cams 2k A4 2.8 30v V6
  94. Do the Passat & A4 share the same ABS sensors ?
  95. Were the result for the European Car 1.8T shootout ever posted?
  96. Let's see. All the masterminds: audi2ptzero, wsywig, rob, cuattrokoop, xr4tic, yippers, and others
  97. OE Bosch injector flow rates
  98. new 6spd in B6 A4 1.8T Anyone know if this is going to match up with the b5 1.8 motor?
  99. are octaine additives bad for the engine?
  100. Need some help...
  101. Bucking from 2nd to 3rd gear
  102. So what will it take to get an RS2 trans into my car, other than me getting pissed and a crow bar?
  103. FMIC on A4 1.8Tquattro
  104. I have a problem with driver's side headlight...
  105. would i need to remove the engine to put new headers on?
  106. Installing 2.8 tranny soon but which parts to get.......(help)
  107. ok, just installed an ECS N75 into my 1.8T. Do I need to reset the ECU? Need advice !
  108. s2
  109. Spark plugs and the 1.8T AMU motor
  110. SAFC. I don't see anywhere in the archives where anbody
  111. possible exhaust blockage....need help diagnosing
  112. My car just died~
  113. Went to Drags again. 12.1sec
  114. what is so hard about replacing a compressor wheel on a ball bearing turbo?
  115. hOW TO turbo an '86 naturally aspirated 2.2liter 5 cyl. 4000?
  116. john, a video for you
  117. What should the MAF readings be on a PES T-28
  118. Anyone want to help me interpret these timing graphs.
  119. Yeah, so I picked up a project car on the side :)....
  120. I am currently having my cylinder head port and polished
  121. K04 vs. RS4 K04... Just read in a an article that they are not the same...
  122. so much to my surprise, limp mode was not solved...
  123. Att Audi2ptzero? Got you car back yet?
  124. Has anyone thought about wrapping the crankcase pipe with exhaust wrap?
  125. MY2000 A4 1.8TQM Test Pipe?
  126. IDLE PROBLEM
  127. ECS N75 valve. Worth the swap? User Reviews Please!
  128. Underhood 'wheeze' on shutdown?
  129. how much power can the 1.8tq 5spd trany take, before issues arise?
  130. limp mode solved...so it seems..tracking tomorrow!
  131. Intersted in getting forged pistons and rods for my large turbo setup, Have questions.
  132. Suspension Q. You shouldn't go past flat with your control arms when lowering....
  133. xpost from AZ - big turbo S4 project
  134. Good technical question....
  135. Question on Greddy valve...
  136. Dyno Runs: When/Where/What/How?
  137. rebuilding a 3B engine from '91 200 20v
  138. N75 valve revisions...
  139. GIAC email problems?
  140. Higher coolant temps.
  141. Timing Questions...
  142. tubular manifold...
  143. 1.8T Internal Engine Parts--Max HP with lots of boost
  144. What kind of gains can I expect with the following mods on a 1.8T
  145. 12 valve V6 Throttle Body
  146. Attn:John Baas- Stupid question but i just go the A4 official repair manual and i cant find the ecu
  147. Anyone do a water injection cleansing?
  148. What about those Fuel Injector cleaner solution?
  149. XR4Tic - you were right about the downpipe. There was plenty of room w/ a DTS
  150. I have a couple slots left for Dyno Day
  151. how much $$$ wil i get set back if i want my 2001 S4 6spd into the 12's?
  152. audi 100 121kW 2.2 turbo pressure
  153. Lots of clutch questions...
  154. GIAC 91 chip and N75 "J" valve on a '03 1.8, does that work???.....
  155. blech! limp mode woes continue..
  156. where can i get a tiptronic transmission oil cooler?
  157. I'm sad.
  158. Anyone looking for a cost friendly wideband, check it out
  159. Anyone w/APR Chip problems on Older A4's?
  160. who's running an oil cooler?
  161. Need help with hybrid BOV question... <cheesy voice>Pretty Please!</cheesy voice>
  162. Intermix with Oil and Coolant...HELP...New 03 3.0
  163. Electronic boost controllers
  164. Big break question.
  165. Clutch Mystery with Recent Southbend install - Xpost from A4 forum
  166. Do they have stainless steel braided clutch lines for audis?
  167. Att Mike. Whats the new story on your car??
  168. H&R's or KW coilovers for 99 A4 QMS
  169. 12v NOS
  170. revotechnik.com
  171. 1990 80 5spd 2.0L 8v
  172. xpost from AZ, +27hp from an equal length header on a KO4
  173. best(cheapest) place to get 475cc injectors?
  174. Wanna find out who's got the most HP?
  175. Rear rotors from a front track A4 and Passat are interchangable right?
  176. what are "safe" EGTs
  177. TTotal engine newbie here..... why cant we use these 350-400hp >>>
  178. 2.8 Tuning/Project [New forum Member]
  179. best tuning upgrade to start with on 1993 90CS
  180. stereo help badly needed
  181. Maf sensor problem.need advice
  182. Best Audi motor for tuning. OPPINIONS NEEDED
  183. Does any one have a 2000 manual A box or a K box ( ecu )they are willing to part with
  184. ok cash in hand can't decided on which turbo......GT30R...GT35R...GT30/37R
  185. Best recomendation for Performance upgrade my 2003 1.8T A4.. please
  186. Break pads ?
  187. A4/B5 suspension question...
  188. Anyone ever had an ECU go bad?
  189. I'm installing a new fuel rail for an injector upgrade but...
  190. places to purschase garrett T28 turbo?
  191. Date set for Dyno Day
  192. from some research looks like the Intrax ARS coilovers
  193. In need of information reguarding custom manifolds and my choices for an upgraded turbo.
  194. Simple question
  195. Triple K K14 or K16
  196. Anybody running a Wideband O2 sensor in their car?
  197. Anyone here run Falken Azenis at the track?
  198. AWD Dyno Day in Troy MI (Updated)
  199. Can someone pls list the ways of reducing understeer in the B6 S4?
  200. tubular exhaust manifold for 1.8t?
  201. X-Post: Calling metal/CF fabrication gurus, AGAIN :)
  202. I need some battery relocation Tips...
  203. Has anybody heard about headers being available for the A4's?
  204. High Air Flow Cat Converter
  205. Help with my turbo project
  206. Help: knock sensor placement on '97-'99 1.8t
  207. Anyone know of the place in Newark NJ that was doing clutches for around $300?
  208. lifter type in 1.8t???
  209. RS6 Tranny parts in an A4 TIp
  210. Block 031 Graphs
  211. single bolt rims and adaptors
  212. any requests on a quiet exaust for a 01 s4........
  213. to mike O
  214. x-post I'm working on getting a groub buy for neuspeed exhaust anyone interested? details inside
  215. lookin to spend $3k or so...just into a chip and exaust, any ideas?.......
  216. Has anyone used Vizard's cam spec program?
  217. TAP
  218. What block do I use to monitor misfires?
  219. Since you guys over here are much more knowledgeable about boost.......
  220. What is the max boost (psi) of a NDBW T-28 kit?
  221. spark plug gap....I'm at .028"....is it worth it to push it to .030" or even .032"?
  222. drag results: 13.236 @ 104.16mph (1.856 60 ft)
  223. custom Intake parts need
  224. Auxiliary Fuel Injectors
  225. Battery relocation question.
  226. My New GIAC X Chip - Please Help!
  227. guys, take a look @ my alignment settings please.
  228. XPost: Garrett Hybrid Q's
  229. Does the 1.8 turbo have Variable Valve Timing ?...
  230. anyone investigate retrofitting a TT/S4 after-run coolant pump on a 1.8t?
  231. Question regarding T-28 programming.
  232. A4 2.8Q performance upgrades?
  233. Intake?
  234. MAS air and Speed density 1.8T motor
  235. what should I use to sseal the threads on brass fittings for oil lines?
  236. any thoughts on this turbo?
  237. xpost about exhaust clamps...
  238. UPsolute chip? Anyone have or tried one?
  239. $15 dyno article
  240. What went wrong?
  241. Those using an FM oil cooler....
  242. Attention John Baas or anyone else- Does the Audi A4 offcial repair manual have the ecu wiring
  243. Porsche Big Red Kit : changing brake pads is a royal PITA
  244. My first A6
  245. I just reinstalled my shocks and Im trying to set everything up
  246. STaSIS Track Sport coilover install question
  247. any cheap mods for audi cab 2.0 8v uk car,air box has k&n no better!!!!
  248. Daily noob question about chipping....
  249. anyone have a k03 for sale? (other than the two in classifieds)
  250. Larger Turbos
