PDA
View Full Version : Performance and Tuning
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. Nitrous Express (Where to mount wet injection injectors) 20vI5
  2. Is this a scam? Audi A4, A6, A8 Intake Sensor Mod 20+hp
  3. GBQ code transaxle
  4. catback exhaust void warranty....
  5. Desperate Plea for AEB Adaptation Channels
  6. anyone have experience with BG Syncro Shift tranny fluid?
  7. Can I get some pics of peoples catch can set ups....
  8. X-post from B5 forum - HELP! Need K04-15 ASAP!
  9. Anyone change their valve seals?
  10. Any shocks that would nicely match with B&G lowering springs on my A4 Cab?
  11. springs....help
  12. getting misfire codes every now and then with apr II+, i have a vag but i'm a n00b
  13. Experiencing some issues with my oil pressure gauge... any thoughts?
  14. also, difference between an A/F meter vs. wideband 02?
  15. whats the difference between mechanical & electric gauges?
  16. Update on cam chain noise on startup and using a lighter weight oil...
  17. boosting my boost.....
  18. Ignition timing issue
  19. where would I go to get FMIC piping made if I already have a core..
  20. will my inj. duty cycle #'s be skewed with an upgraded FPR? TIA
  21. Just installed the KMAC camber kit today.
  22. Been done before..need insight--RS2 tranny-read on.
  23. Anyone here running the NEW Labree split dp for 1.8t?
  24. Redesigned Random Technology A4 1.8 cat?
  25. How do alignment settings impact understeer/oversteer tendencies?
  26. Standalone EM: Part II
  27. what can i do performance wise with $$2000 without voiding
  28. Input on engine swap - A4 - v6 -> 5cyl turbo
  29. Ok folks. Still need your help please!!!! I have narrowed the clunking noise down to the area...
  30. How do I get 250hp at the crank with my B6 1.8T??
  31. Anyone know how APR did on the 1.8t challenge. Did they break 400hp?
  32. It's been a LONG while! (An update)
  33. ecs undredrive pulley, what do you guys think about it?
  34. my stg 2 clutch held K04 power fine, but slips in first (hard launches) with the T28, question:
  35. More Q's on stand alone?
  36. Today I picked up my car from the shop.....
  37. what is the difference between the 95 s6 and the 95.5 s6 trannys?
  38. Need advice on running high boost through my K04...
  39. Need some people who can modify an A$ subframe to add an engine plate?? Help w/good fabricators/??
  40. Looking for a HP gain with A4 V6 30v
  41. A6 question- any of you know how Audi squeezed out the extra 15 horsepower...
  42. need help diagnosing car
  43. Need some help fellas: Metallic clunking noise coming from transmisison upon startup...
  44. Question: K03 making 15 psi and a 28rs making 15 psi why arent the power
  45. Three weeks left in the Audi Club raffle!
  46. Where did the coolant go?
  47. Took Avant in for reapirs!
  48. whats the best place to tap in to get a boost reading on B6 A4?
  49. Stand alone engine management
  50. Diagnosing power loss leads to cam gear position
  51. so i checked my fuel trim .... -5.1% and 14.1% guessing I have a problem.
  52. What would you add to the ATP GT28RS turbo kit besides custom tuning?
  53. where to get a complete AEB 1.8t engine w/ k03?
  54. anyone have any BIRA system 2 brackets they want to sell? (A4-S2)
  55. Timing Belt Mods??
  56. Anyone ever used Luk Pro Gold clutch as replacement?
  57. X-Post: How does this MTM Stage 3 data log look to you all....
  58. Leaning out >5500 RPM... (vag plots)
  59. Compressor surge related: Does anyone back off the throttle partially on boost? eg. city driving
  60. Aquamist 2D install on A4 1.8 - need some help
  61. installation help
  62. need input about gauges -- besides boost, what else is important or good to have for turbo cars?
  63. Got my car back! Question about the new found boost.
  64. ok to replace c box ecu with p box? -- 99.5 1.8 tip
  65. Headers for a super-charged A4..Addt'l HP??
  66. Anyone have experience with Revo Big Turbo Software?
  67. Water Pump went bad at 27k miles....Is it possible? what can cause that?its a 2003 a4 1.8t
  68. Would a 6spd S4 B5 tranny fit on a B5 1.8T without other mods?
  69. Quick sway bar question...
  70. Dyno results...
  71. I have 27,000 miles oil is low what can i fill with until i get my oil change friday...1.8T
  72. Air/Water Intercooler Install (rev 0) complete
  73. T3/T4 manifold on ebay incase anyone in intersted
  74. anyone have this power pully kit?
  75. ok dumb question. how many qts of tranny fluid do i need for a 1.8t quattro and fwd?
  76. why and how do igitions go bad?
  77. Opinions please... DAHLBACK's Chip for the 2.7T
  78. What size threading is on the Oil filter thingy
  79. Project RS4 Sedan
  80. Which syn oil provides more protection 0W40, 5W30, 10W30, etc...
  81. variable cam timing on a 1.8T... how much gain ?
  82. KO4 vs. GT30R vs. T-28
  83. pic of my fmic!
  84. repost from B5 forum--need help checking continuity from ecu to pos
  85. What kind of bolts/studs are everyone using for their stage 3/+ kits?
  86. D2 Coilovers? Any Reviews/Opinions?
  87. Anyway to make a 96 A4 2.8 Go faster?
  88. Sort of Repost From B5 A4 forum.
  89. Wetterauer chipped 1.8T, car is Pinging, have anybody heard of this problem with wett?
  90. looking to buy R/L head off 2.8
  91. Garrett IBE Chipswitching
  92. x-post to b5.......timing belt update (pics)
  93. from B5 forum--no pulse signal on coil & misfire--need ideas
  94. turbo upgrade
  95. KO4 turbo upgrade
  96. Anyone know how to put the car into Service Mode?
  97. 1997 A4 1.8t big turbo options <-- advice needed
  98. Autronic Sm2 Install done..
  99. Cylinder 3 misfire
  100. Scored cylinders...
  101. Need Turbo for 97 A4 1.8T... Suggestions? Offers?
  102. Where can I purchase a used NDBW 1.8T for a Lotus 7 replicar my brother is building?
  103. unplugging coilpack with engine running--what happens?
  104. 2003-04 B6 A4 1.8T boost graphs..
  105. (X-post) Name that tune...lifters?
  106. audi a6 2.7 turbo upgrade
  107. Installed AWE DTS yesterday..bada$$..is a snub mount overkill at this point???
  108. question for you guys regarding an exhaust manifold being ported and polished...
  109. Possible diverter valve problem...advice needed.
  110. I think I blew a turbo?
  111. Need help with engine/turbo swap, is there a better manual than Bentley?
  112. SpeedChip
  113. custom intake with bov.....IDEA for MAF
  114. Name this turbo
  115. Need dragstrip help
  116. can someone reassure me that its ok to use this flywheel...
  117. NGK sparkplugs??? gapping?
  118. Looking for complete AEB engine...
  119. Valve seat problem? Car at shop for almost 5 weeks! WTF!
  120. Which Dyno to get? Escort, Gtech, MrDyno, PocketDyno, Beltronics. Any suggestions
  121. Piston-rod upgrade.. suggestions?
  122. AEB x Other Codes......
  123. Caractere front bumper HELP!
  124. Are Coilpacks interchangable?
  125. What engine mounts are people upgrading to?
  126. Juan Mendoza - Hitman wanted!
  127. APR stage 3 boost question
  128. x-post: tapping the egt sensors on the S4
  129. does neone know if the apex SAFCII works for our b6 audi's 1.8t?
  130. Anyone know the stock hp/torque of a Euro version '96 A6 with a 2.6 engine??
  131. AU 1000 engine tuning
  132. Question regarding injectors...
  133. x-post to a4 forum ATF cooler lines
  134. almost done with new setup
  135. Whats a used K03 worth,? (16k miles)?
  136. If i have a K03 turbo sitting around can i send it somewhere to be beefed up?
  137. *** White Smoke ?
  138. K04-15 Running on APR stage1 K03 software....
  139. STaSIS Tracksport Rear Brakes
  140. Any MBC suggestions (cheap ones)?
  141. Update to blown (sons') engine...
  142. when running a larger turbo setup t-28 or larger what is the best..
  143. Reminder: Achtuning Anniversary Car Show and BBQ this Saturday!!!
  144. Modeling and/or modifying B5 suspension geometry
  145. Stoptech problem. . .
  146. kinda OT - changed timing belt on a kia sephia, having problems now
  147. 12V V6 losing power away from a stop when cold, and also at high speed.
  148. failed rear anti-swaybar uplinks...
  149. Did anyone hear of APR, developing a K04 kit? and AWE having a Super K kit, and ABD's K05 kit?
  150. April 9-10, 2005 Pahrump Audi Driving School
  151. gauging interest, would anyone want to buy
  152. Anybody tried running this on K04 software and injectors?...
  153. Brake Pads?
  154. how many 12sec A4's out there?
  155. Water injection pwnz
  156. xpost. Anyone hear of MJM turbos? Anyone use them?
  157. allroad 2.7t turbo lag ?
  158. bumper shock bolt stuck...help please
  159. giac flashloader
  160. cross post GREDDY FMIC INSTALL
  161. Does anyone have a parts list for an APR stage III kit as well as some sort of instructions Thanks
  162. Anyone use Custom Performance Products susp. pieces. What is concensus on best race susp?
  163. can I drain and fill a 2.8 trans using the fill port?
  164. Clamped the map sensor with a diode, cars acting weird..
  165. Torque Wrenches - Which one.
  166. AWE tuning
  167. Do the B5s have 2 or 4 channel igntions?
  168. Turbo Timer install help??? anyone know
  169. what's your fav MBC...
  170. Engine started, confirmed for Sat. and Sun. Drags at Waterfest - come and visit
  171. chip
  172. soo what will I need extra to make this work with the stock intercooler?
  173. Timing belt tensioner failed on my bud's A4...Have some questions about pulling the head...
  174. What are some symptoms if your wastegate is bad or going bad?
  175. "Lifter" noise/knocking Thread - - Not oil pressure.
  176. 1.8T engine dimensions needed
  177. take advantage of my misfortune
  178. Blown engine.... Hypothetical casue?
  179. Forge BPV - clogging problems?
  180. 2004 Northeast Event Pictures Up...........
  181. I STA is anyone using a Mantaray Motorsport Clutch...
  182. How wide a tire can you install on a 16x7 wheel?
  183. I did some VAG logging to try to figure out my issues,Take a look and lend an thought
  184. Lifter saga continues (noise came back! WTF!!)
  185. Where to buy Samco or other 'reinforced' TBB? TIA
  186. MY B6 NEEDS TO BE FASTER!!!! help
  187. Need help with SPEC clutch problem. Very frustrated.
  188. some questions...
  189. AutoSpeed Introduces our new TRU-DUAL Performance Exhaust Line
  190. Turbo hesitation/erratic boost problems.......
  191. lifters continued ... pic of my 90K miles engine (BWW)
  192. 1.st time running the 1/4 mile advice would be appreciated.
  193. A3 1.8t 2002 Turbo Noise.
  194. Need some help with upgrades
  195. Big Problem!!! Need help :(
  196. Looking for 2000 A6 4.2 Pie Plate 8 Spoke Rims
  197. what could have cause lifters to fail on a 1.8T?
  198. BEST high perf. sparkplug for '02 3.0Q A4 ???
  199. Update: 3500 miles on my South Bend DXD. Still doesn't hold.
  200. Need help from the experts PLEASE READ...
  201. oil circulation to the engine (lifters not getting oil)
  202. Sparkplugs - OEM vs BOSCH/MSD/NGK - HELP!
  203. Upgrade
  204. 2004 Northeast Audi Summer Event THIS WEEKEND!!!
  205. lucky numbers for fathersday! happy fathersday to y'all!
  206. If you car has more than 130000km on it and you haven't replaced the fuel filter, its time...
  207. Since y'all love helping solve my problems so much,
  208. Has anybody used the Brembro Big Brake Kit?
  209. got my boost gauge in the other day and can someone explain some things to me?
  210. Can I get away with just putting eibach springs on my car to lower it to make the gap smaller
  211. not sure if anyone has seen these before, but locking header bolts...
  212. air density calculations...
  213. here's a stupid question, would it make sense to disconnect the alternator..
  214. SPEC clutch and LWF question...
  215. Mintex red box bedding in process..
  216. Anybody with a T-28 ever log block 114? HELP!
  217. Wideband O2 AFR vs calculations based on VAG-COM?
  218. will honed or polished manifold mk difference?
  219. Which windshield washer pump is correct for a 2001 A4 1.8TQ?
  220. help please! ABS and flashing brake warning lights: the dreaded ABS module failure (long)...
  221. My engine cuts out at 5k RPM - no idea why ........read inside for details
  222. clutch issues need advice
  223. whats the typical way of releasing a drag launch rev limiter?
  224. Automatic transmission flare 3rd to 4th
  225. What do you guys think about this?? Go to Products, Click on Hyper Ground or Voltage Systems
  226. adjustable cam gear
  227. 2 Pt. Zero - Have u Quartered ur Car yet? Did u get into the 12's?
  228. Major RICH Problems...Full story inside, will investigate more soon
  229. NE1 using a ProfecSpec2 on a 2001 APR STGIII?? ......
  230. MTM Stage 2 on '03 A4 B6 doesn't deliver :(
  231. did a little searching but not sure...
  232. has any 1 used 104 octane...
  233. 2004 Northeast Audi Event -- June 25th & 26th
  234. AWE-Tuning - chip
  235. Searching for a new Clutch......
  236. looking for K26 compressor maps...
  237. Which clutch of these three would you recommend most?
  238. My dyno day numbers...
  239. Help low dyno #'s
  240. Reccomendations for a good quality and relatively inexpensive fuel pressure gauge...
  241. Dual Mass Flywheel Failure?
  242. My impressions - Spec stage 3 clutch and lightweight flywheel
  243. Boost controller on a nDBW T-28
  244. Genesis
  245. Leads please
  246. Other then a compression test, what else should i have done to make sure
  247. Turbo Upgrade Recomendations?
  248. Northeast Audi Event coming soon!
  249. (noob) switching 2 synth oil any sugg?
  250. Bigger Injector setup issues?
