PDA
View Full Version : Performance and Tuning
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. 2006 Audi A4 2.0t turbo underboost. Wastegate loose. Help.
  2. Remap my Audi A7
  3. Possible boost leak with this setup?
  4. ?Thunder123?
  5. RS5 Tuning and Upgrades In Philly area
  6. OBDEleven coding for 2014 Q7, 3.0T
  7. Audi Q7 2012 4,2TDi CCFC ChipTuning.
  8. HPFP Lobe Lift Dimensions
  9. Best catch can ever?
  10. IS APR REALLY THE BEST OR IS THERE A SHOP IN USA THAT CAN MAKE BETTER NUMBERS ON A CU
  11. Lithium Battery upgrade and energy management system
  12. (CH3OH)+(H2O) Injection?
  13. Intercooler
  14. Anyone familiar with REVO performance and can identify parts?
  15. Is 19 psi to much on a 1.8t?
  16. AWE?
  17. Does a tune void ext.warrenty?
  18. E85/ jb4 tune
  19. Audi Steering wheel
  20. Dual exit conversion ... (B8.5 A4)
  21. fuel injector O ring leak 2018 TT RS
  22. Audi A1 2012 LED Puddle lights?
  23. Audi V8 twin turbo S6 S7 A8
  24. Michigan (not Tokyo) drifting :)
  25. Boost sensor location
  26. Upgrade turbo question
  27. 2016 A5 2.0 TFSI. Tune ?'s
  28. Best Audi motor for a Boxster racecar swap?
  29. 2004 a6 stalls in drive not reverse
  30. 2006 A4 B7 CVT transmission filter service
  31. Magnaflow cat back exhaust
  32. APR AOK?
  33. GIAC Engine and DSG Tune First Impression
  34. ECS Non-resonated Valved Exhaust Questions
  35. Weight reduction without losing interior
  36. Need help with my Chipwerke
  37. diverter Valve delete or by paaa?
  38. 2002 Audi A6 2.7T upgrades??
  39. Overboost or no?
  40. 2004 audi tt quattro 225 drag time issues
  41. 2015 A5 (B8) Exhaust
  42. 98 audi a3 speed sensors connection harness in diagram
  43. 2001 B5 S4 (Eth 4)
  44. 2013 A6 C7 side assist Einbauanleitung?
  45. 2013 A6 C7 side assist Einbauanleitung?
  46. IE compatibility with APR
  47. Tune without TD1 flag
  48. 2010 Audi Q5 Glove Box Removal...
  49. Reverse Engineering a Tune
  50. Need help! 1.8t coil pack conversion!!
  51. A4 1.4 TFSI vs 1.8 TFSI
  52. SI: Tuning: 2.0 TFSI vs. 3.0 TFSI?
  53. 2018 Audi A4 MMi audio sound unavailable
  54. Code out 2003 C5 SAI?
  55. Injector swapping/ upgrade
  56. Bang-for-the-Buck to mod...which NEW Audi?
  57. Heat insulation downpipe and cat 1.8 TFSI
  58. What can I do to make my Q7 better?
  59. A6 3.0 muffler delete
  60. Aftermarket exhaust install question
  61. Armytrix exhaust for ‘15 A5 Quattro coupe 2.0
  62. 2010 Q7 High RPM in low gear
  63. Clutch advice for 3.0tdi
  64. D3 A8L 6 Speed Manual Swap
  65. 2009 S4 Jerking
  66. 2014 RS5 Differential Replacement
  67. Nube understanding about performance upgrades
  68. 5.0L V10 cylinder firing angle
  69. mtm meanin ?
  70. What's the best exhaust system for a 3.2 V6 FSI?
  71. Check engine light on after installing chip
  72. Newly installed Magnaflow Mufflers
  73. Increase engine power.
  74. How to.get more powwer out of 2008 audi A6 3.2L V6 avant
  75. C7 A6 TCU Tune
  76. Usa style parking lights
  77. '16 A3 Downpipe
  78. Loud exhaust note
  79. Lack of power
  80. I need advice
  81. Loud Whining Sound When Super Cold Outside
  82. Audi A4 exhaust sound?
  83. Emission code 0171
  84. Audo Q8 ECU Tune
  85. SQ5 Supercharger Pulley?
  86. cutout
  87. Stage 1 APR tune for Audi A4?
  88. 2004 A6 O2 Sensor Slow Response
  89. Help with flashing gearbox ecu needed
  90. JB4 Piggyback tuning on an B9 S5
  91. Audi A4 Auto ALT 2.0 2006
  92. Will the gearbox handle it?
  93. Valet Mode??
  94. Am I chipped?
  95. 2012 Audi A2 2.0 Mileage/Turbo Lag?
  96. correct chipwerke harness number for Audi A7
  97. Remap??
  98. Android Auto and more in 2005 Audi A8 D3 with MMI 2G High infotainment
  99. 2004 Audi a4
  100. Audi A6 C5 Very slow uphills
  101. How do get an s5 sound from my a6
  102. 2009 Audi S5 Performance Upgrades
  103. 2010 Q5 sport mode question
  104. S-Tronic Question
  105. Looking for RS7 style honeycomb fog lights grilles for 2012 A7
  106. 2015 Q7 - PedalBox question
  107. aftermarket filters 1.4tfsi b9
  108. Careful doing business with JH Motorsports!
  109. SALE ALERT! 10% off ECS Exhaust Cutouts + FREE SHIPPING
  110. best Variable valve exhaust for 2017 a6
  111. 2002 Audi A4 3.0 Quattro Running Rough
  112. ECU flashed tune and TD1 mark on dealer (void waranty)
  113. Will Audi void my warranty if I bring my S4 in for an oil change due to Stage 1 ECU?
  114. K&N air filter on B9 series
  115. Audi A5 1.4tfsi 2018 DTUK tuning
  116. Buying A4 B5 or B7 1.8T for tuning (K04)
  117. 2000 A 6 steering issues
  118. DTM BWE PERFORMANCE ISSUES
  119. Exhaust upgrade for my 2017 A7
  120. Original software for A6 2.7T engine
  121. Fitting Audi 80 B4 engine head on B3
  122. Vacuum issue?
  123. hard starting when cool
  124. Audi A5 2.0 TFSI S tronic ECU remap
  125. Audi A5 2015 2.0 TFSI (S tronic) ECU remap
  126. APR Stage I for B8.5 CVT
  127. Audi parts specifications
  128. Best performance chip upgrade for a 2014 S5 Cab Prestige 3.0TFSI
  129. What would Uncle Jessie do?
  130. how much hp does a k03 push on low boost
  131. S3 or A3+ECU reflash?
  132. Can an intake manifold be damaged during a routine service maintenance?
  133. AŁ aircon failure - please help?
  134. Strange Dyno reading PLEASE HELP
  135. A6 BiTdi Tiptronic to DSG Transmission swap
  136. AUDI A4 B5 1.8T V5 TUNED
  137. 2003 Audi A4 Swapped 2.7t V6 Slipping with 18psi of Boost
  138. A3 2.0 TDI Missfiring problem! Please help!
  139. Best simple bolt ons and air cleaner for ‘17 RS3
  140. APR Stage I ECU Update & Stage II dual Pulley Install + TCU Update!
  141. SALE ALERT! HPA Motorsports Turbo Upgrades, Big Brake Kits, and Coilovers up to $195
  142. APR Stage 1 Tune for 3.0T - For Sale $850
  143. Audi SQ7 4M Speed Limiter Removal
  144. 2018 A5 SB exhaust suggestion?
  145. S4 B5 600-700HP build, Need help!!
  146. A6 c5 034 Bosch 40 upgrade
  147. APR Tune or other?
  148. Is there a SMF for audi A5 3.0 tdi quattro?
  149. Is is possible to put a transmission of a8 4.2 in a6 3.2 car
  150. CVT Transmission Fluid / Filter Change
  151. 2012 vs 2014 A4 0-60 discrepancy
  152. How to make audi a8 faster?
  153. 2018 A3 Unitronic Stage 1 Tune...
  154. Abs coding
  155. VERY LOW MPG 2015 Q5 3.0T
  156. RS4 intermittent cut out problem
  157. Help resolving P0303 Cylinder Misfire
  158. Tuning software
  159. getting very less Miles per gallon for recently bought Audi A4 2015 pre certified
  160. Audi A6 3.0T Throttle Issue
  161. Rev-matching downshifts on a 8-speed Tiptronic gearbox
  162. Help with vacuum tap on B7 for boost gauge
  163. Q5 timing belt replacement at 82,000
  164. Dyno a Quattro, Linked or not
  165. motor oil and petrol
  166. Best Performance Upgrade for a 2011 B8 S4?
  167. 2011 Q7 won't drive
  168. ADVICE PLEASE! GIAC Software... Worth it?
  169. audi a4 b6 avant
  170. C5 A6 Allroad 2.7T
  171. Big boost issues
  172. Might buy a '01 a4 2.8L v6
  173. Exhaust fitment
  174. New Member here, searching for info on Boosted Euro in New Jersey
  175. Ownership
  176. AFE Scorcher GT Module 2.0TFSI
  177. Audi A7 throttle body upgrade, need help
  178. Captain Obvious - Spark Plugs
  179. Buying CPO - advice and tune question
  180. 2007 Q7 Camshaft Position Sensor Location and Replacement
  181. Best performance upgrade for 01 Quattro 2.8?
  182. Evap small leak code P0456
  183. Audi C5 Tuning compilation video! Check it out!
  184. Calling all CVT or general Audi Gurus...click if you know your stuff.
  185. 1998 Audi A4 Quattro 2.8
  186. Redtop 2.0t coil kit with icm delete for 98 a4 b5
  187. Transmission issues b8.5 after tune
  188. Transmission choices
  189. 2006 Audi A4 with rpms dropping stalling and slight shaking
  190. Gear Shift
  191. Audi Steering 2014 A6 or any Audi with electronic steering
  192. CEL issue
  193. Best Audi Quattro moments! Great power! Video.
  194. Hard, jerky shifting in Audi A4 2.0T
  195. AUDI A4 Concert Navigation and Handsfree
  196. Slow acceleration, no faster than 10 mph
  197. A7 S/C pulley slipping?
  198. Tcu a6 c5 can bus code 01196
  199. P003
  200. 2013 S4 - Sports exhaust
  201. Launch control excessive wheelspin
  202. *New Owner* Help Making 2009 Q5 faster
  203. Emissions
  204. Need help installing Neuspeed Power Module
  205. Going from NA to Turbo on 3.2 v6
  206. Help needed urgently
  207. In House Tuning
  208. New here - 2011 A6 3.0T
  209. AUDI 2011 SUPERCHARGED 3.0
  210. Audi 80 B4 how to make second compartment?
  211. Q3 upgrades
  212. Mixing oil for optimum performance
  213. Chipped 2.7T ECU, swap across models?
  214. [Poland] Online Tuning Shop
  215. Audi A6 Power Steering Problem
  216. 2017 A4 performance chip
  217. ECU REMAP
  218. Change A7 exhaust Sound
  219. A4 B8 t04 style big turbo
  220. 2018 A5 exhaust
  221. APR Tuning for a 2016 S7
  222. Codes p0243,p0444,p2294,p2400
  223. 2014 A8 TDI tune help!
  224. New to forum ?s
  225. A7 - Chipwerke Pro Piggyback- TD1?
  226. TURBO LAG VS THROTTLE
  227. Audi A4 B7 Avant Quattro 2.0T inlet cam, tuning capabilities.
  228. A few questions around S/D, throttle kickdown and dynamic mode
  229. a4 b8 2011 manual trasmission chipping question
  230. A4 B5, Giving Codes P0171 & P0174, No CEL
  231. remap my a5
  232. Live Data Boost Profile
  233. SnorkelCharger™ Climate Change Intake System
  234. Stutter/jump/misfire problems
  235. New Owner - Dinantronics Tuner?
  236. Running out of breath!
  237. Running out of breath!
  238. New here! Audi Q5 (8R) Grille question
  239. 2009 Audi A4
  240. Indicator issue
  241. Power Steering leak
  242. Race chip for 2013 s7
  243. Diesel glow plug flashing and emmisons light on
  244. ignition coil replacement didn't work?
  245. Car idles rough after CAI install NEED HELP
  246. Stupid question, but maybe not
  247. Audi a4 1.8t upgrade
  248. Manual boost controller
  249. Exhaust up next. Looking for opinions
  250. Best clutch for reliability, Daily driving and Daily abuse
