PDA
View Full Version : A8 / S8 (D3 Platform) Discussion
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82
  1. Suspension doesn't seem to lower when in dynamic
  2. Source for grille chrome surround?
  3. The name of this Factory 19 inch chrome A8 rim
  4. CEL out of the blue this AM
  5. Main engine seal is leaking bad
  6. AUDI A8 D3 4.2TDI MMI 3G RSE
  7. So many wires so little time..
  8. UK: STUCK OPEN FUEL INJECTOR CAUING WHITE SMOKE OR A FAULTY O2 SENSOR?
  9. 2007 No-Crank intermittently
  10. S8 , power steering reservoir location and fluid.
  11. 2010 A8l bluetooth?
  12. 2010 a8l vs 2011 a8l?
  13. 2007 D3 S8, what is my engine code?
  14. New Project - AUDI A8
  15. Need Help
  16. Lean condition question....
  17. A8 d3 2006 air strut o ring and headliner controls
  18. Is it time to replace front end lower control arms?
  19. Audi S8 5.2 V10 Transmission ATF Drain and Fill piece of cake
  20. D3 alarm siren
  21. SE: Activate visual parking system
  22. Interior lighting
  23. Cylinder head rebuild BFM engine
  24. S8 5.2 V10 new buyer, 68000mi (110000kms) on the clock
  25. A8 D3 4E W12 2004 idling rough
  26. S8 fuel issues
  27. 07 S8 coolant reservoir removal.
  28. Speaker problem
  29. disable soft close?
  30. Oil level sensor defective
  31. 07 S8 coding door locks
  32. Need tire suggestion for these wbeels going on 2010 Audi A8l
  33. Component Protection Active, Audio Remains on Left Side of Car
  34. JH Motorsports spacers
  35. Bake light?
  36. UK: mystery coolent leak?
  37. headlight bulb
  38. Reeeeally Nice A8L (Exklusiv Pkg.) on BaT
  39. Tune
  40. Fluctuating idle when driving
  41. UK: Shall I scrap or repair?
  42. Battery clamp threaded insert came out
  43. EML for misfire
  44. S8 frontal impact- likely total loss?
  45. AUDI A8 3.0TDI KESSY ISSUES
  46. Oil leak on catalytic , not engine oil. Little to no odor
  47. Weird thing happened today!
  48. 08 S8 ami disconnected??? Or wth?
  49. Secondary air injection bank 1 and 2 code
  50. 07-09 S8 Sunroof Recall. It blew off after it was "fixed"
  51. PL: Folding table A8 D3 wiring diagram
  52. Front Bumper & Grill Replacement
  53. 07 Rear Camera
  54. Cold air
  55. PT: air suspension replacement
  56. Scraping sound at drivers window
  57. Refrigerator door?
  58. NO: Car beeps after changing fob batteæry
  59. Another Air Suspension Post? Another Air Suspension Post!
  60. Don't like to give up
  61. I Forgot: Auto-dimming mirrors only work w/o "city" scheme
  62. Please help diagram connect Amp 2009 Bang&Olufsen
  63. Alignment
  64. Battery disconnect
  65. 2008 S8 Windshield washer not working
  66. PRNDS light stays on, on the dashboard and paddles not working
  67. Transitioning from A8 to S8
  68. another case of flooded floorboard
  69. Audi A8 2008 - Xenon light bulb change
  70. Audi A8 2008 - key not identified
  71. 08 Audi S8 heater control issues
  72. Service Manual Link
  73. coolant tank?
  74. Temp reading?
  75. D3 S8 AMI help needed
  76. Transmission reliability
  77. Is this a problem??
  78. Trunk leak
  79. Gearbox service
  80. Replacing rear air strut. My experience so far.
  81. NO: Scanned problems and need help
  82. No High Fuel Pressure
  83. Smoke Test Results
  84. DE: W12 Engine Repair?
  85. 2007 Audi A8L rearview camera not working
  86. A8L Faults
  87. 01437 - Control Position not Learned 005 - Audi 2004 A8l
  88. Friendly reminder to check your suspension
  89. Air suspension
  90. Need help understanding exactly what i should do or is it a lost cause?
  91. Front Parking Aid Warning Chime (H22)
  92. Coolant leaks for BVJ Chain driven motors
  93. a8 keyless fob upgrade
  94. Need to perform Odometer correction using VCDS - How scared should I be? (w/link)
  95. Removing brake caliper pistons S8?
  96. CD Player Issue
  97. A8 crank no start
  98. Coolant temp
  99. anyone found good LED bulb for the cornering light
  100. getAudiparts.com | Your 2021 Black Friday/Cyber Monday Savings are HERE!!!
  101. Solar panel
  102. Knock. knock, who's there? Another crack in the road
  103. Rear shade absolutely dead.
  104. Engine Splash Guard
  105. Procedure for Cam Tensioner replacement 4.2L BFM
  106. Fuel Injector Group "D" - 2009 D3 4.2 ?
  107. sudently died a8l while driving
  108. Steering Wheel Shimmy & Mysterious Knock in Front Suspension
  109. 2006 Audi A8 Suspension adjustment doesn't show up in MMI
  110. CO: Emissions Test Failing
  111. HELP needed, power steering system hose near radiator
  112. Bolt identification
  113. Rare Parts
  114. Help! Air Suspension Solenoid Valve (D3)
  115. Where Is J197?
  116. Another code issue
  117. S8 steam from rear and right of engine - solved
  118. 2004 Audi A8L no start without any lights on dash
  119. Rear caliper stuck
  120. Air Suspension doesn't release air anymore
  121. Need help interpreting Code
  122. O2 Sensor
  123. Free new MAF for pick up in San Diego
  124. Left (US drivers side) Valve Cover Oil leak - Ouch
  125. 06 AUDI A8 Brake Pad Wear Senors
  126. Yellow suspension light. Measured the gap...
  127. Machine gun from the dash when I open the door.
  128. ES: How to activate cornering lights on fog, Audi S8 D3?
  129. TCM Programming
  130. MMI 3G module 5F security login problem logging in via vcp
  131. How not to break hood latch cable
  132. P0133
  133. 2008 A8L 4.2L Emissions Light + Catalytic Converter Questions
  134. NO: 4.0 Diesel, flashing glow plug light
  135. Purchased "Itooz_A6_A8_Q7" 06 A8L D3
  136. AFS headlights not working
  137. Front lights(vanity) and door activated lights buttons not working
  138. Exclusive items A8 D3 (4E)
  139. Mmi car menu but not functioning
  140. Rear suspension collapsed (d3 4,2 alL euro 2004)
  141. Ride Height
  142. P0420 Catalytic converter issue
  143. S8 torsen/differential fluid
  144. Back-up camera module replacement - ebay. 2008 S8
  145. TRUNK SIDE PANEL REMOVAL FOR REAR CANERA MODULE?
  146. anyone tried Arnott's new (not their reman) struts ?
  147. no a/c and bizarre cooling fans
  148. EE: A8 D3 BFM no hot air - HVAC?
  149. IL: Audi S8 body Kit MaxtonDesign
  150. Bad exhaust manifold seal S8 V10
  151. Bank 1 Sensor 1 codes. Sensor bad or wiring?
  152. (possibly) new a8 owner! (TX)
  153. Does anyone know someone who rebuilds the bluetooth module
  154. JXB Performance Driveline Carrier Bearing Support Replacement
  155. winter floor set
  156. Power Issues - Help Needed please
  157. MY tips for air strut replacement...
  158. Audi a8 w12 wobbles
  159. Audi S8 2009 D3 - cold start - engine shaking
  160. 2009 s8 Bluetooth problem
  161. P2177 and Battery Regulation Codes
  162. How to replace the shifter strip
  163. W12 after catalytic converter 02 sensor idea
  164. Audi A8 W12 Cranckshaft/camshaft position sensor location
  165. Rare audi exclusive seats
  166. Audia8 quattro(2005)
  167. Getting special code from AUDI?
  168. MODULE 5F communication problem
  169. Name of wheel
  170. Tweeter Problem Redux
  171. Coolant in the oil
  172. Bose amplifier replacement
  173. 01064 short to Ground - Terminal 58d Interior Light Dimmer
  174. UK: A8 d3 android?
  175. Level Control Module Wont Accept Security Code
  176. SiriusXM Module Revision D to Revision F?
  177. W12 possibly?
  178. UK: Help? 4.2 diesel
  179. Observation question
  180. V-10 custom exhaust
  181. D3 S8 Differential Oil Change
  182. S8 Steering Rack bolts location
  183. The dreaded "Company Comfort Databus in Single Wire" & Parasitic battery drain
  184. New S8 Project - Master Thread
  185. Looking to buy a 04 A8L and join the community
  186. Low Volatage Troubleshooting Help Needed
  187. Download the COMPLETE Maintence Book Here
  188. Bank 1 downstream O2 sensor Anyone?
  189. UK: Diagnostic Report
  190. UK: 01176 - Key 004 - No Signal/Communication
  191. Key cutting and remote reprogramming?
  192. Corrosion in fuse boxes
  193. 2008 S8 Rear Seat Armrest Retrofit
  194. Homelink LED won't blink. Buttons are lit
  195. Timing Belt tools needed
  196. Audi A8 D3 Kessy issue
  197. When it rains it pours
  198. Audi S8 2009 D3 - misfire on all cylinders in specific RPM
  199. CH: Audi mmi starts in engineering mode
  200. ETKA help anyone? PS pump bolt...
  201. Audi a8 mmi 2g software 2120 EU wanted
  202. trashed armrest?
  203. Green screen help
  204. 6HP26 fluid change high mileage
  205. CZ: BIG mmi problem
  206. Suspension clunk after all control arms changed (S8)
  207. A Pillar Cover Passenger side removal help
  208. Tail light flickering issue and WTB Tailight
  209. “Shadowline” trim on Suzuka Grey colour
  210. Next "Arm wrestling issue"
  211. "Resting my arms" today
  212. UK: Problem with internal lighting help please 🙏
  213. IL: I know how to have the V10 LAMBO SOUND
  214. Hella New Style Headlights
  215. Reaching the unreachable - P3147 Oxygen sensor Signal implausibly rich
  216. strange air-conditioning issue
  217. Reluctant sale of my Imported S8 5.2 V10 (2007)
  218. Canton Racing "Accusump" D3 Kit
  219. 3.0TDi noises
  220. w12 transmission harness plug leak
  221. I bought another one
  222. D3 Coolant temp sensor location
  223. Adjust your intake manifold for $433.99
  224. BG: One drifferent '8
  225. Coolant low message
  226. D3 S8 trunk lip spoiler options
  227. Use Audi S8 D4 media system in D3?
  228. A8 D3 as a track car?
  229. A8 D3 as a track car?
  230. 2009 A8L D3 No Crank or Start
  231. 19" tire recommendations 255/50/19 to avoid bubbling tires?
  232. 2004 Audi A8L no start
  233. 2010 d3 sport shifting too early
  234. Is It Possible to DIY Power Steering Pump Without "Service Position"?
  235. S8 v10 O2 sensor problems and locations
  236. S8 v10 O2 sensor problems and locations
  237. Power Steering Fluid Foam?
  238. Latest refinement / parlor trick....
  239. Fuel rail pressure Help
  240. MMI Thunk on Startup
  241. Transmission going into safe mode
  242. Waiting on suspension parts
  243. Source for manifold intake links 1 inch
  244. any cheap S8's for sale?
  245. ETC failure
  246. GE: W12 6.0 (2005) A8 D3 - idling roughly
  247. HR: Combability Question
  248. Weird Trembling 2500-3000rpm
  249. Cerakote Headlight Restoration
  250. Do You Guys Read The FS & OT Forums?
