PDA
View Full Version : A8 / S8 (D3 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82
  1. 2009 Audi A8 Battery replacement questions
  2. Audi Certified Independent Shops
  3. S8 D3 Boot latch Issue
  4. 04' Audi A8L - Roof Racks?
  5. Xenon just on left side
  6. Tesla P85D vs Dodge Hellcat
  7. Fuel filter replacement -2007 MY
  8. Euro front plate bracket--grey vs black?
  9. FYI audiusaparts.com has free shipping over $50
  10. Odd minor brake noise--inside, not at wheels. Anyone else w/ it?
  11. NAIAS photos
  12. Audi D3 Aux Setup
  13. Wow not sure if I'm late to the party....
  14. camshaft chain gear damage
  15. Weard ttrrrrrrrrr sound from front of the car
  16. Front Spalsh Guard
  17. Huge bummer S8 upper oil pan leak
  18. The D5 what do you think?
  19. s8 v10 or s6 v10
  20. Vehicle Sub-Menu in Hidden Menu
  21. new upper control arms
  22. TPMS Module Part number
  23. wheel fitment / need quick reply
  24. Parking Sensor
  25. Keys for 2000 A6 and 2004 A8
  26. S8 in Danbury, CT--anyone looked at it?
  27. Brake Pads: OEM vs. Red Stuff
  28. What upgrades have you done?
  29. S8 vs Merc GL450...stay with me here...
  30. Cabin Heat issue.
  31. Engine vibration
  32. Big 3 of car batteries--where most really come from
  33. reverse light / tail light moisture
  34. Good News V10 Owners with Valve Cover Gasket Leaks
  35. Rapid decompression of air suspension 2008 S8
  36. Antifreeze/ Coolant
  37. My Garage
  38. Water ingress - is it when not if?
  39. HELP
  40. Audi A8 and an Audi RS7 stolen from Audi dealership lot
  41. 4 control arm bushings replaced
  42. Small but significant upgrade/modification
  43. P0174 code for 2004 Audi A8 4.2L
  44. Cold engine shifting - what's the car programmed with?
  45. About to pull the trigger on an 07 A8L
  46. Mmi gear replaced... Still problems
  47. New (to me) A8 in South Africa
  48. 2007 D3 A8L Emergency Brake Dead
  49. Wheel spacers for a D3
  50. D3 A8 W12 G62 Coolant Temperature Sensor Replacement
  51. New Posters to this Forum; PLEASE READ THIS
  52. No heat but everything seems fine. 06 A8l 4.2
  53. free online service manual for Audi's
  54. I just install a paddle shifter steering wheel, need help !
  55. AGM or Lead Acid battery?
  56. Definitive VAG-COM Mods list?
  57. Rattling noise when driving
  58. Cell Phone cradle retrofit help
  59. Audi Side Assist System Fault
  60. Another battery thread
  61. Odd navigation problem with new DVD
  62. My first audi.
  63. steering groan
  64. Window Scratching_2007 A8L
  65. For Sale A8/S8 D3 Lowering Links Never Used $99.00
  66. Radio Code
  67. 2007 S8
  68. Leather Care
  69. Slow rear window
  70. Adaptive Headlight Defective error- input requested
  71. W12, replaced thermostat, not getting up to temp
  72. choosing LED parking lights
  73. Good deal for $7k or stay away
  74. right high beam intermittent connection
  75. Hard and loud bass banging from bose speakers
  76. Happy New Year all!
  77. Battery Died in Parking Lot--Had to get a jump.
  78. 2015
  79. Yet another suspension issue
  80. Recommendations for full size tires for 2006 A8
  81. 2014
  82. Thank you, Forum Members for another year of...
  83. 05 A8 rims
  84. Purchasing a new(used) A8.....repost from D2 Forum
  85. 2004 audi a8 blower ?
  86. Cold weather not my A8's friend
  87. Cannot turn off radio 2004 Audi A8
  88. 2014 Thanks
  89. dumb question on removing the EVAP valve for oil filter access
  90. 2007 A8L - Water Ingress - MMI Component Replacement
  91. Right front air strut
  92. suspension
  93. Rough Ride
  94. Lower Sway Bar & Upper Control Arm Bushing replacement
  95. Osram xenarc night breaker bulbs
  96. Some recent pictures and changes
  97. launch contol
  98. 2004 Audi A8 TPMS displays blank numbers
  99. Folding Mirrors
  100. Wanted: 2007 S8 owners manual
  101. New to me 07' S8
  102. Rear Rotor (310mm): to replace or not
  103. Air suspension relay location
  104. Cleaning chrome door trim
  105. Just purchased a 2004 Audi A8 and have a few questions for now
  106. Huge Service
  107. Looking at 04-06 A8's need advice
  108. Power Trunk Lid Button
  109. Cam Chain Tensioner - Vendor Part Comparison
  110. TPMS Malfuction
  111. Must be living right
  112. Does Bentley cover removing the glove box lock?
  113. What Additive Do You Use?
  114. Went to buy 2008 Audi A8L, but walked away. :(
  115. Air Suspension Question
  116. Key fob programming, D3
  117. New AW member/W12 owner
  118. Battery Dead/Cant Start
  119. 05 A8 Suspension problem
  120. MMI 2G HIDDEN MENU
  121. Owners with custom air bag suspension (airlift, airrunner, etc)
  122. Super odd color and wood trim
  123. Prep for month-long storage
  124. 20 miles on 19 inch spare?
  125. FYI: Tossed S8 B&O door panels on the classifieds
  126. A8/S8 wood options for black interior?
  127. my P0701 code. easiest explanation for me to understand
  128. Sport mode tranny selection
  129. MMI control Unit version issue
  130. Service Drone
  131. VIOLENT events in drive train when cold...!!??
  132. Phantom Shifting in 05 A8L
  133. Build numbers?
  134. Maybe Model D better? Model S DNF. Quattro rolls on...
  135. Rebuilt Strut - Ebay - anyone with experience?
  136. A8 buying advice
  137. Replacing the bottom oil pan seal - Anyone done it?
  138. Repair or Replace ...
  139. battery cable bypassed relay
  140. D3 front seats replaced, heater problem
  141. New to Group, VCDS
  142. Life expectancy on air suspension
  143. Vag-Com
  144. 2008 Audi S8 air conditioning
  145. intermittent failure to start ...finally failed
  146. front suspension issues of a slightly different color
  147. DVD Player Skipping
  148. 2005 A8 Battery Drain / No Charge
  149. Suspension, sway bar, or...?
  150. Subframe alignment for my D3 S8
  151. P0491 and P0492
  152. Central locking and interior courtesy lights
  153. Attention A8 and S8 owners with broken center console cupholder
  154. A8 vibration issue
  155. New Member, Navigation MMI question
  156. Boot dimensions help
  157. How to adjust the sensitivity of the car alarm using VCDS?
  158. 2007 A8L Quatrro with P0014 fault code - please help
  159. New member with new to me S8
  160. Rear brake service misc. notes; another rear suspension close look
  161. MMI screen and controllers not responding
  162. Audi in Cuba
  163. Intermittent Starting Issue when cold outside
  164. How to remove Headlight 07 S8
  165. Differential lubricant change
  166. Whati is the latest SW version
  167. Wheel sensor fault!
  168. Michelin Pilot Sport A/S 3's = GARBAGE
  169. the Battery is dead ; long live the Battery !
  170. Faulty fuel Gauge
  171. Thinking about replacing the whole front suspension
  172. Noisy passenger side window
  173. Bagged '06 A8L, dash light limp mode?
  174. 2008 A8 drivers seat adjust quit.
  175. Oil cooler coolant leak
  176. Car died after starting and wouldn't restart.
  177. dealership said this fault no big deal. opinions ?
  178. Rear windows heating doesn't work, where to start?
  179. Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - December 12th - 19th 2014
  180. Maintenance time and weird vibration woes
  181. getting ready for the first oil change-is operating temperature too much?
  182. What else do you drive?
  183. GPS Issues
  184. oil selection for an S8
  185. what is the meaning of "strut failure" ?
  186. New user info--on the search for an S8. Prices are all over the map?!
  187. The worst scare and snow drive in my S8
  188. fog light change
  189. need help audi a8 3.0 tdi d3 2004 limp mode !!!!
  190. Hello New A8L Owner
  191. Is the difference between early and late steering wheel heating just coding?
  192. Audi A8 air compressor turns on at 25mph
  193. S8 UCA Bushings on Ebay
  194. W12 Questions - Possible Future Buyer
  195. Free 19' 5-Spoke Wheels for '08 D3 with Blizzak-LM32 tires
  196. Swapped snows and it looks like I have some work ahead of me
  197. 2007 S8 Coolant reservoir/tank or valve leak???
  198. have you done a heater valve R & R ?
  199. codes: P1583 and P1400
  200. Audi A8L cover on the side of the rear door speaker
  201. I needed a new airfilter and K&N was on my mind.....
  202. Does the CD player play MP3?
  203. soaked headliner
  204. Galaxy Note 4 not pairing
  205. Fused Relay Burnt up Air ride Pump
  206. Glass Mat Battery ?
  207. Newest member 100K
  208. questions about jacking up and supporting the vehicle
  209. Flash Sale @ DetailersDomain.com - 15% off and Free Shipping - ends 11/22/14 mid est
  210. What's involved in a 90k service? (2005 Audi A8L)
  211. Snow tires: keep all season DWS on or mount Alpin PA3?
  212. oil change on an S8 and resetting the oil life
  213. Is this my OEM battery
  214. S8 D3 VAG-COM Lowering Codes
  215. Lowering Links
  216. Alignment Specs Sport vs Standard Suspension
  217. Audi Design Trends: Prologue concept from LA show per Autoweek (lots of pics too)
  218. Faulty Headlight Power Output Module
  219. Rough shift transmission...fluid or software?
  220. In need of Suspension Help!
  221. 18" "Fat Fives" on 2007 S8
  222. 09 A8 L Battery Completely Dead
  223. Reset Pin Code
  224. Belt or Chain
  225. Air suspension compressor fixed !...but now this
  226. 2008 potential issues
  227. Wheel Interchange Info
  228. Rear Trunk Lid Softclose Not Working
  229. LED Lighting Mod in trunk
  230. need help urgently
  231. Options for exhaust hole repair?
  232. Here's a new one !
  233. uneven, premature wear on rear tires
  234. serpentine engine belt, '07 A8
  235. Software Upgrade INFo
  236. Headlight won't work
  237. Sunroof issues on 09 L
  238. Audi D3 A8 A8 sway bar links 4E0411317E 4E0411317F; $67 DIY
  239. Weird sound from front suspension
  240. Could someone with extended leather shoot me a pic of the B pillar?
  241. Being a Passenger
  242. INTERSTATE BATTERIES - A MUST READ
  243. MMI Problems
  244. Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - November 27th - 30th 2014
  245. trying to remove susp. air compressor mount bolts. help
  246. Rear Vanity Mirrors Stuck
  247. Winter time is approaching....
  248. 2006 Audi A8L Score Card...
  249. Timing cover
  250. 2005 D3 oil cooler removal
