View Full Version : Performance and Tuning
- New sound after ECU upgrade
- Clutch and gear box sticky in the cold
- 2007 A4 Avant 3.2L Quattro, check engine light still on after recent service
- Transmission fault
- Downpipe install Audi TT 180 Quattro Help!!
- Vw Gearbox JJY
- Audi a6 resonater tips
- Help with my APR Emcs type 1 chip
- Replacing 4.2 V8 with 4.2 FSI V8
- Burger Motorsports JB1 Review
- Any interest in OEM steering wheel extender?
- 2005 a4 2.0
- 09 A4 3.2 Performance Upgrades
- Help with my turbo swap a4. Having issues🙃
- Exterior suggestions for b6 A4 1.8T
- Can apr tune permanently remove cel light/pass emissions?
- HMMM.....Steering Wheel
- Slow to boost after bi pipes and darintake?
- '07 D3 4.2L Exhaust suggestions?
- Help me please 2001 A6 Quattro 2.8
- Secure ECU?
- '15 S3 Remus Exhaust and Berger Comp
- 2008 Audi A4 stuck in manual Help please
- Shop in Toronto Area?
- will installing a k&n filter in my q5 make it use more coolant?
- the almighty 6 speed swap
- Q7 TDI DPF DELETE ?
- Considering tune for 2013 Q5 3.0T
- 2015 S5 performance upgrades
- Turbo kit on VR6 3,2
- 3.2 A6 performance woes!
- 2014 S5 mods exhaust/air cleaner/pulley/tune expected COST and options
- Tune at home, or send it in?
- upgrading 1.8t to 2.0t
- Funky sound after I lock my car
- 2000 Audi A4 quattro tranny problems
- 2005 Audi A4 2.0t dtm stalling problem and idling
- Any suggestions for an exhaust for an 2008 A4 S-Line 2.0T?
- 08 Audi pressure loss question
- 2002 Audi A6 (4B) 1.8 Turbo Cold air intake question
- New here
- Low power related to fuel pump?
- 2006 audi a3 manual launch control?
- Audi Q5 2013 2.0 APR PERFORMANCE CHIP STAGE 1
- 2.7t boost/bigger turbo questions
- 2003 a4 1.8 t auto troubleshooting
- 2007 A8 4.2 tune??
- 2010 A5 Quattro Premium
- Electric Power Steering
- Limp Mode
- RS6 mufflers on A6 3.0
- JHMotorsports Tune...Stay away!
- 01 a6 2.8L, idle problems?
- New fmic, cai, 3inch cat-less dp, car is stumbling and surging boost?
- audi A6 2006 2.0 SE TDI
- 2004 Audi A4 battery dying.
- Occupancy Shell
- Vibration/wobble low speed
- whistle/squeal/whine? at high speed
- Vag-Com Houston?
- Audi sport steering wheel
- Major bucking/jerking
- Advice needed for new flywheel
- 2.7t Diode mod?
- Serious question!!
- audi a6 c7 2.0 tdi Ultra
- 2002 Audi A6 Quattro v6 3.0 L
- Anyone running Haltech?
- B7 S4 best exhaust system performance and sound??
- Humming noise inside
- ECU upgrade for a 2013 RS5
- Fan trouble
- High flow cat on otherwise stock 2.0 TSI
- 2001 Audi TT Quattro Exhaust
- 2004 Audi S4 Evap System
- 2001 Audi TT 180 Quattro
- S5 Exhaust
- 2001 A6
- I want my 2010 Audi A4 to be faster
- Tune and car performance survey. (California)
- need help ASAP tuning programs for big turbo Audi TT
- Reviews 2016 Audi A5 Sportback gets sharp new look
- Boost problems
- Over boost!
- please help. Engine won't run after suddenly shutting down on freeway.
- Any Great Alignment Specialists in NYC Area?
- I NEED HELP PLEASE ADVISE
- 2014 Audi Q5 TDI Engine Air Filter
- Q3 2.0T Performance Boost
- ****Audi q5 exhaust suggestions??*****
- 2010 A6 Avant -- Quad exhaust
- DSG ratio tuning
- Memory saver?
- ECU question 96 a4 base
- bad maf, no better with new one installed
- Transmission problem
- Long life service a4 tfsi
- Diverter Valve Question on 2001 225 Audi TT
- 1.8t Magnaflow or Borla?
- 2005 audi tt 1.8L auto
- A4 Quattro 2004
- Audi s4 awe exhaust system
- Pulley upgrade APR STAGE 2 audi s4
- s3 exhaust
- 1991 200 turbo 20v tuning
- Audi A4 A5 A6 A8 factory supercharger / kompressor NEW
- 2006 A6 C6 4.2 ECU upgrade using VCDS
- need help regarding exhaust and warranty?!
- 04 Audi A6 Quattro brake light
- Help! Paint Damage - Egged
- Looking for an oil pump need some serious help
- Plastic diverter valve?
- Blinking red oil light
- 2010 Audi 2.0T Check Engine Light and EPC Light On!!!!! HELP?!?!
- Audi A6 problem! P3081 code
- Don't know where to start
- 1200hp b5
- Weird power loss when pedal is down
- could these fault codes still be valid?
- Titanium CP2 Mandrel Bends!
- What's the best ECU upgrade???
- tranny issues
- Tubo charger
- TT turbo
- 2011 3.0t Quattro c6
- Basic Maintenance Tips Audi A6 2.7T
- Looking for an ECU upgrade for a 2013 Audi S5
- A4 B8 intakes
- Anyone tuning with Autronics or Motec standalone engine/traction computers?
- A6 C6 Brake Upgrade. Lambo, Porsche or other Audi S or RS options?
- 2000 a6 4.2/c5 Quattro problems, please help
- 2.0t quattro stage 3?
- WTB Audi RS2 ECU 95-
- shops in il
- Platinum gray enterior paint code
- B6/B7 recaro seats
- 2001 Audi a4 easy upgrades
- 1992 audi Quattro 100 v6
- Favorite audi specialist shops in tristate ara? (NY NJ CT)
- Turbo issue
- To Flywheel or not, that is the question???
- Looking For Beta Testers (Titanium Exhaust)
- If you need a tune for Audi or VW
- tuning hardware/software availability?
- Want to stick all interior. Sticky drape, what you think about it?
- Throttle body, injectors? 4.2-3.0?
- Audi A6 1.8t automatic(straight pipe)
- E-85 conversion ,2001 audi Tt, any thoughts
- 2014 Q7 3L 245 Which Chip is best ??
- Replacing cats with straight pipe?
- N75j valve install
- 2015 a3 1.8t performance gains
- Racechip response control
- Freddyh
- 2003 Audi A4 Quattro won't accelerate fast-takes a long time to get up to speed
- Running water pump from crank pulley
- random misfire
- problem
- my audi's lighted emblem
- Sluggish 1999 tdi a4
- Has anyone replaced their transmission fluid in their audi 6 3.2 after 100k miles?
- my audi's difference (lighted emblem)
- extract dynamo from audi a4 2001 engine??
- 02 TT Roaster idle issue!?
- A8L Surging
- Is it my turbo ?
- High pitched noise from Engine Bay.
- 42Draft Turbo Back Nightmare
- Transmission slipping
- Tune-up? oil change?
- S5 3.0T HP upgrade options?
- coolant leaking into oil
- Audi a6 2001 2.7 white smoke drives horrible.
- Abs,airbag,cel
- How do i ugrade to stage 2 apr?
- Humming/buzzing noise
- Looking for Capristo Exhaust for RS5!!!
- 2000 Audi a6.
- No Check Engine Light On - Will Not Idle Above 40 mph Intermittenly
- 1.8t boost problem
- S4 boost problems with oem exhaust
- RS5 Exhaust
- Final Drive Gears
- PLEASE HELP
- 2001 A6 2.8. misfires and runs hard at low Rmps and fine at freeway speeds.Help?
- Car cutting out and battery warning light coming on! HELP!
- car wont move
- Turbo
- White Audi
- Custom Warranty / Insurance for Modified Audis
- VAST clutch, where to buy?
- newbie to forum, need some help
- Code 00293 (Multifunction switch): WHO HAS DEALT WITH THIS?!
- 2003 Audi A4 B6 1.8T Quattro MT Exhaust Fix
- HELP! audi tt won't shift into reverse and is revving but no power!
- Chip or not? 2010 A5 2.0T
- Transmission Gear "S"?
- Turbo. Boost won't go past 3
- I want to start dyno tuning Audi and VW's! What schools should I look at?
- chip info
- upgrade thoughts
- Bad experience with APR and 034Motorsport (2012 Audi TTS)
- sensors part of a tune?
- 1990 V8 Quattro - taming a loud custom exhaust
- Tuning Compremise Longevity?
- A7 Top out at 120 mph
- KO4-015 TURBO MANIFOLD FOR AEB MOTORS, XS-power, SSAC
- Annoying Burning oil leak...
- I dig this car.
- APR TUNED 2013 A8 - First tuned A8 4.0 in the US?
- Tuning A8 W12 6.3 Engine
- My new Audi
- Audi tt 3.2L headers?
- APR Sux...
- Do it myself?
- 2009 Audi 2.0TFSi S Line 211bhp High Engine Oil Consumption
- 04 AUDI S4 RADIATOR HELP! ASAP!!!!!
- Audi A4 B5, 2000, 1.8 Flat Spot on Acceleration at low RPM
- Audi manual shifting - hiccups
- audi custom shops located around north dakota.
- 2004 A8 Quattro, Loud Engine Knocking and oil sludge
- AP
- changing to led drl bulbs
- Performance chips? Worth the money?
- B5 or B6
- Thermostat? or?...
- WHERE IS THE PARKING ASSIST SPEAKER/HORN... HOW DO I GET TO IT?
- Where do i start on my 2005 audi a6 4.2L
- Process Of Doing Carbon Fiber
- Audi A4 -Service Question
- 2007 Audi Q7
- AWE Exhaust - Wisconsin
- BOV question
- Evans Waterless coolant
- Looking for a project car what do you guys think
- clutch slippage on chip tunned 2.0TDI
- 2.6 coupe upgrades help
- 1995 Audi A6 2.8 Spitting and Sputtering
- Audi TT Turbo Loss of power
- 2009 A3 2.0T Turbo to Downpipe Question!
- MAJOR EXHUST HELP
- Stock 2013 S5 Exhaust - Any Value?
- 6 Speed Automatic 2005 TT
- Help! My Audi Jidders/hesitates
- HYDE16 Reviews Peloquin LSD and USP Steel Shift Forks
- Initial Review: AWE Exhaust on '13 S4 S-Tronic
- Out of warranty repair help please!!!!!
- 2008 Q7
- Audi A6 2.8 Quattro 1997
