PDA
View Full Version : Performance and Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35
  1. What does the term "setback" mean in reference to an alignment?
  2. Getting APR Stage 3 installed on my TTQ on thursday..
  3. need to upgrade tranny, help
  4. OK all you PES G2 owners read on!
  5. Does anybody know the CFM for the 8E intercooler? Or the CFM B5 intercooler.
  6. anyone tell if i installed my bpv hose incorrectly?
  7. How bad is it
  8. Has any one installed a BMC carbon fibre air box?
  9. How to make a non-turbo 1.8 A3 faster?help
  10. Adjusting my H&R Coilevers
  11. 40 horsepower chip fpr a 2.8? I read...
  12. Mintex brake pad question
  13. Just tryed to install boost gauge, boost isnt reading...
  14. New web site for So. Ca. Audis/VWs
  15. I think my Bailey DV is bad, replacement options? (Long)
  16. apr stage 3 gt turbo to t28
  17. Xpost ~~~~~~Phoenix Group Drive This Saturday the 18th up to Prescott~~~~~~
  18. Anyone know the size of the stock 1.8T throttle body? Also, how big is too big?
  19. Can someone tell me the thread size for Audi wheel lug bolts? M14 x 1.5? TIA
  20. cmh: your ultra lite autometer guages .. what colour is the lighting? how are they lit?
  21. Apexi - any cheap place out there to buy?
  22. xr4tic... What are your impressions of the ATP manifold compared to the stock one?
  23. Forge-Milltek/GIAC impressions
  24. S4 springs and shocks on a 2002 A4 1.8t - please help
  25. Shock and springs for everyday use
  26. Definitive (hah!) synthetic oil thread...
  27. @$#&! JE sent me the wrong piston pin locks.....
  28. APR snub mount success!! EASY!
  29. URL's for the PES and APR kit owner's forums...? Thanks..
  30. Motoroil VW norm 503.00 and 503.01. What's the difference??
  31. better ultimate handling, A4 Quattro or TTQ?
  32. Anyone ever sit in the Recaro Pole Position seat?
  33. VDO boost gauge calibration?
  34. cmh: which egt gauge did you go with? and where did you tap it? tia
  35. Getting excited to chip my car '98 A4 2.8 sport tip. Which ECU to buy??
  36. Aftermarket tachs. What and where did you wire it to? I am using a SPA wired into the
  37. Where can i find ECU for 2002 1.8t other than dealer
  38. "Some assembly required"
  39. Need help understanding alignment specs
  40. i find myself constantly revisiting this issue .. apr stage3 or pes t-28
  41. anyone ever get a dyno run on a pes t-28 .. w/ or w/o race cat? w/ or w/o aftermarket exhaust?
  42. Rally type sport suspension options?
  43. Forged pistons
  44. Anyone running APR aluminum flywheel with AWE DTS?
  45. Anyone with G2 (and Tip) in Bay Area?
  46. Has anyone taken off the exhaust side housing of a K0X turbo?
  47. Changing my injectors today...any thoughts, concerns...
  48. Stupid newbie question- is putting in a GIAC Tiptronic Chip "plug & play"
  49. 02 A4 brochure lists oil capacity as 4.2 liters.Would this mean the oil pan is larger?Could a swap
  50. Question about lightweight batteries
  51. Will the Audi/Remus exhaust fit on a Borla?
  52. help.. questionable tranny.. with sapposely a quaife
  53. Engine Mods
  54. ?Fuel Pump and Injector Question?
  55. 2.8 exhaust?
  56. Six speed Trans for the A4 has the guy finish that project with the S4 trans?
  57. Removing the ECU chastity belt? I was told you have to break the bolts off and drill but I find
  58. anyone DIY apr stage3 install?
  59. which T3/T4 for 1.8T?
  60. CASTROL SYNTEC VS MOBIL 1...OPINIONS??
  61. Small update on the 2.0 conversion......
  62. K03 Compressor Map - Does anybody have one?
  63. PHOENIX MEET~~~~~~~~ Saturday May 4th at 5:30pm~~~~~~~~~~~
  64. Any Websites That I can buy or Hear Miltek Exhaust?
  65. are there any DIY ways to boost my hp???
  66. Anyone consider anything other than the Turbo XS bpv as the top performer?
  67. Hi, anyone know any tuner that makes tip chip for Porsche 993?
  68. Grooved Bilstein settings - archives have several opinions
  69. fs k04 turbo
  70. Spring/Shock/Swaybar combo Advice sought
  71. Dropped the front left of my S4 w/o wheel on for
  72. Modify '02 A4 3.0Q
  73. RE-POST OF Neuspeed exh info for GB.
  74. aftermarket EMs? ATP, APR (do they sell only the em?), pes? any others? (1.8tq)
  75. Trying to find high quality exhaust flex joints
  76. FPR - where did you guys hook it up?
  77. My intake set-up.
  78. Finally got my new manifold prototype (pics inside)
  79. Neuspeed exh...Sorry for all this confusion..Called and finally have all info correct.
  80. somtimes you need to get your whole body into it...
  81. Neuspeed exh...Here is Pic...Supplier was in ERROR.. S4 2 tips-A4 1 tip...
  82. VAG tool wanted ?
  83. Anyone have instructions/FAQ/Bentley's for a clutch install on a 1.8T QMS?
  84. tire reallignment
  85. suspension
  86. Neuspeed exh...BOY THIS IS A KICKER !!!!!!!!!!!
  87. Neuspeed Exh-More info, we are getting close to lift-off.
  88. Has anyone considered putting Gt25 turbos on thier S4 yet?
  89. I would like to Recommend a Audi specialist in NYC
  90. Neuspeed Exh Update as of 1PM Eastern
  91. 2.8 air box mod.
  92. audis race history
  93. Need help choosing a4 2.8v6 exhaust system
  94. Boston Audi Dyno Results
  95. emissions?
  96. Semi OT... looking for good performance mod for g/f's miata..
  97. Help - the unstoppable vibration
  98. Xpost regarding Tranny fluid. Please contribute if you can. Thx.
  99. Anyone seen a custom intercooler for PES G2 Supercharger?
  100. im getting custom exhaust, should i get 2 1/2 or 2 3/4 piping
  101. 2000 audi a4 4 sale with stage 3 apr il mail me if intrestyd bostn
  102. I WANT TO FIT A KO3 TO A 1.8 20V NON TURBO
  103. Turbo question - Would K03's benefit much from porting/polished and clipping the turbine blades?
  104. NE1 replace plastic rear connecting link with metal?
  105. Equal Length headers DONE!!! (Take a looky)
  106. Quaife GB buy on Vortex
  107. Do 02 A4 quattro exhausts fit frontraks?
  108. Stasis' custom valved (digressive) Konis...
  109. Need help locating a seat base for audi A4
  110. 2000 A6 4.2 Chronic Suspension Problems????
  111. Tips?
  112. How's this for a dyno run? Not sure if it's true....
  113. Hey turbo folks, help. Where is the best place to buy exhaust flanges? Preferrably in the US
  114. Brake Pads Revisited: What's good for '97 A4 1.8TQ?
  115. BOV Install, pros.......cons?
  116. Does any one know anything about web cams for the 1.8t?
  117. Can anyone give me info on the results of this products, has anyone tried them?
  118. Just installed miltek exhaust on my 99 a4 1.8TQ
  119. Best place to buy Koni Coilovers?
  120. Suspension clunk/rattle??
  121. i have a question? Lets say a person has a G2 supercharger, is there
  122. Power Surges on 1.8T: Resolution
  123. Does ANYONE have a spare 19" technomagnesio rim?
  124. Damn Faulty Bailey BPV
  125. Stage 3 owners....
  126. What can a malfunctioning wastegate do?
  127. Coilover Bulk Buy?
  128. putting an V6 in a 4000qc
  129. H&R / Eibach - How stiff is stiff??
  130. Alcon 6-piston Calipers,...
  131. Question...How can I stop burning the MAF?
  132. Opinions of the PES TUNING supercharger????
  133. researching DIY suspension install
  134. Took my car for service on Monday. They said I had a leaking Vacuum Hose and fixed it.
  135. RS2 Tranny Questions,... (Lucas_GChips???)
  136. Is this the tip ECU number?
  137. Beru UXF56 is it gapped at .040, has anyone used anything different?CMH,WYSIWYG?
  138. Colour of the injector valves (TT 225HP)
  139. Who has an APR chip with switchable programs?? -more-
  140. new A4 1.8T performance numbers?
  141. Removing the ECU box cover on a 2002 A6 2.7t
  142. Air box problem...HELP!
  143. Anyone with APR stage 3 DBW in the Colo. area?...
  144. 5 Speed Quattro Box for Sale, check MarketPlace
  145. Clutch kit for A4?
  146. Who's running an EGT gauge?
  147. Does anyone have installed or know about GDI-electronic GmbH chip?
  148. THE MONSTER MOD LIST,... (not-yet-final,...)
  149. 19" Ch's make my Brembo's look SMALL!!! Hehe,... what to do???
  150. anybody know the piston size for apr level 3 brake calipers?
  151. 2001 A4 1.8t Front-wheel Drive Coilovers
  152. MTM Stage III Cat and Exh Man Modifications?
  153. Tips on extracting 2.7T from S4
  154. CHIP Time...... GIAC or MTM or APR..........
  155. helping out a friend's new internet company
  156. general questions
  157. Damaged turbo due to oil starvation.
  158. Question for those with experience Building a 1.8 Motor
  159. Highest Practical "Safe" Horsepower through a Tip??
  160. Hair's breadth from pulling the trigger on the Stasis diff mod - engineer types please comment.....
  161. Power Surges on 1.8T
  162. Does anyone know how many gallons or liters of coolant per hour the
  163. What are dissadvantages with getting smaller wheel/tire for low end performance gains?
  164. Anybody autocross their 5k/100/200?
  165. Calipers for sale...
  166. Evo Motorsports AireTEK induction system - opinions?
  167. my friend got brake fluid into his eye today...will he be okay without medical treatment?
  168. pedal position
  169. Finally! Got my JE pistons today, and also picked up some 440cc injectors....
  170. Upgrade Q of the day.
  171. European Speed Stock Air Box Mod
  172. Brake Bias Valves --- work with B5 a4s? Anybody done one?
  173. Q: Vibration while braking (not warped rotors, x-post)
  174. Data logging in VAG-COM question
  175. Poll: Those w/ turbo upgrades are you: DBW or non-DBW
  176. Catalyst threshold too low (bank 1)
  177. Vag-com/tuning questions.
  178. Spark Plugs!
  179. My Forge BPV for sale
  180. Ok everyone, my car was pinging this morning (racing w/...
  181. Vancouver, BC (Canada) Audi A4/S4 meet?
  182. In a bind(literally) need Bently help
  183. Intercooler Temp Gauge
  184. T-28 for sale
  185. FS - Hybrid compressor stuff
  186. Any downside to going for a 3" turbo-back on a 1.8T?
  187. Well it's done no more mods after this past weekend! 8-) This time I mean it!!
  188. Question about timing advancement
  189. Dingster(17th/136), me(31th/136) kill stories summary
  190. injectors and fuel pressure regulator
  191. GT-25 to T-28 swap.
  192. anyone know any links (german-swedish sandwich inside)
  193. Anyone know the specs on the stock S4 fuel system........
  194. Programing 2002 A6 Headlights
  195. FS extrude honed k03/k04 manifold
  196. PLEASE RECOMEND ME WHERY TO BAY WHEELS IN EU AREA
  197. Need a clutch ASAP...suggestions? experiences?
  198. A4/S4 sedan harness bar
  199. K03 or k04 with bigger kkk compressor side?
  200. GReddy A/F guage & 02 sensor ............. Question about 02 sensors..............
  201. ATP downpipe/straight pipe combo
  202. Neuspeed Short shifter qs
  203. anyone using ceramic discs(from 996 Turbo) in your brakes
  204. ARP Head and Main studs - worth it?
  205. Is there a way to check bypass valve with a VAG??
  206. will a k04-23 fit the stock manifold?
  207. Dahlback Racing e-mail,... (and their 1/4 mile with a 640hp A4 1.8T numbers[OMG])
  208. apr' stage 3 turbo kit 4 sale 2000 a4 2000 males on $3200 or best ofer frncscmannino@aol.com
  209. Need help with new brake rotors - Can the Performance board come through?
  210. Operation during low engine temperatures
  211. xr4tic... how far along are you on the T3/T4 work. Do you have the turbo yet?
  212. X-Post: Turbo 12v
  213. Anyone know the redline(peak power) injector pulse duration on the 12v V6?
  214. Suspension problems...please help
  215. 2002 A4Q 3.0 Tip Sport Vibrates...Any suggestions?
  216. Mechanical Gurus please help, having a low boost proplem.....
  217. Xpost.. Finally got off my lazy ass and worked on the suspension!
  218. Increase my HP for my Audi a4 2002 3.0 liters?
  219. Whatever happened with the PES vs. APR $5-digit-USD bet??? (just curious!)
  220. Anyone need 4 Accel 30# injectors(315cc)?
  221. Anyone actually go ahead with the RS2 tranny in their A4 1.8T?
  222. RS2 Tranny pricing,... what should I expect?
  223. Coolant leak on the back of engine A4 1.8T (top). Has anyone experienced this?
  224. anyone selling H&R wheel spacers for the A4?
  225. Uploaded all pictures on picture poster...T3/T4E beauty! =) The car is not clean, sorry!
  226. Forged Crankshaft & RS2 tranny,...
  227. Brake bleeding
  228. Whats the R/S ratio of 1.8t ?
  229. Shameless post: Any interest in my APR chipped ECU for non-dbw A4's? $550 shipped.
  230. chips
  231. FS: 2001 S4
  232. Remote oil filter mount
  233. Attn: Rob Andrews. You gonna be around this weekend? Need to update my ECU.
  234. Turbonetics Ball Bearing T04E,...
  235. Tire Pressure and Slip Angles and Understeer/Oversteer?
  236. RS 6 Sedan Coming to the U.S.
  237. will t3/t4 run on stock or k03 chip?
  238. Can anyone tell me the most common causes of cooling system failure........
  239. Cams,... (solid-lifter cams conversion)
  240. Stand Alone EMS (engine management system)
  241. Advice needed on high performance parts,... the 11 sec audi
  242. Newbie questions what car to purchase, chipping
  243. HELP! engine overheating!!!!!!
  244. Xposted from B5 forum: A4->A6 2.8 liter reprogramming
  245. x-post... 1.18 lateral G's
  246. coilover question - xpost - can you mark where the perches are after corner balancing?
  247. APR BBQ this weekend!
  248. ! ECU Problems maybe? Anyone have this problem (more...)
  249. Wet NOS Kit question...
  250. spent hours in search, coilover DIY install questions...
