- steering column removal
- Repair manual
- E brake won't release, stranded in ice storm!
- Headlights
- S8 v10 not starting after removing inlet manifold and disconecting fuel lines
- NL: Small refrigerator in backseat, buy where?
- Front Axles
- MMI/radio help
- A8 purchasing advice!!
- Purchased 2007 S8
- Audi a8 Radiator 3 plug and 4 plug rad
- Subwoofer Removal
- 2005 D3 Fuel Pump
- J533 Gateway Prompt wire
- Adaptive Headlight Fix w/ Pictures
- D3 Stuff 4 sale - Wheels, Tires, 2 oil filters, Bose AMP, Trunk struts
- D3 update to 5570
- Shipping tires to a buyer
- Front air suspension fails in the cold
- N276 fuel pressure valve
- Audi S8 D3 fuel filter location???
- B&O Speakers
- A little TS guidance for a no start on a 2004
- Urgent Help with Coolant Temp Sensor
- VCDS coding for Fiscon 37196 Bluetooth
- anyone upgraded round fogs to facelift fogs ?
- Electrical issues after battery replacement
- A8 D3 headlight adjuster not working
- Serpentine belt issues
- Accelerator pedal fix/cleaning
- I have a confession to make...
- Track number/wiring diagram help
- UK: Alternator or ? D3 3.0 TDI.
- 08 Audi S8 APR ECU Upgrade: Any thoughts???
- 06 A8L suspension problems
- Trunk leak
- HPFP: which one is failed?
- Fault codes galore. Help. -03 4.2
- Oil Leak
- Air suspension issues
- GB: VCDS alternative for 2005 D3?
- HVAC coding
- Parking brake, abs, esp issue
- Should I upgrade tail lights?
- Real life MPG 2006 A8L 4.2
- Pinch Bolt Christmas
- W12 struts considered 'sport' or no?
- Rear lights upgrade - FACELIFT lights installation
- Driver Exterior mirror
- Anyone try New Bilstein B4 air strut yet?
- Rear floor heater vent.
- Anyone have a pre-facelift front license filler to sell me?
- Anyone with 4 resonator delete OR X/H pipe I can listen to in NJ/NY/CT?
- Rear Brake Pads -Implausible Signal
- ABS module re-coding failed on my D3 S8
- 2006 water pump torque specs or all torque specs list?
- A8 CV D3 warning - SURTRACK/TRAKMOTIVE AD8134 AD8133
- MMI 2G High Update available
- Air suspension upgrade.
- Help with d3 06 soft close doors
- Finally repaired B&O drivers
- Tail lights, anyone?
- Tail lights anyone
- It's my turn... The left strut leaks... Low Rider
- Fueling issue
- know of a very high quality wheel refinishing shop ?
- High beam issue
- 2004 A8L will not allow me to adjust date/time in MMI
- Pass to flash halogens / headlight coding assistance
- Driver side lower seat covering.
- Sick of being on my back working on my D3
- VCDS Scan info
- OEM Parts
- S8 Coolant Leak
- Easiest way to run wiring from battery to the front thru firewall
- Anyone exprienced in working on the oil cooler?
- Starter
- 2005 A8L Key Removal to Access Battery in Trunk
- 2005 A8 D3 EVAP Emission Control Sys P0441
- 2009 Audi S8 coolant reservoir not filling up
- Loose ball bearings in belly pan?
- How To Stream Bluetooth on older D3 with TV Tuner
- Audi A8 2008
- good A8 mechanic needed/upstate NY
- good A8 mechanic needed in upstate NY
- Battery replacement in 05 a8l
- Seat warmer works on back, but not on base
- Unresponsive MMI ('07, S8) Where Do I Even Start?
- 1995 a8 d2 owner manual download
- Timing Belt Hydraulic Tensioer
- 2004 A8 starts then dies
- Missing features in MMI?
- Remapping A8 D3 4.0 TDI
- blower motor
- Please Help ! Need Brembo 6-piston fitment/rotor advice .. :)
- wiper blades
- 07 Audi A8 Theft Module location?
- getAudiparts.com | Black Friday/Cyber Monday FREE SHIPPING + Promo Code!!!
- Front brake pad warning light
- rain sensor
- Brake pad warning
- Does someone have a wiring diagram for MMI “E-380”
- Can't find vacuum leak on S8
- no start just click
- Alarm horn help
- replace tail lights
- I Traded my JUNK Porsche Turbo for an Audi with "No Mechanical Issues"
- Another Serpentine Belt Thread
- 2005 A8L Air Suspension Question for the the Experts on here.
- Rain/Light Sensor help
- Found a Use for a Useless Phone Cradle
- 2006 A-8 Radiator hose access for sealant entry
- MMI 2g Analog TV Tuner Retrofit
- Bose surround audio, need info.
- How come we don't have this for the D3?
- Fuel cap issue
- rls sensor incorrectly coded
- Battery level in MMI
- draining differential fluid
- Advice With Oiling Issue
- Can I Change My 2003 Front Bumper to The Facelift Model?
- Is it new or is it old Timing belt
- 2010 Audi A8L air suspension hose line
- diagnostic challenge
- Purchase advice for '05-'07 A8L W12
- Mission impossible: dead battery
- Dashboard problem
- Need help! 04 Audi A8l won't start
- Vredestein tires?
- Any V10 Gurus? need advice
- Suspension and front end
- CRC Intake Valve & Turbo Cleaner?
- Keyless system not working (door handles or control unit)!?
- Electronic gremlins temporarily preventing engine start in the cold?
- electric windows and sunroof and lighter and radio fuse box location
- Left side door light strip doesn't work
- 2005 year Audi A8 6.0 W12 - Misfiring
- 2006 Audi A8 bumper for an a4 bumper?
- tires match?
- Advice on using 2 different brand tires
- Vibration in car under acceleration load
- Carprog?
- Audi A8 D3 2003 Battery coding denied
- Looking for a pair of LED tail lights
- MMI rotary function not work (and brand new MMI board for sale)
- SPARK PLUG CONDITION - OVERKILL WITH DIELECTRIC GREASE
- 2007 A8L 4.2 rough idle and dying
- Help mmi head say ok error vag com
- Vagcom coding
- SPARK PLUGS BOSCH VERSUS NGK
- MMI Control Module 2009 Audi A8 Does anyone have one for sale
- back seat fun....
- Car skids on wet road and ESP light ON, Almost got into accident!
- Obdeleven brake light coding to European standards
- 2006 rear air suspension (issue?)
- Blue tooth
- Crankcase vent valve.
- My 2006 A8L 131k Miles on Highway 1 to LA
- 0.032 /0.04/0.044
- 2004 A8L Servotronic Issue?
- Ground points
- TV Tuner retrofit MMI 2G
- Tow bar control module location
- Audi A8 D3 Engine advice
- Acc/Start Auth. Lower Limit Exceeded?
- MMI Retrofit from 3G to 3GP
- 2004 Audi A8 air suspension relay
- Removing the rear lock
- No sound after MMI 2G update to 5570
- Quick suspension question
- Timing chain/buying advice
- later year A8 or S8? Advice please
- A8L air suspension tool and helpful hints
- Bentley repair manual
- Fuel injector p/n
- TPMS turned itself OFF? Then came back later LOL
- A8 d3 cant open rear doors and pasenger door due flooding
- Strange compressor issue
- ATF fluid change drained 5.1 liters
- 2007 S8 - air strut Compressor will not shut down - Only 1 relay?
- MMI 2G iPod Interface
- Q7 control head on A8
- MMI Screen / head unit stuck (down)
- Auto-dimming/Electrochromic Mirror Repair for Dark Door Rearview Mirror
- Savings and fuel economy?
- ECM not coded correctly and power train bus missing?
- Air suspension compressor reviews
- ABS MODULE
- 2006 A8L Help reinstalling Nav unit
- What happens at 2800 rpm?
- What happens at 2800rpm? (D3 4.2 40V Engine)
- Typically when I start my car in the morning it idles a little above 1100 RPMs for
- Coolant light flashing and steering stiff
- Carbon Buildup
- WANTED: A8 Roof Rack Crossbars / Base Carrier Bars (4E0071126)
- Overheating question
- What is This?
- Metal retaining clips for fan shroud/radiator expansion tank overflow tube hose ?
- any 4.2tdi knowledge in here?
- 06 A8L MMI acting up
- Infamous Jack Mode
- Anyone found a cheap(er) driver's side mirror?
- Audi A8 Quattro TPMS Sensor
- 07 D3 S8 front suspension sagging
- Far Off Topic: I'm Back
- 3,2 fsi blue smoke + oil in manifolds
- Part number request
- S8 D3 immobiliser/ steering column.coding adaptation
- GB: Looking for someone who can remotely adapt my new steering column and immobiliser
- Living up North wit cold winters
- Broken Control Arm Bolt
- AC issues and other thoughts?
- Fluctuating bright/dim red dashboard and console lamps and backlights
- 2006 A8L 4.2 Tranny clunk on kickdown
- Door rear view mirror
- Will 28.7" Wheel Diameter Work?
- Why is Jack Mode option greyed out?
- No ignition, no crank
- What is this?
- Headlights AUTO function not working
- AMI and Cd changer
- Interior Door Lighting Gremlins
- TPMS failure
- Front grille color code
- Turn signal lights as parking light
- PDC display in mmi 2g high
- blower motor
- Audi D3 ambient light
- suspension drops partially after shutdown
- IRRSINN Got Bashed
- 2005 A8 D3 front end, S8 Conversion
- Fuel Pump Relay Keeps Blowing
- '05 W12, not driving like it should.
- How long would you put off replacing a leaking strut?
- Oil leak - Cylinder Head Gasket?? (see pic)
- Steering column actuator fault or keep vcds in car
- Trunk lid wont close and lock
- Alignment special tools?
- Ecm swap
- leaky diff???
- NO: Genuine Battery theory
- More air strut questions
- Door handle LED´s
- Noise
- Mechanic around douglasville Atlanta area
- Rain sensor
- Water ingress?
- Had an Italian Tune Up today...
- Expansion tank overflowing?
