PDA
View Full Version : Performance and Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. please!! a book/web site for engine-gear box especifications 4_93 audi 90cs....
  2. Does anyone have a link for the 1.8t cam profiles?
  3. Is there a place that is cheaper than ATP to buy piping and silicone couplers?
  4. Advice on A6 4.2 ECU + TIP Chip Mods - please advise!
  5. Can anyone help me with my 98 A4 KO4 misfire problem??
  6. Anyone going this nuts on their dash and Standalone systems? =)
  7. Anyone do an H7 HID conversion kit on their A4? post some pics/how did you disconnect the daytime
  8. smoking 1.8t??
  9. *** Help! I'm getting an awful burnt oil type smell coming out of the engine bay.....
  10. actual boost exceeding spec boost consistently. I posted under the S4 forum, but all help is needed
  11. Is there a Hyrbrid Audi community?
  12. why should you turn off your car when pumping gas?
  13. DBW map sensor wires: which ones ground, 5v, signal?
  14. FMIC, thoughts on Race Tec effectiveness (long)
  15. Busted a JE ring! Anyone have a spare?
  16. How many HP are the coffee can mufflers the rice boys run worth?
  17. I have a 97 instrument cluster without a trip computer, can I swap in a 97 instrument cluster with a
  18. Hi-flow Cat? Where to get one and your thoughts on them?
  19. Got new Stoptech SS lines, really good quality, makes Neuspeed and goodridge look bad...
  20. how would a GT25/40R work on a 1.8t ?
  21. WARNING: Granprix Auto RIP OFF
  22. Just out of curiosity, question regarding cams...
  23. K04 Question. ..........
  24. Fuel line kit...
  25. Noticed some wear on the inside of my front tires, I am interested in getting a camber kit
  26. Anyone know about buying M3 rear lip spoilers???
  27. has anyone droped a 2.7tt engine inside a b6 a4 yet?
  28. Recomendation for a good APR tuner in Portland Oregon?
  29. DSG chip tuning
  30. 30v build up questions
  31. Looking for Cam Gear tool for a 30v V6 TB job
  32. Any downsides to seam welding ?
  33. Cheapest place to buy the disco potato? How much can I can the gt28rs for? TIA
  34. Suspension
  35. Ok what do you tuners think. I have a 03 Allroad 2.7Tip with a Giac Tip chip. There is a Giac ECU...
  36. In response to Lucas.....MY BEAST IS GONNA EAT YOURS!
  37. 2004 a4 1.8t chip ideas
  38. Damn! Turbo timer install is way more than the piece itself...
  39. It Lives!!!!!!!!!
  40. Help... KO4 issue...
  41. Kaboom! No more boost woes!
  42. Is this OK to put in my gas tank?
  43. Autronic standalone
  44. making sense of flow numbers..
  45. may be a dumb question...
  46. Anyone have blown turbos for sale?
  47. X-post re: FK non-disclosure policy
  48. Need help with clutch for MY2000, even after STFA this weekend!
  49. Just installed that Walbro hi flow pump, & a new fuel filter....
  50. anybody ever had a "whiny" fuel pump?
  51. Will I have to go standalone engine management to get close to 300 awhp for a nDBW a4?
  52. FYI - Clicking 1st gear cause
  53. Xpost - need your guys' help w/ suspension installation, bolt connecting upper arms/bearing carrier
  54. RS6 exhaust
  55. Will rx7 denso top feed high impedance injectors fit dbw 1.8t?
  56. Did a compression test and........
  57. Bilsteins: who/where/how much
  58. what cieling height do i need for a lift...
  59. I'm trying to help my son with his GTI...
  60. Mike, remember how I told you I'd kill for an air/fuel curve like yours?
  61. BMW Dinan like options for Audi's??
  62. AEB head
  63. I got new injectors...what should I set my FPR to?
  64. Anybody have a Greddy Type S and a big (er) turbo?
  65. Knife Edge or Lightened crank?
  66. Getting OEM Parts Fast and Reasonably Priced
  67. Upgrade for ECU
  68. Replacing Vacuum lines on a 97 1.8t AEB
  69. Anyone in the Philly/NJ area ready to do a 2.0L build-up
  70. REPOST: Does anyone know how to prevent CEL with K04`s piggi pipes and gutted cats (0 catsT:
  71. Quick update on my car...
  72. What are the best performance brake pads A4 B5
  73. Is TDL Racing still in business?
  74. Drag Day - May 21st - Lebanon Valley Dragway (New England/NY), sign up info...
  75. Re: coilovers... Which brand offers greatest drop and which offers least drop for S4?
  76. ECU Chip Trouble
  77. who has the most heavily moded b6 a4 1.8t?
  78. Who can explain "shot-peening?"
  79. 3.5" TUBING bender (update)
  80. Has anyone ever tried a MBC instead of a chip?
  81. What is DBW?
  82. X-Post: ?'s about DIY on a CO install...
  83. the APR s3 gt25? does anyone have specs for it? how much hp does it support?
  84. Ignition Timing
  85. Timing Belt Problem
  86. Decisions...Decisions...
  87. How much timing retard is normal @ WOT?
  88. CEL and a code of - 17544 "Fuel trim bank- System too rich". Any ideas? On my '99.5 w/ 26K miles.
  89. apr stage i+ problems (x-post from b6) please help...
  90. FYI: All models MY 2000, 2001 Audi Tech Bulletin Engine Oil Capacities
  91. Some Audi injectors for the 1.8T have a long nose extension. Others don't. Why?
  92. Dahlback and TJM Motorsports
  93. how much should a S4 transmission swap to an A4 run w/ parts
  94. Cross posting - Would stock B6 S4 mufflers flow better than 1.8t mufflers?
  95. John B, any news on the catch cans you were looking at making?
  96. question about IAT sensor and fmic
  97. A4 fmic's
  98. Turbo Upgrade Dilemma
  99. Does anyone know where I can get mounting plates for 996 big red calipers to fit on an A4?
  100. x-post, sort of anyway
  101. Stainless steel lines/ APR snub vs Autospeed DTS
  102. Where can I find Motul RBF 600 cheap?
  103. How much would it cost to have a port and polish done?
  104. Part number for MAF sensor on TT
  105. New Shop, New Techs, FORWARD PROGRESS... (long)
  106. attn: xr4tic or Audi2ptzero It took me 2months just to do block 31 log
  107. Could somebody give me a quick run down on the pros and cons of lightweight flywheels?
  108. How do I find out the size of my MAF or would a TT MAF fit.
  109. Turbo Upgrade
  110. Did a data log this AM, wanted some input.....
  111. Anyone know technical specs for 225hp TT Fuel injectors?...
  112. Test pipe
  113. What exactly goes into balancing an engine?
  114. does anyone have a wiring diagram for the aeb 1.8t?
  115. who knows the best...least expensive place to buy H-sport bars?
  116. 2.0L Conversion, Well engine is Built.
  117. braking Q: After searching the archives it seems that only ST brakes seem to be able to match OEM
  118. I am installing a new turbo, and pretty much all coolant is gone. How can I drain the rest of the
  119. coolant
  120. Does anyone have a good write up on removing the injectors?
  121. Should I get updated software now that I'm running a 2.5" Turbo back exhaust? GIAC btw
  122. TRANSMISSION FOR SALE
  123. Hey guys, looking for a helping hand...
  124. HELP
  125. Any feed back on Kumho's V710?
  126. anyone wanna help me with some maths???
  127. How exactly am I supposed to gap my 3 prong spark plugs?
  128. Anybody running a Profec B (or other EBC) with a Tial external wastegate?
  129. Are optima batteries ok? I dont run an aftermarket stereo/subs but needed a battery and had optima
  130. motor mounts and GFB valves
  131. Why don't people here use Nitrous spray bars?
  132. oil temperature difference
  133. questions for anyone with a ported and polished head, 97 1.8t
  134. gas mileage is horrible. I am gonna vag my 02 sensor...what are normal levels?
  135. Can IAT's be logged on a NBDW B5 A4?
  136. pictures of my new engine :)
  137. Does anyone know where I could get some chip sockets?
  138. Non n00b DV Questions
  139. Revisiting the topic on Revo, more input is appreciated. TIA
  140. New software for cam's?
  141. apr stage III who?
  142. relocating the map sensor....
  143. I have some stuff to sell - the hot setup for N-DBW's w/out bottom end build
  144. way to improve fronttrak handling?
  145. shortshifter suggestions or ideas???
  146. p-chip suggestions or ideas???
  147. cat back options or suggestions??
  148. does anyone know how to prvent CEL with piggi pipes and gutted cats (0 cats)
  149. Can some one please tell me.....
  150. Anybody have a K04-020 for sale or a good contact name ??
  151. High rev on the 2.8L 12v
  152. Beyond stage 3...?
  153. how much power does the 1.8T rods safly handle? assuming ->
  154. Still here Rob?
  155. hey xr4tic!
  156. Who needs BREMBOs (kits or rotors)
  157. got new cat-back exhaust, questions (and initial impressions)
  158. x-post: lets solve a little puzzle-Y dsn't my STG3 wanna run? (Idles ok)
  159. car still in the shop, but almost done. here is something to share
  160. Installed stage 3 In my 98.5tqm a4 yesterday, put the ecu in and.....
  161. Open house at our race shop
  162. 13's?
  163. Help needed with K04 issues.........
  164. FMIC/Dyno/Geek testing link
  165. Does anyone know of agood online machine shops?
  166. Maxed out MAF...
  167. Will a tranny from a '96 2.8Q fit my 99 1.8tQ??
  168. Piggy Back Computer Setup For Sale and Greddy Profec B
  169. just for the hell of it -anyone who remembers geometry
  170. custom (homemade) FMIC questions..
  171. Anyone know where I can get a custom bent peice of 3.5" O.D. Aluminum pipe?
  172. My K04 is dead... Looking for a cheap solution ? (TT-225)
  173. No more fire after a compression test ? (1,8T)
  174. Has nyone experienced problems solely bc of their port and polish?
  175. No spark at all cylinders help
  176. Sneek Peek pics at engine build.
  177. Flow Bench Testing on Intake manifold and Head
  178. B6 suspension question??
  179. Brake upgrade
  180. anyone using APR's v-tune softwear??
  181. Some info on the GT28RS from its designer for those interested.
  182. Anyone looking to get rid of their car and subsequently thier kit in the next 2 months or so?
  183. Anyone running plugs 2 heat ranges cooler?
  184. Alcon Ap or any other good brake companies
  185. Question about Autronic SMC system...
  186. Finally dyno'd my TT... x-post...
  187. Repost: but im really curious about this...
  188. Good website with compressor maps for various manufacturer's??
  189. Fri. May 21st - Drag Day - Lebanon Valley Track Rental - Sign-up is open...
  190. Looking for .5mm oversized pistons, rings and main bearings
  191. (puts flame suit on) STG3 guys (X-post frm A4 B5)
  192. Just got word my car is running at 100% again :)
  193. question
  194. Who here has experience replacing a TB on their 2.8? Can you help me do it for my Y2k 2.8 30v
  195. CEL problem: past 100+ mph CEL starts flashing; I'm thinking its CP but not sure which one.
  196. 2.6l bottom end in a aan engine
  197. 3" downpipe and relocated high-flow cat
  198. A good brake discussion in progress ...
  199. Does anybody know if there are any major differences between the Profec-B and the Profec-B Spec II?
  200. stroking 1.8T motor no puns please :)
  201. Crank case ventilation in 98.5 2.8.......
  202. ***Pagging BIG NIPPER©, hows ur build up going, havent' seen any updates
  203. Clicking 1st gear - seaching the archive, its seems to be a broken gear
  204. Curious how much difference an AEB head, Port matched and polished IM and Ported EM would make...
  205. Where To Buy Gt25/35??
  206. x-post - ACNA - Tech/Perf GTG March 20th at AWE in Willow Grove PA
  207. looking for a book on turbocharging theory...
  208. Does anyone have a detail picture of the 20v head, valve side?
  209. can somebody explain nos, wet and dry difference?
  210. How many people would be interested in an oil separator/catch can?
  211. All right, I think I made a decision
  212. Need clutch info...
  213. is there a loss of power when runnig a miltek exhaust?
  214. Not understanding the PCV system on 1.8ts
  215. Should i put steel scouring pads as baffels for my custom made catch can?
  216. Rethinking my custom turbo build up.. more questions...
  217. a couple if questions regarding a new engine...
  218. K04 Boost & MAF
  219. I just removed my TB and there was signifigant oil residue on the inside of the IM...
  220. Next question for you custom turbo guys...
  221. Where do I connect the innovative LM1 external input to log RPM?
  222. dbw 1.8ts have a 3bar map sensor or 2.5bar?
  223. white smoke and oil consumptions ?? (TT-225)
  224. what is a symptom of a weak internal wastegate??
  225. Dual brake calipers
  226. Honestly thinking about designing a custom turbo kit for my B5 1.8T....
  227. what do you guys think of this Adjustable FPR???
  228. What is the ultimate suspension mod to fix TT drive problems. Koni/Eibach? Specifics
  229. Question about off-throttle, fuel injector activity.
  230. anybody have experience w/ brembo sport slotted front rotors?
  231. clutch
  232. Today is a Sad, Sad Day......................
  233. Does anyone have a Bentley or a how-to on replacing the throttle body on an AEB motor?
  234. ebc... whats your take on this?
  235. BIG NIPPER: can you mail me your email add... wana ask you few questions.....tnx
  236. x post K03 Sport Questions
  237. Cotton vs Foam Air Filters. Anyone got good links?
  238. Looking for inepensive fuel pressure tester?
  239. xpost: leaking DV
  240. Man, I'm surprised none of you performance gurus never jumped on the Ecotek!
  241. REPOST from B5--timing belt saga and question
  242. which standalone are you guys using?
  243. adive/opinions requested on fuel pressure gauge...
  244. who makes a good cold Air intake
  245. xr4tic, about your psc001,
  246. Brake caliper thermometer
  247. Ordered Stg3..should be in by end of month. (B5 A4)-->
  248. 2004 1.8T 6-speed - 01E?
  249. John Bass read your email asap. Thank You.
  250. 4000 Quattro non turbo 20 valve swap
