- Air Suspension
- looking for recommended performance mods
- 2007 A8L Vehicle Key stuck
- For sale - License plate filler
- Need help -- w12 suddenly won't crank
- Car wont start
- Pre emptive rebuild
- My ABS error as been narrowed down to heat.
- Mmi
- short squeek under acceleration
- Oil cooler repair failure
- Shifter plastic
- Happy 4th of July AUDI's Bitches!
- Who wants it for $10k then...??
- Oil Cooler coolant leak repair
- Intake manifold removal
- Air conditioning
- aftermarket air compressor
- Radiator Cooling fan
- Front air spring replaced and now front end wont raise
- Car will not run, please help!
- Questions related to intake manifold removal
- headlights warning chime doesn't work
- AC not cold
- ESP Fault on Audin A3.
- W12 oil seperator hoses. Possible solution.
- S8 D3 MMI problems
- AUDI VIN DECODE
- Fuel injector parts
- W12 intake manifold torque specs
- Low-Oil MIL On, but Oil Levels ok?
- air suspention problem
- A8 D3 windscrean wipers replace?
- 104 degrees in Louisiana and trying to get into trunk for 3 hrs
- Headlight body gap problem
- Headlight switch wiring missing???
- Full hydraulic fluid change amount
- ***WannabeRacer.com | Norcal/Bay Area Vinyl Wrapping Tour - July 30th - Aug 3rd 2018*
- Fridge
- Oil filter question
- Getting sirius xm to work
- Engine died while on highway
- Another problem - Mostly just venting
- What is code P168200 (1/2) on 2012 Audi Q5?
- Duplicate Key
- rear dvd changer
- Front air suspension issue...
- oxygen (lamda) sensor b3 s1 codes?
- Door trim foam
- Torque arm removal
- Timing Belt: Crank Pin Locker
- Do I have adaptive headlights???
- 04 A8 will not start
- 2009 vs 2010/11
- Lower control arm
- change Solar Roof into battery trickle charger?
- Q3 MMI Control Unit J794 Failure
- Striving for perfection even in the trunk
- Help identifying clamp
- nothing happens when key is inserted and rotated
- Help Identifying Transmission Part
- 2004 Audi A8 MMI
- Plug-N-Play upgrade
- Lowering links-anyone have some to sell?
- 06 A8 Air ride compressor wiring help needed!
- Clear Transmission learned value without adaptation procedure
- Battery life ?
- 2015/2016 Nav Disc ISO wanted
- 2007 D3 A8 Parking Brake issue & Other electrical gremlins
- Seat leather repair
- RSE: What is the "AUX IN" input for?
- Rear view camera quality and other questions
- Door glass came loose, and other adventures
- 2003 D3 4.2 A/C issue
- What is this cable for 06 A8 rear pad?
- Old and New keyless remote for 2006 Audi A4 cabriolet
- 2008 Audi S8 (D3) How To Play Spotify Best Quality How???
- audi q7 07 plate suspension
- Stripped Valve cover bolt
- New windshield
- Engine support or hoist?
- modify AMI Cable To Stream with $10 30-Pin Bluetooth Receiver
- W12 Oil Dipstick help
- Best way to tackle the Driver side airbag igniter (N199)
- Door Striker Plate Bolt Size
- Suspension Problems with my 06 A8L
- 2008 S8 PROP SHAFT NEEDS REPLACING? SERIOUSLY??
- 2008 S8 APR TUNE- NOT GOOD
- Auto trunk doesn't close all the way...HELP
- NPOCP $25K W12 Executive
- S8 Oil leak from driver valve cover..again
- Door pocket won't close
- Ignition control module?
- Suspension issues 2006 A8L- revised, please help!
- 2010 A8L suspension clarification
- What would the Symptom be on a transmission fluid filter being knocked out
- Will it ever end...?? This happen to anyone before...??
- Airbag suspension
- The 100F heat broke TPMS
- Check engine light/car shaking when stopped
- Looking to buy 2012-2014 A8 - Savanna beige
- 07 A8 4.2 VCDS Scan Results. Please tell me what you see
- Front vs Rear Seat Cushion
- Harsh Ride On Bumps & Slight Knock
- Sporadic Park-Tronic issue
- Ac charged-now not turning on...
- How do I know front rotor size
- Alldata discounted price
- d2s headlamps blowing
- Need help with Dension 500S MMI upgrade
- It still beautifies the parking lot
- Spacers and 66.7 mm wheels
- 06 A8L possible ABS module issue
- rs4 fsi in a8 fsi vehicle
- Trunk lock pull down adjustment
- WATER/METHANOL INJECTION
- Rear door window replacement
- Big deviation in exterior ambient temp display vs actual temp (25+ degrees!)
- where is fuse for license plate light,
- How often does Elect Park brake cycle on it's own
- permanent fix driver's window switch upgrade...
- Trans fluid question
- Audi S8 5.2 V10 RPM fluctuate
- blown power steering line
- 04' a8 suspension issue
- A/C Refrigerant and PAG oil
- AC line O rings at compressor
- Won't Start When Hot
- Battery drain (suspect it's door handles)
- Brake pad indicator
- negative camber issue
- is it compatible fog light control relay 8D0 907 701C with 8D0 907 701B
- PCV valve going bad?
- 2004 A8L - How to clear 02596 Rear Brake Pads Worn Fault?
- Ami to Bluetooth
- 2008 S8 D3 phone tray adaptor update
- A3 e tron mmi upgrade
- Audi a6 allroad 4.2 FSI adaption codes for suspension for snap on verus
- 2007 A8 Misfire P0303
- 2004 Audi A8L left front suspension will not lower???
- Looking for any issues my 05 Audi A8L might have - VagCom print out
- Alternator output - where does it connect to? ...
- AUDI 2004 A8 MMI PROBLEMS
- anyone have the schematic for the RSE system ?
- a/c don't blow cold no mo
- Spark plugs
- 2005 A8 D3 transmission removal and replacement
- Switched 12V in boot for bluetooth
- Anti roll bar /sway bar/ upgrade
- P0343 "CAMSHAFT POSITION SENSOR A, CIRCUIT HIGH" in 2007 A8
- Lost its Brains after visiting shop
- camshaft sensor located on an 2010 Audi A4
- Should I...???
- Battery dead after visiting the shop
- Battery Dead-key stuck
- Blown Rear 12V Socket | Fuse location?
- name of brand Audi uses as supplier for fuel filters ?
- Not working; 30-pin iPod cable w/ MMI 2G-Hiwhat am I doing wrong?
- P1077 code help
- issues related
- Just replaced Brake Switch and now have ESP, ABS and Parking Brake lights coming on
- Left footweld light passenger
- Armrest adjustable
- P1423 - 002 Secondary Air Injection System; Bank 1 Insufficient Flow
- Oil leak
- Rear Pad Rapid Wear
- Looking for help with VCDS data for Battery Manager ...
- Ventilated Seat Issues
- can a non-ACC grille be made to work with ACC car
- What Phone???
- Windshield washer fluid leak problem and solution
- would a stuck/malfunctioning thermostat throw up a code?
- 2006 a8 mmi control unit water damage
- 2006 A8L Air suspension issue in hot weather
- 2006 A8l Adaptive Headlight Dry wiring harness
- Radiator Stop Leak
- Kuhmo Vs Continental DSW06
- Headlight issue
- Randomly won’t start/stalling
- Audi A8 4e Steering wheel in A3 8p1
- RMT air shocks
- Rear Sunshade clip broken. HELP
- 2007 S8 5.2 L w/Milltek
- 3.2FSI BPK Engine Security Access VCDS Code
- Upgrade MMI from 2740 to latest
- 2008 audi s8 5.2 quattro
- T-Belt Time
- at last, RARE option completes my Audi 'Picnic Pkg'
- Where to pry for adjusting camber in the fronf?
- Blue Devil to rescue for head gasket on A8L
- front strut just the dust boot
- 09 without ami port normal????
- Torque converter to flywheel torque value?
- P2915-P2917
- 2006 Build S8 Auto Transmission Paddle Shift Not Working Whilst in 'D'
- Weird vent / blower issue(s)
- No dvd navigation drive...
- Problem with shaking car
- ABS module coding Login error
- Need help finding front grill for 07 S8
- Needles and Gauges?
- DIY PPI checklist
- Engine coolant
- Jacking up driver side (lhd)
- Is it worth it to chip an 07 S8?
- A8L 2008 4.2 ABS warning light parking brake malfunction
- Awdinut Clear Your Private Messages
- Air compressor intake line.
- Air bag warning lamp vs. rear electric seats
- Coolant in Oil 5.2 V10
- Cannot get HID light working
- Motor in door?
- Aftermarket side mirror entry light???
- New owner 2005 A8. MMI ?
- replace battery in the A8
- Got some great new tires for a good price!
- HELP - Removing the CD changer by force?
- Fake or real? Mann air filter
- Retrofitting Satellite radio
- Time To Move On
- PPI recommendation near riverside
- Need some emergency help, stranded
- Ok, soooo...... WHERE DO I GET ONE?
- DWS06 103Y average milage
- Where to download S8 Owners Manual
- Fuel Injectors and Carbon Build up
- Cylinder order
- Coils and plugs very oily...HELP!
- Vorsprung durch technik... :)
- Compressor Hose keeps getting pushed out of Compressor - Advice
- Apple CarPlay vs CarPlay iOS vs iOS Screen Mirroring on MMI 2G
- Canary in coal mine?--both Arnott & RMT are not buying D3 (non sport) air shock units
- what have you used the 'hidden Green Menu' for?
- Help with pinout for passenger exhaust cam sensor
- Best place to sell your Audi online?
- Welp! I finally did it.
- Interior Leak
- Puddle lights
- armrest issue
- Electric/auto steering wheel adjustment has stopped working
- My (Almost-Botched) MMI Upgrade Experience (1070 to 4610 [US])
- Rotor Screw
- Sunroof, guide for innerliner.
- FI: 4.0/4.2TDI pump belt replacement?
- Green suspension light
- getAudiparts.com | Genuine Audi LED Puddle Lights Sets!
- Cost to replace starter and Valve covers?!
