View Full Version : Performance and Tuning
- Any rumors heard about Supersprint coming out with headers for the 2.8 30V?
- my cooling come on late, it comes on when the temp is 1/3 past the middle marker, what is wrong
- I'm going to have a custom race cat made for my car, but have a question about my CEL...
- Chip advice?
- APR or PES stage 3?
- Might be a repost, but ATP updated the compressor maps for GT series turbos (inc. GT28RS)
- B6 1.8Ts have a dual outlet setup, does that mean that if i put together a single outlet system
- Ik22. from the box is 0.0044 gap. What you guys running for your chipped 1.8t?
- How does cold weather affect boost pressure ?
- which one would you use to replace vac lines???
- Stock exhaust pipe size
- Getting closer to 350 whp...
- How an you post a movie?
- 2001 Variable cam... Audi A4 1.8t
- Anybody know the specs of the Schrick cams on 1.8T, i did a search but can't find the answer.
- Hey, approximately how much does it run to put a to3/to4E kit together?
- not sure what exhaust to run(larger turbo guys please read)
- Finally took the car to the dyno...
- Urgent help needed on exaust question...much appreciated
- X-post from B5 A4 forum. Suspension help needed! Thanks.
- Level Ten is still the best place to upgrade the Tiptronic tranny on an 1998 A4 1.8T Quattro right?
- Possible Spec clutch/flywheel issues.......
- I have some new pictures of my crazy project.
- Am I SCREWED??
- Is there a way to find out exactly where I have an exhaust leak?
- General question regarding cam advance
- So what comes after a broken easy out? :-)
- My Pagid orange pads have a bunch of micro-cracks
- looking for tips for storing an engine....
- Where can I pick up a set of RC 440 injectors.. one of mine are acting up.
- X-post: Need help diagnosing a clutch-related problem...
- Quick Q about turbo oil and coolant lines...
- Ok, gunna try a GTG in North East Jersey again: This Sat - the 6th....Weather Permitting!
- Reminder : Miami Audi Meet Tomorrow
- Anyone here have experience w/ race cats on a V6?
- KW INOX Coilovers V1/V2/V3 Holidays Group Buy!
- ATP says that there is no turbo/Downpipe gasket...
- UPSOLUTE chipping in MA (xpost) AW directory advertiser
- o2 sensor
- Does anyone know how to...
- Engine Mount
- does anybody know the Fuel Injector size for the 4.2 V8? 4 valve and 5 valve. thanks
- Pagid Blue vs. Ferodo --- which pad and why?
- 2000 S4. What are the best performace upgrades to do to the car for under $500. Mods inside!
- what can i do to beef up my automatic tranny.
- Can any can with two ports on it be used as a closed catchcan?
- Tranny Swap Can Someone Help
- how much power can i get out of punching out the cats?
- North Jersey GTG.. (X-Post)
- 12.827 at 104.88 today
- Looking for a guage that shows 2 air temp readings?
- X-post: Almost done, but Coolant leak...Ahhh...Help
- Im happy with my new project
- Avant pic request
- I did some 3rd gear runs and could use some help with analysis...
- Question about logging air mass in different temps.
- Anyone know where I can find external dimensions for the 2.8L engine? AAH/ACK preferably...
- I just received stage III and it didn't have any instructions ...
- I'm installing my 2.0L this week, and I'm missing a part, wondering if it's.....
- anyone know how many different software versions there are for ko4 kits?
- got a question for you guys regarding MAF housings...
- HMM what do you guys think about this kind of a weird idea?
- Did some one ever do a Dry Sump setup on 1.8t?
- What's suggested for brake fluid for StopTech brakes, mostly street, some road course...
- For those of you with External Wastegates
- Anyone tried NOS on their 4,2 V8
- Does anyone have any info on ATP's Plug in Standalone? (SMOKINA4TURBO?)
- HELP please!!...... my transmition is very sick
- Used AEB, ABA blocks worth anything?
- Best choice engine to drop in a 1995 audi 90 FWD
- Got a problem with clutch?
- Greddy Turbo Timer III backlight
- HELP!!
- Lookie here if you'd like an AWD dyno in the central Ohio area!
- So is this pinging?
- if i had a bazooka, i would shoot ATP right now.
- anyone know the max CFM flow of a forge 006 DV?
- Stand alone engine management?
- Anyone running the Stassis rear LS diff and center torsen mod??
- urs4: for your stage 3 MAF do I NEED to have a stock airbox?
- Need new plugs what should I get? I am running an APR 1 bar
- Boring Question About Brakepads
- 1.8t MTM Stage 2 w/K04 vs. GIAC K04 kit.
- Got the Mod Bug, and some funds... Chip or Suspension first?
- What is fuel pressure in general? <more>
- Att Mike, Have you repaired your manifold yet?
- Question about TT225 & MAF Part# ..461 A
- thought this might interest someone here. guy is looking for tech help with a 3.0 problem
- Anyone use the Alcon free floating rotors (Stassis)for the alcon 4 piston calipers??
- can someone help me out, will an AEB valve cover fit onto an ATW head???
- x-post from A4 forum: X-Mas options, need some advice
- ATP customer service strikes again! For those with external wastegates, how do you have it mounted?
- Worth while to extude hone the intake manifold to go along with APR S3?
- aNYONE KNOW WHERE TO LOCATE THE WIDE BODY KIT THAT HAS FULL fb FENDERS?
- 300whp 1.8t?
- Got a few questions for the pro anyone know the answers
- impressive engine technology/design
- Cross post on which Vag to buy - interested in comments from owners
- SKS still around these parts?
- Getting a 17963 SAE (P1555) Charge Pressure Upper Limit Exceeded code on a non-DBW car...(X-post B5)
- update to my boost problems *long read* - it's even more confusing (xpost from b5forums)
- Is the GIAC IBE Chipswitch worth it or just get the GIAC chip?
- Looking to plumb in Accusump. need infor on how to plumb oil cooler in with it
- x-post from A4 forum, 17965 and N75 questions
- Has anyone seen this? Looks like Honeywell / Garrett
- Help with trouble...Above 15psi the car missfires in all cylinders...
- 20v 5b wastegate question
- Tech Opinions Please
- Just replaced an ABS sensor that I mangled up during a rear-bearing replacement job and
- would you buy a used set of NS bilsteins with 30k miles on them?
- Anyone know what size bolts b/w ATP Manifold & Turbo
- Has Anyone Ever thoguht about liquad to air intercoolers
- Pulling the Trigger - Big Turbo Time.....
- trying to diagnose recent MAF failures
- I think I threw a rod ??.......Help
- Has anyone installed CPP Uplinks?
- Bypassing post 02 voltage?
- Used Oil Analysis (UOA)
- APR has finally listed the 01 stg III kit and the price increase
- Fuel cut off...ne one what the problem is.... more inside...
- Neuspeed in europe?
- i want to make my 1997 a4 faster
- seen an interesting engine failure? how about one like this
- Already STFA, and found conflicting info....Which Bosch generic 02 sensor can be spliced in?
- G-Tech Pros for $35 on ebay.
- no help on the A4 forum....need help diagnosing my pressure test results
- The TT forum is not too good at this diagnosing bit.. How about you guys? :)
- Planning and Preping to go big turbo...
- With the huge K04 back order are any tuners working on an E05 based kit for B5 A4's??
- Wastegate Dump anyone?
- So if you had a 1.8t with 80k miles and you wanted to refresh the drivetrain where would you start?
- bought a NEW long block
- Questions about Tuning my new Turbo Kit and other ?s (long)
- please help if you can
- attn: john bass....
- Any experience with the 52mm Greddy Electronic boost gauges?
- differential pressure regulator
- Is there a way to calculate approx. how much more fuel is needed when a turbo is upgraded?
- Anyone know where I can get a spare ECU and how much$$ (98.5 n-dbw 1.8t 5spd)
- MBCs, EBCs... Questions..
- Question for ATP turbo kitted guys .---->
- Buying a crate 1.8t from bahn brenner anyone ever used them?
- What's the story on these kits?
- x-post Dyno Result Preview(27-28 dynos at AMS today)
- XR4tic and others, how useful is a wideband O2?
- Maintenance
- hey guys i have a question about fpr...does the b6 have a 3BAR or 4BAR fpr?
- A friend of mine sent me some Timing logs.. Timing correction included..
- Severe timing retard...
- Does the AWM motor uses the same TB as the ATW?
- So i finally got the chance to put my car on the dyno...
- G-Tech/Pro on sale for $99 at Jeg's. Worth it?
- Will I see much gain by going to FK coils from Eibach Pro/Nuesped/Bilsteins?
- Need some help on some DTC...
- X-Post....Power cut on the highway...
- Making it easier for the turbo to make boost -good series of articles but old news now
- Anyone familiar with the SUSS S.S. cone air filter for big flow?
- xr4tic/john ...i got your excel sheet up, what are some good numbers for a chipped 1.8t?
- BOV FOR A4
- Pinging problems, need suggestions
- eurospec heads?
- modified a4 +anyone else helping with my boost problems (APR)
- The mother of all intercooler info sites...
- not an engine question, but suspension / brakes
- Did I just read that GIAC is doing ECU tuning for ATP?
- boost problems...again.
- CHIP AVAILABLE FOR 04 1.8T???
- 13psi boost apr chip....possible help needed.
- Difference between N75 valves
- A buddy of mine is looking at tuning his '00 DBW VW/Audi Bosch car - who sells tuning software?
- Next Project
- who here has the H-sport sway bar kit??
- MAF stuff...i think this german site suggests that a mercedes replacement is cheaper/better?
- does an one still sell an "S" pipe with flang for my HKS SSQ BOV.....
- For those who have strapped on a larger turbo...
- OEM Strut Tower Bar figured out.
- I want to be sure before I order that the ECS Race valve is #034906283H
- ride/handling differences between hr sport/bilsteins vs oem sport/adj bilsteins
- Well, it looks like I may have to buy a new shortblock very very soon :(
- Audiboy - YGM re: your Power Steering Hose mod.
- Could the MAF be the culprit to all my problems?
- does anyone know a good price for a 1.8T engine and all it's wiring harnesses? low mileage
- That may sound wierd, but I need your opinion...
- K04 on a 1.8t cvt.....is it possible barring the torque limits? Views please.
- Where is a good place to pick up high quality aftermarket valves?
- Followup on V6 oil cooler install on the 1.8T......
- Motul vs. Super Blue
- Questions on the APR intercooler
- Ben, any word on my rs4 center cap?
- when APR DPP for 2000 A4 1.8T will on market?
- KTR Performance is the way to go in the Northeast...
- Pics of My new aluminum rad
- Turbo upgrade Tiptronic Chipping...
- what is better turbo or supercharge for 03 A4 3.0??
- WTB: Brake Pads for Porsche Boxster 986 Caliper. Street pads prefer.
- ECU tuning @ home
- Suspension opinions for 01' A6 2.7t
- Autothority Chip for 2.7t / S4 - any expereinces? Invisible from dealer?
- hahaha, this is too funny, read it on another discussion forum...
- Questions on Labree Products and cat-relocation?
- h&r wheel stud conversion
- New offering in road race suspension from SPP. (cross post from S4 forum)
- I had to drive 10 hours with the maf unplugged. any potential damage to the car ?
- a4 1.8T perfomance?
- Which is faster?
- What is a downpipe?
- Suspension Questions
- Compression tester....
- question about getting an allignment...
- Anyone ever use the EVOsport underdrive pulley?
- So for track days running (in summer) 100% water would increase cooling...
- Help! Front KONI perches too small for APR springs
- headers....
- Optimum Shift Points, PES T-28
- What boost should I be making w/an APR chip/exhaust. Car is DBW by the way.
- anyone have apr port tuning with a tiptronic?
- crap... does anyone work @ jcwhitney.com?
- Ignition Solutions...
- intrax springs, how do they compare to eibach and H&R
- Is it possible?
- Has APR ever given the actual increase of their Stage III kit, or is it still speculated to increase
- will I have to worry bout performance pulleys harming my 30v?
- Intelligent aftermarket engine management?
- does anyone know of a company that makes aftermarket down pipes
- Stumbling T-28...
- How difficult is the autronic SMC or SM2 to tune?
- remember my charge pressure negative deviation fault codes from the summer...
- Engine RPM
- Split Second tuning...
- I have Brembo GT brakes on front and use Pagid Orange pads at the track,
- Questions about my new BOV valve
- motor replacement
- Anybody running a brake controller on an S4 (i.e. adjustable bias)?
- For those of you that have gone aftermarket forged internals does the block have to be rebored, even
- stage 3 + 104 race program =
- Who knows when mikes car will be tuned and run first time at track?
- Question about rear suspension thump with coilovers
- Transmission FINALLY died. NEED answers on 2.8 tranny swap! DEAD (xpost on a4)
- Who has a blow-by oil catch can? Pics of your setup? How much oil does it collect / how often?
- Intercooler for s4
- Tried searching, but curious on N2O
- Camber woes!
- The Turbonetics catolog from the TO4B post below made me wonder which turbo series would be better
- Will a Quattro DP work on a FWD are they any different?
- RaceTec FMIC intake temp testing results....
- if I do my DBW to nDBW is my X-chip going to flip out?
- Question: Who knows of a good perfornace exhaust that is not loud and that will work with (more)
- Performance Forum Fanta
