PDA
View Full Version : Performance and Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35
  1. my 93 100CS quattro, is back on the FOR SALE Block!!!
  2. Will a TT KO4 Turbo fit on an 99.5 A4???
  3. * 1998 1.8T Battery...should the water level be up to the very tops for the caps ??
  4. Red Box pads not working well in the rain(and dry also) - will the EBC Green Stuff pads work better?
  5. NY/NJ/PA/CT want to get a gathering at englishtown for some drag racing sometime in november????
  6. Dyno Plot of MTM tuning vs GIAC tuning.
  7. MTM 265HP kit in S3 Vs TTq with only a standard Wett Chip, Surprise Surprise!
  8. Dyno plot of 1999 stock 180HP A4 vs GIAC chip upgrade
  9. Dyno Plot os 1999 stock 180HP A4 Vs Lucas car with GIAC tuned GT25/35
  10. Dyno plot of 2001 RS4 vs GIAC Tuned GT25/35 lucas car.
  11. Dyno Plot of 2000 MTM 265HP S3 vs GIAC tuned GT25/35 Turbo in my car
  12. X-post: ran 14.4 @ 96.93
  13. Which porche model/year casted rotors with holes and calipers will fit on the S4?...
  14. How much stiffer is the A6 2.7T sport package?
  15. Holley carb for a 69 camaro or Eddle?
  16. X-POST from A4: 14.97 @ 92.18
  17. 1.8t
  18. suspension upgrade - 1993 90S
  19. where can i get a flange for a hks ss bov
  20. Still looking for a good tuning shop in the Toronto area, any suggestions?
  21. Urethane Bushings ...?
  22. Etka (Europe)
  23. Good article on brake pads in the latest Max Power (US)
  24. EBC Pads and Stock Rotors Warping
  25. will a driveline stabilizer promote (unwanted) understeer?
  26. any1 know the flow rate of bosch injector #0280 150 991? TIA
  27. Xpost Pricing or story on MAF units
  28. Lookin' at a good deal on a new '01 Mustang GT covertible...help!
  29. Does anyone have a KO4 they want to sell?
  30. are neuspeed bilsteins easy to adjust? how do you it?thx
  31. Chip not working properly... NEED HELP!!
  32. Do F1 cars use filters - and what kind?
  33. Questions about Ford HD Truck Brake Fluid
  34. If I am considering a turbo upgrade what else should I replace to maximize the longevity of my car?
  35. Unrelated post: Bilstein sports and rear upper 'A' arm bushings
  36. 11/3 Adrenalin Motorsports - 4wd dyno & APR chip deals
  37. Brakes Question...
  38. Any news about the 12v chip?
  39. CDA test results!
  40. performance chips?
  41. Help on Tranny Oil
  42. Electronics experts - fuel injector duty cycle meter...
  43. Crosspost: Nor Cal - help get 100 octane in Sunnyvale
  44. Will this A4 1.8T win against an S4?
  45. Measuring 02 Voltage Output?
  46. Anyone know what the little 1inch tube going into the airbox comes from?
  47. Thank you cmh for a great advice !
  48. Has anyone bought from New German Performance?
  49. chips
  50. Has GIAC come out with a multiple program chip yet? And is there a K04 kit that utilizes it?
  51. Any news on the 12v chip?
  52. Some questions about water/air intercooling on the S4
  53. Performance Built K03
  54. K04/16g hybrid turbo
  55. Looking for a K24/26 manifold..
  56. Any place to install springs/shocks in central IL for a reasonable price?
  57. anyone know the size of the AN fittings on the k03/k04? TIA
  58. Does anyone know if GIAC offers free upgrade to their X-chip..
  59. My new injectors averages 14.8 ohms and my 3yr old injectors averages 12.5 ohms
  60. Hybrid GT25/35 maybe for sale.
  61. Labtronic's IC Spray Module
  62. Is the only difference between K03 and K04 the turbine wheel? If no then what are the others?
  63. Does anyone make urethane suspension bushings for the A4?
  64. i ran dead even with a is300 the other day, i thought..(more)
  65. New Chip, Doesn't Blow??
  66. need to locate TODD CANDEY asap, please email me info
  67. Solid lifters
  68. And they're off...
  69. SmackOff In a GrandPrix GTP
  70. FS: 1.8t quattro koni coilovers.. brand new.. i havent even opened the box yet. $850 & shipping.
  71. Neuspeed chip question
  72. How many have Power steering Leaks??
  73. Downpipe for Audi TT
  74. another APR querying post .. anyone have any REAL dyno plots for stage3?
  75. Will a K04'd 01' A4 1.8 make more hp than the earlier cars?
  76. Does Lucas still hang out here?
  77. EFK, anybody LOST boost after installing? How can that be???
  78. Need Help Deciding!~!
  79. Is EVO MS intake worth the money and ...
  80. X-post of my 14.2 run at carlsbad in the A4 forum.
  81. Securing "Stuff"
  82. How many knock sensors does the 1.8T engine have? 4?
  83. Yes-parts for my 1.8t rebuild are finally in!
  84. * Is it easy to change the sway-bar bushings on a 98' 1.8T FWD 5spd ?
  85. qrs guys hard at work .. hehe.
  86. anyone with the AWE ko4 upgrade for tip trans
  87. Spark plugs in the 1.8T
  88. apr STAGE3 owners .. what problems if any have you had? < MY99.5 / > MY00. ??
  89. What's the hp on a 12v?
  90. suspension question
  91. Bilstein: does anybody know the spring rate for the coilovers?
  92. A8 Modifications?
  93. Launching at 3k in a Quattro A4 1.8T... high? lower? need some help here...
  94. Forge Diverter Valve?? Does it work??
  95. What are the most cost effective perf mods for a 97 A4 2.8?
  96. Dumb question, who makes the T-28
  97. delibach racing
  98. Porsche 944 turbo direct bolt on to Ur S4/6, 200tq20v?
  99. Is the clutch self adjusting? My pedal is waaaay too high...
  100. Check the B5 forum at vwvortex.com, there is a groupbuy going on for coilovers (KW)....more
  101. Audi Sport/Eibach spring kit w/ stock shocks?
  102. N75 Duty cycle peaks at 95% and Charge limit is 0 (zero), any thought?
  103. CTNY & NYCMetro Audi Group Meet THIS Sat October 13th. 20 min North of Manhattan! Info inside.
  104. CURRY'S NEW AWD DYNO
  105. CMH:
  106. eibach pro kit, neuspeed sport/race or h&r sport springs? which mates best with stock sport shocks?
  107. Is anybody using a Boost Controller or Air Fuel Controller (ex. Apexi, Blitz) ????
  108. Me again, looked at PES t-28 kit
  109. i herd about a exhaust for the 1.8t that is 3" incluedes a 3" downpipe. i wanted to know if somone e
  110. KKK K26 Turbo? Anybody have any info on them?
  111. Quick Question on GIAC chip - Cold Weather affect?
  112. Experince with GIAC, Vag-com, Bailey BPV 2001A4
  113. for you guys with experience ... stoptech or porsche brakes? i'm brake stupid. =)
  114. Help me tune out my 20v coupe quattro....
  115. To boldly go....
  116. S3 constant speed hesitation - Help appreciated
  117. xr4tic,I sent you mail regarding my recent HFC installation.When U get a chance,could U take a look
  118. i need suggestion. i have a4 2.8 i was looking for an air intake
  119. APR Stage II or Stage III
  120. Just in case, supremepowerparts.com has a groupbuy going on for the EFK, 199
  121. ERROR CODE 2413 *UPDATE* *UPDATE*
  122. finaly went to dyno
  123. ERROR CODE 2413... Running Rich i guess!
  124. any pictures of a 99.5 A4 tq with sport package that has the Audi/Eibach springs....
  125. Good new on engine rebuild!(APR stage III)
  126. Hey APR. I have a 2001.5 that you can use to test stage 3. I will bring it over, and you can....
  127. Anyone know of a place to get Pagid brake pads?
  128. 12v clutch and flywheel options.
  129. Suspension Mods....Questions
  130. lltek cross tower bar - worth it with stock swaybars? anybody else make these for a4's? thanks.
  131. SUIPER TUNER NIGHT SHOW(NY NASSUA COLISEUM) AUDI PERFORMANCE RACING
  132. New link for the oil pressure sender FAQ:
  133. Random Technology high-flow cat install
  134. K&N drop in w/ airbox mod, K04, GIAC, DP, highflow cat, 2.5" exhaust, UD pulley & electric fan kit
  135. Will a Wetteraurer chip for a 98 1.8T Tip work on a 99.5 1.8T Tip? Thanks.
  136. Audi Weekend in PHOENIX, AZ................................................ .....
  137. What to do with leftover turbos from my S4...
  138. need help locating Bosch fuel injector specs....
  139. What cat back exhaust for 1.8T?
  140. MTM Modified A4 for sale
  141. Stock exhaust with no cat?
  142. Neuspeed shortshifters on nopionline.com
  143. Comments on EBC Red track pads? Cheapest place to buy?
  144. Anyone have a spec sheet for Hawk brake pads?
  145. Where can i get a lighted flywheel for the 2.8???
  146. Alcon owners...
  147. Replace the catalytic converter.
  148. How to install an oil pressure sender: One for the FAQs?
  149. Centerforce Clutch Kit Group Buy
  150. Anyone interested in a set of EVO S4 downpipes/cats..intakes???
  151. Xpost: NEED HELP I ran into trouble installing my SPP EFK today on my TIP
  152. what is the best 1/4 mile time for a chip only?
  153. question on controlling body roll in my S4Avant..need decisons very soon
  154. Who here has the variable rad fan control (checked archive)
  155. Thinking of selling my tt and buying an evo vii. Any comments will be appreciated.
  156. Annoying flat spot at 1800 rpm on a stock 2.8 tip.
  157. Mahle or JE ?
  158. Replacing shocks and springs. Do I need to buy locking nuts or do they come with suspension?
  159. X-post chipped KO3 reliability...... WARNING!!!
  160. Japanese Parts for the A4?
  161. Where to order H&R springs??? Shox.com backordered 6 weeks!!!
  162. PES supercharger reliability?
  163. 12v turbo update
  164. Need mod info
  165. some side by side comparison pix of aftermarket xenon/euro housings vs stock xenons
  166. Nokian Winter Tire Availability?
  167. Who makes turbo kits for 2.8 A4's?
  168. Link to post about my T3/T04E
  169. European Car Article: Why did they do that?
  170. Speed improvement from APR Stage 1 Chip
  171. T-28 install pic
  172. K04 or other turbo kits for '02 1.8T A4s
  173. My MTM stage III 97 1.8tq A4 is for sale - see classifieds for more details.
  174. Anyone purchased anything from Supreme Power Parts (SPP) ?...
  175. Is there a difference between the 98 clutch and the 99 clutch???
  176. truth about speedtech
  177. Update your Neuspeed rear sway bar brackets
  178. anyone know what manufacture makes an oval exhaust?
  179. A4 1.8T........12.62sec @ 115mph!!!
  180. Will a 98.5 1.8T run with the complete gage pod disconnected? If I
  181. What do u guys think of the 87 grand national? I think i might be sellin the A4 after all...
  182. VAG - COM guys, help me out!
  183. Anyone know a fair price for S4 Brakes...
  184. 1.8 engine block?
  185. some serious problem, dealer still couldn't figure out. please help!
  186. 2.8 vs 1.8t koni coilover ... spring rates??
  187. How much for EBC Greenstuff pads for A4?
  188. Uneven brake wear... rubbing/grinding noise... need help...
  189. Saw a pic of Innovative Turbo's tubular exhaust manifold for the 1.8T
  190. Has anyone had oil show up in the antifreeze on a TT?
  191. Modding the TT?
  192. OK... show me your exhausts fellas!!
  193. Ball Joints...what do they do?
  194. Has anyone rebuilt the short block on a 1.8T?
  195. VAG-COM tool, where I can get one? How does it look like? I've seen those boost graphics some of you
  196. tranny swap?
  197. A4 1.8T vs. A4 2.8
  198. 1.8T Turbo Boost Control
  199. who knows about knock sensor location? any pic?
  200. What downpipe setup (if any) can fit onto the Borla catback exhaust without modification?? TIA
  201. Here is a link to a dyno chart of the new T28 kit.
  202. Do any S4 people post in here? Had some Q's on running an aquamist system.
  203. Can someone PLEASE help..
  204. BPV. Anyone use this Bosch valve 0 280 142 110. It oem Saab 9000T.
  205. Another possible turbo problem. This time a TT
  206. hey- xrtic! got a couple of questions for you about the water injection
  207. Possible turbo/engine problem...could use some help
  208. Lowering fuel pressure.
  209. Considering the Eibach pro-dampers and pro-kit springs my reasoning is this..
  210. XPost: APR Clutch/Flywheel installed...
  211. 6500rpm fuel cut off on apr v3.0 chip?
  212. Exhaust cut off dump valve?
  213. Finaly went to the track
  214. bilsteins
  215. Who is using NOS or Venom in turbo?
  216. Exhaust options for FWD?
  217. electric fan kit and boost numbers
  218. Primary vs. Secondary O2 sensor readings: At WOT the second O2 is richer than the primary....
  219. can anyone here give me info on installing a blow-off valve?
  220. apr v2 catback installed today @ qrs. woohoo!!!
  221. * * * San Luis Obispo County Audi Owners Read This!! * * *.....
  222. chips,CHIPS,AND MORE chips
  223. check this engine swap blue print...really cool
  224. wastegate spring - 5000 turbo
  225. Alcon/Coleman Brake Upgrade...x-post from A4 forum
  226. car went into the shop OK, came back with really stiff steering.
  227. Transmission problem w/ modded TT-R
  228. Diesel Performance Tuning- All Audi and VW Diesel Drivers
  229. REAR BRAKES
  230. what brake fluids are you guys using? i've heard that ATE super blue is bad stuff for the clutch.
  231. Ahh sux, I went to track (rather long i guess) {oh and nuts to the puncuation/spelling its late}
  232. Any Injector size upgrades for the 12v A4 ..?
  233. Is there any consensus on the "best" strut tower bar?
  234. transmission oil recommendations? drain or just fill? TIA
  235. Chipped CA Turbo Audi Owners and 91 Octane.
  236. It turns out my rotor (Coleman 330mm slotted) was rubbing on my caliper (AP Racing 4-pot)...
  237. Conversion from 1.8T to 2.0T
  238. The stock A4 injectors are rated at 240cc/m, but at what fuel pressure? I NEED to know.....
  239. Will I notice a difference in performance between AWE's Borla exhaust and a Neuspeed/Borla exhaust?
  240. anybody here run a K04 with a GIAC chip intended for orig turbo (K03)?
  241. X-post: to some K04 A4 drag times
  242. Some water injection results at the drags....
  243. Anyone from San Luis Obispo Area want to meet other audi enthusiasts?
  244. Hey WYSIWYG did you locate your exaust leak?
  245. Advice... Info... etc...
  246. X-Post Suspension thoughts more....
  247. FYI------ no chip needed for FMIC
  248. WANTED: Top suspension installer for coil overs audi tt in Long Island NYC
  249. Miketip had another question for you about 12v chip
  250. Blown fuse on timeing control
