PDA
View Full Version : A8 / S8 (D3 Platform) Discussion
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82
  1. A8 D3 2003 Steering lock actuator
  2. Rear parking aid sensor R&R
  3. Didn't think I had to, but I did...
  4. Light strip in door panel
  5. MMI 2g upgrade
  6. Rear timing chain cover leak
  7. 04 Lost key, dealer dicking me
  8. Adding a powered sub to B&O system...
  9. TPMS re-learn procedure after sensor replacementss
  10. AMI doesn't always show up as source option
  11. Audi a8 d3 air suspension PROBLEM
  12. 2010 A8L fuel pump issue?
  13. Help with the fault codes
  14. Converting my A8L into S8
  15. D3 A8 W12 Fun Information
  16. Suspension Leaning Right but no Apparent Leaks
  17. Weird stuff man ....
  18. A8 d3 tablet display
  19. Instrument Cluster Question
  20. Disable TPMS in D3 with OBDeleven pro?
  21. getAudiparts.com | Last Minute Holiday Savings Promo Code: HOLIDAY2020
  22. Front Air suspension high & can't calibrate with VCDS
  23. A8 D3 - starter motor not cranking - EPC and brake lamp light on
  24. Suspension still not working in front...
  25. Need help finding a mechanic around Pittsburgh
  26. Gearbox noise at slow speed
  27. air suspension settings gone from MMI?
  28. Timing slightly off?
  29. Looking for Mechanic around Pittsburgh area
  30. Huge MAF mystery problem
  31. Battery Vent Hose Confusion
  32. best products to touch up seats
  33. 2008 A8 (V8) Heating Issue
  34. UK: CVT Transsmision issue
  35. 01844 - Control Module for Fresh Air Blower (J126) 008 - Implausible Signal
  36. Fuel system: Fuel pump priming every time
  37. Motor Mount Replacement - All or Just One?
  38. SE: help service :(
  39. Labour time for camshaft tensioners on 40v 4.2 D3 A8????
  40. fitments facelift
  41. ES: control head
  42. deAutoLED Black Friday and Cyber Monday sales are LIVE NOW! Best prices of the year!!
  43. Xenon coding problem
  44. Ashtray and Cupholder Lid Gears
  45. Parking Brake Flashing and Beeping in dash Helllllp Me!
  46. can face lift mirrors be fitted to '06 A8 ?
  47. Tire Size Question
  48. PRNDS Lights on Solid
  49. Issues with Air Suspension - compressor sound & front left wheel dropped
  50. service interval details
  51. park sensor module?
  52. 2008 A8L W12 for sale
  53. Unique Suspension Issue - SOLVED
  54. Audi A8 D3 ABS Control Module Defective - 014
  55. Well it is certainly more economical
  56. White smoke from engine
  57. Parking Assist Sensing a Phantom Object
  58. Try not to cry....
  59. A8 D3 wheel bore?
  60. Help on parts number and how it works roof console.
  61. High Level break light issue
  62. Radiator cooling fan issues
  63. Can I Charge Battery With Lower Rated Amp Charger
  64. Front Air suspension problem
  65. Front Air suspension problem
  66. Where to buy genuine parts in UK?
  67. Battery issue or recoding?
  68. Rear Suspension Sag
  69. Towing Using Another Car & Stuck in P - Car Dead
  70. Thinking of selling 2009 S8 - value?
  71. New temp related post no hot air
  72. Misfires after changing O2 sensor
  73. 06 A8L Wide Gauge Cluster Swap - Questions before a Dealer Appointment on Monday
  74. Number Plate
  75. UK: Car Dead Due To Rain & Condensation Inside Car
  76. V10 Camshaft adjuster replacement without engine removed?
  77. AMI not showing in source list after CD swap. Have 4610 MMI
  78. Advice on replacing the air strut?
  79. Goodbye my old faithful 2006 A8L...sad
  80. Bought another D3 - Some faults to fix with VCDS report :)
  81. Trying to swap Trunk lock
  82. Rear Left Taillight Issues - Electric Gremlin?!?
  83. W12 -second dead battery
  84. LED License Plate lights
  85. UK: A8 D3 Anomalous Beeps?
  86. Retrofit reverse camera issue
  87. Trunk styrofoam block??? 2006 A8
  88. Thinking of selling my car...
  89. Play In Steering Wheel On Hard Lock
  90. the mystery of relays, what and where are mine?
  91. Audi a8 d3 4.2L coolant leak parts help
  92. 2008 Audi A8L suddently won't start this morning
  93. SE: Advice MMI dead after water elakare?
  94. UK: Rear end skipping?
  95. MMI 2G mods
  96. Thinking of selling?
  97. '04 A8L Suspension Issue
  98. Sunroof Adjustment
  99. Electronics System Deep Sleep? (Re. Keyless Entry)
  100. Power steering rack
  101. Adding Bluetooth to 2004 and Bluetooth cellphone cradle
  102. Yellow suspension light on after replacing front right strut
  103. Production Numbers D3 Audi A8
  104. HELP! Upper pinch head busted while trying to remove
  105. This vacuum pipe attaches to what?
  106. Oil retention valve
  107. Rear exhaust removal
  108. 2003 A8L D3 4,2 V8 P0020 HELP
  109. Suspension level sensor question....
  110. 2006 Check engine light not coming on
  111. Questions/validation of steps to replace front strut
  112. 67 - voice control ... please access code
  113. Tachometer Replacement?
  114. New front pads but still get intermittent low pad warning
  115. Looking for a front bumper
  116. Power steering leak - Worth to fix?
  117. URGENT! A8 D3 Air Suspension Problem! ON HOLIDAY!
  118. 06 d3 wiring issues
  119. Chasing a misfire
  120. DFW Roll Call!
  121. Parking Brake Malfunction & Alarm & Electrics Acting Up Too
  122. Just one more question about drains
  123. Water damaged kessy a8l keyless entry
  124. Urgent Help Needed! Key Stuck Dead Battery
  125. Hood replacement
  126. S8 transmission modification
  127. P0022, 16406, 17942
  128. Can’t reset service reminder interval (SRI)?
  129. Please help me identify this part
  130. AC condensation causes water drop inside footwells
  131. Front and rear camera the cheap way.
  132. $6085.28 to replace the starter...
  133. Voltage Drop, need cabling locations.
  134. Prospective buyer
  135. Newly rebuilt strut shock leaking
  136. Just finished changing out headlight bulbs...
  137. A8L D3 W12 Tune up How to I want to know
  138. DE: Audi a8 d3 3.7 BFL Timing belt broke on the highway
  139. Wipers went out during a rain storm today :/
  140. 2007 Audi A8 Trunk Motor Replace
  141. Oil leak from a cooler?
  142. A4 wheels on a A8
  143. Nav Update
  144. Rear view mirror leaking😳
  145. All MMI red lights stuck on
  146. Air suspension not lifting or settling
  147. Audi A8 D3 Air Suspension Weird Behavior When Sitting
  148. D3 Fuel pump control
  149. over heating possible radiator fan
  150. D3 A8L 4.2L SUPERCHARGER
  151. imobiliser or mmi issue
  152. Audi a8l keyless entry control unit question
  153. my W12 needs starter replaced...any R&R tips ?
  154. Audi A8 D3 AMI Retrofit
  155. Just bought 09. questions about upgrading to S8 brakes
  156. replace just seals on timing chain adjuster?
  157. Strange wiring.
  158. Cruise control not engaging
  159. Should I replace both front struts?
  160. NextGen OBDEleven Pro that supports iOS
  161. Sunroof misalignment
  162. 2004 Audi a8l with 270k
  163. Engine hunting.
  164. Plenum Drains
  165. What's missing here?
  166. Error code 01487 Air suspension.
  167. New member, please help! AUDI A8 D3
  168. Install CarPlay and Backup Camera Without RVC Controller
  169. DIY Cleaning the DPF after error code 09263
  170. Audi MMi 2G bluetooth very important
  171. Reputable seller of suspension parts?
  172. 2007 S8 misfires cylinder 9 and 10
  173. 2018 Navigation DVDs
  174. Can't clear Malfunction 0010...
  175. Climate control problem
  176. Collaboration of actuator and turbo on an Audi 3.0 tdi d3
  177. 2005 A8 Coolant Pipe Replacement
  178. 2005 A8 Coolant Pipe Replacement
  179. key fob battery low, "safe", no start.
  180. Headlight assembly
  181. Complicated issue with aligning the timing belt
  182. Air Suspension Control Module
  183. Project: A8L rescue on a budget/how I learned to fix this car
  184. Door handle button
  185. Front seat with mind of it's own
  186. Battery + VCDS
  187. Horn issues / errors
  188. A lot of work on my A8... opinions?
  189. Headlight: Hi guys, are there any instructions on removing front bumper on Audi A8L?
  190. Starting issues
  191. Seats from long wheel base on short wheel base
  192. Batter or alternator?
  193. 07 S8 Washer tank leak
  194. Audi S8 D3 keyless control module location and removal
  195. Compression Test Procedure 5.2 BSM
  196. Hands Free Phone fan noise
  197. Looking at 07 W12
  198. D3 S8 Dead Battery Key won't release
  199. Trunk lift motor
  200. Random Misfire
  201. Monitor Camshaft Position Sensor Output Signal
  202. Throttle lag
  203. Headlights AUTO function?
  204. Bem code for Bosch 95ah 850a agm battery?
  205. 2004 A8 transmission fluid
  206. A8 D3 4.2 quatro - sudden stop after ~20 seconds
  207. Who's got a used genuine Audi hitch and electrical install kit?
  208. Rough running, Misfires, Fuel Trim
  209. Air Suspension rebuild
  210. Radio loses memory
  211. S8 Combi Valves
  212. A8 D3 Battery Replacement - Nut Size and AGM Recoding
  213. A8 Air Suspension - Replaced rear struts and then pump but wont air up
  214. Audi a8 abs issues and electrical problems. Help!!
  215. Export phone book
  216. Audi a8 D3 hood problems
  217. Need help! I can't find the post about driveshaft support bearing
  218. Carprog and kessy
  219. Damaged Intake Flap
  220. Will a bad wheel bearing cause abs light to come on?
  221. Air Suspension yellow/green lights
  222. S8 gearbox
  223. 2004 a8 dvd player upgrade
  224. What is This Connector For
  225. Windscreen Wipers Position
  226. Rear wheel bearing
  227. Engine Missfire
  228. Trunk (boot) trim
  229. Audi a8 bfm engine wirining how to.?
  230. Ignition help
  231. AM I BEING OVER CHARGED?
  232. please help ac compressor relay location
  233. Name this part
  234. Driver door electric
  235. Air suspension
  236. Kessy problem
  237. Speed limiter/Governor
  238. A request for help with rear lamp coding USA
  239. Scan result help.
  240. Manifold Gasket Replacement
  241. CP on Bose amp?
  242. Replacing speakers and adding amps in a D3
  243. D3 S8 underbelly
  244. Where is the best place to get my abs module rebuilt?
  245. DAB not finding aby stations
  246. Bang & Olufsen swap/upgrade?
  247. Need info on replacing ABS Speed Sensor
  248. V10 front Oil seal job/ crank locking & coolant?
  249. Can anyone direct me to who sells Coilover suspension for 2005 Audi A8L(D3)
  250. A8 D3 2006 battery drains while driving
