PDA
View Full Version : Performance and Tuning
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. 2.0 liter is in......more
  2. Need front rotors, would like cross drilled/slotted. Best VALUE?
  3. Transmission or Driveshaft noise
  4. slight install problem, please help
  5. Help with codes please!! (Im Stage 3) X-Post
  6. performance hp+lbs ft or stage clutch and flywheel
  7. Can the chip for a ko3 setup be modified for use with ko4s? . . . .
  8. installed an intake and (surprising)
  9. question for people with intakes...
  10. x-post from 1.8T forum
  11. Possible stretched head bolts?
  12. Check this out...water/ alcohol injection w/o a pump
  13. has anyone used this?
  14. torque issue with apr chip
  15. stasis solid motor mounts
  16. x-post from 1.8T Development
  17. update on blown motor
  18. MPX4250 Pressure Sensor for Boost
  19. gas milage with REVO?
  20. Newbie chip info?
  21. Jetex exhaust for 2.8 V6 (A4 or A6Quattro)
  22. xpost: poll on aftermarket clutch break-in period length
  23. CT/NY Audi Group "Spring" Gathering - Momentum Tuning, Wallingford, CT - 3/12/05
  24. Compression Test... all readings low and i already searched...
  25. 2.7 vs. 2.8 engine differences.
  26. anyone on heer have nay insight into this?...B5 x-post...turbo heat wrap....
  27. Anyone have experience with higher strength half-shafts and drivelines?
  28. what's the method for adjusting the fpr?
  29. what plug should I switch to if the plugs are "wet" looking and are
  30. N75J
  31. A4 3.0 in UK
  32. What are axle weights? And why are there so many different ones for one A4 from Audi?
  33. would there be any benefit to running one step colder spark plugs in my car?
  34. SRS Shine Racing Service B5 springs on a 1.8T A4 review
  35. HELP?! Battery drains while sitting
  36. Anyone here have the stock 1.8t IC-TB hose and dont need it anymore?
  37. Performed compression test on my 2.0T today, and was curious if anyone else has....
  38. German S2 race 100-313 in 26.18 sec.
  39. Cheap diy fuel adjuster
  40. suspension question
  41. Has anyone tried to swap an ecu
  42. mods for an a4 1.8t of 2000
  43. hoppen motorsports
  44. can this brake line be removed?/?????
  45. Source for rubber hoses/couplers?
  46. Paging xr4tic and other Walbro users
  47. i'm running the pc16 k04 file
  48. K guys <flame suit on> how tough would it be to make an S4 exhaust fit an A4?
  49. Hey does anyone know this person's email mrnitrous422
  50. power = P x L x A x N
  51. What is the part number for the TT 225 injectors that can be put on the B6 A4 1.8T?
  52. Tracking your 'every day driver'......
  53. Dahlback Tuning. Is it more "risky" of a investment then the more popular GIAC and APR that is more
  54. What does white buildup on the back of exhaust valves signify?
  55. My computer still works?
  56. K04 Dyno Results 2001 and issues......
  57. Dynojet Dyno at IDA Automotive in Freehold, NJ
  58. Who would be interested in Free/Open Source Mapping/Map Editing Software? (more)
  59. Question: Any Ideas how Dahlback gets 600+ HP out of a Audi A4 1.8T?
  60. Camber settings...
  61. AWE KO4
  62. paging audi2ptzero
  63. So how have you addressed the inside rear wheel lifting...
  64. My new year's resolution: Get rid of the MAF!
  65. Is it worth adding a HiFlo Air Intake to an A6C6 4.2 without also putting .....
  66. Stupid Q but: where to find 550cc inj? (550cc=55lb inj???)
  67. Who has dimensions for AWE DTS
  68. Idle problems
  69. Would I be better off getting a Vacuum gauge or a Water temp gauge.
  70. does anyone know where can i get Lemmiwink software?
  71. X-Post - Central PA Tech/Session - ACNA/MAC and APTuning Feb 12th
  72. Running j31 file and looking at injectors,
  73. will 01 fmic fit a 03 1.8t
  74. Adjustable Centre Differential (increasing ratio of torque to back wheels)
  75. Need HID bulb Xenarc 5,400K D2S.. anyone interested to sell?
  76. Finaly did some VAG logs
  77. Coilover Install
  78. APR Stage 3 install on a 2000 Audi A4.. NEED HELP
  79. Fuel Trims dont change
  80. N75 valve hose positioning... Help!
  81. Where's the big benefit of coilovers?
  82. Was wondering who has the best chip upgrade out there right now?
  83. GT3071R hardware in, Questions on DBC conversion?
  84. What else can I do to max out the performance of my K04?
  85. Question about wheel alignment
  86. Any of you guys know this fellow (Kevin. Gath)? Gathb5@hotmail.com
  87. APR pinging issue when transitioning from vacuum to boost under load
  88. Turbo Kits
  89. fiy carbotech has hawk blue race pads for the alcon type b caliper for 82$
  90. Anyone running an APR chip and K04?? Sorry didn't check the tech.
  91. Any of you boys here run one or two Quaife ATBs on your cars?
  92. Milwaukee AWD DYNO Runs $50 Today
  93. Engine power output without turbo?
  94. how efficient will my car run with a 45 degree coupler between the maf and air filter
  95. For future reference for all, please list any AWD Dynos for each state - more info...
  96. injector pulse is over 29ms, what's wrong?
  97. oil capacity question
  98. Anyone running a Full-Race 1.8T Header? Any other headers available out there? Installed pics?
  99. where do turbos cut into exhaust? after all headers are combined?
  100. GT30R turbo
  101. Quik Poll: Which Brand(s) of Sport Springs and Shocks .......
  102. What's the latest year model K03
  103. turbo timer users, how many minutes do you have yours set for?
  104. Stock Audi A4 with Plans and Questions...
  105. Best HP Increase and Upgrades for a lowly A6 4.2
  106. brake upgrade on a 99 a4 fwd 1.8t
  107. x-post: How can a n-dbw w/o maf and map tell that I exceeded max charge pressure?
  108. Are ther any affordable suspension ....
  109. anyone know the spring rate of the wastegate actuator on the k03/k04?
  110. X - post : My A4 parts for sale?
  111. Looking to get a a/f gauge that reads in digits. Other than Defi?
  112. Maybe a dumb Quest. but can B5 S4 calipers and rotors fit on a B5 A4 with no other mod than
  113. STUPID q'S......DOES AUDI HAVE A TUNING KIT LIKE DINAN FOR BMW
  114. Achtuning holiday special Free Shipping* on any item** until Friday 12-17
  115. What are some problems i would run into if I......
  116. Tubro Timer
  117. BRAKES
  118. X-Post: Is power limited in first gear?
  119. I havent seen this posted here yet...so...
  120. Much needed clarification
  121. Repost/X-Post. Upgrade 1.8T engine mounts.
  122. I gots a problem... I think.. 25psi w/ Stage 3. (2nd and 3rd)
  123. APR SUCKS!!!!!!!!!!
  124. those with a 2.8 5 speed on a 1.8t...
  125. 180 TT knock sensor question, searched and posted in TT forum, no help
  126. In the midst of beginning my newest project, I've had another idea I want to try......
  127. where can i get recaro sliders and brackets for my B5 S4 for cheap?
  128. Suspension Question - Audi-Eibach Eurosport springs w/ Bilstein HD's
  129. xpost:anyone have the compressor map and or excel sheet for a k04-15?
  130. X-Post...injector removal
  131. Great article on Sparkplugs (I felt the urge to share!)
  132. can i utilize a catch can on a dbw b6? iirc i believe i've heard i may not be able to b/c of...
  133. Car getting Dyno'd Wednesday, what kind of numbers will I be looking at?
  134. what kind of aftermarket exhaust can I put on an '04 A6 2.7T
  135. Streetwerke is now open for business.
  136. 3 inch SS DP with HFC is listed in the classified.....shoot me a message if interested...
  137. is there an ideal barb/nippl size for fast idle valves? brake vac?
  138. GT28rs on stock ecu
  139. Is "APR tuned" badge dorky?
  140. Is there a non - power steering rack available that would fit a U.S. spec A4?
  141. UPDATE on my Dalhback 2.0 motor and 420hp kit
  142. Bump.. Start to finish for my car. Year in review. New GIAC Injector program almost here..
  143. extensive comunication w/ TJM, hopefully a K04-23 soon........
  144. off clubb5.com, adjust timing via barometric pressure circuit
  145. Which turbos bolt up to stock 10vt manifold (89 MC)?
  146. Newbie question! GIAC vs. APR
  147. 1.8t Challenge Dyno plot
  148. Lookin' for a set of A4 1.8T injectors that are just a little bit smaller......
  149. i know many do not like BOV , but what about the hybrid one
  150. new project
  151. what is a bar (i know dumb question but)...i get that it is something flow related...
  152. Anyone know what Ford injector I could use that flows 270CC (at 3bar)?
  153. Good article on using lightweight crank pulleys...
  154. Im thinking about APR Stage 3, could those that have it please read
  155. Southbend make a good clutch? I need a clutch that will hold 340-50 awt
  156. 2005 A6 4.2 suspension questions - need help!!
  157. Single mass alu flywheel for 5cyl 2.2 turbo ? Does anyone make/sell them?
  158. B6 A4's starting to step up to the plate...
  159. do the 310cc injectors and a 3.0 bar fpr run rich on the pc16 file?
  160. 310cc injector question...
  161. Related to post below....Would individual throtle bodies be beneficial?
  162. Anyone use upgraded intake manifolds? (ie: Dahlback)
  163. 1.8T internals can handle this much power?
  164. What would a K04 TQM do in 0-60mph?
  165. 2002 3.0Q 6sp - Any chips out there?
  166. AWE heavy duty clutch kit for the TT
  167. Schrick Cams w/ KO4 set-up - Hit or Miss?
  168. 1st Rate Shop in Phoenix, Az Area?
  169. Has anyone ever rebuilt a 2.8 30v. Just wondering if it is even considered.
  170. upgrades?
  171. Braking...I'm talking track days here.
  172. 5bar FPR question
  173. When upgrading to the B5 RS4 intercoolers on a B5 S4.....
  174. New Angstrom Wheels Pics.
  175. 2004 S-Line chip tuning: Dahlback, Giac, or AWE?
  176. Anyone else ever have backfiring issues between 1st & 2nd?
  177. How to check timing?
  178. can i swap my t28 for a gt28rs?
  179. High octane fuel question....
  180. BPV to Before Throttle Body
  181. 1997 A4 Quatro automatic
  182. Is better head stud need for higher boost application?
  183. Spooling Characteristics of GT28r vs. GT28rs ?
  184. Water Spray on SMIC?
  185. Trans experts, opinions please.......
  186. just got shadetree VAG, what is normal knock sensor reading?...searched not much info
  187. X-post from B5, Can I remove the metal tube while changing Air Filter?
  188. ATTN - suspension guru's, help me out...(x-post from B6)
  189. Can someone please tell me what WOT means?
  190. Latest Edition Fast Fours n' Rotaries Magazine - LucasG Chips Article
  191. Suggestions for preparing a 1.8T engine for autocrossing...
  192. Status Racing composite racing seats now available at Achtuning
  193. Lost or Missing Boost?
  194. Dyno day at Yarrowsport in Providence RI.
  195. Crosspost: GROUP BUY: Buehn Engineering Hybrid Turbos!
  196. Has anyone put a 1.8T on a DYNO before and after a CAT BACK exhaust upgrade?
  197. people with aftermarket clutches
  198. What is the best EXAUST upgrade Down Pipe Back for my TT225
  199. Euroclass KO4 Beserk Upgrade Update - Including PWR Oil cooler and ECS UDP - LONG POST
  200. Will the APR K04 transverse program work with a longitude A4?
  201. BOost cut?
  202. anyone have a used t-28 chip(ndbw) for sale?
  203. OpenECU
  204. anyone have or know where to get compressor maps for a GT28RS and a KKK K26?
  205. Update: Car is now in the shop getting the Euroclass KO4 beserk kit installed
  206. Anyone know of a seq. tranny for the b5 a4's? True seq, not tip
  207. Anyone know the exact turbo APR uses int the A4 Stage III?
  208. My experience with AWE Tuning
  209. NE1, please! RESISTOR SIZE, AIRBAGS FOR STEERING WHEEL AND REAR SEAT.. 01avant....
  210. DIY Fuel Mixture kit?
  211. Stage 3/T-28 Forge BPVowners: What spring shim combo are you using?
  212. Z-flow fmic good for K03 and eventualy K04?
  213. Question about stage 3 (apr) or T28 on a tip...
  214. Euroclass KO4 Beserk Upgrade Kit - Here is a pic to wet your appetite
  215. injector pulse, fuel pressure and mpg calculation
  216. Question about I/C tubing size in connection with RS4 I/C swap...
  217. Bizarre ... KKK K26 electric turbochargers
  218. VOTE!!! Help Motor Trends R28 Win!!!
  219. with a boost gauge what level of vac should I be seeing at idle?
  220. X-Post: Help with Clutch
  221. correct me if im wrong but i think i may have found something useful
  222. catch can install pics....anyone?
  223. Paging x4rtic or anyone who has 30V V6 ECU harness layout
  224. Can someone explain the concept behind a catch can?
  225. been driving around with my new k04 install...some issues..
  226. Please tell me that this is in no way a gd design for routing IC piping
  227. Stage three problems resolved.
  228. does anyone know where drag coefficents for audis can be found?
  229. More info on UDP's for comment
  230. Kinetic Motorsports A4 exhaust manifold question...
  231. Audi Certified Service, Repair, Performance/Tuning in NJ
  232. Anyone know if there is a way to decrease the sensitivity of the DBW throttle?
  233. OT: Anyone have contact info for SKS? e-mailed him several times with no reply.....TIA
  234. Cars only peaking 16 and holding at like 14 or 15 with APR1+ I think i should have more Boost!!
  235. Yay! KO4-15 finally arrived w/5bar FPR & Gaskets, ECS Under Drive Pulley & PWR Oil cooler
  236. Anybody have this wideband?
  237. XPost - Eddie (formerly) of South Bend
  238. Another gearbox question, except it's about Tip. Does anybody know how modular they are?
  239. Wise ones of the tunning forum, information please.
  240. need some help on fueling after timing advance
  241. Advice on Clutch... X-post
  242. Would appreciate some upgrade advice. (more)
  243. best place to order a sport k04. not the kit jsut the turbo..
  244. TT Clutch?
  245. Lemmiwinks FAQ?
  246. Yay!!! Oh happy day!!!
  247. I want to go big turbo: Need some direction/advice.
  248. has anyone treid to put a old 5 cyl 20v in an a4?
  249. Least cost source for new/rebuilt K03 needed...
  250. X-Post SouthEast PA - MD - DE ACNA Dyno/Day Sat Nov 20th
