PDA
View Full Version : A8 / S8 (D3 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82
  1. Adaptive Headlights D#
  2. W12 siting!
  3. Speaker wire outputs Bang & Olufsen amp
  4. Long Crank EPC and CEL on, codes?
  5. help with connector on front vents
  6. 802HP Audi S8 Talladega R By MTM Launch Control - Video
  7. Preventative Maintenance on the Front of the Engine - S8
  8. Merry Christmas
  9. Help Finding Hoses' Location
  10. Question About water leak on Audi A8
  11. 2004 A8L Back Up Camera
  12. 01770 - Temperature Sensor for Level Control Pump/Compressor (G290) 007 -Short to Gro
  13. MMI Software Update Help
  14. Snowy roads
  15. Driver seat heater partially not working?
  16. Interior fan does not work properly 2003 A8/D3
  17. Component Protection Problems? Solution here!
  18. Suspension Rebuild Writeup.
  19. Malfunctioning Climate Control System/Heater
  20. BACKUP CAMERA VCDS SCAN
  21. Front susp rubbing sound
  22. optical park aid
  23. v10 s8 valve cover replacement
  24. Noticed today that the back of my car is sagging!!!
  25. Door light
  26. Thinking of purchasing a quick jack setup
  27. What do you guys use to replace headlight washer fluid hose?
  28. Clearing Rear Pad Worn DTC
  29. Power Steering Whine and PSF Fluid "Boilover"
  30. keeping AC on with heat and recirc on?
  31. Back-up camera not working
  32. Camshaft Sensor Location D3 Audi FSI motor
  33. W12 PSA
  34. A8 vs Fiat500
  35. Hidden Menu
  36. Gas Door Pin (Actuator?)
  37. Easy removal of air compressor
  38. Bad EPC connection ??
  39. Radio cutting on and off and bluetooth stoped working
  40. Bluetooth
  41. Oil research for W12 / VW 503.01
  42. Driver door not locking/alarm not beeping
  43. Central Electronics Security Code
  44. Electrical Fault - LED Christmas Lights
  45. A6 headlamp in A8
  46. new member - PCV help please
  47. A8 TRANSMION VAVLE BODY REPLACEMENT
  48. OE AUDI PARTS AND LABOR
  49. wood cover on MMI screen
  50. Replacing B&O Tweeter and I LOST the wire
  51. retrofit power folding mirrors
  52. MMI Update 4610 Broke Bluetooth Streaming
  53. Brake Bleeding Procedure?
  54. Boot/Trunklid handler plinth
  55. What would cause brake fault lights to go on?
  56. Rear tail light issue
  57. Electrical Issues
  58. ***Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - January 1st - 7th, 2017***
  59. VCDS - ABS module test
  60. rear footwsell heaters
  61. 2008 A8L added - 4610 software
  62. Having strut rebuilt
  63. Question about TSB 170829
  64. LED Reverse Bulbs
  65. Please confirm drain and fill plug on the 6HP
  66. Auto-Leveling Suspension
  67. The TPMS (Tire Pressure Monitoring System) that works
  68. access to module for MMI power
  69. Prop'shaft centre bearing replacement
  70. vag com newbie questions
  71. vandalism usa
  72. Bay Area vag-com professional
  73. External door lock pushbutton switches
  74. Just starting my interior.
  75. Ceramic pads besides EBC
  76. Odd scenario with blower fan
  77. Electrical Issue -'07 A8L 99.5KMI
  78. 2005 bluetooth or parrot
  79. Ride height videos
  80. Anyone know or do MMI control repair?
  81. CD not Installed
  82. 2005.5 A8 4.2L - About to do Timing Belt
  83. VCDS cable, too good to be true?
  84. New stance. (Spacers )
  85. Intermitant battery drain... fault codes
  86. Door Contact Circuit/Control Unit question
  87. 2008 Audi A8 heat issues center vents
  88. Most of the MMI settings in my 05 D3 are simply gone?
  89. new wheels and spacers.
  90. P1085 - 004 - Lean Limit Exceeded ...PCV hose?
  91. Shifty Business : Electronic shifters, push-button starts
  92. 2004 A8 INTAKE MANIFOLD PRESSURE SENSOR
  93. Cylinder 1 & 2 missfires
  94. Disk brake rotor size for S8
  95. Temperature sensor(s)
  96. Driver side handle will not open or close the car...
  97. New owner.
  98. 2004 Audi A8L not starting!
  99. Intriguing Suspension Issue
  100. ABS module removal
  101. Need some help with my head lights!!!
  102. Tire Pressure Sensors
  103. Tyre dilemma
  104. XM module antenna question...
  105. Jammed Sat Nav/MMI Screen Mechanism
  106. air suspension problem still a8 d3
  107. Guide pulley movement/whining sound?
  108. ABS module
  109. Automatic Headlight "sweep" 2004s do This?
  110. air suspension - paying it forward
  111. !AUDI ONLINE PARTS WINTER RAFFLE!
  112. Installing Bentley on Win 10
  113. How do I access Fuel Econ or Trip Mileage on my D3?
  114. Digital TV and DVD questions
  115. Good wintercar
  116. Maxed out W12
  117. How much is too much oil?
  118. Transmission Security Access Code
  119. I Finally Found The Econ "Button"!
  120. immediate help neeed
  121. Part ID
  122. Parking brake fault when operating trunk...Fix!
  123. XM module compatibility question...
  124. New brake discs and pads.
  125. Possibly the first faulty S8 suspension valve block!
  126. rr door wont turn rear dome light on when opened...
  127. Play in gearstick
  128. Trunk lid motor
  129. Not the regular trunk question. Will not open when car is running
  130. No Compressor... No Problem
  131. W12 Bumper on 2005 4.2 tdi
  132. 2007 A8
  133. WHAT DO YOU WANT TO SEE FROM A PARTS DEALER?
  134. AGM Battery in A8 D3
  135. Transmission Problem!
  136. Temp gauge issue
  137. HELP! Transmission problem or just needs a flush?
  138. Novice DIY Front Suspension
  139. Flex pipe replacement size - A8
  140. Spare Parts Box
  141. Do cigarette lighters still draw power when car is off?
  142. MMI Becker Control Board Car Button Repair
  143. Sticky Articles (Moderator Question)
  144. Suggestions for after market head unit for 2005 A8L Quattro 4.2L. MMI is shot
  145. mmi help
  146. Will unplugging CD player power need reactivation
  147. Vibration at all speeds
  148. Time to take off the 11 year old Bra.......
  149. engine speed sensor fault G28
  150. D3 Style & Shine
  151. audi a8 d3 air suspension problem
  152. power steering fluid level
  153. Coming back
  154. Front Suspension - Strategy?
  155. Strange door lock / soft close problem...ideas?
  156. Air Suspension - Rear Issues
  157. 2005 audi a8 quatro
  158. Fixed: Sticking Keys A8 D3
  159. Guess what!? Headlight change on A8 isn't as hard as everyone says.
  160. A8l park assist rear wiring harness replacement
  161. 0W40 OILS: Mobil 1 or Castrol Edge or Liqui Moly
  162. Oil level sensor - other end of connector lead?
  163. Help! Headlight issue - 2008 S8
  164. Dash is open for MMI repair what else should I do?
  165. Power steering fluid change
  166. Coolant leak help please....
  167. Curious suspension behavior...
  168. Battery dying...and other gremlins
  169. pliz help<< water on mmi control
  170. Noooooooooooob... lol
  171. quick oil change question, and unbelievable mileage
  172. Audi AMI USB Format
  173. Usual Suspension Issue
  174. audi A8l 2008 MMI not working
  175. Is auto suspension adjust after turning off car normal?
  176. Elsavin Engine/Transmission/Final Drive Type Identification
  177. intermittent ticking sound
  178. audi a8 4.0tdi 2005 engine noice 2-3 sec when start
  179. Front suspension drop...is this a sign of an issue
  180. xm radio cuts out quite often...any ideas
  181. 2004 A8L Serpentine belt/Tensioner Replacement.
  182. Blown Door Speaker B&O D3 S8
  183. Convenience Close?
  184. need to locate fuse that sends power to left trunk fuse panel
  185. Hi 07 Audi S8 tire help
  186. my D3 story from 2007-2015 and a D4
  187. Driver door exterior handle swap
  188. winter floor mats
  189. AUDI Newbie pre sales questions - Thanks
  190. P2181 code on my 2005 A8.
  191. rear seat cup holder
  192. No Beep or Chirp when activating alarm
  193. New to the Audi forum. Couple questions about my 2005 A8L.
  194. Grounds and galvanic resisitance
  195. fog light grille
  196. BFM Hydraulic Adjusters
  197. WTB 2006-2007 AUDI A8 what to look for?
  198. Emergency: parking brake warning all of a sudden.
  199. Splash /Mud Guards for the A8
  200. Help! 04 A8L 4.2L coolant leak not cooler
  201. 04 a8L 4.2
  202. Is it possible to create rear seat massage ?
  203. O2 sensor
  204. is it possible to retro fit finger print start ?
  205. TPMS won't enable in MMI
  206. Living with long term problem. Thought I was close today.
  207. VAG Level Control Measuring Blocks
  208. should the steering wheel and drivers seat...
  209. parking assist feature
  210. Audi AMI Lighting Cable
  211. Retrofit Adaptive Cruise
  212. Heat Shield Removal
  213. "Brakepads" indicator still remains after new pad installation.
  214. Installing Hood Latch Release Cable (w/old one already out)
  215. License plate tow hook holder for 04 A8L?
  216. Driver seat rails hex screws
  217. 2004 A8L Ignition Harness bolts
  218. 2004 A8L Backup Lithium Battery
  219. trunk question
  220. Rear seat cup holder removal
  221. Audi wants my A8:
  222. Button illumination
  223. folding mirrors
  224. VAG Com and rear brake issue
  225. 2004 A8L Satellite radio installation. Help!
  226. Noise caused by 22 inch wheels ???
  227. Buy a used POS, then head straight to dealer??
  228. oil
  229. Whiff of oil
  230. Front ashtray cover - oil damping broken
  231. Reprogram Advanced key Master?
  232. Best Source for VCSD?
  233. Hello from Philly
  234. MMI Radio. No radio nor cd option
  235. v10 against the skyline
  236. Random Multiple Misfires
  237. Strange chriping and beeping sounds from dashboard
  238. PSA for high mileage owners
  239. First year costs = $8K
  240. Power Steering Fluid
  241. d3 fog lamp wiring?
  242. Rear side fixed window trim:
  243. Creepy Rear Window - Creeps open!!
  244. Rear axle, lower arm bushings.
  245. Rear Heated Screen Temp Function?
  246. 04 Audi A8 car setup function doesn't work
  247. Slow coolant leak- yes, again
  248. Changing Shift Knob
  249. license plate lights
  250. Poor radio reception...
