View Full Version : Performance and Tuning
- does anyone know if Maximum Boost talks about blow thru turbo setup?
- On ecodetuning.com .....
- Ignition Solutions Coilpacks, worth teh money or overated??
- 5 Cylinder Questions....
- DEFI Amber Gauges now installed & GIAC 'Beserk' Software Peak Boost Reading
- HID xenon upgrade kit for A4 B5
- speed limit question...plz help me!
- Who got the fastest car?
- I'm going to install APR S3. Should I use the stock 4 bar FPR or use an adjustable for tuneability?
- X-post from B5 forum...searched....many conflicting answers...spark plug questions..............
- whats the difference between injectors and a fule rail?
- ok, anybody got a brief run down for whats necessary for a reliable 1.8 to 2.0L conversion
- weisco 2.0L pistons
- timeslip for anyone who cares
- what of oil cooler can i get for a b6 a4 1.8t...(more)
- Dealer just finished installed Stage 3 Clutch and LWFW - what should I expect for the first ride ?
- Dawson's Dreadnaught-X-Post
- Why am I running rich? (stage three 1.8T) Eratic air/fuel ratio.
- federal emmisions
- New DEFI gauges have arrived! WOOT!
- Just got Euro tuner in the mail.
- Do-able or not?
- 1997 a4 1.8t stock Fuel Pressure Regulator Rating?
- mod for a4 3.0 2002 ?
- My day at the dyno with MTM stage three (1.8T)
- best mechanic gloves???
- Who is hosting the 1/4 mile database these days? where is it?
- ARE YOU FVCKIN SERIOUS!!! (still got over heating issues)-->
- Behind the Scenes: Primedia Editor's Charity Challenge
- Hope this isn't a repost...
- Just done next initial stage run.
- A4 swap
- a4 vs s4
- Could I make a front wheel drive audi tranny spin the opposite direction?
- Those who have installed RS4 Tranny mounts: what else did you use besides the mount for it to work?
- Went to the 1/4 strip for the second time, some questions
- T-28 boost follow-up...no leaks anymore, just about to run rich again
- Upgrade path
- I Found LEMMIWINKS program.
- Update on cooling and over heating issues.
- Drive by wire people with test pipes....how do you avoid the rear 02 DTC?
- Anyone mind helping a noob out with some Logs?
- Which plugs to use for a Stage 3 A4?
- Motor Trend eBay Editor's Challenge Volkswagen R28
- Thinking of getting a B5 S4
- is there a way to encode a L box to a K box? both 2000 a6's l is tip k is 6spd
- Stasis Engineering Track Sport Suspension - Should I pull the trigger?
- There has to be somone in here running a greddy profec B spec II boost controller
- performance clutch flywheel
- Thoughts on experimenting with a boost controller...
- anyone have updated info regarding gt30 turbo kits for the 1.8t's?
- anyone know a good place to buy reinforced silicone vaccuum lines like the updated passat ones???
- ****The 2 things I learned while tuning tonight.....*****
- turbo timer
- this sounds bad I'm sure but could I get away with welding two stock
- Is anyone running the Bilstein PSS9 Coil Over System?
- Please help... those with turbo kits (long)
- Anyone tweaked the wastegate rod to squeez hps?
- Turbos
- is it possible to have a switch on the atp ves open,close,regardless of boost
- atp clutch and flywheel
- Stg 3 Problem: Boost problem at full acceleration:
- RS6 Exhaust
- (X-post from A4 B5) Got some SERIOUS issues after custom FMIC install --(read on)--
- Public Kudos to Quattromotion (Nwk, NJ) and Louis their #1 wrench turner.
- cheap place to get a 2.5" pipe bender?
- Cyl 3 Misfires? hot spot?
- I have an idea...... see wat you think
- OK guys...here a quick one for ya. (ATP Dump tube Q)
- how much would the total be if i would want to drop my 03 1.8T maybe like an inch ?
- Clarifaction please: Do I NEED or SHOULD I change the injectors for the KO4-15
- exhaust?
- X-post: Dyno results, do these numbers seem right?
- Low oil pressure on newbuilt engine...?
- About to finally install the KO4-15 - Anything else I should do?
- I have STFA and troubleshot for weeks but still need help :(
- anyone seen this?
- which one better OVER all .... Carbonio intake vs. Boostek intake ?
- Lucas take your car to the 1.4 mile track - Now!
- Kart on the Road!!!
- Slight misfire at idle but no CEL (long)
- Do these cips realy work
- Alignment done...
- Can i put a Blow off valve on my 03 1.8T Auto.? and is it a good idea, why or why not?
- Anyone with an aftermarket steering wheel
- Need some advice
- Another Update
- Anyone know what B5 parts will fit the B6?
- getting JAZ catch can....some questions
- Abt stage 1 chip ( 193 bhp )
- Theory about Seconday Air Inj system code
- 1.8T MY2000 catch can woes....
- Can I do any mods on my 93 100s????
- Dump valve questions
- Not Hitting ANY boost.
- Water injection vs FMIC
- help
- what is the max airflow of K04?? in cfm??
- Interesting observations...
- about the air mass meter change.
- For 100 octane gas, would I want to run colder, hotter or the same heat range spark plugs?
- Stage 3 question (T-28)
- Whatever happened to the idea of using a multi-function aircraft gauge (this was a few years ago)?
- MTM Stage II vs AWE/GIAC K04 kit
- Question....
- Help! Need airbag Resistor Sizes for both SteeringWheel and Rear Seat : 01 Avant.........
- Does anyone have one of the Kinetic Motorsport VW/AUDI 1.8T Longitudinal Turbo Manifold - Any good?
- Turbo
- Sport Exhaust
- VAG-COM OBD II standard interface? will it work??
- anyone selling a k04?
- Adjustable rear Sway Links (CPP) {Setting length}
- Son's car follow up.... :-).. makes me miss my ar even more..
- Hi Flow Exhaust Manifold Options for KKK turbos
- Performance Enhancement - SF Bay Area
- Anyone going to KMD/TJM's Charity BBQ? This Sunday... should be good!
- dyno proof please...
- Dyno excuses...
- Engine back together,...
- BG or Redline?
- Anyone here uses the FK quick power clip on Bumpstops?
- Anyone have an approximate idea on how much power this would have??
- Exhaust ?
- Exhaust System... yes or no?
- gauging interest for fiberglass headlight intake
- Initial Dyno Plot.
- Running pipe for homebrew FMIC to stg3 turbo outlet-->
- AWE and Unorthodox Racing Clutch/Flywheel Question
- anybody know at what pressure the k04 wastegate starts to open?
- All XXTuning Dyno Day Graphs (& pics) are now posted for you to compare to your hearts content..
- Start issue.... HELP!(more)
- Here's the dyno graph.....>
- There is a k04 that fits the B5 A4 engine which flows more than the K04-15 correct???
- 412 hp on a stock head and stock 1.8T block
- Turbo upgrade for 01 A4
- Fuel system making noise, dont think its the pump though.
- 3 inch DP and HFC with o2 sensors and possible cell
- Fault Codes.. help with a cure please
- 95 a6 2.8
- Initial post:: 334 whp achieved!
- I have a 2002 A4. How do you remove the rear tail light to replace a bulb?
- X-post..engine noise............link
- Any idea what would cause this type of scoring on a spark plug?
- Intercooler Q: How come a lot of IC kits use larger piping on the cold side?
- Big turbo peeps.... what clutch are you guys running...
- anyone used zeitronix Zt-2 AF meter? any feedback?
- If any of you So.Cal. peeps wanted to get on a local track.......
- (2004 A6 2.7T) Tuning for newb plz
- DPP - Direct Port Programming Wish List
- This Saturday (9/25) - near Hartford, CT - Dyno Day and Audi Gathering - Come join the fun!
- Hi..my name is Steve and I just got my car tuned by Tuner Transformations
- Best way to drive when running BG44k in the gas?
- Turbo Kit
- DTC 17584 Bank 1:O2S (Lambda) Correction Behind Catalyst: Control Limit Reached
- car not running properly
- 2001.5 S4. What exhaust should i go with for sound/performance?
- Anyone using a SAFC....
- witch injectors should i use....
- Dahlback is in...opinion and some questions
- what is the fastest setup for the b6 audi a4
- hey dlsj5 how do you like boosted tech vs. your old custom system
- What cleaning products to use for cleaning surface area of Pressure plate and flywheel?
- What clutch to buy?
- Curious whats the difference btw engine code ATC, AMU, AWP?
- Anyone using Big Turbo Software?
- Anyone have a link to that guy who was building the 5KQ with a twin turbo 4.2?
- anyone here with apr stage 2+ with dyno numbers in a 1.8t
- New pads on used discs?
- Guess the part?
- NEW TURBO AND FUEL MANAGEMENT 1.8T
- Reminder: 9/25/04 - Audi Dyno Day and Get Together - Come Hang Out - near Hartford, CT
- If you had to replace the turbo in your 98.5/99 A4 1.8T, which turbo would you get any why?
- So is there a concensus for a stage3 clutch for the A4?
- xpost: Can someone diagnose or point me in the right direction with this problem? TIA
- flame suit on...
- tuning companies for B6 S4?
- Replika Maschinen and Elgin Cams open house Sept 18th
- Chipping ??
- any cheaper exhaust alternatives than those 1400 dollar systems
- x-post: RESULTS from yesterday's S4 dyno day @ Harman Motive
- Does this trick work on a '97 1.8t with a test pipe?
- Asked on Vortex..no good answer. APR STG3 turbo..CFM??..anyone??
- Performance Modules
- Throttle cutting...
- Tip-chip question - please forgive double-post
- anyone know specs on the K03? A/R, wheel size, etc.?
- K04 kit with K03 chip
- im taking the injectors out of the car...is there a recommended manual cleaning method?
- 9/25/04 - Audi Dyno Day and Get Together - Come Hang Out - near Hartford, CT
- ok bought the ECS stage 4 bbk. They gave a 16.7mm offset for the rotors. Will this fit an A4 B6?
- Diesel Tuning Boostdog
- Woot! MTM Stage 3 is back installed and back from the ceramic shop...
- Started looking at the vag readings yesterday evening.
- x-post to threads on b5 (intake and cylinder head pics)
- Is running out of gas bad for the car?
- problem with aquamist install...
- question about intercooler tube size.
- Help me decide if I am on the right track with my GReddy PRofec B-spec II boost controller settings
- Ok, for those that wanted to know how and where my turbo spools up.
- b5 a4 timing question
- New Car Ideas....
- what do i need to use an A/F meter as a wideband O2 meter?
- S4 radiator support in an A4?
- :) anyone know where I can get the ARM1 for cheap? Or is Split second the cheapest? Thanks!
- anyone running dahlback chip?....
- Is there any negative effect on the transmission if the rear wheels are further out than the front?
- Catch can - Anybody used this one??
- 12v rebuild/ poss turbo
- Can anyone explain what lemmiwinks channel 13 does exactly?
- Changing engine in a 1991 Audi 90 2.3E Q
- Finally got my car running and started tuning... Autronic Autotune rocks!
- Little chat with dealership about downpipes for B6 S4
- MAF Issues
- Custom exhuast manifold? I know some of you on here were creating your own
- A8 as a track car..
- 9/25/04 Audi Dyno Day Spots are now Open - Wethersfield, CT ....
- dry sump anyone? tips or things to know?
- Got some vids up of this weekend's import war. Including this 8 sec car that hit the wall!
- R32 vs. S4 Avant...
- Revision 1 of Air/Water IC Completed
- got a question for you guys who know about FMIC setups...
- What to look for when buying a used turbo car?
- Anyone got an email address for AWE?
- Perhaps the final update on the MTM Stage 3++
- Full-race manifold for custom GT28rs kit....
- Anybody interested in taking these 5 Bosch injectors off my hands?
- Looking for turbo wastegate 411
- Where can I find aerodynamics figures for 2001 S4 sedans and ...
- This will get you into the performance and tuning mood!!!
- Please educate someone on injectors?
- MTM Stage 3++ update...
- Boost Readings....does this sound correct?
- Considering Neuspeed Super K04, Anyone installed it yet?
- What do you use for Tranny fluid and Differential Fluid?
- Here it is! My write up on my Aquamist 2d install / experience / results... (long & BWW)
- Is the APR Snub mount difficult to install?
- Can someone give me a quick lesson on turbo specs and what they mean?
- Bosch Racing F2CS plugs
- How come I never hear anything about upgraded fuel pumps in Audis?
- Does any know who makes oil cooler with a thermostat?
- Been working on this off & on for a few months now, here's some pics.....>
- S4 VTG Killer - 11.098 ET
- Timing retard on Dahlback Racing chip on TT
- K04s with Stock ECU (A box)
- Air Induction.! Good Idea?
- This question is in reference to the MAFs used on our cars, the B6 A4s.
- slave cylinder...
- Motor mount question and snub mount installation caution...
- 13.35@103.6
- Gear heads need help replacing a 2.8 water temp sensor - TIA
