PDA
View Full Version : Performance and Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. Does ne1 know if the A-box is different for California Audis vs. the other 49 states??
  2. I swapped out MAFS tonight...
  3. slight ticking sound from engine, valves out of alignment?
  4. Anybody have a good compressor map for the K03?
  5. Do you have Neuspeed Sport springs? if so...
  6. Initial impressions of my PES t-28 kit.
  7. Exhaust choice for my t-28....
  8. I unplugged my MAF and still got the negative deviation fault code...
  9. Lucas_Gchips
  10. Suspension question...
  11. my 12v delema
  12. hey guys I know some time back everyone was talking about changing
  13. Can an RS2 tranny be used in an A4 1.8t?
  14. Anyone have any experience with Nitrous on the intercoolers or.......
  15. TT 6spd tranny going for $350 on Ebay
  16. Would installing Schrick Cams be a wothwhile "Mod" ?
  17. After one week and one day my car is running again :)
  18. Any fellings on H&R, Eibach, B&G or Intrax springs on a 4.2?
  19. boost problem?
  20. Correct me if im wrong: Shorter side of frequency valve goes to wastegate actuator...
  21. GIAC chip for tiptronic
  22. Oil pump cavitation
  23. I'd appreciate some input from those w/ more experience in engine architecture/construction
  24. Any ideas on where to find 8mm studs?
  25. Hmm.. how bad is skin contact with R12 AC refigerant cooolant?
  26. FMIC question, can you build a custom FM that does not require chip tuning...
  27. X-Post: Whats the going rate for a PES T-28 kit?
  28. What would cause a Lean Code? I forget which one exaclty
  29. A turbo question...
  30. Another PES t28 questions from me : ) chip related this time....
  31. How the hell are you supposed to install the PES manifold!?!?!?
  32. Has anyone ever turboed a 2.8 12V
  33. any good source for aluminized glass cloth?
  34. Any suggestions on a 3" High flow CAT?
  35. what is a good site for good prices on vdo gauges????
  36. Logged some vag-com runs...do these look normal?
  37. Buying an engine
  38. Anyone run APR Suregrip pads?? Comments on them, good/bad??
  39. Tire Choices,... (need your input)
  40. i have an intercooler question of my own.....
  41. Anyone change the fuel filter on the A4 or S4 yet?
  42. boost leak test...
  43. Turbo 2.8 12V
  44. Curious to know why no one ever mentions/uses "Performance Friction Brake Pads"
  45. studdering S6
  46. 1900 hp dyno pull
  47. What's a good time to replace my spark plugs? What brand is recommended for 30v 2.8?
  48. looking at FMIC cores and thinking about what's out on the market
  49. brullen exhaust
  50. My Situation (update #2)
  51. Car's idling starting to get a bit rough, is it the fuel injectors? What can I do?
  52. it seems like my boost leak is related to Mass Air Flow...
  53. Helmet dilemma - which of these to choose? - (X-Post)
  54. High Flow Cat for A3 1.8T ('97 R reg)
  55. RS2 parts NEW!!! Sell CHEAP!
  56. is it worth getting new injectors on my 98.5 ko4 a4
  57. Those of you that wear glasses with your helmets...please help out a noob!
  58. thermostats
  59. Suggestions for online stores for G-Force Pro Force Hybrid Helmet in stock? Backordered at 3 so far
  60. What's typical for timing advance for a 1.8t , 93octane, chipped only.
  61. Here is my MAF data!...
  62. x-post -> Anyone know of an AWD dyno in toronto area????
  63. Is the head gasket provided with the PES t28 kit the same as stock or different?
  64. Will installing an electronic boost controller be the same as it was on the older s4?
  65. How strong are Silicone Hoses?
  66. Crack in my exhaust manifold...Can this be fixed? see picture.....
  67. Peltier Intake
  68. Fuel cell install. Michigan area shops?
  69. Which CoilOvers to get?
  70. Custom FMIC install - Finally
  71. Audi2PTZero - Is your car back on the road? Have u run it down the quarter yet?
  72. Does anyone have any tips on getting the stock turbo out?
  73. My Situation (update)
  74. BPV
  75. Blow Off Valves
  76. More on my negative deviation fault code...
  77. has anyone had trouble installing RC injectors?
  78. 1.8T oil grade recommendations
  79. Are there any places that sell just the manifold that you can bolt a garrett turbo to?
  80. I hope this is the real deal, or...maybe I don't...
  81. would anyone be able to answer some questions regarding intercoolers?
  82. European Car 1.8T Contest?
  83. Whats a good material to make a full heat shield out of?
  84. APR on the road
  85. External oil cooling for high-stressed 016 gearbox
  86. I'm replacing some vacuum lines tonight...
  87. abs control unit replacement
  88. Anybody know of an APR dealer in CT closer to Hartford than Norwalk?
  89. 02 Simulators?
  90. "Triple C" Camber adjustment Bolt
  91. Has anyone used ATP's fmic on an A4?
  92. Need brake pad advice
  93. anyone have a source for aftermarket tranny mounts?
  94. Yippers...
  95. MPEG of 12.77 run
  96. Werks of Art Stage 3 Clutch arrived today - thanx Juan!
  97. Has anyone here ever had any problems with the forge BPV?
  98. Anyone with a Stage 3 or PES T28 kit
  99. repost: help with this code please.... 17884 Evap Leak Detection pump insufficient vacuum...
  100. Much ado about BPV's and BOV's.
  101. questions about FMICs and fit
  102. Anyone here ever bend a coilover..ie; H&R?
  103. Oil leakage :-( Ideas on where it's coming from?
  104. need a tunner/shop with exp installing K04 kits in LI/Queens NY... TIA
  105. question on MBC for 2000 1.8t
  106. yet another charge pressure: negative deviation fault code...
  107. Dual Twin Exhaust on a 4.2
  108. Call me stupid, but who the manufacturer of the 12v perf heads again.. I cant find it in search..
  109. Went 1St time to the drag strip.
  110. Yipper here is one of the vag logs of my 2 liter K04 runs at the track
  111. anyone know how much it is to chrome pipes?
  112. Help! for the 20V (coupe quattro) stainless steel exhaust header gurus.. TIA
  113. Looking for sport suspension for 2000 A6 4.2
  114. Booked in for AVO Custom 2.5" SS Cat back Zhorst - Should i get a free flow cat as well?
  115. Is G12 coolant perfectly safe for an Aluminum Rad ?
  116. How much interest would there be for a Euro tuner to come to the east coat and custom tune?
  117. Have VAG-COM, chipped ECU, spare ECU. What should I log?
  118. Anyone with an early 99 2.8Q..
  119. What stand alone system is everyone using...which one is the best for our cars?
  120. How much power could be gained with a fmic on my car because of pulled timing?
  121. S4 Chip FOR SALE
  122. cams
  123. 03 A4 Avant 1.8T Oettinger Body Kit
  124. virgin...(30k)... '01 S4 looking for "safe?" additional hp
  125. Anyone know what the Greddy ProfecB spec II is over the original ProfecB?
  126. Will an APR chipped ECU out of a 2000 1.8TMQ fit a similiar car regardless of the model ECU that it
  127. K04 for the '01 A4: Are larger fuel injectors needed?
  128. matching injectors to maf housing - some info
  129. Misfire in cylinder #2!!!
  130. doing the EFK soon, any tips?
  131. what brand has this logo?
  132. Any chip modifications for an 1990 Audi 90 2.3L 5 cylinder?
  133. Time slip from last night
  134. should i get a K&N pannel filter or a full air intake for my 99 A4 1.8t ?
  135. Where can i get a 6sp transmission from audi or vw?
  136. Mod noob questions (snub mount, REVO/chipping)...
  137. Bleeding air from cooling system
  138. Replacement fuel pump for TT?
  139. Question on hoses...
  140. how miserable will I get if I convert my A4 to become right hand steering?
  141. help needed, please
  142. What's a good fuse size to put on my oil temp gauge?
  143. who has modded their MAF? anything to watch for?
  144. N75 valve replaced with N75 valve from beetle turbo S. should I expect any problems?
  145. Does anyone know anything about these SS lines?
  146. Advice needed please!
  147. Need Max power
  148. where is the best place to order a evoshield from?
  149. Finaly instaled the New timing belt with updated tensioner and some other mods. BWW
  150. Replacement fuel pump
  151. 5 bar fuel pressure regulator
  152. Fuel management questions, serious help needed on system choices. PLEASE
  153. Anyone here drive/own an "older 911"? (X-Post)
  154. Any thoughts on variable nozzle turbo's?
  155. Where can i get SS bends cheap??
  156. What's up with these brake rotors?
  157. What is the correct way to bed in a new clutch?
  158. Anyone know of Todd Candey contact info or email addr?
  159. Update on my charge pressure negative deviation...
  160. Disconnecting the PCV valve, is it a bad thing to do?
  161. Anyone know of a stage 3 clutch upgrade for the 2002 Audi A4?
  162. Does anyone have a set of 4 440cc injectors I could borrow?
  163. x-post ..... question about boost pressure n temp.
  164. Silicone Vacuum Hoses
  165. Engine noise...how much is normal (1.8T)?
  166. Where can I get a catch can for crankcase breather?
  167. ok, where can i get this?
  168. audi R8 racing video and/or sound?
  169. What drawbacks are there when a turbo intake pipe has too many bends?
  170. Make the absolute TT
  171. brake lines on lowered suspenssion.
  172. What would happen if the vac line from the intake manifold...
  173. New x-chip and a knocking at hard acceleration
  174. Help with Charge Pressure Control: Negative Deviation...
  175. Are there any free downloading programs that would allow viewing of maps from bin or hex files?
  176. A.W.E. stage 2 clutch kit arrived
  177. So My Clutch is F_ked. I need a new one - Works of Art Stage 3?
  178. VR6 vs. stock throttle body (not installed yet)
  179. Xpost, some quick G-tech 0-60mph times
  180. (x-post) Seeking further info on damper question.
  181. (x-post from B5 A4) Could DTC 16517 cause boost loss?
  182. vacuum readings over 60Hg...what's broken?
  183. A new Continuously Variable Valve Actuation system
  184. Those with big turbos, can you tell me if silicone hose for boost gauge will collapse under boost?
  185. oil viscosity emissions question
  186. underdrive pulleys
  187. Got into an accident :( - Anybody know if they make aftermarket radiators....
  188. GT30 turbo kit problems
  189. I bought a used k04 kit.....
  190. Installing front lower control arm: front driver's side?
  191. Wastegate adjustment on biturbo?
  192. Any suggestions? When hot the revs sometimes 'stick' - have to blip the throttle
  193. Opinion pls. Should I hollow out my cat?
  194. S4 Boost Pressure Test
  195. Any ideas as to why I would be getting ignition timing retardation?
  196. Hoping someone here can help with my 20V CQ fuel injectors....
  197. What boost are you seeing with APR Stage 3?
  198. Exausts
  199. J&E Piston Sizes = Proprietary Info?
  200. performance boost for A6 2.7T
  201. Lookee here!
  202. My car has 5psi less boost as a result of running low on gas and experienceing "fuel slop"(long)
  203. will I loose the abillity to use VVT if I switch to an AEB Head on my ATW block..
  204. 1.8t GT30 update (dynoed)
  205. Approx differences with S4 Box Installed.
  206. Lossing boost... Vagged..
  207. Which exhaust would give more power..??? (more)
  208. Can B6 1.8T benefit from MAF upgrade? Who sells?
  209. Is a Split Second PSC1 needed on a K03 w/...
  210. Does anyone have an APR EMCS Home Programmer they would like to sell?
  211. New Product: ProDiag diagnostic tool for your PalmOS powered device!!
  212. 1996 audi cabriolet poor transmission shift cold weather
  213. Need urgent help with 1.8tqm (LONG)
  214. Audi2ptzero...or anyone with k04 knowledge..
  215. http://forums.audiworld.com/oz/msgs/1653.phtml
  216. A6 2.7T Tires
  217. Continuing with Mods to Coupe Quattro... with question though..
  218. How can I tell if my clutch needs to be replaced?
  219. What does this fault code mean?
  220. race pipes on a stg 3?
  221. Super AFC?...
  222. Airflow numbers question...
  223. Aftermarket blow-thru MAF installed
  224. DV fluttering on part throttle?
  225. where do u get that locked torx screw driver?
  226. intercooler cooler anyone with one?
  227. Is there a break-in required on a new turbocharger or can I stomp away? ;-)
  228. Good place to get tuning work done in Long Island, NY area?
  229. where do we get oil and water fittings and lines?
  230. May I install PES Supercharge kit for my A6 2.4Q?
  231. Problems with Newly instaled GIAC Chip !! ??
  232. n-DBW Ko4 - what boost are you seeing?
  233. smell of fumes when WOT on a A4 1.8t cvt. Please help...........
  234. gt30 installed on 1.8t.....
  235. Poll for those of you running without any catalytic converters:
  236. Turbo oil inlet hose.. how can i get this thing out !!??
  237. Are coilovers a DIY thing on an A6?
  238. Help: any reports of ECUs being damaged during a chip installation?
  239. What chip for my 97 1.8t manual
  240. Hey, is anyone running the ECS tuning stage 2 clutch and light steel flywheel?
  241. Would a chipped A4 benefit from a manual boost control system?
  242. Shortshifter advice... Neuspeed, Stratmosphere, or Tanoga??
  243. anybody know how/where to install a trans temp gauge on a 99.5 1.8t tiptronic? i need instruction.
  244. BIRA System 6 Brake Upgrade installed on A8
  245. can some verify that this cam timing is correct, for 20v 5cylinder engine pic inside....
  246. chip question
  247. New turbo pic :)
  248. What size injectors to use with this? ;-)
  249. is it posable to turbo a 12v
  250. S4 6-Speed install all done!!
