PDA
View Full Version : A8 / S8 (D3 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82
  1. A8 D3 AC Compressor Not Engaging, help pls!
  2. Just bought a second hand A8 D3 2009
  3. Rear inner tail light problem again!
  4. 2007 A8 SWB pulsing/clicking
  5. Pics of my 2010 A8L
  6. key program problem
  7. Hood Release Broken?
  8. Allen plug under HPFP
  9. Should I stay away from the 04 A8s (first year cars)
  10. Sputter upon cold start and check engine light
  11. Part Number for Lock Actuator/latch for rear soft close
  12. Plastic Battery Harness
  13. Bump stop in air spring
  14. MMI on the brink of working but what's stopping it??
  15. 2007 Audi A8 D3 4.2 timing chain advice..
  16. Sunroof drains
  17. seat trim
  18. 07 Audi S8 5.2 V10
  19. Suspension
  20. Door Trim Panel Pocket
  21. Wheel rash repair
  22. Oil Pump Intake Screen
  23. Water from roof drains flooded passenger floor. MMI dead since
  24. What size are the rotors with a 19” wheel?
  25. MMI wrong version
  26. Recomendation VAGcoding expert
  27. Airbag Switch
  28. S8 REAR MAIN SEAL LEAK
  29. Remove Inner Aluminum Door Panel
  30. Audi bluetooth
  31. Oil Non-Return Valves
  32. Another oil leak thread, but doesn't match anything I've seen.
  33. What is the technical term for the air vaccum line that connects to the strut?
  34. ISO Tail light lens
  35. Air valve in strut
  36. Finally time to tackle air suspension problems
  37. Quick question
  38. Correct boot motor
  39. Preparing for S8 ownership.
  40. Advanced Key Locked in Trunk
  41. Rip air compressor
  42. Bose Amp Issues
  43. Rear Diff took a dump
  44. Instrument cluster not communicating
  45. cup holder removal
  46. High Crankcase Vacuum and Ticking?
  47. How to clean the engine? Safely, that is.
  48. Excessively high vacuum at oil cap
  49. 4.2L BFM Camshaft Sensor / Speed Sensor incorr Correlation
  50. Considering switching from D3 to D4
  51. 2005 Audi A8 rough idle
  52. Tail light out
  53. Roller Rocker Removal
  54. Upgrade from D3 to D4?
  55. Roof console removal (without torx screws)
  56. It's still performing gracefully at 128k miles
  57. What do you use for a Phone Mount in your Car?
  58. Anybody reupholstered their interior?
  59. parking assist system
  60. My uncle Audi A8 4.2l that been sitting for a long time
  61. S8 - DIY steering rack replacement?
  62. FSI Injector Removal
  63. S8 stiff steering
  64. Engine Code Location & P-Codes
  65. Control arm pinch bolt size?
  66. Diagnosing and Repairing Air Suspension
  67. Considering a D3 A8L purchase
  68. 4.2 FSI High Pressure Fuel Pump Cam Follower
  69. 2003 Audi a8 d3 3.7 v8 headlight problem...
  70. Air compressor "get what you pay for"?
  71. Audi A8 D3 facelift conversion
  72. Air suspension leak - one corner only?
  73. Intake removal for maintenance 2008 A8L
  74. Power soft close doors
  75. RS style black honeycomb front grill
  76. Bentley software to set rear pad thickness
  77. Those dang rear brakes!
  78. Coolant leak too
  79. This isn’t looking too well
  80. More brake issues!
  81. Continuing off my shaking car post
  82. Valve cover gasket availablity
  83. MMI dead
  84. Purge valve location.
  85. Overheating
  86. URGENT
  87. Need to find an AMI adapter for USB-C for Android - PIXEL 2
  88. S8 and A8 calipers interchangeability???
  89. KESSY Question
  90. Bang & Olufsen Tweeter (Left) Audi S8 Issue
  91. Audi A8L W12 - Rear Pillar Vents No heating
  92. Battery replacement
  93. Compressor question
  94. how low is low?
  95. Rear passenger door will not open from outside
  96. It's my turn... TPMS turned itself off?
  97. The Codes are back!
  98. Jack mode if lifted by hoist-necessary?
  99. Muffler delete questions
  100. Piston Removal
  101. What to do
  102. Fan on full blast wont turn off
  103. 2009 s8 v10 parts help
  104. New guy here - Transmission issue
  105. ACC issue - 00234 Misadjusted
  106. Help kessy unit 2005 A8L
  107. 2004 a8 wont crank need help with codes
  108. 06 A8 Jumped time.....Need advice PLZ
  109. One year of ownership and 23K miles later
  110. Vag com?
  111. D3 Essentials ?
  112. Little help
  113. 2004 audi a8 only 1 fan turns on
  114. Any way to get into the steering wheel controls?
  115. Single Brake is Shot
  116. Removing intake flaps
  117. Manually turning the crankshaft pulley
  118. MMi update
  119. Pins in oil pan
  120. Car is shaking when braking
  121. Rebuilding a front strut, easy job!
  122. programmable TPMS sensors?
  123. 2006 4.2 TDI DPF cleaned but glowplug still flashing
  124. Potential bad air ride compressor ?
  125. Engine Databus Error 6.0 W12
  126. MMI: Center console issue
  127. Coding for rear HVAC
  128. 2006 engine start stop switch upgrade
  129. Fixed center console arm rest latch
  130. White bad smell smoke from exhaust
  131. Exhaust options?
  132. Intake Removal/Disassembly 2010 4.2
  133. 2008 A8 Inoperative suspension troubleshooting and repair
  134. 2010 A8L Mystery Tick/Knock
  135. New to me 2007 S8
  136. OEM Replacement Badge for 2009 S8 Steering Wheel
  137. Pulsing rpm at idle from 640/680
  138. Time to go, again
  139. Repair Manual
  140. Just got a code on my wife audi 02432 and 02430
  141. Rear bumper Chrome Molding removal
  142. Is the 5.7 abs module component protected?
  143. Is my key just bad?
  144. Rear Suspension Issue Won't pump up.
  145. W12 executive rear seat removal
  146. I want to activate Satellite Radio on an European car
  147. Picking up an A8L next week with air suspension issue
  148. S8 D3 Service Position
  149. Replaced front shock, now having lifting issues
  150. Tips and advice on buying a 2004-2005 Audi A8L (my first audi)
  151. Wiper Blade Length
  152. Center shifter cover
  153. Anyone have the PN for a heated steering wheel clock spring?
  154. 2004 audi a8L
  155. Upper manifold gasket
  156. How do I replace the suspension module?
  157. leaky valve seals??? and other issues
  158. What is this hose to?
  159. parking brake error
  160. Oil change
  161. 2004 audi a8
  162. Sporadic ECP/ESP and check engine. When it rains it pours. LITERALLY.
  163. What is this?
  164. 2006 or 2007 A8? Input
  165. Yet Another Buying Advice/Opinion Thread
  166. Alignment..
  167. Park Brake motor test
  168. Emergency Parking Brake Module needs replacing - difference in part #s for A/B/etc?
  169. TPMS sensor -which one?
  170. Mystery Misfire Help Please
  171. 5.7 abs module
  172. Car faults
  173. Adaptive Cruise Control (ACC) Error
  174. Can a 4.2L cylinder head be pulled w/o pulling the motor?
  175. NEED HELP IDENTIFYING SOMETHING
  176. S8 Buying Advice
  177. Nightbreakers
  178. Cup holder differences
  179. Innooperable Suspension
  180. Is there a dealer CPU flash that fixes misfire?
  181. Replace 2G MMI Bose Amp with 3G MMI Bose Amp?
  182. About to purchase Used A8 L D3, Can I join the club!?
  183. Almost done with tail lights...
  184. Need a little diagnostics help.
  185. Brake/tail light "burn out" sensor ?
  186. Suspension troubles - thought I dodged a bullett
  187. Parking distance sensor acting weird
  188. A8 loss of power
  189. Location of Air Suspension Control Module?
  190. Witch is my MMI type?
  191. VW/Audi W12 engine Tightening torques
  192. The Tired Blower Motor Has Finally Given Up
  193. MMI bluetooth
  194. Left turn signal indicator
  195. TPMS from EBAY
  196. W12 misfire and air leak help.
  197. What do you guys think of these.....?
  198. ISO and inner tail light problems
  199. Child Locks stuck on
  200. Well my access and start authorization module is toast...
  201. Is there supposed to be some trim around the gear shifter or no?
  202. 2007 S8 V10 Engine Noise - What do you think it is?
  203. my car can't decide what height to be
  204. Headlight Range Control Defective warning
  205. Can someone tell me what is supposed to be here?
  206. Noisy New Air Suspension Pump
  207. question for Euro members...
  208. No power to the suspension compressor
  209. ABS Module replacement
  210. A8 D3 Quattro 4.2 Exhaust
  211. Car lost all power when I hit start button sat for 24 hrs no power now power is back
  212. Placement of radar detector kill switch
  213. 2004 A8L: Help MMi interface stolen from trunk
  214. Brake options for the D3.
  215. N205 replacement
  216. How to remove corner trim
  217. Battery level sensor accuracy?
  218. How to remove amplifier in a 2005 A8
  219. Sudden electrical issues
  220. 08 A8L 4.2l exhaust flex pipe shot - options?
  221. Is there a cheaper alternative code reader
  222. 2006 Audi a8 suspension... Weird
  223. 2006 Audi a8 suspension... Weird
  224. Yet Another Suspension Issue. Please explain - I'm perplexed!
  225. 09 D3 S8 remotes inoperative....
  226. 2005 A8 No heat solved, easy check first
  227. Help I can’t find my Kessy
  228. Locating O2 Sensor
  229. 2008 AUDI A8 FUEL ISSUE CODE P0088
  230. parking sensor intermitent
  231. Rear sunblind repair
  232. 08 Audi A8 quattro
  233. Squeaking noise behind the steering wheel
  234. O2 Sensor
  235. Bad Air Compressor?
  236. Sound System Fault
  237. 2008 A8 windshield replacement
  238. Highbeams Settings in VCDS
  239. Check engine code
  240. First Scan of car, many faults
  241. Performance air suspension
  242. MIL on for evap leak any ideas?
  243. EPB Not Working
  244. Water damage
  245. Adaptive Air Suspension Diagnosis - cold weather(-28F)
  246. 2004 A8L 132K KMs Air Suspension Issue Started Today
  247. Help with Access to CCM Comfort Module
  248. It's my turn... water in the trunk lid?
  249. Wheel and tire fitment
  250. Timing chain life on a W12
