View Full Version : Performance and Tuning
- Found the problem, thanks for all the help I got from AW...
- part # for combination valve on AWM (2001) A4?
- Yep that's right, count all eight of them!! This is Crazy :)
- INFO on "LOW GAS PRICES"...
- Is it ok to use a copper crush washer for the pyrometer? I dont have the white one that came w/it.
- front mount question
- Euro tuner challenge dyno result
- ANyone have the racetec throttle body?
- A6 1.8 T Q Chip Tuning Help
- Suspension Question...
- Anyone know a source 4 custom timing belts?? Esp if already set up to do VW/Audi
- will ST BBK fit w/17" oem sport 5 star rims
- D2 Coilovers ?!?! They have an Audi application
- To install K04 or not too......
- Lucas_Gchips, have you gotten the new manifold on your car yet?
- Replaced Engine Mounts this evening (New Tech)
- 01-02 TT225 head on a 03 B6 1.8t block?
- (Flame suit on) Just picked up a FORGE Bov for sh*ts and giggles..
- Full race tubular manifold for 1.8T
- paging xr4tic
- F*CKING SPEC!!!!
- on the motronic, are injectors able to keep open 100% duty cycle?
- what is the best way to get power from my car?
- Where's my missing boost?
- Need some 1" OD silicon tubing and some good quality smaller hose clamps, where to find???
- Vortrag hood molds. I was told that Richard Sierra has them and posts here? I'm trying
- What's the difference between Yokohama A032R and A048?
- Oil around DV
- Help! boost question
- Would this turbo bolt up to the PES T28 manifold?
- What should I install to make my stage 3 more reliable?
- FWD Problem solved
- 2.5 V6 Turbo Diesel into US?
- ATP turbo upgrade
- How U guys like my new block for the car?
- Rod length
- need advise what to do...
- Need advice on K04 setup for '00 A4...
- What kind of IC heatsoak to expect while idling (autox related)?
- K04 intake temp questions. Heat soak and....more?
- X-Post: Question about SS-jacketed brake lines...
- just a couple of questions for the poeple who attend track events..
- AWE Stage 2 clutch and LWFW initial impressions -- totally honest, substantially positive
- A tecnical question.
- EuropeanCar Magazine 1.8t Challenge Contest!!!! enter to win!
- Has anyone played with the revo lemmiwinks on a 2.8 yet??
- clutch break in questions
- Several S4s using MBCs (in place of the N75) and bypassing N249s are still seeing tapering boost.
- Will the car flip out if I completely disconnect the N75 valve and run a manual boost controller?
- John/Xr4tic, what MAF did you end up running? Pro-flow Univer or a Ford?
- 1996 a4 stalling
- FWD Problem...
- A4 1.8 chip procedure for dummies
- question about NOx / C02 spray
- Anyone have a good way of measuring MAF voltage and airflow to develop the MAF curve?
- Anyone familiar with this "VW" turbo?
- xpost: CEL this morning
- Lucas? (or someone else?) How much work is it to change to the S4 biturbo transmission?
- what does a rust colored spark plug tip indicate?
- racing clutch? short shifter? ANYONE...
- How much boost would I gain?
- O2 sensor enlightenment.
- Boge Turbo Gas of Bilstein for this application?
- Final T3 Flange manifold finnished.
- Stasis engineering Firm 1.8T engine Mounts
- New Underdrive Crank pully with Trigger teeth.
- BIGNIPPER what is the engine code for your engine block?
- John/Xr4tic, what trim / AR is your turbo? when does it spool?
- clutch help
- What's this mean, is it normal?
- Why does markbradford call DBW t28 kits "ticking time bombs" Should I be worried?
- does anyone know where i can get my hands on a DBW APR stage 3 kit?
- (x-post from b5) Weird thing going on with my turbo bolt.
- where can I get 159mm vw/audi forged rods? and what rods are good? (price vs performance)
- overly rich condition...(x-post from B5)
- Brembo brakes
- went to install the LWFW from spec on sat. and....
- Any clutch recommendations for 700hp S4 ?
- Questions before larger turbo goes in
- I'm looking for FMIC piping and/or another solution to my problem.
- What ever happened to TripComp DEI?? Is it still in the works??
- How much of a diff does a DP make on a B5 1.8T, what about K04, is it worth it? Thanks for the
- Dont buy anything from(Motodyne)
- how are the k03s different in the b6 and the b5?
- Valve reliefs
- Installing my K04 upgrade in my A4 soon. What else should i do to
- Oil Pressure help
- Ko4 or Eo5 which one is better?
- X-post: What's wrong with this pic??
- Got to love GIAC 16 Pounds of pure pleasure..... Puts a :) on my face.....
- Our 99.5 MTM Stage 2 Avant now on cars.com...
- I need help installing a apexi turbo timer foor 2003 audi a4 did search nothing ne help please
- Can Anyone recommed some quality performance upgrades for my 'O2 A4?
- what do you think causes spark plugs to get like this?
- 19 min to swap pads in Boxster BBK... what is your fastest?
- HELP with front bumper order (Ultra sport pkg)
- Comments re: Axxis ultimate vs. Porterfield RS brake pads
- Bosch Maf - Voltages range from ? 0.0 to 5.00 V. What is the resolution between these two points.
- The resolution provided with MAF vrs MAP.. Considerable if you where going to fine tune a car
- Anyone in Fort Wayne, IN who has experience with suspension installation?
- Whats the best race clutch for a '02 3.0Q 6sp?
- X-Post: Almost to 60k miles: Ordering Parts: need some help....TIA
- Info Needed
- anyone know if AA box will be compatible w/ P box ECU?..........more>...
- Revo or APR ?
- 150mm rods and pistons with different compression height? For 1.8T ->
- checking for vacuum/boost leaks
- paging xr4tic or audi2ptzero
- problem with coolant temp gauge
- 5 bar FPR with MTM stage 2 and K04
- (XPost)Would some of you guys be willing to list....
- 1988 Audi 90 Exhaust Options (5 cyl. manual)
- nubie question
- are there any alternative programs for pes' t28 kit?
- Has anyone here bypassed the stock oil cooler?
- I need some advice for my 1.8T. Doing a rebuild...
- Tranny stabilizer bar for Tip
- GIAC J31 K04 Programming
- Help, Inside tire edge worn on one wheel in the front. What to look for?
- any1 know if the compressor and turbine wheels....
- I am trying to contact Ryann about his 2.0L T28 setup. Anyone know if he has AIM or anything?
- Koni vs Bilstein...experienced input kindly requested.
- any new news regarding the release date of the APR stage 3+ kit?
- I'm installing an oil cooler, is 10NA a good size for the lines
- Drag Day - May 21st - Lebanon Valley Dragway (New England/NY), Sign Up Now...
- Difference between A6 2.8/2.7 rear suspension...
- anyone have the H&R cup kit?
- Looking for a tuning job (please read)
- How are ATP running this GT28RS kit without an N75 valve?
- Has anyone ever put a T-28 on a upgraded 2.0L AEB engine?
- Please HELP! My car is in the shop right now and I need help making a decision on what I want to do.
- Ok..so no mounts..how about suggestions for a beefier tranny..(ideas???)
- EGT Probe Mounting Locations....Problem
- which MAF sensors will fit my car? 98.5 A4
- 4.11 rear gears available?
- pulled tranny today to find my pressure plate cracked in half...
- where is the second 02 sensor before the cat on a 2.8 30v? I found the one under the engine coolant
- Which is softer and has best adjustment range, Koni or Bilstein?
- Urethane engine/tranny mounts (b5 A4 1.8TQ)--where to find???
- Big turbo without software?
- Induction kit
- slight oil residue on shock... bad?
- H &R sport vs H &R race springs... What do you gentleman think?
- Racing Clutch?
- Does anyone know if the 996tt caliper and 993tt caliper are the same
- possible clutch issue.......
- Bosch platinum spark plugs
- oil in DV
- Need help with performance UPGRADE!
- Help with Bosst leak... I think
- ive never gotten my car painted before, how much approx?
- X-Post: Free lap time on Road Course in Ontario...
- I have some questions about building my engine. Please help a dumb noob out ;P
- How do you determine how much a 1.8T engine is worth?
- '01s: what low temp switch did you use to install an EFK? Neuspeed only has one for nDBW.
- source for Boxster caliper small parts?
- I need a reusable High Flow air filter, recommendations?
- Need some help with high flow injectors...
- noob - question prior to buying please
- I'm sure I know the answer, but is there any disadvantage to upgrading the clutch before a turbo...
- Who's running a Profec-B?
- X-post: How many cells/square inch on stock Audi A4 (B6) cats?
- Anyone ever use ECS tuning budget Coilover kit? Leave feedback...
- Fuel Injection Cleaning
- has anyone done a suspension and exhaust swap on a quattro b6 a4, and if so, do you know where i can
- 2004 Northeast Audi Summer Event Info/Registration/Forums/Site is up!
- Changing tie-rod ends..difference in model years???
- squeeking
- transverse vs longitudinal
- Where can I buy a fully built 1.9l or 2.0l race engine for my 98 A4?
- out of curiosity, Would an older s4 or rs2 5cyl turbo engine fit in a b5 a4?
- What causes the cat related CEL?
- Newbie question and x-post: Just got some new BPVs for my A6, are the 710Gs the same as 710Ns? TIA
- what exactly makes the aircon cold? *noob q
- Anyone here have a Stutter box/MSD with launch control module?
- Anyway to defeat the CEL with testpipes in place of CATS?
- tolulene question
- Need some feedback on these planned upgrades...
- Uneven pad wear
- 97 A6 Q: Best acceleration performance boost for the $$?
- Bad car shuttering, feels like engine/ tranny movement, Help!!
- NOOB Question, What does DBW stand for? Is it Drive By Wire?
- would a dead battery for 3-4 weeks mess with software on a chip?
- electric fan controller question
- How bad is it to run the car with the crank case breather tube plugged?...
- After over 20 dyno runs, can't identify the problem...
- What's the cheapest electronic boost gauge you guys have seen?
- I'm sure you guys would appreciate this new product....
- megasquirt!!!
- What's the formula for determining piston speed given stroke, compression ratio and RPMs?
- Have to go back to stock brakes for a bit...pad recommendation
- Quattro is it awd or just ?
- Has anyone ever bronzed an oem clutch???
- Has anyone successfully got rid of Catalyst Efficiency below threshold
- Questions about block 002 and duty cycles..
- Recommended Reading...
- Recommendations for lightweight lifters for my 12 valve? I don't want to spend much more than OEM,
- anyone using a mist system on the b6 a4 1.8t yet?
- Question for those with a fuel pressure gauge in their cars...
- Stock SMIC dimensions?
- If anyone needs up to 3' of 6061-0, 2.25" x 0.065" pipe, let me know...
- Thinking about doing a diy dual smic. Can the input output ports of the stock IC be reversed?
- New word in car design...
- asked in the a4 forum but got no answer...
- Will US chip (a program file) work on an Euro ECU (...) ?
- Corner weights - Audi S4 and an Audi A4
- Anybody ever change the stock throttle body on the 2.7 engine for improved perf?
- surging problems with new ecu...
- New Tuning Shop In Chicago
- Got this timeslip by email. what do you guys think
- Folgers coffee can vs Ricer muffler: which gets more HP??? = )
- Damn, clutch won't disengage, anyone have this problem before?
- Anyone know how to decrease power assist steering on S4?
- Anyone have a wideband O2 meter/logger that they'd be willing to rent out for a week or two?
- Futrell Autowerks slotted/dimpled rotors?
- anyone with fk koenigsports on a b6 know a good setting?
- Anyone paint their Audi Grill black? Do you have to rip off the chrommed plastic to paint or just
- And another more updated chip question
- cracked ex. man. from pes kit
- B6 w/ B5 S4 brakes
- '03 B6 A4 1.8TQ Sedan: What is the optimal turn setting on Konis with Eibach springs?
- Need Clutch Installation in Louisville KY
- Drag Day - May 21st - Lebanon Valley Dragway (New England/NY), sign up info...
- Recommendations on Air intake kits? I know of K&N and AEM that make kits, but I'm just...
- turbo upgrade
- Spark Plugs brand, Gap and its effect on LTFT ? NE1 care to summarize from experience?
- Dahlback Racing
- K&N Part 57-0514 2001 A4
- Turbo whining when accelating in 1st and into 3rd from 2nd sometimes......
- worth the hassle?
- 1.8L 150hp vs. 1.8L 170hp
- bbr sides and rear valence for low price...
- Anyone experimented with the ground wires in the engine compartment? Over on the EVO board...
- has any difinative answer been given by APR on the stage 3 + for nDBW, if so how many of you feel
- GIAC Mobile Tuner Config Files
- ECU and TIP Chip feedback?
- Manual Boost Controler...
- what does the stock A4/S4 SMIC flow?
- Problem with cam bearing
- Will my AWE flywheel work with any other clutch?
- Question for you guys regarding cams and head...
- Car is up and running on the streets...
- Dahlback A4 project- any updates?
- Are there any SOLID evidence that LWFW is harmful to the crank? I did STFA but couldn't find...
- Boost problems :( & and cant figure it out......
- What fuel pressures are people with larger injectors running?
- Piggy back systems
- What would the ideal A/F curve look like?
- What is a 2.7T engine and 6 speed worth?
- who makes 880cc injectors for a4?
