PDA
View Full Version : Performance and Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. Looking for cheap 6 cyl A4Q - body damage/high miles no problem
  2. New Hi Flow Hi Performance Exhaust manifold for Garrett Turbo
  3. Does anybody know where I can get CAM2 leaded gas in the White Plains, NY area?
  4. Anyone have specs for Pagid Orange pads?
  5. Anyone know what the throttle valve controller is and what may cause it to malfunction?
  6. opinions on intercoolers. SPR and EVO fmic?
  7. Congratulations to all the AWE Tuning winning cars!
  8. Need info hooking up Autometer Tach to 1.8T motor
  9. For anyone looking for head studs on a 20V (4 cyl) or 30V (6 cyl) motor....
  10. Joe (zyxt) I saw an earlier post about you graphing some measuring blocks....
  11. Where can I check to see what........
  12. Can you guys help me with a few questions regarding PSS9 installation (xpost from TT forum)
  13. Torque Wrench basics - store clicker-types at a low setting
  14. X-post on air intake questions. any and all info appreciated TIA
  15. a question about spooling...(more)
  16. Altitude questions....does your boost/vacuum change when you are 1000ft up, or at sea level?
  17. EGT gauge for a 2.8L 30V (& other gauge questions)
  18. When a Jack Stand is rated to hold 2 tons - is that sufficent to hold my A6 on one side ...
  19. is a custom exhaust good for a 3.0 a4?bad?
  20. Boost Gauge Reinstall - Need help from the smart guys please. (X-Post)
  21. X-Post 12v Help Please
  22. Opinions on Mobil-1 5w30 fully synthetic (Trisynthetic)?? How bout vs. 5w30 new formula?
  23. Help please...
  24. anyone running a Tec-III EMS?
  25. Is there any benefit of tying a SPAL fan to a SMIC for additional airflow across it?
  26. anyone ever run the N-75 & a Boost controller in parallel
  27. Surprising results of Evo magazine's tire test.......
  28. First data on the Wilson Manifold and TB mod...
  29. Juan You have Email re Shipment.
  30. Bilstein Sport Struts..Self adjusting or adjustable?
  31. Help: Loosing Boost
  32. How helpful can VW Tool and OBD Tool be for an Audi ('01 S4)?? With a VAG-COM cable.
  33. Anybody have instructions on removing clutch master cylinder?? Need help
  34. I read that the Hyundai WRC car uses a 5th injector at the turbo inlet to spin the turbo...
  35. Are you sure you want your intake that low?
  36. Anybody got any ideas for performance parts for my Audi 5000 turbo quattro with the MC engine
  37. Anybody have an opinion on running AMSOIL 0w30 in a TT? or the oil itself?
  38. mechanical illiterate in New England
  39. For Auction: DEFI HUD Boost Gauge and Turbo Timer kit
  40. 02 A4 Suspension Experts or People With Experience.....please help(more)
  41. will I get any performance increase from a new o2 sensor
  42. Possible problem with S3 1.8T (non-DBW)
  43. installing my big turbo very soon. . .
  44. just had an engine/turbo swap also installed an apr chip now i have a studder when taking off, help!
  45. location of the speed sensor wire on the instrument cluster.
  46. GFB Blow Off Valve - nearest dealer
  47. FS: stock duel innercoolers off of a 225 quatro TT
  48. Alright guys, I need help. I have had SIII for about 3 weeks now and the clutch is now starting to
  49. MIDNIGHT CAR AUDIO & PERFORMANCE ACC.410667TINT
  50. ECU questions....
  51. 12 valvers, I GOT A GREAT IDEA, we'll smoke all the little turbo freaks...
  52. My next mod will be the installation of a Neuspeed manifold,custom downpipe and
  53. Anyone raced Honda S2000? Had a good go here!
  54. X-post on the install of the modded manifold and throttle body...
  55. I'm set on the bilsteins but eibach or H&R?????
  56. The latest pics.......
  57. CEL back on......does "misfire detected cyl 1" mean that i'm running on 5 instead of 6cy
  58. Just got a great intake and throttle body job done!
  59. Ok, only sort of performance related but what is the website
  60. Thoughts on using a 996TT intercooler on an A4 1.8t? 50% cross sectional improvement...
  61. You know what the best part of having SIII is?...............................
  62. how much is it to p/p a 5cyl head
  63. Fuel Additives?
  64. How to troubleshoot the Wastgate or N75 valve problem?
  65. S4 Chip Please help
  66. Spec Vs Werks Of Art ..........clutches.......
  67. Anybody with 8E modifications?
  68. a4 2.8 engine enhancements?
  69. Go Fast Bit BOV.
  70. HID Conversion Kits - Hella / Philips
  71. Misfire detcted Cyl 1 w/new mods CE light.HELP??!!
  72. NEW PICTURES!!! (Audi R4R back in action,...)
  73. any thoughts on Oil Accumulators?
  74. A4 R4R is rolling again!!! =)
  75. Difference between air-to-air and liquid-to-air ics?
  76. Whose got a battery mounted in the rear of their A4?
  77. xpost: vag-com question ...
  78. Kindova tuning article I just posted in S4 Xpost
  79. EEEEEEEEEEEEEEEEEEEEEEET'S ALIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIVE........
  80. one more time......t-28 turbo 4/s
  81. need hi flow cat help... cross post..
  82. can you remove the front differential of a 4wd vehicle to make it rwd?
  83. When i re-do my suspension what is everything i should do
  84. Place to buy MAF for 2000 Audi A4 online? Fair price
  85. Got an oil change from Jiffy Lube..ended up costing me $101.00..
  86. Can someone explain backpressure, and differences between different exhaust sizes?
  87. Ok here is a tough one..How do I make my 99 A6 Avant oversteer on Throttle.
  88. Radiators, & oil coolers..
  89. Going to Shine Racing to debug ongoing boost struggles
  90. need help 4 tune up;spark plug gap
  91. APR Stage III install part 2 (long)
  92. which red LEDs match our dashes??
  93. Plugs
  94. does any one know of a temp gauge that will monitor two temp sources??
  95. GIAC X-Chip 225 TT
  96. woohooo! ~200miles on 1/2 tank of 93 running between 80-95mph on the highway.
  97. APR Stage III install, part 1 (long)
  98. T-28 FOR SALE
  99. What's the gap setting for supercharged A4? .038?
  100. Air intake charger w/ Vortex Booster
  101. at Avant Fest yesterday, rode in Todd's AWE "ROCKET" Wagon..unreal
  102. Anyone with experience on Neuspeed's K04 upgrade for TT 180?
  103. My A4 is back from PES after chip problem..the now has ass!!!!
  104. GIAC chips made by Garrett..Same company that makes the detectors at airports??
  105. What will happen if I retain stock chip after I install K04 in my TT 180?
  106. If I change my spark plugs what kind to get and what tools needed ('98 2.8 A4 55K mi.)
  107. I have a 99 A6 Avant with a stock exhaust..has a very annoying humming noise..
  108. GFB valve installed. X-Post
  109. I'm going to roll fenders this weekend...to make way for 235-40-18 on a 8.5 rim and 30 off set.. ...
  110. Blown turbo hose club..
  111. A4 Apr stage 3 owners, interested in wategate upgrade
  112. did anybody put a rear sway bar for an a4?
  113. Question about A/F ratios & "Enrichment"
  114. Oettinger Body Kits / Corbeau racing seats / custom Graphics
  115. How much boost should I be seeing with APR Stage III?
  116. APR Emblems??? Where are they?
  117. Hp potential for the 2.2l turbo engine?
  118. I Really need help
  119. am i the only one who has their neuspeed sway bar set like this??
  120. Has anyone removed the center resonator only for more power?
  121. what is the diameter of the 'high flow' cat used in the APR stage 3 kit (longitude 1.8T)
  122. Suggestions on oil for my 99 1.8TQ
  123. Anyone selling exhaust for 1999+ A6????
  124. Anyone have a used ABT chip/ECU for sale?? - for a 2001.5 S4 M-box. TIA.
  125. S4 tip tranny in A4Q 1.8T tip?
  126. 12 seconds!
  127. Looking for S6 type lower grille for my 99 A6 Avant...anybody?
  128. HELP:have all my pieces now(SPP DP & Milltek)lots of clamps.Do I have to weld this connection?
  129. Thoughts on clutch upgrade for TT.... What would be a "fair" price for install.
  130. Knock sensors going haywire?
  131. after market SPECIAL oil filter worth it or now
  132. Anyone know any good twisty roads around Melbourne, Australia? Ta.
  133. NOS !?
  134. how do I check if my rear differential still has oil in it??? NEED HELP
  135. Mobil-1 0w30 is NOT claiming ACEA-A2/A3. How bad is it?
  136. Tuners in the tri-state area
  137. K04 problem
  138. are slotted drilled rotter worth spending $200 more on roters then the 40 oems cost??they are used o
  139. pod size for 60mm gauge? 2-5/6 inch diameter pod?
  140. I need good cheap sloted roters.. where should i get them
  141. tested the top end of the apr non dbw program v3.1a.....142mph not bad @ all....
  142. ARGH!
  143. K04-15 going rate how much easy to install ??? upgrade program?
  144. whats the highest performance(highest boiling point) brake fluid available?&&
  145. APR Snub Mount installed!
  146. HELP GIAC CHIP PROBLEM!!
  147. 4.2liter V8: A6 vs. S6
  148. some info on misting the Intercooler with water to reduce intake temps
  149. some info on Water Injection & how to build a kit
  150. Refigerated Air/Water Intercooler
  151. Need a little input on a suspension issue please. I have C/O's on my 1.8t and after ~6k miles I find
  152. Mobils website suggests 15W 50 for turbocharged engines..
  153. Rebuilding the Forge BPV (as requested)
  154. Curse you ATP!!!! (another reason why my car isn't running yet)
  155. Questions about Borla Exhausts
  156. exhaust shop in LA/OC
  157. Throttle error codes
  158. attn: Pelican Blue-T28
  159. Potential problem with RS4 clutch install......need feedback
  160. Audi Tuning ZURICH (CH) - HELP!!!
  161. Hey CharlieG, how did you mount your JAZ oil breather?
  162. erm this is second time. with some corrections...
  163. octane booster .. anything recommended? good? snake oil?
  164. a4 people with boost gauge and 1bar chips. what psi/bar when crusing @ 85mph?
  165. some help guys... some maths dilema
  166. Need some help.. Im going to relocate my battery to the rear of my car
  167. xr4tic... I thought you might be interested to hear this..
  168. Rio NightRacer Movie - Shoted inside a 280HP RS3!
  169. I know some of you guys have opened up the engine to do work. Does anyone know what Audi uses for
  170. Mintex Brake Pad Question?
  171. lame VAG question - help please
  172. FOR SALE 2000 S4 GIAC Chip, 80hp increase.
  173. would there be any interest in a Side mounted "Air to Water" Intercooler for the A4 1.8t?
  174. Looking for Abt .8 bar chip experiences? i'll take the good and bad
  175. What happened to vortrag?
  176. multitronic?
  177. Swaybar questions
  178. Another small update: Timing belt is on!
  179. need MORE HP for 1.8T...ideas? help?
  180. Any advice on installing an adjustable fuel regulator on a 12v 2.8
  181. NE1 selling 19mm Neuspeed rear sway bar?
  182. Roar intake/hypercharger reviews
  183. K04 problems: graph of requested vs actual boost
  184. Total clutch failure? I say yes!
  185. MC1 vs MC2
  186. Any mods that can be done to the throttle bodyto add HP?
  187. Audi Rally Footage!!!
  188. Exhaust sound clips.
  189. Removing Cat?
  190. JUST RETURNED FROM PES TUNING...SUPERCHARGER INSTALLED...HOLY S..T!!!!!!
  191. Anybody know the procedure for rebuilding a Forge BPV?
  192. Fuel Pump (5000T for use on a 4k Q?) --> New TO Group =)
  193. Ignition
  194. what are the tuning options for a 91 200 quattro? where?
  195. six speed conversion complete
  196. Does anybody know if there is short shifter for '95 90?
  197. Alright... I've been gone for 2 weeks... is the x-chip available for the 2001 A4?
  198. How many people interested in a 350HP+ kit for 1.8T?
  199. Introducing Achtuning!
  200. newbie question: does using spacers on your wheels compromise the axle in any way?
  201. Hey guys, does the oil pressure in the 1.8t ever go above 80psi?
  202. APR Stage 3
  203. how many here have experience blown struts on their h&r coilovers? how?
  204. Fooling the ECU to run larger injectors by using a bigger MAF housing.....
  205. we are weak and insecure
  206. does anyone have a list of Intercoolers?
  207. Just Finnished BPV Testing.
  208. Crap, limp mode again
  209. Block 138 -- Engine Status @ Misfire
  210. Anybody out there test the GIAC chipped '02 1.8T on an engine dyno? TIA. :)
  211. 2000 A4 with GIAC and Milltek boost issues resolved! (long)
  212. tornado fuel saver
  213. Flywheel question.....
  214. springs
  215. *FOR SALE* PES G2 sc
  216. 1.8T engines differences
  217. Bigger Brake Question
  218. UhOh - Troubleshoot boost problem please (long-xpost)
  219. My stock injectors are petered out (I THINK), HELP!!
  220. paging Lucas (GFB Hybrid BOV)
  221. Stage III need clutch suggestions/updates
  222. what should i use to clean the turbo? i want to use the intake side as a paper weight.
  223. Stasis coilover feedback requested
  224. Spark Plug Confirmation
  225. GROUP BUY --> Tanoga Short Shifter from A.W.E. Tuning
  226. My KO4-25 turbo for the 1.8T is for sale...
  227. UUC shortshifter question!!!
  228. What sensor inputs does the ECU use in Open Loop Mode?
  229. Forged Pistons - are they all the same ? (size wise)
  230. '98 a6 2.4 want more speed
  231. WTB: Bilstein shocks for A4 Quattro
  232. Atten: LarryTT & blueshirTT (+ anyone else willing to help): need VAG readings
  233. anyone know where i can buy 60mm omori egt guages? preferably metric. ??
  234. is there a site listing dtc's? numbers and descriptions?
  235. Anyone have a good source for Stock A4 sized cross-drilled rotors.
  236. Update on GIAC chip w/ Forge Milltek
  237. Yet another 2.0 conversion update.....
  238. Is anyone else running the FMIC X-Chip for the 225 TT? I've got a few boost questions...
  239. 5 lug conversion
  240. neuspeed exhaust
  241. how do i know what program i am running
  242. Well....Stage 3 in a TTQ is a reality...
  243. Quick! Anyone know the torque specs for APR's lightweight flywheel?
  244. motor swap question
  245. xr4tic - what's up with the motor?
  246. AUDIBOY: you rode in a apr stage3 with a cone intake?
  247. FS manifold $75 Neuspeed chip $75 Greddyboost
  248. Chippinp the A8
  249. Plans for GIAC DBW K03 "X" chip - also CMH question
  250. who makes the best DV for a 99 1.8????
