View Full Version : Performance and Tuning
- Exhaust options for an '01 A6 2.7T?
- Micrometer adjustable Torque wrench - "adjust to lowest setting when not in use" . . .
- who here has a AVC-R in there TT?? need advice
- Just got Bosch F5DPOR plugs they come gapped at 0.6 mm (.24) for my A4 1.8 any problems with using
- Spring Help ASAP! Please
- I had a question on a bypas valve
- Thanks Everyone for the help... Got another one for you!
- Intermittent Misfire - coilpacks?
- Redline product users, and people who know about the products....(link to question inside)...
- 12sec Time Slips att. Mau.
- Liam in Montreal
- Octoberfest and Open House @ Hartmann Motorsports 10-06-02
- Question for A4 1.8T APR Stage 3 owners
- Big Brake Kit for the Bentley !!
- What's the corrolation (sp) between trap speed and ET?
- brake pad question......
- T28 kit for 2001 A4..
- Is it possible to use RS4 oem clutch on '01 A4 1.8tqm...
- EBC Green or other low dust pad with Stoptech rotors.
- I have been having problems with my S4 being slow , do you think I should
- S4 swap to my A4 1.8 T Quattro 95'
- Anyone selling their 2.8 PES 2nd gen supercharger?
- Wetterauer 2.8 V6 30V chip performance
- injector size?
- Lucas please contact me asap...AIM: xxbignipperxx or Email...
- Does anyone with bentley know if it has detailed pictures of transmission?
- Does anyone know what turbos the Rs6 is going to use? K16s???
- Greddy turbo timer installation and pricing s4 2001
- X-Post: Storing 100 octane.. does it go bad in time? how long?
- A Turbonetics T3/T4 to my A4 1.8T
- Performance upgrade for 02' a4 3.0
- club18t.com
- Squeaky Suspension
- Looking for a good hi-flow cat, any suggestions (1999.5 1.8T)
- new s4 vs. MTM "RS4" allroad?
- S4/A6 2.7T tip tranny bolt up to A4 1.8T that had tip tranny?
- The Clutch saga continues...
- Aquamist Group Buy
- Clutch & Flywheel
- Leaking rear end Audi 90cs Quattro and Cat conv question
- '98 A4 1.8T having surge problems ..... anyone ever had this......
- Is the new S4's compresion ratio too high to..
- O.CT = Wow!
- Stoptech pad bedding procedure question.
- Eibach springs on 2 week backorder at shox.com
- airbag light
- Brake pad suggestions
- What do I do about "Intermittent Misfire detected in cylinder1", same for number 2..
- what are peoples thoughts on either Milltek or LLTEK(Brullen) exausts?
- Quattro club event (driving school) at NHIS in NH next week
- Trubo might be SHOT. HELP!
- Intake Air System - Leak Detected
- 20v turbo (7A turbo converted)
- 1.8T motorswap into 88 VW FOX GL
- Ran a miserabe 148 HP at curry's clash.....
- Changing Stoptech pads this week, any advice?
- So my neighbor gave me a can of Octane Booster thats 35% Nitromethane.....
- Anybody know the login code for the VAG-COM to recode the soft code of a ECU??
- anyone know a good place to get exhaust pipe materials in BC canada?
- Tiptronic
- I want to learn more about water injection on a a4 1.8T..
- YOUR RS4 IN AN ACTION FILM- SUBMISSION DEADLINE TOMORROW!
- Night at drags finally in the 12's
- anything you would ever want to know about oilfilters..
- anyone selling a test pipe....
- 1.8T timing chain problems/questions
- Need new control arm bushings: Where and what to get???
- can someone show me how to launch my 3.0 a4,,,
- Is a Full 3" exhaust to much for a Ko4?
- Where to buy a bosch 5-bar fuel pressure regulator
- APR Stage 3 dyno results from ATP Dyno Day
- I am looking for O.Z. Novas any one have any for sale?
- Advice on getting a chip for my 1999.5 A4 2.8
- Anybody use OZ Chrono on the track or autoX?
- Clutch install on an A4 1.8tq.....Degree of difficulty & a few "?"s
- MTM CHIP for 01' S4 avant For Sale
- Liam in Montreal where did you get the roll bar?
- XPost: Any seal problems using Motul 600? Help! (M!)
- Question for those running Redline tranny fluid, MT-90 or MT-L?
- Help
- Lower control arm/vibration question
- ***HOUSTON*** Race Gas Sale!! link inside
- would removing my muffles effect performance?.. i have a 3.0 a4
- HELP: Need tel # to Avalon Motorsports in CO...Zev, anyone? TIA
- Performance of chipped 1.8t vs. 3.0 stock?
- Need clutch help, x-post
- How to fix brake pad chatter with Stoptechs?
- Anyone getting rid of their chip
- How hard would it be to change to non DBW???
- anyone know if there's a way to turn the odometer lights to red?
- While were sharing Xposts-Clutch Problems
- Xpost- Regarding what to do with engine damage from spark plugs...
- Beru-Ultras
- Throttle Body Mod
- Cat back for 1998 A4 2.8 Quattro
- Anybody running their A4 without the Cat???
- Is there any place other than AMSOIL to buy amsoil synthetic oil?
- Somebody BUY MY BRAKES!!! Never installed StopTech brakes!
- FS exhaust manifold and tires
- STaSIS Support Cross Post
- To the person who was selling brake upgrade for the S4 (or anyone selling), email me. Thx.
- Sick of DBW...who can tune one?
- Eisenmann exhaust best for Audi?
- 5 point seat belts: Best setup for Audi?
- H&R wheels spacers-reliability and racing
- can you put a 3" down pipe to a 2.5" custom exhaust???
- Does the FMIC from SPP work in unison with the OEM IC or is it stand alone ?
- A4 1.8T chip project.....
- Procedure for changing pads with stoptechs
- After tracking S4 last week, there's still 'rubbing' or 'shuddering' when braking and after ...
- Where to buy '02 S4 brake pads?
- 2248 mBar reading on VAG-COM = 1.248 BAR of boost?
- Soooo Sloooow.....
- motul brake fluid users .. how often do you change?
- Upgrades for 1991 Audi 100
- Anyone know where I can get a set of 4:11's for the 5 speed ?
- Questions about the a4 1.8T
- Just wanted to Thank the guys on this forum for their help.....
- What is the best chip for my 2003 A4 1.8 T ??
- What knock sensor voltage is considered detonation via VAGCOM? (Also chip update on 2.0 conv)
- Has anyone installed a custom made exhaust for a 2002 A4 3.0?
- I've done the search, time to ask the group: a couple questions on the Neuspeed chip
- any engine upgrades apart from chipping for audi a8 4.2
- 2.8 30v ECU upgrade through Greedspeed
- I'm tracking my S4 in 3 weeks, what engine stuff do I need?
- Does anyone know if a suspension from a 99 can be swapped with a 2000 suspension?
- 103 race fuel
- Which exaust for a 2.8 quattro?!?!?!?!
- Need HELP diagnosing possible turbo problem...
- Possible Throttle problem??
- Got the new Software from PES.............Woo-Hoo!
- Boost pressure control valve
- can u add a 3" down pipe to a 2.5" exhaust ???
- can anyone reccomend good springs to go along with bilstein sport shocks on a 2.8?
- Looks like some bad news for "Werks of Art" and Juan.
- T3/T4E install, day two.....
- ??AEM intake water stopper??
- Opinions on Pagid Blue for street use
- Boost controllers on pre-DBWs..
- **** that won't void your warranty
- day one of T3/T4E install
- Vag test questions
- I need some information about chipping my car ..
- diverter valve install help
- how many miles to wait before you put in a giac x chip?
- Does anyone have a link to a how-to on removing a K-03?
- so how exactly does the vag read torque?
- wut can i do after a supercharger for more power?...
- Stage III Passat - 2nd gear TOAST!
- KO4 Kit Questions
- question about stock A4 IC piping
- Anyone interested in Apr chip with 2 programs for 97-99.5. I am in SoCal.
- Looking for Juan Mendoza?
- Mintex Ctech or Hawk HPS???
- M3 vs the Cops
- Need advice, K 04 install only with K 03 software, FPR question....TIA!
- x-post-BIRA sys 1 Boxster brackets for A4/TT for sale!
- x-post Electric fan kit
- Problem I face...Keep and Modify. sell buy new and modify ??
- Hey guys P.Nelson asked a good question a few posts back
- 96 A4 2.8 supercharger?
- CLUTCH & message to JUAN MENDOZA
- I want to transform my 4000Q from autocross to rallycross....
- repost: Which big turbo software is most reliable for a 2000?
- Eibach Pro_damper or Bilstein Shocks for 2.8 Quattro with Sport Package?
- can some one post a pic of the connector for the intercomp lap timer cable that hooks to a pc?
- Where's xr4tic's 2.0 Conv. update???; I need my weekly fix of envy . . .
- can and if possible. putting a K04 turbo in a A4 2.8
- Just installed H&R's on my A8, pictures thread below
- Hey Audiboy...
- How to boost performance 1991 100 automatic?
- Does anyone have experience using Performance Meters such as the Race-Technology AP22 or G-TECH pro?
- Install now or wait?
- Best A4 FMIC?
- Brake fluid question - is it still good? & SS brake lines?
- NEW 2003 a4 1.8t quattro
- Buy my new, never installed, StopTech brakes...PLEASE, emergency!!!
- 1.8t A4 60,000 mile service $$ what to expect?
- Another brake pad question...
- FOR SALE (A4 APR Stage III Turbo)
- Exaust for 2.8? A!Avantgarde, Remus, ????
- What's a good sport pad for the street and maybe one track day or so?....
- If I put a Shrick 272 cam on my 2.2...(m)
- x-post - MTM Exhaust installed on the '02 S6 Avant.
- YOUR S4/RS4 IN AN INDEPENDENT ACTION MOVIE
- Audi 1.9 TDI Superchip for sale
- Where can I get 100 or 104 octane in the NYC area?
- Installing H&R Coilovers on my 97 A8 this weekend, few questions
- Can you use the S4/RS4 clutch in the 1.8T?
- TT 180 engine vs. 225
- Oil Question
- hey guys (first post in this forum) =)....is the neuspeed extrude honed manifold worth the $600
- exhaust question??? which one??
- x-post to motorsports forum. Looking for a good track brake pad.
- For sale: GIAC Chipped ECU for non-dbw 1.8T's - $650 shipped
- Does the front trak A4 have the same gear ratios as
- just thought I would share here-ran a 14.66 @ 92.9 in my stage 2 A4
- Which chip should I get for a 99' A4 1.8T quattro Tiptronic??
- Just got my S4 back with new 1st/2nd gears/syncros BUT: exhaust is much louder now! ??? Anyone?
- Kumho Ecsta V700 Feedback and Pagid Orange/Stoptech question
- Do we(A4s) have any options as to different final drives?
- Finally got off my lazy ass and finished up the WI install
- Xpost: Anyone know where the oil temp sensor is on a ATW dbw motor?
- Juan Mendoza (???)
- intrax springs opinion
- Are A4 head gaskets subject to failure?
- Happy Ending with boost issues 00 1.8T GIAC/Milltek (long)
- Has anyone done an S4 6-speed tranny swap on their A4?
- How to hook up 92 Corrado tach to the
- non-DBW vs. DBW engine differences?
- Bad noise while shifting.
- Now I have S3īs original wheels!!! My A3 looks great!
- i am looking for springs??
- Strange smoke...
- Ok guys, I need help diagnosing a problem. Car is a 99.5 1.8tq with
- Need a recommendation for a track biased street/track tire
- 88 90
- MONTREAL : Julep tonight (Tuesday, August 6th) -> Audi/VW meet!!
- Need Performance Parts sales help...Please help!...cross posted to A4 Forum
- For those who switch between Pagid Orange and non-Pagid street pads...
- interesting exhaust note: removing rear muffler does not increase noise at all >>
- High-flow fuel pump install in an A4 (somewhat of a How-to)
- Where can i find Itg CF air boxes..?
- XPost: Colony of Sea Monkeys discovered in Audi brake fluid...
- anybody ever put a 2.5l crank in a 5 cylinder?
- engine additives. fuel injector cleaners etc......what are the best to use to regains power
- Does it make sense to do an oil change between Quattro club events...
- 15w50 in the S4? Absurd or not? If so, what do you run and why?
- Final Gear Ratio..
- We have all seen the AEB & ATW 1.8T's , but I have purchased an ADR?
- Need suggestions for a decent spring compressor in the $40-60 range...
- more power for a 3.6l v8
- when does a v8 rpm sensor need to be replaced ?
- Selling APR CHIP W/ECU and exhaust for S4 any one interested
- SPP Intrax owners on S4
- weight reduction: my PC680
- Exhaust theory: Effect of muffler + Cats on Exhaust Pulse???
- GTG in Edison,NJ on 8/7 with Audi Performance & Racing
- question about suspension
- Crosspost from the A4 forum... anyone know any good custom muffler shops around Philly (m)
- Headers from Supersprint for A4's...Any rumors??
- pics of 255/40/17s (victoracers) on ET35
- Anyone know why Autothority S4 chip is so cheap...?
- Upgrade performance
- this is hardly a tuning question
- Latest update: Did I ever mention how much I love doing exhaust work?
- 1991 80 5cyl airbox
- Link to S4 forum: S4 with 19" Dronell VR (type II)
- 2002 A4 OEM Wheels and Tires for sale.
- Post from A4 forum on oil in trubo hose...please help!
